Airbnb Guest Management Kit with Auto Expiring Lock Codes
Managing Airbnb guests efficiently and securely is crucial for a smooth hosting experience. One of the best ways to achieve this is by using smart locks that offer auto-expiring access codes, remote management, and seamless integration with your home security system. Below, we highlight the top Wyze smart lock products designed to simplify guest access while ensuring your property remains secure.
Wyze Lock Bolt: The Ultimate Smart Lock for Airbnb Hosts
Key Features for Guest Management
- Auto-Expiring Access Codes: Generate temporary door codes that automatically expire after a set time, perfect for short-term guests.
- Fingerprint Unlock: Guests can enter with a quick fingerprint scan, eliminating the need for physical keys.
- Backlit Keypad with Anti-Peep Technology: Enter codes discreetly with extra digits before or after your code to prevent code theft.
- Auto-Lock Timer: Set your door to auto-lock after a delay, so you never worry about leaving it unlocked.
- Remote Emergency Codes: If a guest is locked out, send a one-time emergency code remotely via the Wyze app.
- Long Battery Life: Up to 12 months on 4 AA batteries, with USB-C emergency charging if batteries die.
- Weatherproof and Pick-Proof: Solid metal construction with IPX5 rating ensures durability and security.
Why Wyze Lock Bolt is Perfect for Airbnb
This lock replaces your existing deadbolt and installs in about 20 minutes, making it an easy upgrade for your rental property. The Wyze app acts as your command center, allowing you to create and manage up to 20 access codes and 50 fingerprints, track entry history, and control the lock remotely via Bluetooth.
"Wyze Lock Bolt is a solid, no frills smart lock with perfect fingerprint scans."
Secure your Airbnb with Wyze Lock Bolt
Wyze Lock: Smart Home Integration with Remote Access
Advanced Features for Enhanced Control
- Keep Your Existing Deadbolt: Add smart capabilities without replacing your lock hardware.
- Remote Access Anywhere: Control and monitor your lock from anywhere via WiFi.
- Auto-Unlock & Auto-Lock: Automatically unlock when you approach and lock when you leave.
- Voice Assistant Compatibility: Works with Alexa and Google Assistant for hands-free control.
- Send Virtual Keys: Share digital keys with guests that can be revoked anytime.
- Quick Installation: Installs in under 15 minutes and compatible with most single cylinder deadbolts.
Ideal for Hosts Who Want Full Smart Home Integration
Wyze Lock comes with a gateway that extends its range and connectivity, making it perfect for hosts who want to monitor and control guest access remotely. It supports multiple communication methods including Bluetooth, Zigbee, and WiFi, ensuring reliable performance.
Smart access management with Wyze Lock
Replacement Parts for Wyze Lock Bolt
To keep your Airbnb smart lock running smoothly, Wyze offers essential replacement parts:
- Wyze Lock Replacement Part Kit: Includes screws, cables, and components to restore your lock to like-new condition.
- Wyze Lock Bolt Screws: Replacement screws compatible with Wyze Lock Bolt.
- Wyze Lock Bolt Interior Assembly Battery Cover: Replacement cover for the battery compartment.
- Wyze Lock Bolt Interior Assembly Metal Plate: Metal plate to anchor the interior assembly securely to your door.
These parts ensure your lock remains reliable and secure for every guest stay.
Why Choose Wyze Smart Locks for Airbnb Guest Management?
Efficient guest access management is key to a successful Airbnb hosting experience. Wyze smart locks provide:
- Security: Advanced encryption and two-factor authentication protect your property.
- Convenience: Auto-expiring codes and remote management reduce the hassle of key exchanges.
- Durability: Weatherproof and pick-proof designs withstand daily use and outdoor conditions.
- User-Friendly App: Manage access codes, fingerprints, and lock status all from your smartphone.
With Wyze smart locks, you can confidently welcome guests while maintaining full control over your rental property’s security.
Summary of Products for Airbnb Guest Management
Product Name | Key Benefits | Price |
Wyze Lock Bolt | Fingerprint unlock, auto-expiring codes, keypad, auto-lock | $79.98 |
Wyze Lock | Remote access, voice control, virtual keys, auto-unlock | $123.99 |
Wyze Lock Replacement Parts | Maintain and repair your Wyze Lock Bolt | From $2.99 |
Secure your Airbnb property with Wyze smart locks and enjoy seamless guest management with auto-expiring lock codes and smart home convenience.
What is the best smart lock for Airbnb guest management?
The Wyze Lock Bolt is an excellent smart lock for Airbnb guest management. It offers auto-expiring access codes, fingerprint unlock, a backlit keypad with anti-peep technology, and remote emergency code generation, making it ideal for short-term rental hosts.How do auto-expiring lock codes work for Airbnb guests?
Auto-expiring lock codes allow you to generate temporary door codes for your Airbnb guests. These codes automatically expire after a set period, ensuring that guests only have access during their stay and enhancing your property’s security.Can I manage my Airbnb smart lock remotely?
Yes, with Wyze smart locks, you can manage your Airbnb property remotely. The Wyze Lock offers remote access via WiFi, allowing you to monitor and control your lock from anywhere, send virtual keys, and track entry history through the Wyze app.What are the main differences between Wyze Lock Bolt and Wyze Lock?
Wyze Lock Bolt replaces your existing deadbolt and features fingerprint unlock, auto-expiring codes, and a backlit keypad. Wyze Lock, on the other hand, adds smart capabilities to your existing deadbolt, offers remote access via WiFi, voice assistant compatibility, and virtual key sharing for guests.How secure are Wyze smart locks for Airbnb properties?
Wyze smart locks are designed with advanced security features, including encryption, two-factor authentication, weatherproof and pick-proof construction, and anti-peep technology on keypads, ensuring your Airbnb property remains safe and secure.Can I install Wyze smart locks myself?
Yes, both Wyze Lock Bolt and Wyze Lock are designed for easy DIY installation. Wyze Lock Bolt installs in about 20 minutes, while Wyze Lock can be installed in under 15 minutes and is compatible with most single cylinder deadbolts.What happens if the smart lock batteries die?
Wyze Lock Bolt has a long battery life of up to 12 months on 4 AA batteries. If the batteries die, you can use USB-C emergency charging to temporarily power the lock and regain access.Are replacement parts available for Wyze Lock Bolt?
Yes, Wyze offers replacement parts for the Lock Bolt, including screws, cables, battery covers, and metal plates. These parts help maintain and repair your smart lock to ensure reliable operation for every guest stay.Can I use voice assistants with Wyze smart locks?
Wyze Lock is compatible with Alexa and Google Assistant, allowing you to control your lock hands-free using voice commands for added convenience.How many access codes and fingerprints can I manage with Wyze Lock Bolt?
With Wyze Lock Bolt, you can create and manage up to 20 access codes and 50 fingerprints, making it easy to accommodate multiple guests and users.
