Wyze Battery Cam Pro: Affordable Entry-Level Home Security Camera
Affordable Entry-Level Battery Cameras for Home Security
When it comes to securing your home on a budget, the Wyze Battery Cam Pro stands out as an excellent choice. Designed for easy installation and wireless convenience, this camera offers pro-grade features without the hefty price tag. Whether you want to monitor your front porch, backyard, or any other area, the Wyze Battery Cam Pro delivers reliable security with impressive video quality and smart detection capabilities.
Wyze Battery Cam Pro: Powerful Features at a Low Cost
High-Resolution Video and Smart Detection
The Wyze Battery Cam Pro captures crystal-clear footage in 2.5K HDR resolution, ensuring you see every detail day or night. Its advanced radar and PIR motion detection system provides early and precise alerts, reducing false alarms. Customize detection zones through the Wyze app to focus on the most important areas around your home.
Wire-Free and Weatherproof Design
Forget about complicated wiring or hubs. This camera is completely wire-free and runs on removable, rechargeable battery packs that last up to six months on a single charge. Rated IP65 for weather resistance, it can withstand rain, dust, and extreme temperatures, making it perfect for outdoor use in any season.
Integrated Spotlight and Siren
Enhance your home security with a built-in 150-lumen spotlight and a loud siren. The spotlight activates automatically when motion is detected, deterring potential intruders, or you can manually control it via the app for added safety during nighttime activities.
Flexible Power Options
For extended use, the Wyze Battery Cam Pro can be paired with the Wyze Solar Panel, converting sunlight into power to keep your camera running longer without frequent recharging. This solar-powered option is ideal for those who want continuous monitoring with minimal maintenance.
"No wires. No hubs. Just reliable, wireless security wherever you need it."
Home security with Wyze Battery Cam Pro
Wyze Battery Cam Pro + Solar Panel: Extended Battery Life and Convenience
Solar-Powered Security
The bundle including the Wyze Battery Cam Pro and Solar Panel offers the same high-quality 2.5K HDR video and smart motion detection but adds the convenience of solar charging. This means less downtime and fewer battery swaps, perfect for users who want a low-maintenance security solution.
Robust Technical Specs
  • Battery Capacity: 6200mAh rechargeable battery lasting up to 6 months
  • Charging Time: Approximately 9 hours
  • Connectivity: Dual-band WiFi (2.4 & 5 GHz) for faster, more reliable connections
  • Weatherproof: IP65 rating for all-weather durability
  • Night Vision: Color night vision with integrated IR and white LEDs
  • Audio: Enhanced two-way audio with built-in microphone and speaker
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT
This bundle is ideal for homeowners who want to maximize security coverage with minimal effort and cost.
Bird Feeder Wireless Camera Bundle: Security Meets Nature Watching
For those who want to combine home security with a touch of nature, the Bird Feeder Wireless Camera Bundle is a unique option. It includes the Wyze Battery Cam Pro, a Wyze Bird Feeder, and a Solar Panel, allowing you to monitor your yard while enjoying live views of visiting birds.
Features of the Bird Feeder Bundle
  • Weather-Resistant Bird Feeder: Durable polycarbonate design attracts a variety of birds year-round
  • Macro Lens Adapter: Ensures clear, close-up views of feathered visitors
  • Wireless Convenience: Battery-powered camera with solar charging for extended use
  • Live Streaming & Notifications: Watch and receive alerts via the Wyze app
This bundle is perfect for bird lovers who want to keep an eye on their property and enjoy wildlife watching simultaneously. Enjoy birdwatching with Wyze Bird Feeder Bundle
Essential Accessories to Enhance Your Wyze Battery Cam Pro
Wyze Removable Battery Pack
Keep your camera powered without interruption by having extra rechargeable battery packs on hand. Each pack offers 6200mAh capacity and can last up to six months, making battery swaps quick and easy.
Wyze Battery Charging Dock
Charge two battery packs simultaneously with the compact and efficient charging dock. This accessory ensures your batteries are always ready to go, minimizing downtime.
Why Choose Wyze Battery Cam Pro for Budget Home Security?
  • Affordable Pricing: Starting at just $89.98 for a single camera
  • No Hub Required: Simplifies setup and reduces additional costs
  • Flexible Mounting: Wall, ceiling, or pole mounting options with included mounts
  • Smart Features: Radar + PIR motion detection, color night vision, and app control
  • Expandable System: Add solar panels and accessories as needed
Wyze Battery Cam Pro offers an unbeatable combination of affordability, advanced features, and ease of use, making it the perfect entry-level battery camera for home security on a smaller budget. Secure your home affordably with Wyze Battery Cam Pro
FeatureWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelBird Feeder Wireless Camera Bundle
Price$89.98 (1 Pack)$109.98$139.98 / $154.96
Included ItemsWyze Battery Cam ProWyze Battery Cam Pro + Wyze Solar PanelWyze Bird Feeder + Wyze Battery Cam Pro + Wyze Solar Panel
Video Resolution2.5K HDR (2560 x 1440)2.5K HDR (2560 x 1440)2.5K HDR (Wyze Battery Cam Pro)
Power SourceRemovable, Rechargeable Battery PacksBattery + Solar Panel for continuous powerBattery + Solar Panel for continuous power
Motion DetectionRadar + PIR Motion DetectionRadar + PIR Motion DetectionRadar + PIR Motion Detection (via Battery Cam Pro)
Integrated Spotlight & SirenYesYesYes (via Battery Cam Pro)
Weatherproof RatingIP65IP65IP65 (Bird Feeder, Solar Panel, Battery Cam Pro)
WiFi Support2.4 & 5 GHz2.4 & 5 GHz2.4 & 5 GHz (Battery Cam Pro)
Local RecordingYes, via microSD card (not included)Yes, via microSD card (not included)Yes, via microSD card (Battery Cam Pro)
Battery LifeUp to 6 months per charge (with removable battery)Extended with Solar PanelExtended with Solar Panel
Camera Colors AvailableBlack, WhiteBlack, WhiteBlack, White (Battery Cam Pro); Blue, Brown (Bird Feeder)
Bird Feeder IncludedNoNoYes
Bird Feeder FeaturesN/AN/AWeather-resistant, 1L seed capacity, Macro Lens Adapter
Mounting OptionsFlexible, includes wall and ceiling mountsFlexible, includes wall and ceiling mountsIncludes mounting accessories for Bird Feeder and Cam
Additional FeaturesTwo-way audio, Bluetooth setup, dual-band WiFiSame as Battery Cam Pro + Solar powerSame as Battery Cam Pro + Bird Feeder with live view
What makes the Wyze Battery Cam Pro a good choice for affordable home security?The Wyze Battery Cam Pro offers pro-grade features like 2.5K HDR video, smart motion detection, and wireless installation at an affordable price. With no need for hubs or complicated wiring, it provides reliable home security on a budget.
How long does the Wyze Battery Cam Pro battery last on a single charge?The Wyze Battery Cam Pro uses a 6200mAh rechargeable battery pack that can last up to six months on a single charge, depending on usage and environmental conditions.
Is the Wyze Battery Cam Pro weatherproof for outdoor use?Yes, the Wyze Battery Cam Pro is rated IP65 for weather resistance, making it suitable for outdoor use in rain, dust, and extreme temperatures.
Does the Wyze Battery Cam Pro have night vision?Yes, the Wyze Battery Cam Pro features color night vision with integrated IR and white LEDs, ensuring clear footage even in low-light conditions.
Can I use the Wyze Battery Cam Pro with a solar panel?Absolutely. The Wyze Battery Cam Pro can be paired with the Wyze Solar Panel, allowing for solar-powered charging and extended battery life with minimal maintenance.
What smart home systems is the Wyze Battery Cam Pro compatible with?The Wyze Battery Cam Pro works with Alexa, Google Assistant, and IFTTT, making it easy to integrate into your existing smart home setup.
What are the main features of the Wyze Battery Cam Pro + Solar Panel bundle?The bundle includes the Wyze Battery Cam Pro and a solar panel, offering 2.5K HDR video, smart motion detection, solar charging for less downtime, dual-band WiFi, color night vision, and enhanced two-way audio.
What is included in the Bird Feeder Wireless Camera Bundle?The Bird Feeder Wireless Camera Bundle includes a Wyze Battery Cam Pro, a weather-resistant Wyze Bird Feeder, a macro lens adapter for close-up bird views, and a solar panel for extended battery life.
How can I extend the battery life of my Wyze Battery Cam Pro?You can extend battery life by pairing the camera with the Wyze Solar Panel for continuous solar charging or by keeping extra Wyze Removable Battery Packs charged and ready for quick swaps.
What accessories are available for the Wyze Battery Cam Pro?Essential accessories include the Wyze Removable Battery Pack for uninterrupted power and the Wyze Battery Charging Dock, which charges two battery packs simultaneously.
How easy is it to install the Wyze Battery Cam Pro?Installation is simple and wire-free, with flexible mounting options for walls, ceilings, or poles. No hub is required, making setup quick and hassle-free.
What is the starting price of the Wyze Battery Cam Pro?The Wyze Battery Cam Pro starts at just $89.98 for a single camera, making it an affordable option for entry-level home security.
What are the key features of the Wyze Battery Cam Pro that make it suitable for home security?How does the Wyze Battery Cam Pro compare to other entry-level battery cameras on the market?Do you have any ongoing promotions or discounts for the Wyze Battery Cam Pro?
