Quiet, Energy-Efficient Refurbished Air Purifier for Living Rooms
Quiet and Energy Efficient Refurbished Air Purifier for Your Living Room
When it comes to maintaining a fresh and healthy living room environment, a quiet and energy-efficient air purifier is essential. The (Refurbished) Wyze Air Purifier offers an excellent balance of performance, smart features, and whisper-quiet operation, making it an ideal choice for living rooms where peace and clean air go hand in hand.
(Refurbished) Wyze Air Purifier: Premium Performance at a Great Value
Whisper-Quiet Operation
Operating at just 21 decibels, the refurbished Wyze Air Purifier is quieter than a purring kitten, ensuring it won’t disturb your relaxation, conversations, or sleep. This ultra-quiet performance makes it perfect for living rooms where noise can be a distraction.
Powerful Air Cleaning
With a Clean Air Delivery Rate (CADR) of 350, it cycles through up to 12,000 cubic feet of air every hour, effectively purifying spaces up to 550 sq. ft (42 m²). This means your living room air stays fresh and free from allergens, dust, and pollutants.
Smart Controls and Air Quality Alerts
Equipped with smart controls, laser particle detection, and real-time air quality alerts, this purifier keeps you informed and in control. Compatible with Alexa and Google Home, you can adjust settings effortlessly via voice commands or the Wyze app.
Certified and Reliable
CARB certified for safety and efficiency, the refurbished model comes with premium filters and a recommended filter replacement every 6 months, ensuring long-lasting clean air without the luxury price tag.
Customize Your Air with Wyze Air Filters
Tailored Filtration for Your Needs
The Wyze Air Purifier supports three types of custom filters to address specific air quality concerns:
  • Allergen Filter (Standard): Combines a Pre-Filter, HEPA 13, and granulated carbon to capture common allergens and odors.
  • Formaldehyde Filter (Premium): Includes True HEPA 12 and activated manganese carbon to destroy heavy odors and harmful chemicals like formaldehyde, common in new furniture and construction materials.
  • Wildfire Filter (Special Use): Designed to absorb pollutants from wildfire smoke with chemically modified granulated carbon and HEPA 12.
Easy Filter Replacement
Changing filters is simple and quick, so maintaining optimal air quality is hassle-free. Filters typically last between 4 to 12 months depending on usage and filter type.
"You don't drink the same drink or eat the same food as everyone else. Why should you breathe the same air?" Customize your air purification to your lifestyle and environment.
Man replacing air purifier filter in living room Effortless filter replacement keeps your air fresh
Convenient Filter Subscription Service
Never worry about running out of replacement filters with the Wyze Air Filter Subscription. Choose your preferred filter type and receive timely shipments to keep your purifier running at peak performance.
  • Filters include Allergen, Formaldehyde, and Wildfire options.
  • Service life ranges from 4 to 12 months depending on filter type.
  • Each filter is composed of high-quality materials like True HEPA and activated carbon for maximum pollutant removal.
Why Choose Wyze Air Purifier for Your Living Room?
  • Quiet Operation: At 21 decibels, it’s perfect for quiet living spaces.
  • Energy Efficient: Designed to clean large rooms without high power consumption.
  • Smart Features: App control, voice assistant compatibility, and real-time air quality monitoring.
  • Affordable Luxury: Premium filtration and smart tech without breaking the bank.
  • Refurbished Quality: A-grade refurbished units offer the same performance with added value.
Cozy living room with air purifier Enhance your living room air quality quietly and efficiently
Summary
For a quiet, energy-efficient, and smart air purifier tailored to your living room, the (Refurbished) Wyze Air Purifier combined with customizable Wyze Air Filters and a convenient subscription service is the perfect solution. Enjoy clean, fresh air without noise distractions or high costs, all while benefiting from smart home integration and easy maintenance.
Feature(Refurbished) Wyze Air PurifierWyze Air FilterWyze Air PurifierWyze Air Filter Subscription
TypeRefurbished Air PurifierReplacement FilterNew Air PurifierFilter Subscription
Price$139.99$37.99 - $63.99 (depending on filter type)$169.99 - $194.99 (depending on filter type)$37.99 - $63.99 (depending on filter type)
Filter VariantsAllergen, Formaldehyde, WildfireAllergen Filter (Standard), Formaldehyde Filter (Premium), Wildfire Filter (Special Use)Allergen Filter (Standard), Formaldehyde Filter (Premium), Wildfire Filter (Special Use)Allergen Filter, Formaldehyde Filter, Wildfire Filter
CADR (Clean Air Delivery Rate)350N/A350214 - 362 m³/h (depending on filter)
Noise Level21 dBN/A21 - 54 dBN/A
Filter CompositionN/APre-filter + HEPA 13/12 + Activated Carbon/MnO2Pre-installed filters: Pre-filter + HEPA 13/12 + Activated Carbon/MnO2Pre-filter + True HEPA 13/12 + Activated Carbon/MnO2
TVOC Removal EfficiencyN/AN/AN/A92.7% - 98.9% (depending on filter)
Service Life (Filter)Recommended replacement every 6 monthsN/AN/A4 - 12 months (depending on filter)
WeightN/A1.5 - 1.9 lb (depending on filter)N/A1.5 - 1.9 lb (depending on filter)
DimensionsN/A8.1" x 8.1" x 11.3"N/A8.1" x 8.1" x 11.3"
FeaturesSmart controls, AQ alerts, laser particle detectionCustom filters for specific needsSmart controls, AQ alerts, laser particle detection, auto mode, child lock, Alexa/Google Home compatibleReplacement filters for Wyze Air Purifier
Room CoverageUp to 550 sq. ft (42 m²)N/AUp to 550 sq. ft (42 m²)N/A
WarrantyN/AN/AN/AN/A
AvailabilityLow stock (43 left)Out of stockOut of stockAvailable
What makes the (Refurbished) Wyze Air Purifier ideal for living rooms?The (Refurbished) Wyze Air Purifier is perfect for living rooms due to its ultra-quiet operation at just 21 decibels, powerful air cleaning for spaces up to 550 sq. ft, energy efficiency, and smart features like app control and real-time air quality alerts.
How quiet is the Wyze Air Purifier during operation?The Wyze Air Purifier operates at only 21 decibels, making it quieter than a purring kitten. This ensures it won’t disturb your relaxation, conversations, or sleep in your living room.
What size room can the Wyze Air Purifier clean effectively?The Wyze Air Purifier is designed to purify rooms up to 550 square feet (42 m²), making it suitable for most living rooms and large spaces.
What types of filters are available for the Wyze Air Purifier?The Wyze Air Purifier supports three custom filter types: Allergen Filter (Standard), Formaldehyde Filter (Premium), and Wildfire Filter (Special Use). Each filter targets specific air quality concerns such as allergens, odors, chemicals, and wildfire smoke.
How often should I replace the Wyze Air Purifier filter?It is recommended to replace the Wyze Air Purifier filter every 4 to 12 months, depending on the filter type and usage. The Allergen, Formaldehyde, and Wildfire filters each have different lifespans.
Is the Wyze Air Purifier energy efficient?Yes, the Wyze Air Purifier is designed to be energy efficient, providing powerful air cleaning for large rooms without high power consumption.
Does the Wyze Air Purifier have smart features?Yes, the Wyze Air Purifier offers smart controls, laser particle detection, real-time air quality alerts, and is compatible with Alexa and Google Home for voice commands and app-based control.
What is included in the Wyze Air Filter Subscription service?The Wyze Air Filter Subscription service allows you to choose your preferred filter type (Allergen, Formaldehyde, or Wildfire) and receive timely shipments, ensuring you never run out of replacement filters and your purifier runs at peak performance.
Is the refurbished Wyze Air Purifier reliable and safe?Yes, the refurbished Wyze Air Purifier is CARB certified for safety and efficiency, and comes with premium filters. A-grade refurbished units offer the same performance as new models at a more affordable price.
How easy is it to replace the filter in the Wyze Air Purifier?Replacing the filter in the Wyze Air Purifier is simple and quick, making it easy to maintain optimal air quality in your living room with minimal hassle.
What are the specific features of the Wyze Air Purifier that make it suitable for living rooms?How does the Clean Air Delivery Rate (CADR) of the Wyze Air Purifier compare to other air purifiers?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Air Purifier?
