Air Filter Replacement That Lasts At Least Six Months
When it comes to maintaining clean and healthy indoor air, choosing the right air filter replacement that lasts at least six months is essential. Wyze offers a range of air filters and purifiers designed to provide long-lasting, effective air cleaning tailored to your specific needs. Whether you want to combat allergens, formaldehyde, wildfire smoke, or everyday pollutants, Wyze has you covered with premium filters that deliver superior performance and durability.
Wyze Air Filter: Customizable Filters for Every Environment
Wyze Air Filters are designed to fit your unique air quality needs, offering specialized filtration options that last between 4 to 12 months depending on the filter type and usage.
Filter Variants and Lifespan
Allergen Filter (Standard)
Combines a Pre-Filter, HEPA 13, and Granulated Carbon to capture common allergens and pollutants.
Service Life: 6 to 12 months
Price: $37.99
Formaldehyde Filter (Premium)
A premium-grade filter that not only traps pollutants but also destroys heavy odors and harmful chemicals like formaldehyde, a carcinogenic VOC found in tobacco smoke, new furniture, and construction materials. It features a Pre-Filter, True HEPA 12, and Granulated Carbon with Activated Manganese.
Service Life: 5 to 12 months
Price: $63.99
Wildfire Filter (Special Use)
Designed for wildfire smoke and fire pollution, this filter uses a Pre-Filter, True HEPA 12, and Chemically Modified Granulated Carbon to maximize absorption of fire-related pollutants.
Service Life: 4 to 12 months
Price: $40.99
"Customize your air like you customize your burger."
Wyze Air Filters adapt to your environment, whether you're near wildfire smoke, living in a new home, or managing pet odors and allergens.
Easy Filter Replacement
Replacing your Wyze Air Filter is simple and hassle-free. Just remove the old filter and insert the new one to keep your air purifier running at peak performance.
Alt text: Man holding Wyze air purifier while replacing the air filter at home
Wyze Air Purifier: Powerful, Smart, and Quiet
The Wyze Air Purifier is a smart home device that comes pre-installed with your choice of the above filters, offering a complete air cleaning solution with advanced features.
Key Features
- High CADR (Clean Air Delivery Rate): 350 CADR, cycling 12,000 cubic feet of air per hour, effectively cleaning large rooms quickly.
- Whisper-Quiet Operation: Runs at just 21 decibels on low, quieter than a purring kitten.
- Smart Controls: Compatible with Google Home and Alexa, with app-based controls for fan speed, child lock, and display dimming.
- Laser Particle Sensor: Detects ultra-fine particles down to 0.3 microns, updating air quality data 100 times per second.
- Air Quality Alerts: Real-time indoor and outdoor air quality monitoring with hyper-local accuracy via the Wyze app.
Filter Options Pre-Installed
- Allergen Filter (Standard)
- Formaldehyde Filter (Premium)
- Wildfire Filter (Special Use)
Maintenance and Filter Life
Wyze recommends replacing the air purifier filter every six months to maintain optimal performance. The Wyze app will notify you when it's time for a replacement, making upkeep effortless.
Alt text: Hand replacing Wyze air purifier filter in a cozy home setting
Wyze Air Filter Subscription: Hassle-Free Replacement Filters
To ensure you never run out of fresh filters, Wyze offers an Air Filter Subscription service that delivers replacement filters right to your door.
Subscription Benefits
- Convenient, scheduled delivery of your chosen filter type.
- Filters available: Allergen, Formaldehyde, and Wildfire.
- Each filter lasts between 4 to 12 months depending on type and usage.
- Filters feature advanced compositions such as True HEPA and activated carbon for superior pollutant removal.
Filter Specifications
Filter Type | TVOC Removal Efficiency | CADR (Particulate Matter) | Service Life | Composition |
Allergen Filter | 92.7% | 362 m³/h (214 CFM) | 6–12 months | Pre-filter + True HEPA 13 + Activated Carbon |
Formaldehyde Filter | 98.9% | 317 m³/h (186 CFM) | 5–12 months | Pre-filter + True HEPA 12 + MnO2 + Activated Carbon |
Wildfire Filter | 97.1% | 342 m³/h (186 CFM) | 4–12 months | Pre-filter + True HEPA 12 + Activated Carbon |
With the subscription, you can maintain clean air effortlessly without worrying about running out of replacement filters.
Why Choose Wyze Air Filters for Long-Lasting Air Quality?
- Durability: Filters last at least six months, with some lasting up to a year depending on usage.
- Customization: Choose filters tailored to your environment and air quality concerns.
- Smart Notifications: The Wyze app alerts you when it’s time to replace filters.
- Advanced Filtration: True HEPA and activated carbon layers capture a wide range of pollutants, including allergens, VOCs, and wildfire smoke.
- Affordable: Premium filtration without a premium price tag.
According to Wyze, replacing your air purifier filter every six months ensures the best performance and cleanest air possible.
Summary
For air filter replacements that last at least six months, Wyze offers a comprehensive ecosystem of air filters, purifiers, and subscription services designed to keep your indoor air fresh, clean, and healthy. Whether you need to tackle allergens, formaldehyde, or wildfire smoke, Wyze’s customizable filters and smart air purifiers provide effective, long-lasting solutions with easy maintenance and smart home integration.
How long do Wyze air filter replacements last?
Wyze air filter replacements are designed to last at least six months, with some filters lasting up to 12 months depending on the filter type and usage. Regular replacement ensures optimal air purifier performance and clean indoor air.What types of Wyze air filters are available?
Wyze offers three main types of air filters: the Allergen Filter (Standard), the Formaldehyde Filter (Premium), and the Wildfire Filter (Special Use). Each filter is tailored to address specific air quality concerns such as allergens, formaldehyde, and wildfire smoke.What is the difference between the Allergen, Formaldehyde, and Wildfire filters?
The Allergen Filter combines a Pre-Filter, HEPA 13, and Granulated Carbon to capture common allergens and pollutants. The Formaldehyde Filter uses a Pre-Filter, True HEPA 12, and Granulated Carbon with Activated Manganese to remove formaldehyde and heavy odors. The Wildfire Filter features a Pre-Filter, True HEPA 12, and Chemically Modified Granulated Carbon to absorb wildfire smoke and fire-related pollutants.How do I know when to replace my Wyze air filter?
The Wyze app provides smart notifications to alert you when it’s time to replace your air filter. Wyze recommends replacing the filter every six months for optimal performance, but actual lifespan may vary based on usage and environment.Is it easy to replace a Wyze air filter?
Yes, replacing a Wyze air filter is simple and hassle-free. Just remove the old filter and insert the new one to keep your air purifier running efficiently.What are the benefits of the Wyze Air Filter Subscription service?
The Wyze Air Filter Subscription service delivers replacement filters directly to your door on a convenient schedule. You can choose from Allergen, Formaldehyde, or Wildfire filters, ensuring you never run out of fresh filters and always maintain clean indoor air.How effective are Wyze air filters at removing pollutants?
Wyze air filters feature advanced filtration technologies such as True HEPA and activated carbon layers. They are highly effective at removing a wide range of pollutants, including allergens, VOCs like formaldehyde, and wildfire smoke, with TVOC removal efficiencies up to 98.9% depending on the filter type.Are Wyze air purifiers compatible with smart home systems?
Yes, Wyze air purifiers are compatible with Google Home and Alexa. They also offer app-based controls for fan speed, child lock, and display dimming, as well as real-time air quality monitoring.What is the Clean Air Delivery Rate (CADR) of Wyze air purifiers?
Wyze air purifiers have a high Clean Air Delivery Rate (CADR) of 350, cycling 12,000 cubic feet of air per hour. This makes them effective for quickly cleaning the air in large rooms.Why should I choose Wyze air filters for long-lasting air quality?
Wyze air filters offer durability, lasting at least six months, and are customizable to your specific air quality needs. They provide advanced filtration, smart notifications for replacements, and affordable pricing, making them an excellent choice for maintaining clean and healthy indoor air.
