Smart Deadbolt Locks with Auto Unlock & Wireless Gateway
Smart Locks for Deadbolts with Auto Unlock and Wireless Gateway
Upgrade your home security with the latest smart locks designed specifically for deadbolts, featuring auto unlock capabilities and wireless gateway integration. These smart locks provide convenience, enhanced security, and seamless control right from your smartphone or fingerprint. Below, we highlight the top product that fits your needs perfectly.
Wyze Lock Bolt: The Ultimate Smart Deadbolt Replacement
Key Features and Benefits
Ultra-Fast Fingerprint Unlock Say goodbye to fumbling with keys. The Wyze Lock Bolt features an ultra-fast fingerprint reader that unlocks your door in less than a second with just a touch of your finger. This biometric access ensures quick and secure entry for you and your family. Luxurious Backlit Keypad with Anti-Peep Technology The solid metal exterior includes a backlit keypad for easy nighttime use. Anti-peep technology allows you to enter extra digits before or after your code, preventing onlookers from guessing your passcode. Auto-Lock for Peace of Mind Never worry about leaving your door unlocked again. The Wyze Lock Bolt auto-locks after a set delay, configurable through the Wyze app, ensuring your home stays secure even if you forget to lock the door. Bluetooth Connectivity & Local Control The lock connects via Bluetooth, allowing you to lock or unlock your door through the Wyze app when within range. The app also lets you create and manage up to 20 access codes and store up to 50 fingerprints. Long Battery Life with Emergency USB-C Charging Powered by 4 AA batteries, the lock lasts up to 12 months. If batteries run low or die, a USB-C port provides emergency power to unlock the door temporarily. Weatherproof and Pick-Proof Design Rated IPX5 for weather resistance, the Wyze Lock Bolt is built tough to withstand outdoor elements. Its keyless design eliminates the risk of lock picking. Easy Installation Replaces your existing deadbolt in about 20 minutes, compatible with most exterior doors.
Technical Specifications
  • Styles available: Matte Black, Satin Nickel
  • Price: $79.98
  • Battery: 4x AA batteries (up to 12 months)
  • Connectivity: Bluetooth
  • Security: Hardware encryption, two-factor authentication
  • Weather Resistance: IPX5
  • Access: Fingerprint, keypad, app control
  • Max fingerprints stored: 50
  • Max access codes: 20
"Wyze Lock Bolt is a solid, no frills smart lock with perfect fingerprint scans."
Wyze Lock Bolt Lifestyle Secure your front door with Wyze Lock Bolt’s smart fingerprint access.
Enhance Your Smart Lock with Wyze Wireless Gateway and Security Bundle
For users seeking a fully integrated smart home security system, the Front Porch Security Bundle combines the Wyze Lock Bolt with a wireless gateway and video doorbell for comprehensive control and monitoring.
What’s Included in the Bundle?
  • Wyze Lock Bolt for secure, keyless entry
  • Wyze Lock Gateway to enable remote access and automation
  • Wyze Video Doorbell with 1080p HD video and two-way audio
  • Wyze Chime for audible alerts inside your home
Benefits of the Wireless Gateway
  • Extends the lock’s connectivity beyond Bluetooth range
  • Enables remote locking/unlocking and real-time notifications
  • Supports integration with Alexa and Google Assistant for voice control
  • Provides automation options and lock history tracking in the Wyze app
Technical Highlights of the Bundle
  • Video Doorbell: 1080p HD, 120° vertical x 88° horizontal field of view, IP65 weather-resistant
  • Lock Communication: Bluetooth, Zigbee
  • Gateway Range: Up to 50 feet to lock and router
  • Operating Systems: Android 5.0+, iOS 9.0+
  • Lock Battery Life: 5-6 months (depending on usage)
Wyze Lock Bolt with App Control Control your Wyze Lock Bolt remotely with the Wyze app and wireless gateway.
Replacement Parts for Wyze Lock Bolt
To keep your Wyze Lock Bolt functioning smoothly, Wyze offers essential replacement parts:
  • Wyze Lock Bolt Screws – Replacement screws for secure installation.
  • Wyze Lock Bolt Interior Assembly Metal Plate – Anchors the interior assembly to the door.
  • Wyze Lock Bolt Interior Assembly Battery Cover – Replacement cover for the battery compartment.
  • Wyze Lock Replacement Part Kit – Includes various components compatible with Wyze Lock.
These parts ensure your smart lock remains reliable and easy to maintain.
Why Choose Wyze Lock Bolt for Your Deadbolt?
"Experience the perfect blend of convenience, security, and smart home integration with Wyze Lock Bolt."
  • Fast and secure fingerprint unlocking
  • Auto-lock feature for added safety
  • Wireless gateway support for remote access and automation
  • Durable, weatherproof design for all climates
  • Easy installation replacing your existing deadbolt
  • Affordable price with premium features
Upgrade your home security today with Wyze Lock Bolt and enjoy the peace of mind that comes with smart, keyless entry and wireless control.
FeatureWyze Lock BoltThe Front Porch Security Bundle
Product TypeBluetooth Smart LockSecurity Bundle (Lock + Video Doorbell + Chime + Optional Cam)
Price$79.98$123.99 - $173.97 (varies by variant)
Lock TypeDeadbolt replacementIncludes Wyze Lock or Wyze Lock Bolt
Fingerprint SensorYes, ultra-fast fingerprint readerIncluded if Wyze Lock Bolt variant chosen
KeypadBacklit keypad with anti-peep technologyIncluded if Wyze Lock Bolt variant chosen
Auto-lock FeatureYesYes (via Wyze Lock or Lock Bolt)
App ControlYes, via Wyze app (Bluetooth connection)Yes, remote lock/unlock and lock history via Wyze app
Video Doorbell IncludedNoYes, Wyze Video Doorbell or Video Doorbell Pro included
Video Resolution (Doorbell)N/A1080p HD (Wyze Video Doorbell) or higher with Video Doorbell Pro
Two-way Audio (Doorbell)N/AYes
Additional Cameras IncludedNoOptional Wyze Cam V3 included in some variants
Installation Time~20 minutesVaries by components, Lock Bolt installs in ~20 minutes
Weather ResistanceIPX5Lock Bolt: IPX5; Doorbell: IP65
Battery Life (Lock)Up to 12 months (4 AA batteries)Same for Lock Bolt
Emergency One-Time CodesYesYes (via Wyze Lock Bolt)
Maximum Fingerprints Stored50Same for Lock Bolt
Maximum Access Codes20Same for Lock Bolt
Lock History & NotificationsYes, via Wyze appYes, via Wyze app
Auto-expiring CodesYesYes
Hardware EncryptionYesYes
Two-Factor AuthenticationYes (in app)Yes
Keyless EntryYesYes
Compatible Door TypesMost exterior doorsSame as Wyze Lock Bolt
Included AccessoriesLock Bolt unit, batteriesLock Bolt or Lock, Video Doorbell, Chime, optional Cam V3
What is the Wyze Lock Bolt and how does it improve home security?The Wyze Lock Bolt is a smart deadbolt replacement designed to enhance home security with features like ultra-fast fingerprint unlocking, auto-lock, and a backlit keypad with anti-peep technology. It offers keyless entry, Bluetooth connectivity, and can be integrated with a wireless gateway for remote access and automation, providing both convenience and robust protection for your home.
How does the fingerprint unlock feature work on the Wyze Lock Bolt?The Wyze Lock Bolt features an ultra-fast fingerprint reader that unlocks your door in less than a second with just a touch. It can store up to 50 fingerprints, allowing quick and secure access for multiple users without the need for physical keys.
What is anti-peep technology on the Wyze Lock Bolt keypad?Anti-peep technology allows you to enter random digits before or after your actual passcode on the backlit keypad. This prevents onlookers from guessing your code, enhancing the security of your smart lock.
Does the Wyze Lock Bolt have an auto-lock feature?Yes, the Wyze Lock Bolt includes an auto-lock feature that automatically locks your door after a set delay, which you can configure through the Wyze app. This ensures your door is always secure, even if you forget to lock it manually.
Can I control the Wyze Lock Bolt remotely?You can control the Wyze Lock Bolt remotely by integrating it with the Wyze Lock Gateway, which extends connectivity beyond Bluetooth range. This allows you to lock or unlock your door, receive real-time notifications, and manage access codes from anywhere using the Wyze app.
What is included in the Wyze Front Porch Security Bundle?The Wyze Front Porch Security Bundle includes the Wyze Lock Bolt, Wyze Lock Gateway for remote access, Wyze Video Doorbell with 1080p HD video and two-way audio, and Wyze Chime for audible alerts. This bundle provides comprehensive security and smart home integration for your front door.
Is the Wyze Lock Bolt weatherproof and pick-proof?Yes, the Wyze Lock Bolt is rated IPX5 for weather resistance, making it suitable for outdoor use in various climates. Its keyless design also eliminates the risk of lock picking, providing added security for your home.
How long does the Wyze Lock Bolt battery last and what happens if it runs out?The Wyze Lock Bolt is powered by 4 AA batteries, which can last up to 12 months depending on usage. If the batteries run low or die, you can use the emergency USB-C port to temporarily power the lock and unlock your door.
How easy is it to install the Wyze Lock Bolt?The Wyze Lock Bolt is designed for easy installation, replacing your existing deadbolt in about 20 minutes. It is compatible with most exterior doors and comes with all necessary hardware for a straightforward setup.
What replacement parts are available for the Wyze Lock Bolt?Wyze offers several replacement parts for the Lock Bolt, including replacement screws, an interior assembly metal plate, a battery cover, and a comprehensive replacement part kit. These parts help maintain the reliability and longevity of your smart lock.
What smart home integrations are supported by the Wyze Lock Bolt and Gateway?When paired with the Wyze Lock Gateway, the Wyze Lock Bolt supports integration with Alexa and Google Assistant, enabling voice control and automation options for your smart home.
How many access codes and fingerprints can the Wyze Lock Bolt store?The Wyze Lock Bolt can store up to 20 unique access codes and up to 50 fingerprints, making it ideal for families, guests, or rental properties requiring multiple users.
What are the available styles and price of the Wyze Lock Bolt?The Wyze Lock Bolt is available in Matte Black and Satin Nickel finishes. It is priced at $79.98, offering premium smart lock features at an affordable cost.
What are the installation requirements for the Wyze Lock Bolt?Can the Wyze Lock Bolt be integrated with other smart home devices?Are there any ongoing promotions or discounts for the Wyze Lock Bolt?
