Wyze Battery Cam Pro: Easy-to-Move Camera for Rotating Home Coverage
Easy to Relocate Cameras for Rotating Coverage Around Your Home: Wyze Battery Cam Pro Series
If you're looking for a versatile, easy-to-move security camera that offers rotating coverage around your house, the Wyze Battery Cam Pro lineup is an excellent choice. These cameras are designed to be wire-free, weatherproof, and packed with smart features that make home monitoring effortless and flexible. Whether you want to keep an eye on your front porch, backyard, or any other spot, these cameras can be relocated quickly to cover every angle.
Wyze Battery Cam Pro: Wire-Free, High-Resolution Security Anywhere
Key Features and Benefits
  • 2.5K HDR Video Resolution: Crystal-clear 2560 x 1440 video quality ensures you never miss a detail.
  • Wire-Free Design: No hub required, making it easy to move the camera around your property.
  • Integrated Spotlight & Siren: Built-in spotlight and 100 dB siren enhance security and deter intruders.
  • Radar + PIR Motion Detection: Advanced motion sensors detect movement accurately, reducing false alerts.
  • Removable, Rechargeable Battery Packs: 6200mAh batteries last up to 6 months on a single charge, with quick 9-hour recharge time.
  • IP65 Weatherproof: Durable for outdoor use in rain, snow, or sun.
  • Dual-Band WiFi Support: Connects to both 2.4 GHz and 5 GHz networks for reliable streaming.
  • Wide Field of View: 134° diagonal, 108° horizontal, and 56° vertical coverage for broad monitoring.
  • Two-Way Audio: Communicate through the built-in speaker and microphone.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation.
  • Compact and Lightweight: Measures 2.5 x 1.8 x 3.5 inches and weighs just 0.94 lbs, making it easy to relocate.
Why It’s Perfect for Rotating Coverage
The Wyze Battery Cam Pro’s wire-free design and lightweight build allow you to easily move it from one location to another, providing flexible coverage around your home. Whether you want to monitor your driveway during the day and switch to the backyard at night, this camera adapts to your needs without complicated rewiring.
Wyze Battery Cam Pro + Solar Panel: Continuous Power for Extended Outdoor Use
Enhanced Features with Solar Power
  • All the features of the Wyze Battery Cam Pro, plus:
  • Solar Panel Included: Keeps your camera charged continuously, reducing the need to manually recharge batteries.
  • Color Night Vision: Thanks to the integrated spotlight and white LEDs, see clear color images even in low light.
  • Local and Cloud Storage: Supports up to 256 GB microSD cards and optional cloud recording with Cam Plus.
  • Same Weatherproof and Wireless Convenience: IP65 rating and dual-band WiFi ensure reliable outdoor performance.
Ideal for Long-Term Outdoor Monitoring
Pairing the Wyze Battery Cam Pro with the solar panel is perfect for users who want hassle-free, long-term outdoor surveillance without worrying about battery life. The solar panel keeps the camera powered, so you can maintain rotating coverage around your property without interruption.
Bird Feeder Wireless Camera Bundle: Watch Nature and Secure Your Home
What’s Included?
  • Wyze Battery Cam Pro (Black or White)
  • Wyze Bird Feeder with vibrant blue and orange design
  • Wyze Solar Panel for continuous power
Features
  • Birdwatching Made Easy: View and record live video of feathered visitors while securing your home.
  • Weather-Resistant and Wire-Free: Perfect for outdoor use in various weather conditions.
  • Macro Lens Adapter: Capture detailed close-ups of birds and surroundings.
  • Integrated Smart Camera: Same 2.5K HDR video, motion detection, and two-way audio as the Battery Cam Pro.
This bundle is a unique way to combine home security with nature observation, making it a great choice for bird lovers who want to keep an eye on their property.
Accessories to Maximize Your Wyze Battery Cam Pro Experience
Wyze Removable Battery Pack
  • Extra 6200mAh Rechargeable Battery: Extend your camera’s uptime by swapping batteries.
  • USB-C Charging Port: Convenient and fast charging.
  • Compact and Lightweight: Easy to carry and replace on the go.
  • Lasts Up to 6 Months: On a single charge, perfect for long-term use.
Wyze Battery Charging Dock
  • Charge Two Batteries Simultaneously: Keep multiple batteries ready for uninterrupted camera use.
  • Compact Design: Fits easily on any desk or shelf.
  • Includes Power Adapter and USB-A to USB-C Cable: Everything you need to start charging right away.
Why Choose Wyze Battery Cam Pro for Rotating Home Coverage?
"The Wyze Battery Cam Pro offers unmatched flexibility with its wire-free design, long-lasting battery, and high-quality video resolution. Its easy relocation capability means you can cover every corner of your home without hassle."
With its combination of portability, smart features, and weather resistance, the Wyze Battery Cam Pro series is the ideal solution for homeowners seeking rotating coverage around their property. Add solar power or extra batteries to keep your cameras running longer, and enjoy peace of mind knowing your home is protected from every angle.
Wyze Battery Cam Pro in Outdoor Setting Wyze Battery Cam Pro easily relocates for flexible home coverage Wyze Battery Cam Pro + Solar Panel Setup Solar panel keeps your Wyze Battery Cam Pro powered continuously Wyze Battery Cam Pro on Porch Compact and weatherproof design for outdoor use
By choosing Wyze Battery Cam Pro and its accessories, you get a smart, easy-to-relocate camera system that delivers rotating coverage and reliable security for your home.
Feature / ProductWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelBird Feeder Wireless Camera BundleWyze Removable Battery PackWyze Battery Charging Dock
Description2.5K HDR, Wire-Free, No Hub, Spotlight, Siren, Radar + PIR, Removable Battery, IP65, Dual-band WiFiSame as Battery Cam Pro + Wyze Solar Panel for continuous powerIncludes Wyze Bird Feeder, Wyze Battery Cam Pro, Wyze Solar Panel; birdwatching bundleReplacement 6200mAh rechargeable battery for Battery Cam Pro and Duo Cam DoorbellDual Battery Charging Dock, charges two batteries simultaneously
Video Resolution2.5K HDR (2560 x 1440)2.5K HDR (2560 x 1440)2.5K HDR (via Wyze Battery Cam Pro)N/AN/A
Power SourceRemovable rechargeable batteryBattery + Solar PanelBattery + Solar Panel (via included Battery Cam Pro & Solar Panel)Rechargeable battery packCharges battery packs
Battery CapacityIncluded battery pack (6200mAh)Included battery pack (6200mAh)Included battery pack (6200mAh)6200mAh Lithium Ion batteryN/A
WeatherproofIP65IP65IP65 (Bird Feeder and Camera)N/AN/A
Motion DetectionRadar + PIRRadar + PIRRadar + PIR (via Battery Cam Pro)N/AN/A
Spotlight & SirenYesYesYes (via Battery Cam Pro)N/AN/A
Wireless Connectivity2.4 & 5 GHz WiFi2.4 & 5 GHz WiFi2.4 & 5 GHz WiFi (via Battery Cam Pro)N/AN/A
Local RecordingYes (microSD card, not included)Yes (microSD card, not included)Yes (via Battery Cam Pro)N/AN/A
Included AccessoriesRemovable battery packRemovable battery pack + Solar PanelWyze Bird Feeder, Wyze Battery Cam Pro, Wyze Solar PanelN/AN/A
Dimensions2.5" x 1.8" x 3.5"Same as Battery Cam ProBird Feeder: 7.48" x 10.12" x 8.58"2.9" x 1.6" x 0.9"Charging Dock: 2.6" x 2" x 1"
Weight0.94 lb (camera only)Same as Battery Cam ProBird Feeder: 2.5 lb; Camera: 0.94 lb3.9 oz (110g)2.75 oz (78g)
Price$89.98 (1 pack)$109.98 (bundle)$139.98 (bundle)$22.99$17.99
Mounting OptionsWall, ceiling (with Universal Mount)Same as Battery Cam ProSame as Battery Cam ProN/AN/A
Charging TimeN/A (battery included)N/A (battery included)N/A~9 hours at 25°C~8.5 hours at 25°C
Additional FeaturesBluetooth setup, Two-way audio, Cam Plus subscription availableSame + continuous power via solar panelBird Feeder with macro lens adapter, Alexa/Google/IFTTT integrationUSB-C charging portCharges two batteries simultaneously
What makes the Wyze Battery Cam Pro ideal for rotating home security coverage?The Wyze Battery Cam Pro features a wire-free, compact, and lightweight design, making it easy to relocate around your property. Its weatherproof build and long-lasting rechargeable battery allow you to move the camera to different locations, such as your front porch, backyard, or driveway, for flexible and comprehensive home security coverage.
How long does the Wyze Battery Cam Pro battery last on a single charge?The Wyze Battery Cam Pro is equipped with a 6200mAh removable, rechargeable battery pack that can last up to 6 months on a single charge, depending on usage and environmental conditions.
Is the Wyze Battery Cam Pro weatherproof for outdoor use?Yes, the Wyze Battery Cam Pro has an IP65 weatherproof rating, making it suitable for outdoor use in rain, snow, or sunny conditions.
Does the Wyze Battery Cam Pro require a hub or wiring for installation?No, the Wyze Battery Cam Pro is completely wire-free and does not require a hub, making installation and relocation simple and hassle-free.
What video quality does the Wyze Battery Cam Pro offer?The Wyze Battery Cam Pro provides crystal-clear 2.5K HDR video resolution (2560 x 1440), ensuring you capture every detail in your surveillance footage.
Can the Wyze Battery Cam Pro connect to both 2.4 GHz and 5 GHz WiFi networks?Yes, the Wyze Battery Cam Pro supports dual-band WiFi, allowing it to connect to both 2.4 GHz and 5 GHz networks for reliable streaming and connectivity.
What smart features are included with the Wyze Battery Cam Pro?The Wyze Battery Cam Pro includes advanced features such as radar and PIR motion detection, integrated spotlight and 100 dB siren, two-way audio, and compatibility with Alexa, Google Assistant, and IFTTT for smart home integration.
How does the Wyze Battery Cam Pro + Solar Panel bundle benefit outdoor surveillance?The Wyze Battery Cam Pro + Solar Panel bundle provides continuous power to your camera, reducing the need for manual recharging. This setup is ideal for long-term outdoor monitoring, ensuring your camera stays powered and operational for uninterrupted security.
What storage options are available for the Wyze Battery Cam Pro?The Wyze Battery Cam Pro supports local storage with microSD cards up to 256 GB and offers optional cloud recording with the Cam Plus subscription for added flexibility.
What is included in the Wyze Bird Feeder Wireless Camera Bundle?The Wyze Bird Feeder Wireless Camera Bundle includes a Wyze Battery Cam Pro (available in black or white), a vibrant Wyze Bird Feeder, and a Wyze Solar Panel for continuous power. It also features a macro lens adapter for close-up birdwatching and all the smart security features of the Battery Cam Pro.
Are there accessories available to extend the Wyze Battery Cam Pro’s battery life?Yes, you can purchase additional 6200mAh removable battery packs and a Wyze Battery Charging Dock, which allows you to charge two batteries simultaneously for uninterrupted camera use.
Does the Wyze Battery Cam Pro offer color night vision?Yes, the Wyze Battery Cam Pro provides color night vision, thanks to its integrated spotlight and white LEDs, allowing you to see clear color images even in low-light conditions.
How wide is the field of view on the Wyze Battery Cam Pro?The Wyze Battery Cam Pro offers a wide field of view with 134° diagonal, 108° horizontal, and 56° vertical coverage, ensuring broad monitoring of your property.
Can I use the Wyze Battery Cam Pro for both home security and birdwatching?Yes, the Wyze Bird Feeder Wireless Camera Bundle allows you to enjoy birdwatching with live video and macro close-ups while also providing all the security features of the Wyze Battery Cam Pro for home monitoring.
What are the key features of the Wyze Battery Cam Pro?How does the solar panel enhance the functionality of the Wyze Battery Cam Pro?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Battery Cam Pro?
