Best Auto Lock Smart Door Locks That Sense Door Open and Closed – Wyze Lock Bolt & Wyze Lock for Ultimate Home Security
Discover the ultimate convenience and security with Wyze's cutting-edge auto lock smart door locks. Designed to seamlessly integrate into your connected home, these smart locks not only provide keyless entry but also intelligently sense when your door is open or closed, automatically locking to keep your home safe without any extra effort.
Wyze Lock Bolt: The Ultimate Auto Lock Smart Deadbolt Replacement
Experience a new level of smart home security with the Wyze Lock Bolt, a Bluetooth-enabled smart lock that replaces your existing deadbolt with advanced features tailored for modern living.
Key Features and Benefits
  • Ultra-Fast Fingerprint Sensor: Unlock your door instantly with a touch of your finger, eliminating the need for keys or codes.
  • Backlit Keypad with Anti-Peep Technology: Enter your access code discreetly, even in low light, while preventing others from seeing your input.
  • Auto-Lock Function: Never worry about forgetting to lock your door again. The Wyze Lock Bolt automatically locks when the door is closed.
  • Lock and Unlock History: Monitor who enters and exits your home through the Wyze app, providing peace of mind and control.
  • Built-in Jam Detection Alarm: Alerts you if the lock mechanism encounters any obstruction.
  • Emergency One-Time Codes: Grant temporary access to guests or service providers securely.
  • Weather Resistant (IPX5): Durable enough to withstand outdoor elements.
  • Long Battery Life: Powered by 4 AA batteries (included) lasting 10-12 months.
Specifications
  • Communication: Bluetooth 5.0 with a 16 ft range.
  • Door Compatibility: Fits doors 1-3/8” to 1-3/4” thick with backset options of 2-3/8” or 2-3/4”.
  • Operating Temperature: Keypad works from -13°F to 122°F.
  • Weight: 2.75 lbs.
  • Color Options: Matte Black and Satin Nickel.
The Wyze Lock Bolt is perfect for those who want a sleek, secure, and smart deadbolt replacement that senses door status and auto-locks for ultimate convenience.
Wyze Lock Bolt Lifestyle Secure your front door effortlessly with Wyze Lock Bolt.
Wyze Lock: Smart Add-On for Your Existing Deadbolt
If you prefer to keep your current deadbolt but want to add smart functionality, the Wyze Lock is the ideal solution. It adds "brains" to your existing lock, enabling smart control and auto-lock features without replacing your hardware.
Why Choose Wyze Lock?
  • Auto-Unlock & Auto-Lock: The lock senses when you approach or leave and automatically unlocks or locks your door.
  • Remote Access: Control your lock from anywhere using the Wyze app.
  • Voice Control: Compatible with Alexa and Google Assistant for hands-free operation.
  • Virtual Keys: Send temporary or permanent virtual keys to family, friends, or service providers.
  • Easy Installation: Installs in under 15 minutes without professional help.
  • Compatibility: Works with most single cylinder deadbolts.
  • Communication Methods: Bluetooth, Zigbee, and WiFi for flexible connectivity.
  • Range: Up to 50 ft to gateway or router, 16 ft Bluetooth to phone.
  • Indoor Use with IPX5 Rating: Suitable for indoor doors with some moisture resistance.
Specifications
  • Power Source: 4 AA batteries (included) with 5-6 months battery life.
  • Operating Temperature: 14°F to 131°F.
  • Colors Available: Silver and White.
  • Included Items: Wyze Lock, Gateway, batteries, mounting plate, adapters, and quick start guide.
The Wyze Lock is perfect for those who want to keep their existing deadbolt but upgrade to smart, auto-locking convenience with remote and voice control.
Wyze Lock Lifestyle Add smart control to your existing deadbolt with Wyze Lock.
Why Choose Auto Lock Smart Door Locks That Sense Door Status?
Smart locks that detect whether your door is open or closed and auto-lock accordingly provide unmatched security and peace of mind. You no longer need to worry about accidentally leaving your door unlocked or fumbling for keys in the dark. These locks integrate seamlessly with your smartphone, allowing you to monitor and control access remotely, receive notifications, and manage user permissions easily.
Benefits Include:
  • Enhanced Security: Automatic locking reduces the risk of unauthorized entry.
  • Convenience: Keyless entry options like fingerprint, keypad, or app control.
  • User Management: Share access with family or guests without physical keys.
  • Integration: Works with smart home ecosystems and voice assistants.
  • Durability: Weather-resistant designs ensure reliable performance.
Replacement Parts for Wyze Lock Bolt
To keep your Wyze Lock Bolt functioning perfectly, Wyze offers a range of replacement parts:
  • Wyze Lock Replacement Part Kit: Essential components compatible only with Wyze Lock.
  • Wyze Lock Bolt Interior Assembly Metal Plate: Anchors the interior assembly securely to your door.
  • Wyze Lock Bolt Interior Assembly Battery Cover: Replacement cover for the battery compartment.
  • Wyze Lock Bolt Screws: Set of screws for secure installation.
These parts ensure your smart lock remains reliable and easy to maintain.
Conclusion
For a smart door lock that senses door open and closed status and auto-locks for your safety, Wyze offers two excellent options:
  • Wyze Lock Bolt for a full deadbolt replacement with fingerprint and keypad access.
  • Wyze Lock for upgrading your existing deadbolt with smart features and remote control.
Both provide robust security, convenience, and seamless integration into your smart home ecosystem. Upgrade your home security today with Wyze’s auto lock smart door locks and enjoy peace of mind with every door closure.
Product Tags Included:
  • Wyze Lock Bolt
  • Wyze Lock
FeatureWyze Lock BoltWyze Lock
Replaces DeadboltYesNo (replaces interior side only)
Auto-LockYesYes
Auto-UnlockNoYes
Door Position SensingBasic (motor position sensor)Advanced (built-in gyroscope)
Fingerprint ReaderYesNo
KeypadBuilt-in backlit keypadOptional wireless keypad
Remote AccessNo (Bluetooth local control only)Yes (via Gateway and WiFi)
Voice ControlNoYes (Alexa, Google Assistant)
Battery Life10-12 months (4 AA batteries)5-6 months (4 AA batteries)
Weather ResistanceIPX5 ratedIndoor use only
Installation TimeAbout 20 minutesUnder 15 minutes
Price$62.86$123.99
If you would like more help, you can chat with an agent via our Wyze Support chat.
What is an auto lock smart door lock that senses door open and closed?An auto lock smart door lock that senses door open and closed is a smart home device designed to automatically lock your door when it detects that the door is closed. This feature enhances security and convenience by ensuring your door is never accidentally left unlocked.
What are the main features of the Wyze Lock Bolt smart deadbolt replacement?The Wyze Lock Bolt offers ultra-fast fingerprint unlocking, a backlit keypad with anti-peep technology, auto-lock functionality, lock and unlock history tracking, a built-in jam detection alarm, emergency one-time codes, weather resistance (IPX5), and a long battery life of 10-12 months.
How does the Wyze Lock Bolt auto-lock feature work?The Wyze Lock Bolt automatically locks your door when it senses that the door is closed, providing peace of mind and eliminating the worry of forgetting to lock your door.
Can I monitor who enters and exits my home with Wyze smart locks?Yes, both the Wyze Lock Bolt and Wyze Lock allow you to monitor lock and unlock history through the Wyze app, so you can see who has accessed your home and when.
What is the difference between Wyze Lock Bolt and Wyze Lock?The Wyze Lock Bolt is a full deadbolt replacement with fingerprint and keypad access, while the Wyze Lock is an add-on that upgrades your existing deadbolt with smart features like auto-lock, remote access, and voice control without replacing your current hardware.
Is the Wyze Lock Bolt weather resistant?Yes, the Wyze Lock Bolt is weather resistant with an IPX5 rating, making it suitable for outdoor use and able to withstand various weather conditions.
How do I install the Wyze Lock or Wyze Lock Bolt?The Wyze Lock Bolt replaces your existing deadbolt and comes with all necessary hardware for installation. The Wyze Lock installs in under 15 minutes as an add-on to your current deadbolt, requiring no professional help.
What connectivity options do Wyze smart locks offer?The Wyze Lock Bolt uses Bluetooth 5.0 for communication, while the Wyze Lock supports Bluetooth, Zigbee, and WiFi, allowing for flexible connectivity and remote access via the Wyze app.
Can I control Wyze smart locks remotely?Yes, the Wyze Lock can be controlled remotely through the Wyze app, allowing you to lock or unlock your door from anywhere. The Wyze Lock Bolt uses Bluetooth, so remote control is available within Bluetooth range.
Are Wyze smart locks compatible with voice assistants?The Wyze Lock is compatible with Alexa and Google Assistant, enabling hands-free voice control. The Wyze Lock Bolt does not currently support voice assistants.
What doors are compatible with Wyze Lock Bolt and Wyze Lock?The Wyze Lock Bolt fits doors 1-3/8” to 1-3/4” thick with backset options of 2-3/8” or 2-3/4”. The Wyze Lock works with most single cylinder deadbolts, making it suitable for a wide range of standard doors.
How long do the batteries last in Wyze smart locks?The Wyze Lock Bolt is powered by 4 AA batteries that last 10-12 months, while the Wyze Lock uses 4 AA batteries with a battery life of 5-6 months.
What replacement parts are available for Wyze Lock Bolt?Wyze offers a range of replacement parts for the Wyze Lock Bolt, including the Wyze Lock Replacement Part Kit, Interior Assembly Metal Plate, Interior Assembly Battery Cover, and screws for secure installation.
What are the benefits of using an auto lock smart door lock that senses door status?Benefits include enhanced security through automatic locking, keyless entry options like fingerprint or keypad, easy user management, integration with smart home systems and voice assistants, and durable, weather-resistant designs.
Can I grant temporary access to guests with Wyze smart locks?Yes, both Wyze Lock Bolt and Wyze Lock allow you to grant temporary or permanent virtual keys or one-time codes to guests, family, or service providers for secure, keyless entry.
What are the key features of the Wyze Lock Bolt?How does the auto-lock function work on the Wyze Lock?Do you have any ongoing sales or discounts for the Wyze Lock products?
