Best Quiet Refurbished Air Purifier for Large Rooms Up to 550 Sq. Ft. – Affordable, Smart & Ultra-Silent Wyze Air Purifier
The Best Quiet Refurbished Air Purifier for Large Rooms Under 550 Square Feet
Are you searching for a quiet, effective, and budget-friendly refurbished air purifier for your large room? The (Refurbished) Wyze Air Purifier is the perfect solution for spaces up to 550 sq. ft., offering premium air cleaning performance, whisper-quiet operation, and smart features—all at a fraction of the cost of new models.
Why Choose a Refurbished Wyze Air Purifier?
Powerful Air Cleaning for Large Rooms
The (Refurbished) Wyze Air Purifier is engineered to purify the air in rooms up to 550 square feet, making it ideal for living rooms, bedrooms, offices, and more. With a Clean Air Delivery Rate (CADR) of 350 m³/h, it can cycle the air in a 500 sq. ft. room over three times per hour, ensuring your environment stays fresh and healthy.
“Wyze Air Purifier cycles a whopping 12,000 cubic feet of air every hour (350 m³/h CADR)! Translation: it’s like dumping two swimming pools full of clean, pristine air into your house every sixty minutes.”
Ultra-Quiet Operation
Enjoy peace and quiet with noise levels as low as 21 decibels on the lowest setting—quieter than a purring kitten. Even at higher speeds, the purifier remains unobtrusive, so you can sleep, work, or relax without distraction. Noise Levels:
  • Level 1: <20.8 dBA
  • Level 2: <24.6 dBA
  • Level 3: <44.5 dBA
  • Level 4: <52.1 dBA
Advanced Filtration for Every Need
The refurbished Wyze Air Purifier comes with a brand-new filter (type may vary: Allergen, Formaldehyde, or Wildfire), each designed to tackle specific air quality challenges:
  • Allergen Filter (Standard): Removes dust, pollen, mold, and pet allergens.
  • Formaldehyde Filter (Premium): Targets chemical gases, VOCs, and formaldehyde—ideal for homes with new furniture, renovations, or smokers.
  • Wildfire Filter (Special Use): Specially formulated for smoke and industrial pollutants.
All filters are True HEPA, capturing 99.97% of airborne particles as small as 0.3 microns, and include granulated carbon for odor and gas removal.
Smart Features for Effortless Air Quality
  • Laser Particle Sensor: Continuously monitors air quality down to 0.3 microns and adjusts purification automatically.
  • Smart Controls: Use the Wyze app to control fan speed, set schedules, and receive air quality alerts.
  • Energy Efficient: Designed to run 24/7 with minimal energy cost—about $3.50 per month at max speed.
“Wyze Air Purifier is energy efficient and quiet when the pollution level is low, so you can keep your air clean 24/7.”
Easy Maintenance & Filter Replacement
Changing filters is quick and hassle-free, ensuring your purifier always operates at peak performance. The Wyze app notifies you when it’s time for a replacement, and the convenient handle makes moving the unit between rooms a breeze. Lifestyle image of a hand replacing the filter in a Wyze Air Purifier, showing easy maintenance in a home setting.
Healthier Air, Healthier Home
The (Refurbished) Wyze Air Purifier is CARB certified, meaning it does not produce harmful ozone or byproducts. It’s designed to remove:
  • Dust, pollen, and pet dander
  • Mold spores and bacteria
  • Viruses and VOCs
  • Odors and smoke
“Indoor air is on average 4x to 5x more polluted than outdoor air, according to the US EPA.”
Perfect for Bedrooms, Living Rooms, and More
Whether you’re dealing with allergies, pet odors, wildfire smoke, or just want to breathe cleaner air, the (Refurbished) Wyze Air Purifier is a smart, quiet, and affordable choice for large rooms up to 550 sq. ft. A man holding a Wyze Air Purifier in a modern living room, highlighting its suitability for large home spaces.
Key Specifications at a Glance
  • Room Size: Up to 550 sq. ft.
  • CADR: 350 m³/h (206 CFM)
  • Noise Level: 21–54 dBA
  • Filter Types: Allergen, Formaldehyde, Wildfire (brand new filter included)
  • Smart Features: App control, air quality alerts, auto mode
  • Energy Use: ~$3.50/month at max speed
  • Dimensions: 9.5" x 9.4" x 18.5"
  • Weight: ~9 lbs
Why Refurbished?
Choosing a refurbished Wyze Air Purifier means you get the same powerful performance and smart features as a new unit, but at a lower price and with a reduced environmental impact. Each unit is thoroughly tested and comes with a brand-new filter for your peace of mind.
Breathe Easy with Wyze
Upgrade your home’s air quality with a quiet, effective, and affordable refurbished air purifier designed for large rooms. The (Refurbished) Wyze Air Purifier delivers premium performance without the premium price tag—so you can breathe easy, sleep better, and enjoy a healthier home environment. A clean, modern home environment with a Wyze Air Purifier, representing fresh air and peace of mind.
Invest in your health and comfort with the (Refurbished) Wyze Air Purifier—quiet, smart, and perfect for large rooms up to 550 sq. ft.
Note: The refurbished unit includes a brand-new filter (type may vary). For best results, replace the filter every 6 months.
Breathe better. Live better. Choose Wyze.
What is the coverage area of the refurbished Wyze Air Purifier?The (Refurbished) Wyze Air Purifier is designed for large rooms up to 550 square feet, making it ideal for living rooms, bedrooms, offices, and similar spaces.
How quiet is the refurbished Wyze Air Purifier during operation?The Wyze Air Purifier operates as quietly as 21 decibels on its lowest setting, which is quieter than a purring kitten. Even at higher speeds, it remains unobtrusive, ensuring a peaceful environment for sleep, work, or relaxation.
What types of filters are available with the refurbished Wyze Air Purifier?The refurbished Wyze Air Purifier comes with a brand-new filter, which may be an Allergen, Formaldehyde, or Wildfire filter. All filters are True HEPA, capturing 99.97% of airborne particles as small as 0.3 microns, and include granulated carbon for odor and gas removal.
How effective is the Wyze Air Purifier at cleaning the air?With a Clean Air Delivery Rate (CADR) of 350 m³/h, the Wyze Air Purifier can cycle the air in a 500 sq. ft. room over three times per hour, efficiently removing dust, pollen, pet dander, mold spores, bacteria, viruses, VOCs, odors, and smoke.
Does the refurbished Wyze Air Purifier have smart features?Yes, the Wyze Air Purifier features smart controls via the Wyze app, allowing you to adjust fan speed, set schedules, and receive air quality alerts. It also includes a laser particle sensor that monitors air quality and automatically adjusts purification levels.
Is the refurbished Wyze Air Purifier energy efficient?Absolutely. The Wyze Air Purifier is designed to run 24/7 with minimal energy consumption, costing about $3.50 per month at maximum speed.
How easy is it to maintain and replace filters in the Wyze Air Purifier?Maintenance is simple and hassle-free. The Wyze app notifies you when it’s time to replace the filter, and the unit’s design makes filter changes quick and easy. For best results, replace the filter every 6 months.
Is the refurbished Wyze Air Purifier safe and certified?Yes, the Wyze Air Purifier is CARB certified, ensuring it does not produce harmful ozone or byproducts, making it safe for use in your home.
What are the benefits of choosing a refurbished Wyze Air Purifier?Choosing a refurbished Wyze Air Purifier provides the same powerful performance and smart features as a new unit at a lower price, while also reducing environmental impact. Each refurbished unit is thoroughly tested and includes a brand-new filter.
What are the key specifications of the refurbished Wyze Air Purifier?Key specifications include: coverage for rooms up to 550 sq. ft., CADR of 350 m³/h (206 CFM), noise levels from 21–54 dBA, three filter types (Allergen, Formaldehyde, Wildfire), smart app controls, energy use of ~$3.50/month at max speed, dimensions of 9.5" x 9.4" x 18.5", and a weight of approximately 9 lbs.
What are the different filter types available for the Wyze Air Purifier?How does the laser particle sensor work in the Wyze Air Purifier?Do you have any ongoing sales or discounts for the Wyze Air Purifier?
