Wyze Battery Cam Pro: Reliable Night Motion Sensor Camera
Reliable Motion Sensor Cameras for Nighttime Trespasser Detection
When it comes to securing your property against unwanted visitors at night, having a reliable motion sensor camera is essential. Wyze offers top-tier options designed to detect trespassers effectively, even in low-light conditions. Among these, the Wyze Battery Cam Pro and its solar-powered variant stand out for their advanced features, wire-free convenience, and robust night vision capabilities.
Wyze Battery Cam Pro: Advanced Nighttime Security Without Wires
Crisp 2.5K HDR Video Quality
The Wyze Battery Cam Pro delivers stunning 2.5K HDR video resolution (2560 x 1440), ensuring every detail is captured clearly. Whether it’s a shadowy figure or a suspicious movement, this camera provides sharp footage to help you identify trespassers with confidence.
Dual Radar + PIR Motion Detection
Equipped with both radar and passive infrared (PIR) sensors, the Wyze Battery Cam Pro offers superior motion detection accuracy. This combination reduces false alarms caused by pets or environmental factors, alerting you only when genuine human activity is detected.
Integrated Spotlight & Siren
For enhanced deterrence, the camera features a built-in spotlight and a 100 dB siren. When motion is detected, the spotlight illuminates the area in color night vision mode, while the siren can scare off intruders immediately.
Long-Lasting Battery & Weatherproof Design
Powered by removable, rechargeable 6200mAh battery packs, the camera can operate up to 6 months on a single charge. Its IP65 weatherproof rating means it withstands rain, snow, and dust, making it perfect for outdoor use in various climates.
Flexible Connectivity & Smart Home Integration
Supporting both 2.4 GHz and 5 GHz WiFi bands, the camera ensures stable connections. It integrates seamlessly with Alexa, Google Assistant, and IFTTT, allowing you to control and automate your security setup effortlessly.
Compact & Easy Installation
With a lightweight design (0.94 lbs) and standard 1/4” - 20 mounting options, installation is quick and versatile. The included wall mount makes positioning the camera in optimal locations hassle-free.
"Wyze Battery Cam Pro combines high-resolution video, smart motion detection, and long battery life to provide reliable night surveillance without the need for wiring or hubs."
Outdoor security camera mounted on house exterior at dusk Wyze Battery Cam Pro securing home exterior at night
Wyze Battery Cam Pro + Solar Panel: Continuous Power for Uninterrupted Security
Solar-Powered Convenience
The Wyze Battery Cam Pro + Solar Panel bundle offers the same powerful features as the standard Battery Cam Pro but adds a solar panel for continuous charging. This setup is ideal for locations where frequent battery recharging is inconvenient.
All the Features You Expect
  • 2.5K HDR video resolution
  • Radar + PIR motion detection
  • Integrated spotlight and siren
  • Color night vision with 2 IR and 2 white LEDs
  • IP65 weatherproof rating
Extended Battery Life with Solar Support
The solar panel keeps the rechargeable battery topped off, reducing downtime and ensuring your camera remains active even during extended periods of motion activity or adverse weather.
"Harness the power of the sun to keep your Wyze Battery Cam Pro running 24/7, providing peace of mind with minimal maintenance."
Wyze Cam v4: Indoor and Budget-Friendly Option
High-Quality Video and Night Vision
The Wyze Cam v4 offers 2.5K QHD video resolution with color night vision supported by 4 IR LEDs and 2 white spotlight LEDs. It’s a great choice for indoor or covered outdoor areas where wired power is available.
Motion Detection and Smart Features
This camera includes wide dynamic range, 8x digital zoom, and a built-in siren. It supports two-way audio and integrates with Alexa, Google Assistant, and IFTTT for smart home compatibility.
Weather Resistance and Mounting Flexibility
Rated IP65 for weather resistance, the Wyze Cam v4 can be used outdoors with the appropriate power adapter. Multiple mounting options, including magnetic mounts, make it easy to position.
"Wyze Cam v4 is a versatile, affordable camera that balances quality and smart features for indoor or sheltered outdoor security."
Why Choose Wyze for Nighttime Trespasser Detection?
  • Superior Night Vision: Color night vision with powerful LEDs ensures clear images even in complete darkness.
  • Accurate Motion Detection: Radar + PIR sensors minimize false alarms and detect human movement reliably.
  • Wireless Freedom: Battery-powered options eliminate the need for complicated wiring or hubs.
  • Weatherproof Durability: IP65-rated cameras withstand harsh outdoor conditions year-round.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for seamless automation.
  • Long Battery Life: Up to 6 months on a single charge, extendable with solar power.
Summary of Wyze Motion Sensor Cameras for Night Security
ProductVideo ResolutionPower SourceMotion DetectionNight Vision TypeWeatherproofSpecial Features
Wyze Battery Cam Pro2.5K HDRRechargeable Battery PacksRadar + PIRColor Night VisionIP65Integrated Spotlight & Siren
Wyze Battery Cam Pro + Solar2.5K HDRBattery + Solar PanelRadar + PIRColor Night VisionIP65Continuous Solar Charging
Wyze Cam v42.5K QHDWired Power AdapterPIRColor Night VisionIP65Multiple Mounting Options
Protect your home or business with Wyze’s reliable motion sensor cameras designed for effective nighttime trespasser detection. Whether you prefer the wire-free convenience of the Battery Cam Pro or the continuous power of the solar bundle, Wyze has you covered with smart, durable, and high-quality security solutions.
FeatureWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelWyze Cam v4
Video Resolution2.5K HDR2.5K HDR2.5K QHD (2560x1440)
Power SourceBattery (Removable, Rechargeable)Battery + Solar PanelWired (Indoor USB Power Adapter)
Wireless Connectivity2.4 & 5 GHz WiFi2.4 & 5 GHz WiFi2.4 GHz Wi-Fi, Wi-Fi 6
Hub RequiredNoNoNo
Integrated Spotlight & SirenYes (150 lumens LED, motion-activated)Yes (150 lumens LED, motion-activated)Yes (motion-activated spotlight, 72 lumens)
Motion DetectionRadar + PIR Motion DetectionRadar + PIR Motion DetectionYes (with motion detection zones)
Weatherproof RatingIP65IP65IP65
Local StorageMicroSD card (optional)MicroSD card (optional)MicroSD card up to 512 GB
Cloud StorageOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional subscription plan
Night VisionColor Night VisionColor Night VisionEnhanced Color Night Vision
Two-Way AudioYesYesYes
Bluetooth SetupYesYesYes (Bluetooth 5.2)
DimensionsNot specifiedNot specified2in x 2in x 2 3/8in
WeightNot specifiedNot specified0.49 lb (222 g)
Mounting OptionsFlexible, includes ceiling mount optionFlexible, includes ceiling mount optionStand, Wall mount, Ceiling mount, Magnetic
Price (Single Unit)$89.98$109.98$100.00
Additional FeaturesRemovable battery packs, radar + PIR sensorsSolar panel for continuous powerWi-Fi 6 support, Alexa & Google Assistant
What makes Wyze motion sensor cameras effective for nighttime trespasser detection?Wyze motion sensor cameras are equipped with advanced features such as 2.5K HDR video resolution, radar + PIR motion detection, and color night vision with powerful LEDs. These features ensure clear footage and accurate detection of human movement, even in complete darkness, making them highly effective for nighttime trespasser detection.
How does the Wyze Battery Cam Pro detect motion at night?The Wyze Battery Cam Pro uses a combination of radar and passive infrared (PIR) sensors to accurately detect motion. This dual-sensor system minimizes false alarms from pets or environmental factors and ensures that only genuine human activity triggers alerts, even in low-light conditions.
What is the video quality of Wyze Battery Cam Pro and Wyze Cam v4?Both the Wyze Battery Cam Pro and Wyze Cam v4 offer high-resolution video. The Battery Cam Pro provides 2.5K HDR (2560 x 1440) video quality, while the Wyze Cam v4 delivers 2.5K QHD resolution. This ensures crisp, detailed footage for identifying trespassers.
Can Wyze motion sensor cameras be used outdoors?Yes, Wyze motion sensor cameras such as the Battery Cam Pro, Battery Cam Pro + Solar, and Wyze Cam v4 are rated IP65 for weather resistance. This means they can withstand rain, snow, and dust, making them suitable for outdoor use in various climates.
How long does the Wyze Battery Cam Pro battery last?The Wyze Battery Cam Pro is powered by removable, rechargeable 6200mAh battery packs and can operate for up to 6 months on a single charge, depending on usage and environmental conditions.
What are the benefits of the Wyze Battery Cam Pro + Solar Panel bundle?The Wyze Battery Cam Pro + Solar Panel bundle offers continuous charging through solar power, reducing the need for manual battery recharging. This setup ensures uninterrupted security, especially in locations where frequent battery changes are inconvenient.
Does the Wyze Battery Cam Pro have a built-in siren and spotlight?Yes, the Wyze Battery Cam Pro features an integrated 100 dB siren and a built-in spotlight. The spotlight provides color night vision, and the siren can be activated to deter intruders when motion is detected.
Are Wyze cameras compatible with smart home systems?Wyze cameras integrate seamlessly with popular smart home platforms, including Alexa, Google Assistant, and IFTTT. This allows for easy control and automation of your security system.
Is the Wyze Cam v4 suitable for outdoor use?The Wyze Cam v4 is IP65 weather-resistant and can be used outdoors when paired with the appropriate power adapter. It is ideal for indoor or covered outdoor areas where wired power is available.
What mounting options are available for Wyze cameras?Wyze cameras offer flexible mounting options. The Battery Cam Pro includes a standard wall mount and supports 1/4” - 20 mounting, while the Wyze Cam v4 features multiple mounting options, including magnetic mounts, for easy installation in optimal locations.
What is the difference between Wyze Battery Cam Pro and Wyze Cam v4?The Wyze Battery Cam Pro is a wire-free, battery-powered camera with radar + PIR motion detection, integrated spotlight and siren, and is ideal for outdoor use. The Wyze Cam v4 is a budget-friendly, wired camera suitable for indoor or sheltered outdoor areas, offering PIR motion detection, color night vision, and multiple mounting options.
How does color night vision work on Wyze cameras?Wyze cameras use a combination of infrared (IR) and white LEDs to provide color night vision. This technology allows the cameras to capture clear, full-color images even in low-light or nighttime conditions, enhancing the ability to identify trespassers.
What are the key features of the Wyze Battery Cam Pro?How does the motion detection work in the Wyze Battery Cam Pro?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Battery Cam Pro?
