Discover the Wyze Air Purifier Collection: Breathe Cleaner, Live Better
When it comes to improving your home's air quality, Wyze offers a range of air purifiers and filters designed to fit your lifestyle and specific needs. Whether you want whisper-quiet operation, smart home connectivity, or customizable filtration options, Wyze has you covered. Explore the features and benefits of the Wyze Air Purifier lineup and find the perfect solution to clear your air and refresh your living space.
Wyze Air Purifier: Premium Air Quality with Smart Controls
The Wyze Air Purifier is engineered to deliver clean, fresh air quietly and efficiently. With a Clean Air Delivery Rate (CADR) of 350, it effectively purifies rooms up to 550 sq. ft., making it ideal for bedrooms, living rooms, or home offices.
Key Features:
- Whisper-Quiet Operation: At just 21 decibels, it runs silently in the background without disturbing your daily activities or sleep.
- Premium Filters: Choose from three pre-installed filter options tailored to your environment:
- Allergen Filter (Standard) for everyday dust, pollen, and pet dander.
- Formaldehyde Filter (Premium) to combat harmful gases often found in new homes.
- Wildfire Filter (Special Use) designed to filter smoke and particulates during wildfire seasons.
- Smart Connectivity: Control your purifier remotely via the Wyze app, schedule cleanings, and monitor air quality in real-time.
- Sleek Design: Compact and modern with a durable gray plastic body that fits seamlessly into any room decor.
"Buy a Wyze Air Purifier and save your marriage." — A playful reminder that clean air can improve your home's atmosphere and relationships.
Price Range: $169.99 - $194.99 depending on filter choice.
Enhance your home's air quality with smart, easy-to-use purification.
Wyze Air Filter: Customize Your Air Purification
Why settle for one-size-fits-all air filters when you can customize your air like your favorite meal? The Wyze Air Filter accessories allow you to tailor your purifier’s performance to your unique environment and health concerns.
Filter Options:
- Allergen Filter (Standard): HEPA 13 filter captures dust, pollen, and pet dander.
- Formaldehyde Filter (Premium): HEPA 12 with activated carbon targets harmful gases and odors.
- Wildfire Filter (Special Use): Designed to filter smoke and fine particulates during wildfire events.
Additional Specs:
- Dimensions: 8.1" x 8.1" x 11.3" (205 mm x 205 mm x 286 mm)
- Weight: Ranges from 1.5 to 1.9 lbs depending on filter type
- Includes pre-filter and activated carbon layers for enhanced purification
Price Range: $37.99 - $63.99 per filter
"You don't drink the same drink or eat the same food as everyone else. Why should you breathe the same air?"
Easily swap filters to match your air quality needs.
(Refurbished) Wyze Air Purifier: Affordable Clean Air Solution
Looking for a budget-friendly option without compromising on quality? The refurbished Wyze Air Purifier offers the same powerful performance and smart features as the new model but at a lower price point.
Highlights:
- Same 350 CADR and whisper-quiet 21 dB noise level
- Compatible with all filter types: allergen, formaldehyde, and wildfire
- Supports smart controls for remote operation and scheduling
- Suitable for rooms up to 550 sq. ft.
Price: $139.99
Save money and the environment by choosing a certified refurbished unit that delivers clean air and peace of mind.
Why Choose Wyze Air Purifiers?
- Smart Home Integration: Seamlessly connect with your Wyze ecosystem for voice control and automation.
- Customizable Filtration: Select filters that address your specific air quality concerns.
- Quiet and Efficient: Enjoy clean air without noise disruption.
- Stylish and Compact: Designed to fit any room without taking up much space.
Breathe easier knowing your air purifier is working hard to keep your home environment fresh and healthy.
Summary of Wyze Air Purifier Products
Product | Price Range | Key Features | Filter Options |
Wyze Air Purifier | $169.99 - $194.99 | 350 CADR, 21 dB, smart controls | Allergen, Formaldehyde, Wildfire |
Wyze Air Filter (Accessories) | $37.99 - $63.99 | Customizable HEPA & activated carbon | Allergen, Formaldehyde, Wildfire |
(Refurbished) Wyze Air Purifier | $139.99 | Same specs as new, budget-friendly | Allergen, Formaldehyde, Wildfire |
Experience the difference of cleaner air with Wyze Air Purifiers — your smart, customizable, and quiet solution for a healthier home.
What is the Wyze Air Purifier and how does it improve air quality?
The Wyze Air Purifier is a smart, efficient device designed to deliver clean, fresh air in your home. With a Clean Air Delivery Rate (CADR) of 350, it effectively purifies rooms up to 550 sq. ft. It features whisper-quiet operation at just 21 decibels, customizable filter options, and smart controls via the Wyze app, making it ideal for bedrooms, living rooms, and home offices.What filter options are available for the Wyze Air Purifier?
Wyze offers three filter options for its air purifiers: the Allergen Filter (Standard) for dust, pollen, and pet dander; the Formaldehyde Filter (Premium) for harmful gases and odors; and the Wildfire Filter (Special Use) designed to filter smoke and fine particulates during wildfire seasons.How do I control the Wyze Air Purifier remotely?
You can control the Wyze Air Purifier remotely using the Wyze app. The app allows you to schedule cleanings, monitor real-time air quality, and adjust settings from anywhere, providing convenient smart home integration.What is the price range for Wyze Air Purifiers and filters?
The Wyze Air Purifier is priced between $169.99 and $194.99, depending on the filter choice. Replacement filters range from $37.99 to $63.99 each. Refurbished Wyze Air Purifiers are available for $139.99.What are the benefits of choosing a refurbished Wyze Air Purifier?
A refurbished Wyze Air Purifier offers the same powerful performance, smart features, and compatibility with all filter types as the new model, but at a lower price point. It is a budget-friendly and environmentally conscious option for clean air.How quiet is the Wyze Air Purifier during operation?
The Wyze Air Purifier operates at just 21 decibels, making it whisper-quiet and suitable for use in bedrooms, nurseries, or any space where minimal noise is important.Can I customize the filtration of my Wyze Air Purifier?
Yes, Wyze Air Purifiers allow you to customize filtration by choosing from different filter types based on your specific air quality needs, such as allergens, formaldehyde, or wildfire smoke.What are the dimensions and weight of Wyze Air Filters?
Wyze Air Filters measure 8.1" x 8.1" x 11.3" (205 mm x 205 mm x 286 mm) and weigh between 1.5 and 1.9 lbs, depending on the filter type.Are Wyze Air Purifiers compatible with smart home systems?
Yes, Wyze Air Purifiers integrate seamlessly with the Wyze ecosystem, allowing for voice control and automation within your smart home setup.What makes Wyze Air Purifiers a good choice for home air purification?
Wyze Air Purifiers offer smart home integration, customizable filtration, quiet and efficient operation, and a stylish, compact design. They are engineered to fit any room and address a variety of air quality concerns, making them a versatile solution for healthier indoor air.
