Upgrade Your Home with the Refurbished Wyze Lock Bolt Smart Lock
Transform your traditional deadbolt into a cutting-edge smart lock with the
Wyze Lock Bolt. Designed as a retrofit solution, this Bluetooth-enabled smart lock offers seamless integration with your existing door hardware, providing advanced features like ultra-fast fingerprint access, auto-locking, and app control. Perfect for smart home enthusiasts looking to enhance security and convenience without replacing the entire door system.
Wyze Lock Bolt: The Ultimate Smart Lock Retrofit for Deadbolts
Key Features and Benefits
- Ultra-Fast Fingerprint Sensor: Unlock your door instantly with a quick fingerprint scan, eliminating the need for keys or codes.
- Backlit Keypad with Anti-Peep Technology: Enter your access code discreetly even in low light, with a keypad designed to prevent code peeking.
- Auto-Lock Function: Never worry about forgetting to lock your door again; the Wyze Lock Bolt automatically locks after a set time.
- Replaces Existing Deadbolt: Easily retrofit your current deadbolt without complicated installation or door modifications.
- Built-in Jam Detection Alarm: Alerts you immediately if the lock mechanism is jammed or tampered with.
- Emergency One-Time Codes: Share temporary access with guests or service providers securely via the Wyze app.
- Bluetooth 5.0 Connectivity: Reliable wireless communication with a range of up to 16 feet.
- Weather Resistant (IPX5): Durable enough to withstand outdoor conditions, operating in temperatures from -13°F to 122°F.
Specifications
- Color Options: Matte Black, Satin Nickel
- Power Source: 4x AA Batteries (included) with 10-12 months battery life
- Door Compatibility: Fits doors 1-3/8” to 1-3/4” thick, with backset options of 2-3/8” or 2-3/4”
- Deadbolt Diameter: 1”
- Weight: 2.75 lbs
Experience the convenience of keyless entry combined with robust security features, all controlled from your smartphone or fingerprint.
Secure your front door with Wyze Lock Bolt smart lock
Enhance Your Smart Home with Wyze Lock Bolt Replacement Parts
To keep your Wyze Lock Bolt functioning flawlessly, Wyze offers a range of replacement parts designed specifically for this smart lock:
Wyze Lock Bolt Screws
- Replacement set of screws compatible with Wyze Lock Bolt.
- Affordable and easy to install.
- 30-day hassle-free return policy.
Wyze Lock Bolt Interior Assembly Battery Cover
- Replacement battery cover for the interior assembly.
- Ensures your lock’s battery compartment stays protected.
- 30-day hassle-free returns.
Wyze Lock Replacement Part Kit
- Includes essential parts for repair or maintenance.
- Available as a Replacement Part Kit or Adapter Replacement Kit.
- Compatible only with Wyze Lock.
Wyze Lock Bolt Interior Assembly Metal Plate
- Metal plate to securely anchor the interior assembly to your door.
- Available in multiple quantities.
These parts ensure your smart lock remains reliable and easy to maintain, extending the life of your smart home upgrade.
Complete Your Smart Home Security with The Front Porch Security Bundle
For a comprehensive smart home upgrade, consider the
Front Porch Security Bundle which pairs the Wyze Lock Bolt with Wyze’s smart video doorbells and chimes:
- Wyze Video Doorbell: View your front porch in crisp 1080p HD with two-way audio.
- Remote Lock/Unlock: Control your door lock remotely and monitor lock history via the Wyze app.
- Motion Detection & Alerts: Stay informed with real-time notifications of porch activity.
- Voice Assistant Compatibility: Works seamlessly with Alexa and Google Assistant.
This bundle offers an all-in-one solution for front door security and convenience, perfect for busy households and smart home aficionados.
Control your Wyze Lock Bolt effortlessly via the Wyze app
Why Choose a Refurbished Wyze Lock Bolt?
Opting for a refurbished Wyze Lock Bolt is a smart choice for budget-conscious homeowners who want premium smart lock features without the premium price tag. Each refurbished unit undergoes rigorous testing to ensure it meets Wyze’s high standards for performance and reliability.
Upgrade your home security with a trusted smart lock that offers fingerprint access, auto-locking, and seamless app integration — all while being eco-friendly and cost-effective.
Summary
The
Wyze Lock Bolt is the perfect smart lock retrofit for deadbolts, offering:
- Keyless fingerprint and keypad access
- Auto-locking for peace of mind
- Easy installation replacing your existing deadbolt
- Long battery life and weather resistance
- Compatible replacement parts for maintenance
- Integration with Wyze’s smart home ecosystem
Upgrade your home today with the Wyze Lock Bolt and enjoy the convenience and security of a modern smart lock system.
What is the Wyze Lock Bolt and how does it work?
The Wyze Lock Bolt is a Bluetooth-enabled smart lock designed to retrofit your existing deadbolt. It offers keyless entry through an ultra-fast fingerprint sensor, a backlit anti-peep keypad, and app control. The lock is easy to install, replacing your current deadbolt without complicated modifications, and provides enhanced security and convenience for your home.What are the key features of the Wyze Lock Bolt smart lock?
Key features of the Wyze Lock Bolt include an ultra-fast fingerprint sensor, backlit keypad with anti-peep technology, auto-lock function, built-in jam detection alarm, emergency one-time codes, Bluetooth 5.0 connectivity, and weather resistance (IPX5). It is designed for easy installation and seamless integration with your existing door hardware.Is the Wyze Lock Bolt compatible with my door?
The Wyze Lock Bolt fits doors that are 1-3/8” to 1-3/4” thick and supports backset options of 2-3/8” or 2-3/4”. It replaces standard deadbolts with a 1” diameter, making it compatible with most residential doors.How is the Wyze Lock Bolt powered and how long does the battery last?
The Wyze Lock Bolt is powered by 4 AA batteries, which are included with your purchase. The battery life typically lasts between 10 to 12 months, depending on usage.What color options are available for the Wyze Lock Bolt?
The Wyze Lock Bolt is available in two color options: Matte Black and Satin Nickel, allowing you to choose the finish that best matches your door hardware.What replacement parts are available for the Wyze Lock Bolt?
Wyze offers several replacement parts for the Lock Bolt, including screws, an interior assembly battery cover, a metal plate for the interior assembly, and a replacement part kit. These parts are designed to keep your smart lock functioning reliably and are backed by a 30-day hassle-free return policy.What is the Front Porch Security Bundle and what does it include?
The Front Porch Security Bundle combines the Wyze Lock Bolt with Wyze’s smart video doorbells and chimes. It includes a Wyze Video Doorbell with 1080p HD video and two-way audio, remote lock/unlock capabilities, motion detection and alerts, and compatibility with Alexa and Google Assistant for a comprehensive smart home security solution.Why should I choose a refurbished Wyze Lock Bolt?
A refurbished Wyze Lock Bolt offers all the premium features of a new smart lock at a more affordable price. Each refurbished unit undergoes rigorous testing to ensure high performance and reliability, making it a cost-effective and eco-friendly choice for upgrading your home security.Does the Wyze Lock Bolt work with voice assistants?
Yes, the Wyze Lock Bolt is compatible with popular voice assistants such as Alexa and Google Assistant, allowing you to control your lock and monitor your front door with voice commands.How does the Wyze Lock Bolt enhance home security?
The Wyze Lock Bolt enhances home security with features like fingerprint access, auto-locking, anti-peep keypad, jam detection alarm, and the ability to share one-time access codes securely via the Wyze app. It also integrates with Wyze’s smart home ecosystem for comprehensive security management.
