Home Surveillance Camera Featuring Wide Viewing Angle and Crisp Details: Wyze Battery Cam Pro
When it comes to securing your home with a surveillance camera that offers a wide viewing angle and crisp, detailed video, the
Wyze Battery Cam Pro stands out as a top choice. Designed for wire-free convenience and high-quality imaging, this camera is perfect for homeowners seeking reliable, flexible, and smart security solutions.
Wyze Battery Cam Pro: Wire-Free, High-Definition Security
Crisp 2.5K HDR Video Resolution
The Wyze Battery Cam Pro captures stunning 2.5K HDR video, delivering sharp, vibrant images day and night. Its high dynamic range ensures balanced lighting and richer colors, so you never miss a detail whether it’s bright daylight or low-light conditions.
Wide Viewing Angle & Smart Motion Detection
Equipped with advanced Radar + PIR motion detection, this camera offers precise and early alerts. You can customize detection zones in the Wyze app to focus on specific areas, reducing false alarms and enhancing security. The integrated spotlight with 150 lumens of LED light activates on motion, illuminating potential intruders instantly.
Weatherproof and Wireless Freedom
Rated IP65 for weather resistance, the Wyze Battery Cam Pro is built to withstand rain, dust, and extreme temperatures. Its wire-free design means no hubs or power outlets are required, allowing you to place it anywhere around your home or property.
Flexible Power Options
The camera features removable, rechargeable battery packs that last up to six months on a single charge. For extended use, you can easily hot-swap batteries or add the Wyze Solar Panel to convert your camera into a solar-powered security system, reducing downtime and maintenance.
Dual-Band Wi-Fi and Easy Setup
Supporting both 2.4 GHz and 5 GHz Wi-Fi networks, the camera connects quickly and reliably. Setup is simplified with instant BluetoothⓇ pairing—no QR code scanning needed. Plus, enhanced two-way audio lets you communicate through the built-in microphone and speaker.
Experience flexible, wire-free home security with Wyze Battery Cam Pro.
Wyze Battery Cam Pro + Solar Panel: Continuous Power, Endless Protection
Solar-Powered Convenience
The
Wyze Battery Cam Pro + Solar Panel bundle offers all the features of the Battery Cam Pro with the added benefit of continuous solar power. This means your camera stays charged longer without manual intervention, perfect for remote or hard-to-reach locations.
Same High-Quality Video and Detection
Enjoy the same 2.5K HDR video resolution, integrated spotlight, and dual Radar + PIR motion sensors. The solar panel is weatherproof (IP65) and designed specifically to keep your camera powered by converting sunlight into energy efficiently.
Local Storage and Smart Features
Record motion events locally to a microSD card (sold separately) without needing a subscription. The camera also supports Cam Plus for advanced smart detections like person, package, and vehicle notifications.
Secure your home day and night with smart lighting and surveillance.
Enhance Your Wyze Battery Cam Pro Experience with Accessories
Wyze Removable Battery Pack
Keep your camera powered without interruption by using additional 6200mAh rechargeable battery packs. Each battery lasts up to six months and charges conveniently via USB-C.
Wyze Battery Charging Dock
Charge two battery packs simultaneously with the compact and efficient dual charging dock. This accessory ensures you always have a fresh battery ready to swap in.
Wyze Universal Mount (Long)
For ceiling or high-elevation mounting, the longer stem mount provides flexible installation options, helping you achieve the perfect angle for wide coverage.
Bonus: Bird Feeder Wireless Camera Bundle
For nature lovers and bird watchers, the
Bird Feeder Wireless Camera Bundle combines the Wyze Battery Cam Pro, Wyze Solar Panel, and a vibrant Wyze Bird Feeder. This bundle lets you enjoy live video and recordings of feathered visitors while securing your outdoor space.
- Weather-resistant and wire-free setup
- Includes macro lens adapter for close-up birdwatching
- Compatible with Alexa, Google Assistant, and IFTTT
Why Choose Wyze Battery Cam Pro for Home Surveillance?
"The ultimate battery-operated, wire-free home security camera with pro-grade features and flexible power options."
- Wide viewing angle and crisp 2.5K HDR video for detailed surveillance
- Integrated spotlight and siren for active deterrence
- Radar + PIR motion detection for smart, precise alerts
- IP65 weatherproof rating for all-season durability
- Wireless and hub-free for easy installation anywhere
- Optional solar power for continuous, eco-friendly operation
Secure your home with confidence and clarity using the Wyze Battery Cam Pro and its versatile accessories.
What is the video resolution of the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro captures crisp 2.5K HDR video, providing sharp, vibrant images with balanced lighting and rich colors for detailed surveillance day and night.Does the Wyze Battery Cam Pro support wireless installation?
Yes, the Wyze Battery Cam Pro is completely wire-free and does not require any hubs or power outlets, allowing for flexible placement anywhere around your home or property.How does the Wyze Battery Cam Pro detect motion?
The Wyze Battery Cam Pro uses advanced Radar + PIR motion detection for precise and early alerts. You can customize detection zones in the Wyze app to focus on specific areas and reduce false alarms.Is the Wyze Battery Cam Pro weatherproof?
Yes, the Wyze Battery Cam Pro is rated IP65 for weather resistance, making it suitable for outdoor use in rain, dust, and extreme temperatures.What are the power options for the Wyze Battery Cam Pro?
The camera features removable, rechargeable battery packs that last up to six months on a single charge. You can also add the Wyze Solar Panel for continuous solar-powered operation.Can I use the Wyze Battery Cam Pro with both 2.4 GHz and 5 GHz Wi-Fi networks?
Yes, the Wyze Battery Cam Pro supports both 2.4 GHz and 5 GHz Wi-Fi networks for fast and reliable connectivity.How easy is it to set up the Wyze Battery Cam Pro?
Setup is quick and simple with instant Bluetooth pairing—no QR code scanning required. The camera also features enhanced two-way audio for easy communication.What is included in the Wyze Battery Cam Pro + Solar Panel bundle?
The Wyze Battery Cam Pro + Solar Panel bundle includes the camera and a weatherproof solar panel, providing continuous solar power for longer operation without manual charging.Does the Wyze Battery Cam Pro support local storage?
Yes, you can record motion events locally to a microSD card (sold separately) without needing a subscription.What smart features are available with the Wyze Battery Cam Pro?
With Cam Plus, the Wyze Battery Cam Pro offers advanced smart detections such as person, package, and vehicle notifications.What accessories are available for the Wyze Battery Cam Pro?
Available accessories include removable 6200mAh battery packs, a dual battery charging dock, and a universal mount (long) for flexible installation options.What is the Bird Feeder Wireless Camera Bundle?
The Bird Feeder Wireless Camera Bundle combines the Wyze Battery Cam Pro, Wyze Solar Panel, and a vibrant Wyze Bird Feeder, allowing you to enjoy live video and recordings of birds while securing your outdoor space.Is the Wyze Battery Cam Pro compatible with smart home systems?
Yes, the Wyze Battery Cam Pro is compatible with Alexa, Google Assistant, and IFTTT for seamless smart home integration.How long does the Wyze Battery Cam Pro battery last?
Each rechargeable battery pack can last up to six months on a single charge, depending on usage and environmental conditions.What makes the Wyze Battery Cam Pro a good choice for home surveillance?
The Wyze Battery Cam Pro offers a wide viewing angle, crisp 2.5K HDR video, integrated spotlight and siren, smart motion detection, weatherproof design, wireless installation, and optional solar power, making it a versatile and reliable home security solution.
