Easy to Mount Wireless Security Cameras with Adjustable Motion Detection Zones
When it comes to securing your home or property, having a reliable, easy-to-install wireless security camera with advanced motion detection is essential. The
Wyze Battery Cam Pro series offers exactly that — a powerful, wire-free security solution with customizable motion detection zones to keep you informed and protected.
Wyze Battery Cam Pro: Wireless Security Made Simple
Stunning 2.5K HDR Video Quality
Experience crystal-clear video with 2.5K HDR resolution that captures every detail in vibrant color, day or night. The camera’s high dynamic range ensures balanced images, making it easier to identify faces, packages, or any unusual activity.
Wyze Battery Cam Pro features a dual-sensor system combining Radar and PIR motion detection. This powerful combo allows for earlier and more precise motion alerts. Customize detection zones in the Wyze app to focus on specific areas, reducing false alarms and ensuring you only get notified about what matters most.
Wire-Free and Weatherproof
No need for power outlets or complicated wiring. The camera runs on removable, rechargeable battery packs and is rated IP65 weatherproof, making it perfect for outdoor use in rain, snow, or shine.
Integrated Spotlight and Siren
Enhance your security with a built-in 150-lumen spotlight and siren. The motion-activated light can deter intruders, and you can manually control the spotlight via the app for added safety during nighttime activities.
Flexible Mounting Options
Mount your camera anywhere with ease. The Wyze Universal Mount (Long) accessory offers a durable, adjustable solution for ceiling or patio installations, providing versatile placement options to suit your needs.
Wyze Battery Cam Pro + Solar Panel: Continuous Power, Zero Hassle
Solar-Powered Convenience
Never worry about battery life again. The Wyze Battery Cam Pro + Solar Panel bundle converts sunlight into power, allowing your camera to stay up longer with less frequent charging. This eco-friendly option is perfect for remote locations or busy households.
All the Features of the Battery Cam Pro
Enjoy the same 2.5K HDR video, adjustable motion zones, integrated spotlight, and weatherproof design with the added benefit of continuous solar power.
Essential Accessories to Enhance Your Wyze Battery Cam Pro
Wyze Removable Battery Pack
Keep your camera running without interruption by swapping out batteries quickly. Each 6200mAh rechargeable battery lasts up to 6 months on a single charge, and the built-in USB-C port makes charging simple and fast.
Wyze Battery Charging Dock
Charge two battery packs simultaneously with this compact and efficient charging dock. Perfect for households with multiple cameras or for keeping spare batteries ready at all times.
This heavy-duty metal mount with a longer neck is designed for versatile mounting applications, including ceilings and patios. It’s compatible with Wyze Battery Cam Pro and many other Wyze cameras, providing a secure and adjustable installation.
"Wyze Battery Cam Pro offers pro-grade protection with the convenience of wireless installation and customizable motion detection zones, making it an ideal choice for easy-to-mount home security."
Why Choose Wyze Battery Cam Pro?
- Easy Installation: No wires or hubs required, set up in minutes with BluetoothⓇ.
- Customizable Motion Zones: Focus on what matters with adjustable detection areas.
- High-Quality Video: 2.5K HDR resolution with color night vision.
- Weatherproof Durability: IP65 rating ensures reliable performance outdoors.
- Flexible Power Options: Removable batteries or solar panel for continuous operation.
- Integrated Security Features: Spotlight and siren to deter intruders.
- Smart Connectivity: Dual-band Wi-Fi support (2.4 & 5 GHz) for faster, stable connections.
Capture Every Moment with Confidence
With local recording support via microSD card (sold separately), you can store motion events without a subscription. Plus, the Wyze app offers smart notifications for people, packages, vehicles, and even bird detection with Cam Plus subscription.
Secure your home effortlessly with Wyze Battery Cam Pro’s easy mounting and wireless design.
Keep your camera powered continuously with the Wyze Solar Panel bundle.
Stay prepared with the Wyze Battery Charging Dock, charging two batteries at once.
Protect your home with the Wyze Battery Cam Pro series — the ultimate easy-to-mount wireless security camera with adjustable motion detection zones and flexible power options.
What is the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro is a wireless security camera designed for easy installation and advanced home protection. It features 2.5K HDR video quality, customizable motion detection zones, weatherproof durability, and flexible power options including removable batteries and solar panel compatibility.How do I install the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro is easy to install with no wires or hubs required. Simply mount the camera using the included hardware or the Wyze Universal Mount (Long) accessory, and set it up in minutes using BluetoothⓇ and the Wyze app.What video quality does the Wyze Battery Cam Pro offer?
The Wyze Battery Cam Pro provides stunning 2.5K HDR video resolution, ensuring crystal-clear images with vibrant color and high dynamic range for both day and night surveillance.Can I customize motion detection zones with Wyze Battery Cam Pro?
Yes, the Wyze Battery Cam Pro allows you to set adjustable motion detection zones through the Wyze app. This feature helps reduce false alarms by focusing on specific areas that matter most to you.Is the Wyze Battery Cam Pro weatherproof?
Yes, the Wyze Battery Cam Pro is rated IP65 weatherproof, making it suitable for outdoor use in rain, snow, or shine.What power options are available for the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro can be powered by removable, rechargeable battery packs or continuously with the Wyze Solar Panel bundle, providing flexible and eco-friendly power solutions.How long does the Wyze removable battery pack last?
Each Wyze removable battery pack has a 6200mAh capacity and can last up to 6 months on a single charge, depending on usage and environmental conditions.What is included in the Wyze Battery Cam Pro + Solar Panel bundle?
The Wyze Battery Cam Pro + Solar Panel bundle includes the wireless camera and a solar panel that converts sunlight into power, allowing for continuous operation with less frequent charging.Does the Wyze Battery Cam Pro have a spotlight and siren?
Yes, the Wyze Battery Cam Pro features a built-in 150-lumen spotlight and a siren. The spotlight can be motion-activated or manually controlled via the Wyze app to deter intruders and enhance nighttime security.Can I record video locally with the Wyze Battery Cam Pro?
Yes, the Wyze Battery Cam Pro supports local recording via a microSD card (sold separately), allowing you to store motion events without a subscription.What accessories are available for the Wyze Battery Cam Pro?
Essential accessories include the Wyze Removable Battery Pack, Wyze Battery Charging Dock (for charging two batteries simultaneously), and the Wyze Universal Mount (Long) for versatile mounting options.Does the Wyze Battery Cam Pro support smart notifications?
Yes, the Wyze app provides smart notifications for people, packages, vehicles, and even bird detection with a Cam Plus subscription.Is the Wyze Battery Cam Pro compatible with both 2.4 GHz and 5 GHz Wi-Fi?
Yes, the Wyze Battery Cam Pro supports dual-band Wi-Fi (2.4 GHz and 5 GHz) for faster and more stable wireless connections.
