Buy Refurbished Wyze Lock with Gateway for Indoor Smart Door
Upgrade your indoor door security with the Wyze Lock Bolt and its smart gateway system. Designed for seamless integration into your connected home, this refurbished smart lock solution offers convenience, safety, and smart automation at an affordable price. Whether you want keyless entry, remote access, or enhanced security features, the Wyze Lock Bolt with Gateway is the perfect choice for indoor smart door management.
Wyze Lock Bolt: Advanced Smart Lock Features
The Wyze Lock Bolt is a Bluetooth-enabled smart lock that replaces your existing deadbolt with a sleek, modern design and cutting-edge technology.
Key Specifications:
- Ultra-Fast Fingerprint Sensor: Unlock your door instantly with a quick fingerprint scan.
- Backlit Keypad with Anti-Peep: Enter your code securely even in low light, with protection against prying eyes.
- Auto-Lock Function: Automatically locks your door if you forget, ensuring your home stays secure.
- Lock and Unlock History: Track access events directly from the Wyze app.
- Built-in Jam Detection Alarm: Alerts you if the lock mechanism is jammed or tampered with.
- Emergency One-Time Codes: Provide temporary access to guests or service personnel.
- Power Source: 4x AA batteries included, lasting 10-12 months.
- Communication: Bluetooth 5.0 with a 16 ft range.
- Weather Resistance: Rated IPX5, suitable for indoor use withstanding typical temperature ranges.
- Door Compatibility: Fits standard deadbolts with backset options of 2-3/8” or 2-3/4” and door thickness from 1-3/8” to 1-3/4”.
Available in elegant
Matte Black and
Satin Nickel finishes, the Wyze Lock Bolt blends style with functionality.
Say goodbye to fumbling with keys and enjoy the luxury of quick, secure access with just a tap or fingerprint.
Experience smart home security with Wyze Lock Bolt on your front door.
Wyze Lock Bolt with Gateway: Complete Indoor Smart Door Solution
For enhanced connectivity and remote control, the Wyze Lock Bolt can be paired with the Wyze Lock Gateway, creating a powerful indoor smart door system.
What’s Included in the Bundle:
- Wyze Lock Bolt (Matte Black or Satin Nickel)
- Wyze Lock Gateway (White)
- Batteries (4x AA for lock, 2x AA for keypad)
- Mounting accessories and adapters
- Quick Start Guide
Gateway Features:
- Extended Range: Gateway extends lock communication up to 50 feet, allowing remote lock/unlock via WiFi.
- Multi-Protocol Communication: Supports Bluetooth, Zigbee, and WiFi for reliable connectivity.
- Indoor Use: Designed specifically for indoor environments with IPX5 weather resistance.
- Compatibility: Works with Android 5.0+ and iOS 9.0+ devices.
- Smart Home Integration: Compatible with Alexa and Google Assistant for voice control.
Lock Features in the Bundle:
- Lock/unlock your door remotely from anywhere.
- View lock history and motion events in the Wyze app.
- Receive notifications for door activity.
- Indoor-only design ensures optimal performance and security.
This bundle is ideal for those seeking a comprehensive smart door solution with remote access and real-time monitoring.
Control your indoor smart door effortlessly with Wyze Lock Bolt and Gateway.
Replacement Parts for Wyze Lock Bolt
Maintain your Wyze Lock Bolt with genuine replacement parts designed for easy installation and compatibility.
Available Replacement Parts:
- Wyze Lock Replacement Part Kit: Includes essential components to keep your lock functioning smoothly.
- Wyze Lock Bolt Interior Assembly Battery Cover: Protects the battery compartment inside the lock.
- Wyze Lock Bolt Interior Assembly Metal Plate: Anchors the interior assembly securely to your door.
- Wyze Lock Bolt Screws: Replacement screws set for mounting and assembly.
All replacement parts come with a 30-day hassle-free return policy, ensuring peace of mind.
Why Choose Refurbished Wyze Lock Bolt with Gateway?
- Cost-Effective: Get premium smart lock features at a fraction of the price.
- Certified Quality: Refurbished units are tested and restored to meet high standards.
- Eco-Friendly: Reduce electronic waste by choosing refurbished smart home devices.
- Smart Home Ready: Easily integrates with your existing Wyze ecosystem and smart assistants.
Conclusion
The refurbished Wyze Lock Bolt with Gateway is the ultimate indoor smart door solution for anyone looking to enhance home security with modern technology. Enjoy keyless entry, remote control, and smart automation all in one affordable package. With reliable Bluetooth and Zigbee communication, long battery life, and a sleek design, this smart lock bundle is perfect for your connected home.
Upgrade your indoor door security today with Wyze Lock Bolt and Gateway — smart, secure, and simple.
Product Tags Summary
What is included with the refurbished Wyze Lock Bolt with Gateway bundle?
The refurbished Wyze Lock Bolt with Gateway bundle includes the Wyze Lock Bolt (available in Matte Black or Satin Nickel), Wyze Lock Gateway (White), 4x AA batteries for the lock, 2x AA batteries for the keypad, mounting accessories and adapters, and a Quick Start Guide.What are the key features of the Wyze Lock Bolt?
The Wyze Lock Bolt features an ultra-fast fingerprint sensor, backlit keypad with anti-peep technology, auto-lock function, lock and unlock history tracking, built-in jam detection alarm, emergency one-time codes, and is powered by 4x AA batteries lasting 10-12 months. It communicates via Bluetooth 5.0 and is rated IPX5 for indoor weather resistance.How does the Wyze Lock Gateway enhance the smart lock experience?
The Wyze Lock Gateway extends the lock's communication range up to 50 feet and enables remote lock and unlock functionality via WiFi. It supports Bluetooth, Zigbee, and WiFi protocols, and allows integration with Alexa and Google Assistant for voice control.Is the Wyze Lock Bolt with Gateway suitable for outdoor use?
No, the Wyze Lock Bolt with Gateway is designed specifically for indoor use. It has an IPX5 weather resistance rating, which is suitable for typical indoor environments.What door types are compatible with the Wyze Lock Bolt?
The Wyze Lock Bolt fits standard deadbolts with backset options of 2-3/8” or 2-3/4” and door thicknesses from 1-3/8” to 1-3/4”.Can I control the Wyze Lock Bolt remotely?
Yes, when paired with the Wyze Lock Gateway, you can lock and unlock your door remotely from anywhere using the Wyze app.Does the Wyze Lock Bolt support smart home integration?
Yes, the Wyze Lock Bolt with Gateway is compatible with Alexa and Google Assistant, allowing for voice control and integration into your smart home ecosystem.What replacement parts are available for the Wyze Lock Bolt?
Available replacement parts for the Wyze Lock Bolt include the Wyze Lock Replacement Part Kit, Interior Assembly Battery Cover, Interior Assembly Metal Plate, and replacement screws. All parts come with a 30-day hassle-free return policy.Why should I choose a refurbished Wyze Lock Bolt with Gateway?
Choosing a refurbished Wyze Lock Bolt with Gateway is cost-effective, eco-friendly, and ensures certified quality. Refurbished units are tested and restored to meet high standards, offering premium smart lock features at a lower price while reducing electronic waste.How long do the batteries last in the Wyze Lock Bolt?
The Wyze Lock Bolt is powered by 4x AA batteries, which typically last between 10 to 12 months under normal usage.What mobile devices are compatible with the Wyze Lock Bolt and Gateway?
The Wyze Lock Bolt and Gateway are compatible with Android devices running version 5.0 or higher and iOS devices running version 9.0 or higher.
