IP65 Rated Headlamp & Lighting for Wyze Cam v3 Outdoor Security
IP65 Rated Headlamp Solutions for Wyze Cam v3 Outdoor Security
When it comes to securing your home or business outdoors, having a reliable, weather-resistant lighting and camera setup is essential. For users of the Wyze Cam v3 looking to enhance their outdoor security with an IP65 rated headlamp or lighting solution, Wyze offers several innovative products and bundles designed to provide superior illumination, continuous power, and smart automation — all built to withstand the elements.
Wyze Cam v4: The Ultimate Outdoor Security Camera with IP65 Rating
The Wyze Cam v4 is a standout choice for outdoor security, boasting an IP65 weather resistance rating that ensures it can handle rain, snow, and dust without compromising performance. This makes it an ideal upgrade or companion for Wyze Cam v3 users seeking enhanced durability and image quality.
Key Features of Wyze Cam v4
  • IP65 Weather Resistance: Designed to endure harsh outdoor conditions, the Wyze Cam v4 is fully protected against dust ingress and low-pressure water jets from any direction.
  • Crystal-Clear 2.5K QHD Resolution: Capture every detail with Quad High Definition clarity, providing sharper and more vibrant video than previous models.
  • Enhanced Color Night Vision: Unlike traditional infrared night vision, the Wyze Cam v4 uses advanced hardware to deliver full-color video even in low-light environments, giving you superhero-like vision at night.
  • Motion-Activated Spotlight: The built-in spotlight activates upon detecting motion, illuminating your property and deterring unwanted visitors.
  • Wi-Fi 6 Support: Enjoy a stronger, more reliable connection at greater distances, ensuring your camera stays online and responsive.
  • Smart Alerts & Detection: Receive notifications for motion, sound, and even smoke or CO alarms, with optional AI-powered person, pet, package, and vehicle detection through subscription plans.
  • Multiple Mounting Options: Flexible installation with stand, wall, ceiling, or magnetic mounts.
  • Continuous Local Recording: Supports microSD cards up to 512GB for 24/7 event capture.
Why Choose Wyze Cam v4 for Outdoor Security?
The Wyze Cam v4 is the clearest and most durable Wyze camera yet, making it perfect for outdoor use where weather resistance and image quality are paramount. Its IP65 rating ensures reliable operation in all seasons, while the color night vision and spotlight provide superior nighttime security.
Cam v4 + Lamp Socket v2 Bundle: Power Your Wyze Cam Without an Outlet
For those who want to power their Wyze Cam v4 outdoors without the hassle of running extension cords or finding nearby outlets, the Cam v4 + Lamp Socket v2 Bundle offers a smart and elegant solution.
Highlights of the Lamp Socket v2 Bundle
  • No Outlet Needed: The Lamp Socket v2 harnesses power directly from your existing outdoor light fixture, eliminating the need for additional wiring.
  • Easy Installation: Simply screw the socket into your outdoor lamp fixture like a lightbulb, then attach your Wyze Cam v4. No electrician required.
  • Smart Lighting Integration: The socket not only powers your camera but also makes your outdoor lighting smart. Control your lights remotely via the Wyze app.
  • Motion-Activated Lighting: Set your lights to turn on automatically when the Wyze Cam detects motion, enhancing security and convenience.
  • Expandable Setup: Link multiple lamp sockets for broader coverage and group control.
  • Dusk to Dawn Automation: Automatically turn lights on at dusk and off at dawn, saving energy and providing consistent illumination.
Compatibility and Usage
The Lamp Socket v2 works seamlessly with Wyze Cam v3, v3 Pro, v4, Cam OG, and Cam Pan v3, making it a versatile accessory for existing Wyze users upgrading their outdoor security.
Why IP65 Rating Matters for Outdoor Headlamps and Cameras
An IP65 rating means the device is dust-tight and protected against water jets, which is crucial for outdoor security equipment exposed to unpredictable weather. Using an IP65 rated headlamp or lighting accessory with your Wyze Cam ensures:
  • Durability: Protection from dust and water extends the lifespan of your security setup.
  • Reliability: Continuous operation without weather-related interruptions.
  • Safety: Reduced risk of electrical hazards caused by moisture ingress.
The Wyze Cam v4 itself carries this IP65 rating, and when paired with the Lamp Socket v2, you get a fully weatherproof, smart lighting and security solution.
Enhance Your Outdoor Security Setup Today
Whether you want the clearest, most weather-resistant camera with advanced night vision or a smart, easy-to-install power solution for your Wyze Cam, these Wyze products provide everything you need for robust outdoor security. Invest in the Wyze Cam v4 and the Cam v4 + Lamp Socket v2 Bundle to enjoy:
  • Superior image quality day and night
  • Continuous, reliable power without messy wiring
  • Smart lighting automation linked to your camera’s motion detection
  • Peace of mind knowing your security system is built to withstand the elements
Outdoor Security with Wyze Cam v4 Experience crystal-clear security with Wyze Cam v4 in any weather. Smart Outdoor Lighting with Lamp Socket v2 Easily power your Wyze Cam and control outdoor lights with the Lamp Socket v2.
FeatureWyze Cam v4 Outdoor BundleCam v4 + Lamp Socket v2 BundleWyze Cam v4
Price$69.99$49.96$100.00
Included Items1x Wyze Cam v4, 1x Wyze Outdoor Power Adapter, 1x Wyze MicroSD Card 128GB1x Wyze Cam v4, 1x Lamp Socket v21x Wyze Cam v4, Quick Start Guide, Wall Mount Plate, Wall Mount Tape, Screw Kit, Indoor USB Power Adapter, 6-ft micro USB to USB-A cable
Camera Colors AvailableBlack, Grey, WhiteBlack, Grey, WhiteWhite, Grey
Video Resolution2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD (2560x1440)
Night VisionEnhanced Color Night Vision + Motion-activated spotlightColor Night VisionEnhanced Color Night Vision + Motion-activated spotlight
Power SourceRequires Wyze Outdoor Power Adapter (included)Powered via Lamp Socket v2 (no outlet needed)Indoor USB Power Adapter (included), Outdoor Power Adapter sold separately
Local Storage128GB Wyze MicroSD Card includedmicroSD card sold separatelymicroSD card sold separately (up to 512GB)
Wi-Fi SupportWi-Fi 6Wi-Fi 6Wi-Fi 6
CompatibilityAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant, IFTTT
Weather ResistanceIP65Lamp Socket not weatherproof; suitable for damp locationsIP65
Mounting OptionsStand, Wall mount, Ceiling mount, Magnetic mountSame as Wyze Cam v4Stand, Wall mount, Ceiling mount, Magnetic mount
Additional Features24/7 local recording, motion & sound detection, smoke & CO alertsMotion-activated lights, dusk to dawn automation, link multiple sockets24/7 local recording, motion & sound detection, smoke & CO alerts
Warranty1 Year1 Year1 Year
What does IP65 rating mean for Wyze Cam v4 and outdoor headlamp solutions?An IP65 rating means the Wyze Cam v4 and compatible outdoor headlamp solutions are dust-tight and protected against water jets from any direction. This ensures reliable operation and durability in harsh weather conditions, making them ideal for outdoor security setups.
Is the Wyze Cam v4 suitable for outdoor use?Yes, the Wyze Cam v4 is specifically designed for outdoor use with its IP65 weather resistance rating. It can withstand rain, snow, dust, and other challenging outdoor elements while delivering high-quality video and security features.
What are the key features of the Wyze Cam v4 for outdoor security?The Wyze Cam v4 offers IP65 weather resistance, 2.5K QHD resolution, enhanced color night vision, a motion-activated spotlight, Wi-Fi 6 support, smart alerts and detection, multiple mounting options, and continuous local recording with microSD cards up to 512GB.
How does the Cam v4 + Lamp Socket v2 Bundle power my Wyze Cam outdoors?The Cam v4 + Lamp Socket v2 Bundle allows you to power your Wyze Cam v4 directly from your existing outdoor light fixture, eliminating the need for extension cords or nearby outlets. Simply screw the socket into your lamp fixture and attach your camera for easy, electrician-free installation.
Can I control my outdoor lights with the Lamp Socket v2?Yes, the Lamp Socket v2 makes your outdoor lighting smart. You can control your lights remotely via the Wyze app, set them to turn on automatically when motion is detected, and automate lighting schedules such as dusk to dawn operation.
Which Wyze cameras are compatible with the Lamp Socket v2?The Lamp Socket v2 is compatible with Wyze Cam v3, v3 Pro, v4, Cam OG, and Cam Pan v3, making it a versatile accessory for a range of Wyze outdoor security cameras.
Why is an IP65 rated headlamp or lighting accessory important for outdoor security cameras?An IP65 rated headlamp or lighting accessory ensures your outdoor security camera setup is protected from dust and water, providing durability, reliable operation, and safety from electrical hazards caused by moisture.
What are the benefits of using Wyze Cam v4 with the Lamp Socket v2 for outdoor security?Using Wyze Cam v4 with the Lamp Socket v2 provides superior image quality, continuous and reliable power without messy wiring, smart lighting automation linked to motion detection, and a fully weatherproof security solution.
Does the Wyze Cam v4 support continuous local recording?Yes, the Wyze Cam v4 supports continuous local recording with microSD cards up to 512GB, allowing you to capture 24/7 events for enhanced security.
How does the Wyze Cam v4 enhance nighttime security?The Wyze Cam v4 features enhanced color night vision and a motion-activated spotlight, providing full-color video and bright illumination even in low-light conditions to deter unwanted visitors and improve nighttime surveillance.
What are the key features of the Wyze Cam v4 that make it suitable for outdoor security?How does the Lamp Socket v2 work with the Wyze Cam v4?Are there any ongoing promotions or discounts available for Wyze products?
