Bluetooth Smart Locks: Secure Keyless Entry & Visitor Tracking
Bluetooth Smart Lock for Secure Keyless Entry and Visitor Tracking
Upgrade your home security with advanced Bluetooth smart locks designed for seamless keyless entry and comprehensive visitor tracking. These smart locks not only provide ultra-fast access but also integrate with mobile apps to keep you informed about who enters your home and when. Explore the top solutions that combine convenience, security, and smart technology for your front door.
Wyze Lock Bolt: Ultra-Fast Bluetooth Smart Lock
Key Features and Benefits
- Instant Keyless Entry: Unlock your door in less than a second using the ultra-fast fingerprint sensor or the backlit keypad with anti-peep technology.
- Bluetooth 5.0 Connectivity: Reliable wireless communication up to 16 feet ensures smooth operation with your smartphone.
- Auto-Lock Function: Never worry about forgetting to lock your door; the Wyze Lock Bolt automatically locks after a set time.
- Visitor Tracking: View lock and unlock history directly in the Wyze app to monitor who accessed your home and when.
- Built-in Alarm: Detects jam attempts and alerts you immediately for enhanced security.
- Emergency One-Time Codes: Provide temporary access to visitors or service personnel without sharing permanent codes.
- Weather Resistant: Rated IPX5, suitable for various climates with operating temperatures from -13°F to 122°F.
- Easy Installation: Replaces your existing deadbolt with compatibility for standard door thicknesses and backsets.
Specifications
- Power Source: 4x AA batteries (included) with 10-12 months battery life.
- Weight: 2.75 lbs
- Color Options: Matte Black, Satin Nickel
- Door Compatibility: Fits doors 1-3/8” to 1-3/4” thick, with 2-3/8” or 2-3/4” backset.
- Deadbolt Diameter: 1”
Experience the perfect blend of security and convenience with the Wyze Lock Bolt, designed to keep your home safe while simplifying your daily routine.
Wyze Lock Bolt installed on a front door for secure keyless entry
The Front Porch Security Bundle: Complete Smart Home Access Management
Comprehensive Security with Smart Lock and Video Doorbell
- Integrated System: Combines the Wyze Lock with Wyze Video Doorbell and Chime for a full front porch security solution.
- Remote Lock/Unlock: Control your door lock from anywhere using the Wyze app, perfect for letting in guests or service providers remotely.
- Visitor Monitoring: View your front porch in crisp 1080p HD video with two-way audio to greet visitors or deter unwanted guests.
- Lock History & Motion Events: Track all lock activity and porch motion events in one app for complete peace of mind.
- Voice Assistant Compatible: Works seamlessly with Alexa and Google Assistant for hands-free control.
- Weather Resistant Components: Video doorbell rated IP65 for outdoor durability; lock designed for indoor use.
Bundle Includes
- Wyze Lock
- Wyze Lock Gateway
- Wyze Video Doorbell and Chime
- Batteries, mounting hardware, and quick start guides
Technical Highlights
- Wyze Lock Battery Life: 5-6 months depending on usage.
- Communication: Bluetooth and Zigbee for lock; WiFi for video doorbell.
- Video Doorbell Specs: 2K sensor, 120° vertical x 88° horizontal field of view, night vision with infrared LEDs.
- Operating Temperatures: Lock (14°F to 131°F), Doorbell (-4°F to 122°F).
This bundle is ideal for homeowners seeking a smart, connected solution that combines secure keyless entry with real-time visitor tracking and video monitoring.
Control your Wyze Lock Bolt remotely via smartphone app for secure access management
Replacement Parts for Wyze Lock Bolt
Maintain your smart lock’s performance with genuine replacement parts designed specifically for the Wyze Lock Bolt:
- Wyze Lock Bolt Screws: Affordable set of screws for secure installation or replacement.
- Interior Assembly Battery Cover: Protects the battery compartment inside the lock.
- Interior Assembly Metal Plate: Anchors the interior assembly firmly to your door.
- Wyze Lock Replacement Part Kit: Includes essential components for repair or upgrade.
All parts come with a 30-day hassle-free return policy, ensuring your smart lock stays in top condition.
Why Choose Bluetooth Smart Locks for Your Home?
Bluetooth smart locks like the Wyze Lock Bolt offer a perfect balance of security, convenience, and smart home integration. With ultra-fast fingerprint access, app-based visitor tracking, and automatic locking features, you can enjoy peace of mind knowing your home is protected without fumbling for keys.
Embrace the future of home security with smart locks that provide secure keyless entry and detailed visitor tracking, all controlled effortlessly from your smartphone.
Summary of Featured Products
Feature | Wyze Lock Bolt | The Front Porch Security Bundle |
Product Type | Bluetooth Smart Lock | Security Bundle (Lock + Video Doorbell + Chime + Cameras) |
Price | $79.98 | $123.99 - $173.97 (varies by variant) |
Keyless Entry | Yes (Fingerprint sensor & backlit keypad) | Yes (Includes Wyze Lock Bolt) |
Fingerprint Reader | Ultra-fast fingerprint sensor | Included (Wyze Lock Bolt) |
Backlit Keypad | Yes | Included (Wyze Lock Bolt) |
Auto-lock Feature | Yes | Included (Wyze Lock Bolt) |
App Control | Yes (Bluetooth connection required) | Yes (Remote lock/unlock, lock history, doorbell video) |
Lock History | Yes | Yes |
Access Codes | Up to 20 access codes | Included (Wyze Lock Bolt) |
Fingerprints Stored | Up to 50 fingerprints | Included (Wyze Lock Bolt) |
Emergency One-Time Codes | Yes | Included (Wyze Lock Bolt) |
Anti-Peep Technology | Yes | Included (Wyze Lock Bolt) |
Weatherproof Rating | IPX5 | Lock: IPX5; Doorbell: varies by model |
Battery Life | Up to 12 months (4 AA batteries) | Lock: Up to 12 months; Doorbell and Chime battery life varies |
Installation Time | About 20 minutes | Lock installation + doorbell setup |
Door Compatibility | Most exterior doors | Lock compatible with most doors |
Included Devices | Wyze Lock Bolt only | Wyze Lock Bolt + Wyze Video Doorbell + Chime (varies by variant) |
Video Doorbell Resolution | N/A | 1080p HD (Wyze Video Doorbell) |
Two-Way Audio | N/A | Yes (Video Doorbell and Chime) |
Remote Lock/Unlock | Yes (via Wyze app within Bluetooth range) | Yes (via Wyze app, including from doorbell viewer) |
Locking Method | Fingerprint, keypad, app, one-touch lock button | Same as Wyze Lock Bolt |
Additional Cameras Included | No | No (except some variants include Wyze Cam V3) |
Integration with Video Doorbell | N/A | Yes, lock/unlock from doorbell viewer |
Warranty | Standard Wyze warranty | Standard Wyze warranty |
What is a Bluetooth smart lock and how does it enhance home security?
A Bluetooth smart lock is an advanced door lock that uses Bluetooth technology to enable secure, keyless entry. It enhances home security by allowing you to unlock your door with your smartphone, fingerprint, or keypad, and provides features like visitor tracking, auto-locking, and real-time alerts for unauthorized access attempts.How does the Wyze Lock Bolt provide keyless entry?
The Wyze Lock Bolt offers instant keyless entry through an ultra-fast fingerprint sensor or a backlit keypad with anti-peep technology. This allows you to unlock your door in less than a second without needing physical keys.Can I track who enters my home with the Wyze Lock Bolt?
Yes, the Wyze Lock Bolt features comprehensive visitor tracking. You can view the lock and unlock history directly in the Wyze app, allowing you to monitor who accessed your home and when.What is included in the Front Porch Security Bundle?
The Front Porch Security Bundle includes a Wyze Lock, Wyze Lock Gateway, Wyze Video Doorbell and Chime, batteries, mounting hardware, and quick start guides. This bundle provides a complete smart home access management solution with both keyless entry and video monitoring.Can I control the Wyze Lock remotely?
Yes, with the Wyze app, you can control your Wyze Lock remotely. This allows you to lock or unlock your door from anywhere, making it easy to let in guests or service providers even when you’re not home.Is the Wyze Lock Bolt weather resistant?
Yes, the Wyze Lock Bolt is rated IPX5 for weather resistance and operates in temperatures ranging from -13°F to 122°F, making it suitable for various climates.How long does the battery last on the Wyze Lock Bolt?
The Wyze Lock Bolt is powered by 4 AA batteries, which provide a battery life of 10-12 months under normal usage.What visitor tracking features are available with Wyze smart locks?
Wyze smart locks offer detailed visitor tracking through the Wyze app, where you can view lock and unlock history, receive alerts for jam attempts, and monitor all access events for enhanced security.Are there replacement parts available for the Wyze Lock Bolt?
Yes, genuine replacement parts for the Wyze Lock Bolt are available, including screws, interior assembly battery covers, metal plates, and a complete replacement part kit. All parts come with a 30-day hassle-free return policy.Is the Wyze Lock Bolt easy to install?
Yes, the Wyze Lock Bolt is designed for easy installation and is compatible with standard door thicknesses (1-3/8” to 1-3/4”) and backsets (2-3/8” or 2-3/4”). It replaces your existing deadbolt without the need for professional installation.Does the Wyze Lock Bolt work with voice assistants?
The Wyze Lock (included in the Front Porch Security Bundle) is compatible with Alexa and Google Assistant, allowing for hands-free control. The Wyze Lock Bolt itself is primarily controlled via Bluetooth and the Wyze app.What security features does the Wyze Lock Bolt offer?
The Wyze Lock Bolt includes a built-in alarm to detect jam attempts, anti-peep technology on the keypad, auto-lock functionality, and the ability to generate emergency one-time codes for temporary access.What are the video capabilities of the Wyze Video Doorbell included in the bundle?
The Wyze Video Doorbell features a 2K sensor, 120° vertical by 88° horizontal field of view, and night vision with infrared LEDs, providing clear video monitoring of your front porch day or night.
What are the key features of the Wyze Lock Bolt?How does the visitor tracking feature work with the Wyze Lock?Are there any discounts or promotions currently available for the Wyze Lock?
