No WiFi Mobile App Smart Lock with Fingerprint Unlocking
Looking for a smart lock solution that offers fingerprint unlocking without relying on WiFi or cloud connectivity? The
Wyze Lock Bolt is the perfect choice for those who want secure, fast, and keyless entry with local Bluetooth control only. This smart lock replaces your deadbolt and provides a seamless unlocking experience with an ultra-fast fingerprint sensor and a backlit keypad — all without the need for a WiFi connection or mobile app cloud dependency.
Wyze Lock Bolt: The Ultimate No WiFi Fingerprint Smart Lock
Ultra-Fast Fingerprint Access
Say goodbye to fumbling with keys or worrying about lost access codes. The Wyze Lock Bolt features an ultra-fast fingerprint reader that unlocks your door in less than a second. Simply place your finger on the sensor, and you’re in — no WiFi or internet connection required. This local Bluetooth connection ensures your fingerprint data stays private and secure, encrypted directly on the device.
Luxurious Backlit Keypad with Anti-Peep Technology
The lock’s exterior boasts a solid metal construction with a sleek, modern design available in Matte Black or Satin Nickel finishes. The backlit keypad makes it easy to enter your access code even in the dark. Plus, with anti-peep technology, you can enter extra random digits before or after your code to keep your passcode safe from prying eyes.
Auto-Lock for Peace of Mind
Never worry about leaving your door unlocked again. The Wyze Lock Bolt includes an auto-lock timer you can set via the Wyze app (Bluetooth connection required for setup). After your specified delay, the lock automatically secures your door, giving you added security without any extra effort.
Robust Security and Weatherproof Design
This smart lock is fully pick-proof by eliminating the need for physical keys. It’s also built tough with IPX5 weatherproofing, making it suitable for most exterior doors and weather conditions. The lock runs on 4 AA batteries that last up to 12 months, with a low battery indicator and a USB-C port for emergency charging if needed.
Easy Installation and Local Control
Wyze Lock Bolt replaces your existing deadbolt in about 20 minutes with no complicated wiring. Control and manage the lock locally via Bluetooth through the Wyze app on your smartphone. The app lets you create and store up to 20 access codes and 50 fingerprints, view lock/unlock history, and generate emergency one-time codes — all without any cloud dependency.
"Wyze Lock Bolt is a solid, no frills smart lock with perfect fingerprint scans."
Secure your home effortlessly with Wyze Lock Bolt’s fingerprint unlocking.
Replacement Parts for Wyze Lock Bolt
To keep your Wyze Lock Bolt functioning perfectly, Wyze offers essential replacement parts:
- Wyze Lock Bolt Screws — Replacement screws for secure installation.
- Wyze Lock Bolt Interior Assembly Battery Cover — Replacement cover for the battery compartment.
- Wyze Lock Bolt Interior Assembly Metal Plate — Metal plate to anchor the interior assembly firmly to your door.
These parts ensure your smart lock stays reliable and easy to maintain over time.
Why Choose Wyze Lock Bolt for No WiFi Fingerprint Smart Locking?
- No WiFi Required: Operates fully on local Bluetooth connection, ensuring privacy and no cloud dependency.
- Fingerprint Unlocking: Ultra-fast and secure biometric access for quick entry.
- Backlit Keypad: Easy nighttime use with anti-peep code entry for enhanced security.
- Auto-Lock Feature: Automatically locks your door after a set time to prevent accidental unlocks.
- Weatherproof & Pick-Proof: Durable design for outdoor use and enhanced security.
- Long Battery Life: Up to 12 months on 4 AA batteries with emergency USB-C charging.
- Easy Installation: Replaces existing deadbolt in about 20 minutes without professional help.
Backlit keypad with anti-peep technology for secure code entry.
Enhance Your Home Security with Wyze Front Porch Security Bundle
For those interested in a comprehensive smart home security setup, consider the
Front Porch Security Bundle which pairs the Wyze Lock Bolt with Wyze Video Doorbell and Chime. This bundle offers:
- 1080p HD video monitoring of your front porch.
- Two-way audio to greet visitors remotely.
- Remote lock/unlock and lock history viewing via the Wyze app.
- Compatibility with Alexa and Google Assistant for voice control.
While the Wyze Lock Bolt itself does not require WiFi for fingerprint unlocking, this bundle adds WiFi-enabled video security for a complete smart home experience.
Summary
If you want a
no WiFi mobile app smart lock with fingerprint unlocking, the
Wyze Lock Bolt stands out as a secure, convenient, and privacy-focused solution. Its local Bluetooth control, fast fingerprint sensor, and robust security features make it ideal for anyone seeking keyless entry without cloud dependency.
What is the Wyze Lock Bolt and how does it work without WiFi?
The Wyze Lock Bolt is a smart lock that offers fingerprint unlocking and keypad access without requiring WiFi or cloud connectivity. It operates using a local Bluetooth connection, ensuring your data stays private and secure. You can control and manage the lock via the Wyze app on your smartphone, but only through Bluetooth, not the internet.Does the Wyze Lock Bolt require a mobile app or cloud connection to function?
No, the Wyze Lock Bolt does not require a cloud connection or WiFi to function. All features, including fingerprint unlocking and keypad access, work locally. The Wyze app is only needed for initial setup and management via Bluetooth, ensuring your information remains private and off the cloud.How fast is the fingerprint unlocking on the Wyze Lock Bolt?
The Wyze Lock Bolt features an ultra-fast fingerprint sensor that unlocks your door in less than a second. This provides quick and secure access without the need for keys or codes.What security features does the Wyze Lock Bolt offer?
The Wyze Lock Bolt offers several security features, including an ultra-fast fingerprint reader, a backlit keypad with anti-peep technology, auto-lock functionality, pick-proof design (no physical keyhole), and IPX5 weatherproofing for outdoor durability.Can I use the Wyze Lock Bolt at night or in low light?
Yes, the Wyze Lock Bolt has a backlit keypad, making it easy to enter your access code even in the dark. The anti-peep technology also allows you to enter random digits before or after your code for added security.How does the auto-lock feature work on the Wyze Lock Bolt?
The Wyze Lock Bolt includes an auto-lock timer that you can set via the Wyze app (using Bluetooth). After your specified delay, the lock will automatically secure your door, providing peace of mind and added security.Is the Wyze Lock Bolt weatherproof and suitable for exterior doors?
Yes, the Wyze Lock Bolt is built with IPX5 weatherproofing, making it suitable for most exterior doors and various weather conditions.How long does the Wyze Lock Bolt battery last and how is it powered?
The Wyze Lock Bolt runs on 4 AA batteries, which can last up to 12 months. It also features a low battery indicator and a USB-C port for emergency charging if needed.How many fingerprints and access codes can I store on the Wyze Lock Bolt?
You can store up to 50 fingerprints and 20 access codes on the Wyze Lock Bolt, all managed locally via Bluetooth through the Wyze app.How easy is it to install the Wyze Lock Bolt?
The Wyze Lock Bolt is designed for easy installation, replacing your existing deadbolt in about 20 minutes without the need for complicated wiring or professional help.Are replacement parts available for the Wyze Lock Bolt?
Yes, Wyze offers essential replacement parts for the Lock Bolt, including screws, the interior assembly battery cover, and the interior assembly metal plate to ensure your lock remains reliable and easy to maintain.What is the Wyze Front Porch Security Bundle?
The Wyze Front Porch Security Bundle combines the Wyze Lock Bolt with the Wyze Video Doorbell and Chime, offering 1080p HD video monitoring, two-way audio, remote lock/unlock, lock history viewing, and compatibility with Alexa and Google Assistant for a complete smart home security solution.Is the Wyze Lock Bolt compatible with voice assistants?
While the Wyze Lock Bolt itself does not require WiFi for fingerprint unlocking, it can be part of the Wyze Front Porch Security Bundle, which is compatible with Alexa and Google Assistant for voice control.
