Refurbished Air Purifier for Continuous Indoor Air Quality
Refurbished Air Purifier Ideal for Continuous Indoor Air Purification
When it comes to maintaining clean and healthy indoor air continuously, a reliable air purifier is essential. For those seeking an eco-friendly and cost-effective solution, refurbished air purifiers offer premium performance without the luxury price tag. Below, we explore the ideal refurbished air purifier options and their customizable filters to keep your indoor environment fresh and safe.
(Refurbished) Wyze Air Purifier: Premium Performance, Refurbished Value
The (Refurbished) Wyze Air Purifier is a top choice for continuous indoor air purification, combining advanced technology with affordability. This refurbished model delivers the same high-quality air cleaning capabilities as new units, making it perfect for long-term use in homes or offices.
Key Features:
  • CADR of 350: Efficiently cleans air in rooms up to 550 sq. ft, ideal for living rooms, bedrooms, or home offices.
  • Whisper-quiet operation: At just 21 decibels, it runs silently, ensuring no disturbance during sleep or work.
  • Smart controls & AQ alerts: Monitor air quality in real-time with smart home compatibility.
  • Laser particle detection: Detects particles as small as 0.3 microns for precise air quality measurement.
  • Filter options: Compatible with allergen, formaldehyde, and wildfire filters to target specific pollutants.
  • CARB certified: Meets strict air quality standards for safety and performance.
  • Recommended filter replacement every 6 months: Ensures continuous optimal purification.
"A luxury air purifier without a luxury price tag."
This refurbished unit is a smart investment for anyone wanting continuous, effective air purification with smart features and trusted performance. Wyze Air Purifier in Kitchen Experience clean air in your living space with the Wyze Air Purifier.
Wyze Air Purifier: New and Versatile for Every Home
For those who prefer a brand-new unit, the Wyze Air Purifier offers premium filtration and smart home integration with multiple filter variants to suit your specific air quality needs.
Highlights:
  • Multiple filter variants: Choose from Allergen (Standard), Formaldehyde (Premium), or Wildfire (Special Use) filters.
  • CADR ratings: Up to 350 m³/h for allergen filter, ensuring rapid air cleaning.
  • Quiet operation: Noise levels range from under 21 dBA to 52 dBA depending on fan speed.
  • Smart home compatibility: Works seamlessly with Google Home and Alexa for voice control.
  • Compact design: Dimensions of 9.5" x 9.4" x 18.5" fit easily in any room.
  • Filter life: Approximately 6 months, balancing performance and maintenance.
This model is perfect for users who want customizable air purification tailored to their environment, whether combating allergens, chemical pollutants, or wildfire smoke.
Wyze Air Filter: Customize Your Air Purification
To complement your Wyze Air Purifier, the Wyze Air Filter accessories provide tailored filtration options that address specific indoor air challenges.
Filter Options:
  • Allergen Filter (Standard): HEPA 13 filter capturing common allergens.
  • Formaldehyde Filter (Premium): Targets harmful gases and VOCs with up to 98.9% TVOC removal efficiency.
  • Wildfire Filter (Special Use): Designed for smoke and particulate matter during wildfire seasons.
Additional Benefits:
  • Activated carbon layer: Enhances removal of odors and gases.
  • Virus and bacteria efficiency: Filters remove up to 99% of airborne pathogens.
  • Service life: Ranges from 4 to 12 months depending on filter type and usage.
These filters allow you to customize your air purifier’s performance to your unique indoor air quality needs, ensuring continuous and effective purification. Changing Air Purifier Filter Easily replace filters to maintain optimal air quality.
Why Choose a Refurbished Wyze Air Purifier?
Refurbished air purifiers are a sustainable choice that combines quality, affordability, and environmental responsibility. The Wyze refurbished air purifier undergoes rigorous testing to ensure it meets the same standards as new units, providing peace of mind and continuous indoor air purification.
  • Cost-effective: Save significantly compared to new models.
  • Certified quality: A-grade refurbished units with warranty.
  • Smart features: Same smart controls and alerts as new devices.
  • Ideal for continuous use: Designed to run quietly and efficiently day and night.
Conclusion
For continuous indoor air purification, the (Refurbished) Wyze Air Purifier stands out as the ideal choice, offering premium filtration, smart features, and whisper-quiet operation at a great value. Paired with customizable Wyze Air Filters, you can tailor your air cleaning to your specific needs, ensuring a healthier home environment all year round.
Product Summary
(Refurbished) Wyze Air Purifier Wyze Air Purifier (New) Wyze Air Filter (Accessories)
Feature(Refurbished) Wyze Air PurifierWyze Air PurifierWyze Air Filter
TypeRefurbishedConnected HomeConnected Home (Accessory)
Price$139.99$169.99 - $194.99$37.99 - $63.99
Variants (Pre-installed filter)Any FilterAllergen Filter (Standard), Formaldehyde Filter (Premium), Wildfire Filter (Special Use)Allergen Filter (Standard), Formaldehyde Filter (Premium), Wildfire Filter (Special Use)
CADR (Clean Air Delivery Rate)350 CADR350 CADR (12,000 cubic feet/hour)Particulate Matter CADR: 362, 317, 342 m³/h (varies by filter)
Noise Level21 decibels (whisper-quiet)21 to 54 decibelsN/A
Filter TypePremium filtersTrue HEPA + Activated Carbon (varies by filter)Pre-filter + True HEPA 12/13 + Activated Carbon (varies by filter)
Smart ControlsYesYes, with app, Alexa, Google Home compatibilityN/A
Air Quality AlertsYesYesN/A
Particle DetectionLaser particle detectionLaser particle sensor (0.3 microns, 100x/sec)N/A
Filter Service LifeNot specifiedNot specified4-12 months (varies by filter)
DimensionsNot specified8.1" x 8.1" x 11.3" (205 mm x 205 mm x 286 mm)8.1" x 8.1" x 11.3" (205 mm x 205 mm x 286 mm)
WeightNot specified1.5 - 1.9 lb (varies by filter)1.5 - 1.9 lb (varies by filter)
Return PolicyFinal Sale, No returns30-day hassle-free returnsNo returns
Additional FeaturesLuxury air purifier without luxury price tagAuto Mode, child lock, dimmable display, app control, Google Home & Alexa compatibleCustom filters for specific needs (allergens, formaldehyde, wildfire smoke)
What are the benefits of choosing a refurbished Wyze Air Purifier?A refurbished Wyze Air Purifier offers premium air purification at a lower cost, making it an eco-friendly and budget-friendly choice. Each unit undergoes rigorous testing to ensure it meets the same quality standards as new models, and comes with smart features, quiet operation, and a warranty for peace of mind.
How effective is the (Refurbished) Wyze Air Purifier at cleaning indoor air?The (Refurbished) Wyze Air Purifier features a Clean Air Delivery Rate (CADR) of 350, efficiently purifying rooms up to 550 sq. ft. It uses advanced laser particle detection to capture particles as small as 0.3 microns, ensuring high-quality air cleaning for living rooms, bedrooms, or offices.
What types of filters are available for Wyze Air Purifiers?Wyze Air Purifiers are compatible with three main filter types: the Allergen Filter (HEPA 13 for common allergens), the Formaldehyde Filter (targets harmful gases and VOCs), and the Wildfire Filter (designed for smoke and particulate matter). Each filter addresses specific indoor air quality challenges.
How often should I replace the filters in my Wyze Air Purifier?It is recommended to replace Wyze Air Purifier filters every 6 months for optimal performance. Depending on the filter type and usage, the service life can range from 4 to 12 months.
Is the Wyze Air Purifier suitable for continuous use?Yes, both the refurbished and new Wyze Air Purifiers are designed for continuous operation. They feature whisper-quiet performance (as low as 21 decibels) and efficient air cleaning, making them ideal for day and night use in homes or offices.
Are Wyze Air Purifiers compatible with smart home systems?Yes, Wyze Air Purifiers offer smart controls and real-time air quality alerts. They are compatible with Google Home and Alexa, allowing for convenient voice control and integration into your smart home ecosystem.
What certifications do Wyze Air Purifiers have?Wyze Air Purifiers are CARB certified, meeting strict air quality and safety standards for use in homes and offices.
How do Wyze Air Filters help with specific air quality issues like allergens, VOCs, or wildfire smoke?Wyze Air Filters are designed to target specific pollutants: the Allergen Filter captures common allergens, the Formaldehyde Filter removes harmful gases and VOCs with up to 98.9% TVOC removal efficiency, and the Wildfire Filter is optimized for smoke and particulate matter during wildfire seasons.
What is the noise level of the Wyze Air Purifier during operation?The Wyze Air Purifier operates at a whisper-quiet noise level, starting as low as 21 decibels and reaching up to 52 decibels depending on the fan speed, ensuring minimal disturbance during sleep or work.
Why is a refurbished air purifier considered an eco-friendly choice?Choosing a refurbished air purifier helps reduce electronic waste and supports sustainability by extending the life of high-quality devices. Refurbished units provide the same performance as new ones while minimizing environmental impact.
What are the key features of the Wyze Air Purifier?How does the Wyze Air Purifier compare to other air purifiers on the market?Do you have any ongoing sales or discounts for the Wyze Air Purifier?
