Smart Lock with Emergency One-Time Code & Backlit Keypad
Smart Lock with Emergency One-Time Code and Backlit Keypad
Discover the ultimate convenience and security for your home with the Wyze Lock Bolt — a cutting-edge smart lock designed to replace your traditional deadbolt. Featuring a luxurious backlit keypad and an ultra-fast fingerprint reader, this smart lock offers seamless keyless entry combined with advanced security features, including emergency one-time codes for guests.
Wyze Lock Bolt: Key Features and Benefits
Ultra-Fast Fingerprint Access & Backlit Keypad
Say goodbye to fumbling for keys. The Wyze Lock Bolt unlocks your door in less than a second with a simple tap on its ultra-fast fingerprint sensor. The exterior boasts a solid metal build with a luxurious backlit keypad, making it easy to enter your code even in the dark.
The keypad also features anti-peep technology, allowing you to enter extra digits before or after your code to prevent onlookers from guessing your access code.
Emergency One-Time Codes for Secure Guest Access
Worried about giving out permanent codes? The Wyze Lock Bolt lets you generate emergency one-time access codes remotely via the Wyze app. These single-use codes expire within 4 hours, ensuring temporary guests or service providers can enter securely without compromising your home’s safety. You can create up to 16 such codes every 4 hours, perfect for flexible access management.
Auto-Lock & One-Touch Locking
Never worry about leaving your door unlocked again. The lock features an auto-lock timer configurable through the app, which automatically locks the door after a set delay. Additionally, locking is as simple as pressing the lock button on the keypad or using the Wyze app when within Bluetooth range.
Robust Security & Weatherproof Design
Wyze Lock Bolt is fully pick-proof by eliminating the need for physical keys. It’s built tough with an IPX5 weatherproof rating, ensuring reliable performance in various weather conditions. The lock uses hardware encryption to protect your fingerprint and code data, and the app employs two-factor authentication for added security.
Long Battery Life with USB-C Backup
Powered by 4 AA batteries, the Wyze Lock Bolt offers up to 12 months of battery life. When batteries run low, a red indicator flashes to alert you. If the batteries die while you’re away, a USB-C port allows for a quick emergency charge so you can still enter your access code.
Easy Installation & Stylish Design
Replacing your existing deadbolt is quick and straightforward, taking about 20 minutes. The lock’s sleek metal design complements any exterior, blending security with style. Wyze Lock Bolt Lifestyle Secure your home effortlessly with Wyze Lock Bolt’s smart technology and elegant design.
Additional Replacement Parts for Wyze Lock Bolt
To keep your Wyze Lock Bolt functioning perfectly, consider these compatible replacement parts:
  • Wyze Lock Bolt Screws — Replacement screws for secure mounting.
  • Wyze Lock Bolt Interior Assembly Battery Cover — Replacement cover for the interior battery compartment.
  • Wyze Lock Bolt Interior Assembly Metal Plate — Metal plate to anchor the interior assembly firmly to your door.
  • Wyze Lock Replacement Part Kit — Comprehensive kit for Wyze Lock maintenance and repairs.
These parts ensure your smart lock remains reliable and easy to maintain over time.
Enhance Your Home Security with the Front Porch Security Bundle
For a complete smart home security solution, pair the Wyze Lock Bolt with the Wyze Video Doorbell and Chime in the Front Porch Security Bundle. This bundle lets you:
  • View your front porch in crisp 1080p HD video.
  • Communicate with visitors via two-way audio.
  • Remotely lock and unlock your door and monitor lock history through the Wyze app.
  • Integrate with Alexa and Google Assistant for voice control.
This all-in-one package offers peace of mind and convenience, making your home smarter and safer. Wyze Lock Bolt with Video Doorbell Complete your smart home setup with Wyze Lock Bolt and Video Doorbell.
Why Choose Wyze Lock Bolt?
  • Emergency one-time codes for secure, temporary access.
  • Backlit keypad with anti-peep technology for privacy and ease of use.
  • Fingerprint sensor for ultra-fast, keyless entry.
  • Auto-lock feature to prevent accidental door unlocking.
  • Robust security with hardware encryption and two-factor authentication.
  • Weatherproof and pick-proof design for reliable protection.
  • Long-lasting battery with USB-C emergency charging.
  • Easy installation replacing your existing deadbolt in minutes.
Upgrade your home security with the Wyze Lock Bolt — smart, secure, and designed for modern living. Wyze Lock Bolt Installation Simple installation replaces your deadbolt in about 20 minutes.
ProductTypePrice (USD)Key FeaturesCompatibilityIncluded Items / NotesReturn Policy
Wyze Lock BoltConnected Home79.98Bluetooth smart lock, fingerprint reader, backlit keypad, auto-lock, pick-proof, weatherproof (IPX5), up to 12 months battery lifeReplaces existing deadboltMatte Black or Satin Nickel styles, installs in ~20 minutes30-day hassle-free returns
Wyze Lock Bolt ScrewsReplacement Parts2.99Replacement set of screwsWyze Lock BoltScrews only30-day hassle-free returns
Wyze Lock Bolt Interior Assembly Battery CoverReplacement Parts9.99Replacement interior battery coverWyze Lock BoltInterior battery cover30-day hassle-free returns
Wyze Lock Bolt Interior Assembly Metal PlateReplacement Parts4.99Metal plate to anchor the interior assembly to the doorWyze Lock BoltMetal plate30-day hassle-free returns
Wyze Lock Replacement Part KitReplacement Parts4.99 - 19.99Replacement part kit (includes Adapter Replacement Kit option)Wyze LockTwo styles: Replacement Part Kit ($4.99), Adapter Replacement Kit ($19.99)30-day hassle-free returns
The Front Porch Security BundleCameras123.99 - 173.97Bundle includes Wyze Lock (or Lock Bolt), Wyze Video Doorbell(s), Chime, Wyze Cam V3, Wyze Cam OG(s)Wyze Lock / Lock BoltMultiple bundle variants combining locks and cameras; features 1080p/2K video, two-way audio, Alexa/Google support30-day hassle-free returns
What is the Wyze Lock Bolt and how does it improve home security?The Wyze Lock Bolt is a smart lock designed to replace your traditional deadbolt, offering advanced security features such as an ultra-fast fingerprint reader, a backlit keypad with anti-peep technology, and emergency one-time codes for secure guest access. It is pick-proof, weatherproof, and uses hardware encryption and two-factor authentication to protect your data.
How does the fingerprint access work on the Wyze Lock Bolt?The Wyze Lock Bolt features an ultra-fast fingerprint sensor that unlocks your door in less than a second with a simple tap. This provides seamless, keyless entry and enhances both convenience and security.
What is the backlit keypad and anti-peep technology on the Wyze Lock Bolt?The Wyze Lock Bolt’s backlit keypad makes it easy to enter your code even in the dark. Its anti-peep technology allows you to enter extra digits before or after your actual code, preventing onlookers from guessing your access code and enhancing privacy.
How do emergency one-time codes work on the Wyze Lock Bolt?Emergency one-time codes can be generated remotely via the Wyze app. These single-use codes expire within 4 hours, allowing temporary guests or service providers secure access without compromising your home’s safety. You can create up to 16 one-time codes every 4 hours.
Does the Wyze Lock Bolt have an auto-lock feature?Yes, the Wyze Lock Bolt includes an auto-lock timer that can be configured through the Wyze app. The door will automatically lock after a set delay, and you can also lock it instantly by pressing the lock button on the keypad or using the app within Bluetooth range.
Is the Wyze Lock Bolt weatherproof and pick-proof?The Wyze Lock Bolt is built with a solid metal exterior and has an IPX5 weatherproof rating, ensuring reliable performance in various weather conditions. It is also pick-proof, as it eliminates the need for physical keys.
How long does the Wyze Lock Bolt battery last and what happens if it runs out?The Wyze Lock Bolt is powered by 4 AA batteries, providing up to 12 months of battery life. A red indicator flashes when the batteries are low. If the batteries die, you can use the USB-C port for a quick emergency charge to enter your access code.
How easy is it to install the Wyze Lock Bolt?The Wyze Lock Bolt is designed for easy installation, replacing your existing deadbolt in about 20 minutes. Its sleek metal design complements any exterior, blending security with style.
What replacement parts are available for the Wyze Lock Bolt?Available replacement parts for the Wyze Lock Bolt include Wyze Lock Bolt Screws, Interior Assembly Battery Cover, Interior Assembly Metal Plate, and a comprehensive Wyze Lock Replacement Part Kit. These parts help maintain and repair your smart lock as needed.
Can the Wyze Lock Bolt be integrated with other smart home devices?Yes, the Wyze Lock Bolt can be paired with the Wyze Video Doorbell and Chime in the Front Porch Security Bundle. This allows you to view your front porch in HD, communicate with visitors, remotely lock and unlock your door, monitor lock history, and integrate with Alexa and Google Assistant for voice control.
What are the main benefits of choosing the Wyze Lock Bolt for home security?The Wyze Lock Bolt offers emergency one-time codes, a backlit keypad with anti-peep technology, ultra-fast fingerprint entry, auto-locking, robust security with encryption and two-factor authentication, weatherproof and pick-proof design, long battery life with USB-C emergency charging, and easy installation.
Can you tell me more about the auto-lock feature of the Wyze Lock Bolt?How does the anti-peep technology work on the backlit keypad?Do you have any ongoing sales or discounts for the Wyze Lock Bolt?
