Wyze Battery Cam Pro: Easy Angle Adjustments for Clear Security
Wyze Battery Cam Pro: Simple Angle Adjustment for Clear Views
When it comes to securing your home or monitoring key access points, having a camera that is easy to adjust and delivers crystal-clear video is essential. The Wyze Battery Cam Pro stands out as a top choice for those seeking flexible, wire-free security with simple camera angle adjustments to capture every important detail.
Effortless Camera Angle Adjustment
The Wyze Battery Cam Pro features a versatile mounting system with a standard 1/4” - 20 thread, allowing you to easily tilt and swivel the camera to achieve the perfect viewing angle. Whether you want to monitor your front door, driveway, or backyard, this camera’s adjustable mount ensures you get a clear view of all key access points without complicated installation.
Stunning 2.5K HDR Video Quality
Equipped with a 2.5K HDR resolution (2560 x 1440), the Wyze Battery Cam Pro delivers sharp, vibrant video footage day and night. Its CMOS-Starlight sensor combined with an F1.6 lens and a wide 134° diagonal field of view captures more area with exceptional clarity. This means you won’t miss any important activity, even in low-light conditions.
Wire-Free and Weatherproof Design
Enjoy the freedom of wireless installation with no hub required. The camera runs on removable, rechargeable 6200mAh battery packs that last up to 6 months on a single charge. Plus, with an IP65 weatherproof rating, the Wyze Battery Cam Pro is built to withstand rain, snow, and extreme temperatures from -20°C to 50°C (-4°F to 122°F).
Smart Features for Enhanced Security
  • Integrated spotlight and 100 dB siren to deter intruders
  • Radar + PIR motion detection for accurate alerts
  • Two-way audio with built-in microphone and speaker for real-time communication
  • Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home integration
Home security camera mounted outdoors
Wyze Battery Cam Pro + Solar Panel: Continuous Power and Clear Views
For those who want the convenience of continuous power without frequent recharging, the Wyze Battery Cam Pro + Solar Panel bundle is an excellent solution. It combines all the features of the Battery Cam Pro with a solar panel that keeps your camera charged using natural sunlight.
Solar-Powered Convenience
The included solar panel provides a steady 2.5W, 5V DC power supply, reducing the need to manually recharge the battery packs. This is perfect for locations with ample sunlight, ensuring your camera stays powered and ready to capture clear footage at all times.
Same High-Quality Video and Motion Detection
This bundle maintains the 2.5K HDR video resolution, wide 134° field of view, and advanced radar + PIR motion detection of the standard Battery Cam Pro. You get the same reliable, clear view of your property with the added benefit of solar-powered endurance.
Easy Installation and Smart Integration
Mount the camera and solar panel easily with included hardware, and control everything through the Wyze app. The camera supports dual-band WiFi (2.4 & 5 GHz) and works with Alexa, Google Assistant, and IFTTT for voice commands and automation. Solar panel powering outdoor security camera
Essential Accessories for Extended Use and Convenience
Wyze Removable Battery Pack
Keep your Wyze Battery Cam Pro running longer with an extra Wyze Removable Battery Pack. This 6200mAh rechargeable lithium-ion battery is designed specifically for the Battery Cam Pro and Duo Cam Doorbell, providing up to 6 months of power on a single charge. The USB-C charging port makes recharging quick and convenient.
Wyze Battery Charging Dock
Charge two battery packs simultaneously with the Wyze Battery Charging Dock. This compact dock comes with a power adapter and USB-A to USB-C cable, making it easy to keep multiple batteries ready for use. It fully charges batteries in approximately 8.5 to 9 hours, so you can swap batteries without downtime. Charging dock with batteries
With the Wyze Battery Cam Pro and its solar-powered variant, adjusting camera angles for a clear view of key access points has never been easier. Combined with essential accessories like extra battery packs and charging docks, you can maintain continuous, high-quality surveillance effortlessly.
Summary of Wyze Battery Cam Pro Products
Wyze Battery Cam Pro Wire-free, 2.5K HDR, adjustable mount, IP65 weatherproof, up to 6 months battery life. Wyze Battery Cam Pro + Solar Panel Same features as Battery Cam Pro plus solar panel for continuous charging. Wyze Removable Battery Pack Extra 6200mAh rechargeable battery for extended use. Wyze Battery Charging Dock Dual charging dock for two batteries at once.
FeatureWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelWyze Removable Battery PackWyze Battery Charging Dock
TypeCameraCamera + Accessory BundleAccessory (Battery)Accessory (Charging Dock)
Video Resolution2.5K HDR2.5K HDRN/AN/A
Power SourceRemovable, Rechargeable Battery PacksRemovable Battery + Solar Panel6200mAh Rechargeable BatteryCharges up to two batteries simultaneously
Battery CapacityIncludedIncluded6200mAh Lithium IonN/A
Battery LifeUp to 6 months per chargeExtended with Solar PanelUp to 6 months per chargeN/A
Charging MethodUSB-C (via battery pack)USB-C + Solar PanelUSB-C charging portUSB-A to USB-C cable, charges 2 batteries
Weatherproof RatingIP65IP65N/AN/A
Motion DetectionRadar + PIRRadar + PIRN/AN/A
Spotlight & SirenIntegratedIntegratedN/AN/A
Wi-Fi Support2.4 & 5 GHz2.4 & 5 GHzN/AN/A
Local RecordingYes (with microSD card)Yes (with microSD card)N/AN/A
Mounting OptionsFlexible, includes universal mountFlexible, includes universal mountN/AN/A
DimensionsCamera: 2.5" x 1.8" x 3.5"Camera + Solar Panel: Solar Panel 173mm x 120mm x 17mm2.9" x 1.6" x 0.9" (75mm x 40mm x 22mm)Dock: 2.6" x 2" x 1" (58mm x 52mm x 26mm)
Weight0.94 lb (camera)Camera + Solar Panel3.9 oz (110g)2.75 oz (78g)
Price (USD)$89.98 (1 pack)$109.98 (bundle)$22.99$17.99
Additional FeaturesNo hub required, wire-free, dual-band Wi-Fi, Bluetooth setup, two-way audioIncludes solar panel for continuous power, same features as Battery Cam ProHot-swap battery, long battery life, USB-C chargingCharges two batteries simultaneously, includes power adapter and cable
CompatibilityN/AN/AWyze Battery Cam Pro and Wyze Duo Cam DoorbellWyze Battery Cam Pro battery packs
What is the Wyze Battery Cam Pro?The Wyze Battery Cam Pro is a wire-free, weatherproof security camera that offers 2.5K HDR video quality, simple angle adjustment, and up to 6 months of battery life. It is designed for easy installation and clear monitoring of key access points around your home.
How do I adjust the viewing angle of the Wyze Battery Cam Pro?The Wyze Battery Cam Pro features a versatile mounting system with a standard 1/4” - 20 thread, allowing you to easily tilt and swivel the camera for the perfect viewing angle. This ensures you can monitor your front door, driveway, or backyard with ease.
What video quality does the Wyze Battery Cam Pro provide?The Wyze Battery Cam Pro delivers stunning 2.5K HDR video resolution (2560 x 1440) with a wide 134° diagonal field of view. Its CMOS-Starlight sensor and F1.6 lens ensure sharp, vibrant footage both day and night, even in low-light conditions.
Is the Wyze Battery Cam Pro weatherproof?Yes, the Wyze Battery Cam Pro has an IP65 weatherproof rating, making it suitable for outdoor use in rain, snow, and extreme temperatures ranging from -20°C to 50°C (-4°F to 122°F).
How long does the Wyze Battery Cam Pro battery last?The Wyze Battery Cam Pro uses removable, rechargeable 6200mAh battery packs that can last up to 6 months on a single charge, depending on usage and environmental conditions.
What smart features does the Wyze Battery Cam Pro offer?The Wyze Battery Cam Pro includes an integrated spotlight, a 100 dB siren, radar + PIR motion detection for accurate alerts, and two-way audio with a built-in microphone and speaker. It is also compatible with Alexa, Google Assistant, and IFTTT for smart home integration.
What is included in the Wyze Battery Cam Pro + Solar Panel bundle?The Wyze Battery Cam Pro + Solar Panel bundle includes the Battery Cam Pro and a solar panel that provides continuous 2.5W, 5V DC power. This setup reduces the need for manual recharging by keeping your camera powered with natural sunlight.
Does the Wyze Battery Cam Pro + Solar Panel bundle maintain the same video quality?Yes, the Wyze Battery Cam Pro + Solar Panel bundle maintains the same 2.5K HDR video resolution, 134° field of view, and advanced radar + PIR motion detection as the standard Battery Cam Pro.
How do I install the Wyze Battery Cam Pro and solar panel?Both the Wyze Battery Cam Pro and the solar panel are easy to install with the included hardware. The camera supports dual-band WiFi (2.4 & 5 GHz) and can be controlled through the Wyze app for convenient setup and management.
What accessories are available for the Wyze Battery Cam Pro?Essential accessories for the Wyze Battery Cam Pro include the Wyze Removable Battery Pack, a 6200mAh rechargeable battery for extended use, and the Wyze Battery Charging Dock, which allows you to charge two battery packs simultaneously.
How long does it take to charge Wyze Battery Cam Pro batteries with the charging dock?The Wyze Battery Charging Dock can fully charge two battery packs in approximately 8.5 to 9 hours, ensuring you always have a charged battery ready for use.
Is the Wyze Battery Cam Pro compatible with smart home systems?Yes, the Wyze Battery Cam Pro works with Alexa, Google Assistant, and IFTTT, allowing for voice commands and seamless smart home automation.
What are the smart features included with the Wyze Battery Cam Pro?Can you tell me more about the solar panel option for the Wyze Battery Cam Pro?How does the radar and PIR motion detection work on the Wyze Battery Cam Pro?
