Refurbished Air Purifier with Low Energy Consumption and Quiet Operation
If you're searching for a
refurbished air purifier that combines
low energy consumption with
quiet operation, the
Wyze Air Purifier (Refurbished) is an excellent choice. Designed to deliver clean air efficiently and silently, this device is perfect for maintaining a healthy home environment without the noise or high power bills.
Wyze Air Purifier (Refurbished) – Smart, Quiet, and Energy Efficient
Whisper-Quiet Operation
The refurbished Wyze Air Purifier operates at an ultra-quiet noise level of just
21 decibels, which is quieter than a purring kitten. This makes it ideal for bedrooms, nurseries, or any living space where peace and quiet are essential.
Powerful Air Cleaning Performance
Despite its quiet operation, it boasts a
Clean Air Delivery Rate (CADR) of 350, cycling through
12,000 cubic feet of air every hour. This means it can effectively purify the air in rooms up to
550 sq. ft (42 m²), removing allergens, dust, smoke, and other pollutants.
Running on standard
AC 120V / 60 Hz power, the purifier is designed to be energy efficient, helping you save on electricity bills while maintaining fresh air quality.
Smart Features for Modern Living
- Smart controls allow you to manage the purifier remotely via the Wyze app.
- Air Quality (AQ) alerts keep you informed about indoor air conditions.
- Laser particle detection provides precise monitoring of ultra-fine particles down to 0.3 microns.
- Compatible with Google Home and Alexa for voice control.
Certified and Reliable
The unit is
CARB certified, ensuring it meets strict air quality and safety standards. Filter replacement is recommended every 6 months for optimal performance.
"A luxury air purifier without a luxury price tag."
Enjoy clean air quietly in your home
Wyze Air Purifier – Brand New with Customizable Filters
If you prefer a brand-new unit, the Wyze Air Purifier offers the same quiet and efficient performance with the added benefit of
customizable filters tailored to your specific air quality needs.
Filter Options to Match Your Environment
- Allergen Filter (Standard): Combats common allergens with HEPA 13 and granulated carbon.
- Formaldehyde Filter (Premium): Destroys heavy odors and harmful chemicals like formaldehyde, a carcinogenic VOC found in new furniture and building materials.
- Wildfire Filter (Special Use): Designed to absorb pollutants from wildfire smoke with chemically modified granulated carbon.
Smart and Automated Air Cleaning
- Auto Mode adjusts fan speed based on real-time air quality.
- Child lock and dimmable display for family-friendly use.
- Easy filter replacement with a handy handle for portability.
Quiet Yet Powerful
Operates between
21 and 54 decibels, balancing power and silence perfectly.
Wyze Air Filter – Customize Your Air Purifier’s Performance
To maintain peak air purification, Wyze offers
replacement filters compatible with both new and refurbished Wyze Air Purifiers.
Filter Types:
- Allergen Filter: Pre-filter + HEPA 13 + granulated carbon for everyday use.
- Formaldehyde Filter: True HEPA 12 + activated manganese to neutralize dangerous gases.
- Wildfire Filter: True HEPA 12 + chemically modified carbon for fire pollution.
"Customize your air like you customize your burger."
Easy Filter Replacement
Replacing your filter is simple and quick, ensuring your purifier continues to operate efficiently without hassle.
Quick and easy filter changes keep your air fresh
Why Choose a Refurbished Wyze Air Purifier?
- Cost-effective: Save money while enjoying premium air purification.
- Eco-friendly: Reduce waste by giving a high-quality product a second life.
- Certified Quality: A-grade refurbished units undergo rigorous testing.
- Smart Home Integration: Seamlessly fits into your connected home ecosystem.
Summary
For those seeking a
refurbished air purifier that excels in
quiet operation and
low energy consumption, the
Wyze Air Purifier (Refurbished) is a top contender. With smart features, powerful filtration, and customizable filters, it offers a comprehensive solution to improve your indoor air quality affordably and efficiently.
What are the benefits of choosing a refurbished Wyze Air Purifier?
A refurbished Wyze Air Purifier offers premium air purification at a lower cost, is eco-friendly by reducing waste, and undergoes rigorous testing to ensure certified quality. It also features smart home integration for seamless control.How quiet is the Wyze Air Purifier (Refurbished) during operation?
The refurbished Wyze Air Purifier operates at an ultra-quiet noise level of just 21 decibels, making it quieter than a purring kitten. This makes it ideal for bedrooms, nurseries, and other quiet spaces.How energy efficient is the Wyze Air Purifier (Refurbished)?
The Wyze Air Purifier (Refurbished) is designed for low energy consumption, running on standard AC 120V / 60 Hz power. This helps you maintain clean air in your home while saving on electricity bills.What size room can the Wyze Air Purifier (Refurbished) effectively clean?
The Wyze Air Purifier (Refurbished) has a Clean Air Delivery Rate (CADR) of 350 and can purify the air in rooms up to 550 sq. ft (42 m²), cycling through 12,000 cubic feet of air every hour.What smart features does the Wyze Air Purifier offer?
The Wyze Air Purifier includes smart controls via the Wyze app, air quality alerts, laser particle detection for monitoring ultra-fine particles, and compatibility with Google Home and Alexa for voice control.Is the Wyze Air Purifier (Refurbished) certified for safety and air quality?
Yes, the Wyze Air Purifier (Refurbished) is CARB certified, ensuring it meets strict air quality and safety standards.How often should I replace the filter in my Wyze Air Purifier?
For optimal performance, it is recommended to replace the filter in your Wyze Air Purifier every 6 months.What types of replacement filters are available for Wyze Air Purifiers?
Wyze offers three types of replacement filters: the Allergen Filter (HEPA 13 + granulated carbon), the Formaldehyde Filter (True HEPA 12 + activated manganese), and the Wildfire Filter (True HEPA 12 + chemically modified carbon).Can I customize the filter in my Wyze Air Purifier?
Yes, Wyze Air Purifiers support customizable filters, allowing you to choose from Allergen, Formaldehyde, or Wildfire filters to match your specific air quality needs.How easy is it to replace the filter in a Wyze Air Purifier?
Replacing the filter in a Wyze Air Purifier is simple and quick, ensuring your device continues to operate efficiently with minimal hassle.Does the Wyze Air Purifier support smart home integration?
Yes, the Wyze Air Purifier is compatible with Google Home and Alexa, allowing for convenient voice control and integration into your smart home ecosystem.What is the difference between the refurbished and brand new Wyze Air Purifier?
Both refurbished and brand new Wyze Air Purifiers offer quiet, energy-efficient performance and smart features. The brand new unit also provides customizable filter options tailored to specific air quality needs.
