Wyze Lock Bolt: The Ultimate Smart Deadbolt Replacement
Tired of fumbling with your keys or worrying about whether you locked the door? The
Wyze Lock Bolt is a cutting-edge Bluetooth smart lock designed to replace your traditional deadbolt with a sleek, secure, and ultra-convenient solution. Whether you want to unlock your door with a fingerprint, keypad, or app, this smart lock offers seamless access management for your home.
Unlock your door in less than a second with the touch of a finger or a tap in the Wyze app.
Key Features and Benefits
- Ultra-Fast Fingerprint Sensor: Gain instant access with a highly responsive fingerprint reader that recognizes your touch in a flash.
- Backlit Keypad with Anti-Peep: Enter your code easily even in the dark, with a keypad designed to prevent prying eyes from seeing your entry.
- Auto-Lock Function: Never worry about forgetting to lock your door again; the Wyze Lock Bolt automatically locks after a set time.
- Lock and Unlock History: Monitor who enters and exits your home with detailed access logs available in the Wyze app.
- Built-in Alarm for Jam Detection: Stay secure with an alarm that alerts you if the lock is jammed or tampered with.
- Emergency One-Time Codes: Provide temporary access to guests or service providers without compromising your security.
- Easy Installation: Replaces your existing deadbolt without complicated tools or professional help.
Technical Specifications
- Color Options: Matte Black, Satin Nickel
- Weight: 2.75 lbs
- Power Source: 4x AA Batteries (included) with 10-12 months battery life
- Communication: Bluetooth 5.0 with a 16 ft range
- Weather Resistance: IPX5 rating for durability in rain and snow
- Operating Temperature (Keypad): -13°F to 122°F
- Door Compatibility: Fits doors 1-3/8” to 1-3/4” thick, with backset options of 2-3/8” or 2-3/4”
- Deadbolt Diameter: 1”
Stylish and Secure Design
The Wyze Lock Bolt combines modern aesthetics with robust security. Its matte black and satin nickel finishes complement any door style, while the backlit keypad and fingerprint sensor add a touch of luxury and convenience.
Secure your home with Wyze Lock Bolt’s smart technology and sleek design.
Essential Replacement Parts for Wyze Lock Bolt
To keep your Wyze Lock Bolt functioning flawlessly, Wyze offers a range of replacement parts designed specifically for this smart lock.
Wyze Lock Bolt Screws
- Purpose: Replacement set of screws compatible with the Wyze Lock Bolt.
- Price: $2.99
- Benefit: Perfect for quick fixes or if you lose the original screws during installation or maintenance.
- Return Policy: 30-day hassle-free returns.
Wyze Lock Bolt Interior Assembly Metal Plate
- Purpose: Metal plate to securely anchor the interior assembly of the lock to your door.
- Price: $4.99
- Quantity Options: Available in sets from 1 to 10 pieces.
Wyze Lock Bolt Interior Assembly Battery Cover
- Purpose: Replacement battery cover for the interior assembly to protect the batteries and internal components.
- Price: $9.99
- Compatibility: Designed exclusively for the Wyze Lock Bolt.
These replacement parts ensure your Wyze Lock Bolt remains in top condition, extending the life and reliability of your smart lock system.
Why Choose Wyze Lock Bolt for Your Home?
The Wyze Lock Bolt is more than just a lock; it’s a smart home upgrade that enhances your security and convenience. With its advanced fingerprint sensor, app control, and auto-locking features, it offers peace of mind and effortless access management. Plus, the availability of affordable replacement parts means you can maintain your lock easily without hassle.
Experience the future of home security with Wyze Lock Bolt — smart, secure, and stylish.
Control your Wyze Lock Bolt remotely with the Wyze app for ultimate convenience.
Summary
- Wyze Lock Bolt: Smart deadbolt replacement with fingerprint sensor, backlit keypad, and app control.
- Replacement Parts: Screws, metal plate, and battery cover designed for easy maintenance.
- Durability: Weather-resistant and built to operate in extreme temperatures.
- Security: Auto-lock, jam detection alarm, and emergency codes for flexible access.
Upgrade your home security today with the Wyze Lock Bolt and enjoy keyless convenience combined with robust protection.
Effortless installation and modern design make Wyze Lock Bolt a smart choice for your front door.
What is the Wyze Lock Bolt?
The Wyze Lock Bolt is a Bluetooth-enabled smart deadbolt replacement that offers keyless entry through a fingerprint sensor, backlit keypad, or the Wyze app. It is designed to enhance home security and convenience by replacing your traditional deadbolt with a modern, secure solution.How does the Wyze Lock Bolt unlock?
You can unlock the Wyze Lock Bolt using its ultra-fast fingerprint sensor, the backlit keypad with anti-peep technology, or remotely through the Wyze app on your smartphone.Does the Wyze Lock Bolt have an auto-lock feature?
Yes, the Wyze Lock Bolt features an auto-lock function that automatically locks your door after a set period, ensuring your home stays secure even if you forget to lock up.Can I monitor who enters and exits with the Wyze Lock Bolt?
Yes, the Wyze Lock Bolt provides detailed lock and unlock history through the Wyze app, allowing you to monitor who enters and exits your home.Is the Wyze Lock Bolt weather resistant?
Yes, the Wyze Lock Bolt is IPX5 rated for weather resistance, making it durable in rain and snow. It operates in temperatures ranging from -13°F to 122°F.What doors are compatible with the Wyze Lock Bolt?
The Wyze Lock Bolt fits doors that are 1-3/8” to 1-3/4” thick and supports backset options of 2-3/8” or 2-3/4”. The deadbolt diameter is 1 inch.How is the Wyze Lock Bolt powered and how long does the battery last?
The Wyze Lock Bolt is powered by 4 AA batteries (included) and offers a battery life of 10-12 months under typical usage.What color options are available for the Wyze Lock Bolt?
The Wyze Lock Bolt is available in Matte Black and Satin Nickel finishes to complement various door styles.Is installation of the Wyze Lock Bolt easy?
Yes, the Wyze Lock Bolt is designed for easy installation and can replace your existing deadbolt without the need for complicated tools or professional help.What replacement parts are available for the Wyze Lock Bolt?
Wyze offers replacement screws, an interior assembly metal plate, and an interior assembly battery cover specifically designed for the Wyze Lock Bolt. These parts help maintain your lock’s performance and longevity.Are there return policies for Wyze Lock Bolt replacement parts?
Yes, all Wyze Lock Bolt replacement parts come with a 30-day hassle-free return policy.Does the Wyze Lock Bolt have a built-in alarm?
Yes, the Wyze Lock Bolt features a built-in alarm that alerts you if the lock is jammed or tampered with, enhancing your home’s security.Can I provide temporary access to guests with the Wyze Lock Bolt?
Yes, the Wyze Lock Bolt allows you to generate emergency one-time codes for guests or service providers, giving them temporary access without compromising your security.What is the Bluetooth range of the Wyze Lock Bolt?
The Wyze Lock Bolt uses Bluetooth 5.0 with a range of up to 16 feet for reliable connectivity with your smartphone.
