Floodlight Mount Solutions for Easy Installation and Enhanced Security
When it comes to mounting your floodlight cameras, choosing the right floodlight mount is essential for a hassle-free setup and optimal performance. Wyze offers a range of plug-in mounts designed specifically for their floodlight cameras, eliminating the need for complex junction box installations. Whether you want a simple plug-and-play solution or a complete floodlight camera bundle, Wyze has you covered.
Wyze Cam Floodlight Plug-In Mount: Simple, Safe, and Versatile
The
Wyze Cam Floodlight Plug-In Mount is the perfect accessory for anyone looking to avoid the complexity and cost of hardwiring a floodlight. This mount offers a straightforward plug-in design that works seamlessly with all Wyze Cam Floodlight models, including v1, v2, and Floodlight Pro.
Key Features:
- Plug-n-play installation: No junction box required, making setup quick and easy.
- Outdoor safe: Rated for outdoor use with an operating temperature range from -22°F to 122°F.
- Long power cord: Comes with a 20 ft (6m) power cord for flexible placement.
- Multiple color options: Available in black and white to match your home exterior.
- Complete mounting kit included: Silicone ring, mounting screws, foam tape, and quick start guide.
This mount is ideal for homeowners who want a reliable, weather-resistant mounting solution that simplifies floodlight installation without sacrificing safety or durability.
Easy outdoor installation with Wyze Cam Floodlight Plug-In Mount
Wyze Cam Floodlight Pro + Plug-In Mount: Premium Security Bundle
For those seeking an all-in-one security lighting solution, the
Wyze Cam Floodlight Pro + Plug-In Mount bundle offers a powerful combination of advanced floodlight camera technology and the convenience of a plug-in mount.
Highlights:
- 2.5K QHD resolution with crystal-clear video quality.
- 180° ultra-wide field of view for maximum coverage.
- 3000 lumens of bright light output to illuminate large outdoor areas.
- Color night vision for clear images even in low light.
- Plug-in mount included for easy, no-junction-box installation.
- Smart integrations: Compatible with Alexa, Google Assistant, and IFTTT.
- Weather resistant: IP65 rating ensures durability in harsh conditions.
- 20 ft power cord for flexible mounting locations.
This bundle is perfect for users who want a high-performance floodlight camera with a simple mounting solution that can be installed quickly and safely.
Wyze Cam Floodlight v2 + Plug-In Mount: Balanced Performance and Convenience
The
Wyze Cam Floodlight v2 + Plug-In Mount bundle offers a great balance of features and ease of installation for everyday home security needs.
Features:
- 2K HD video with vibrant color night vision.
- 160° wide-angle view to cover broad outdoor spaces.
- 2800-lumen LED lights for bright illumination.
- Advanced motion detection and a loud 105dB siren.
- Plug-in mount included with 20 ft cable and cable management strap.
- No junction box needed for quick and easy setup.
This bundle is ideal for homeowners who want a reliable floodlight camera with strong lighting and smart features, combined with a hassle-free mounting solution.
Wyze Cam Floodlight v2 illuminating a driveway with smart motion detection
Floodlight Security Bundle: Ultimate Protection with Dual Floodlights
For comprehensive outdoor security, the
Floodlight Security Bundle combines the power of both the Floodlight Pro and Floodlight v2 cameras, offering unmatched coverage and lighting.
Bundle Benefits:
- Dual floodlight cameras: Floodlight Pro (2.5K QHD) and Floodlight v2 (2K HD).
- Super-bright LEDs: 3000 lumens (Pro) and 2800 lumens (v2).
- Wide field of view with motion-activated voice deterrence.
- 24/7 recording with microSD card support up to 256 GB.
- IP65 water resistance for all-weather durability.
- Dimmable and adjustable lighting for customized security.
- Smart home compatibility with Alexa, Google Assistant, and IFTTT.
This bundle is perfect for those who want to dominate the dark with powerful lighting and advanced security features, all mounted easily on walls or ceilings.
Wyze Cam Floodlight v2 Standalone: Flexible Mounting Options
If you already have a mounting solution or want to customize your setup, the
Wyze Cam Floodlight v2 is also available as a standalone product. It supports wall or ceiling mounting and offers:
- 2800 lumens of bright, dimmable light.
- 2K video with color night vision.
- 105dB siren and two-way audio.
- IP65 weather resistance.
- Smart integrations for voice control and automation.
This option is great for users who want to pair the floodlight with their preferred mounting accessories or upgrade existing installations.
Why Choose Wyze Floodlight Mounts?
Wyze floodlight mounts provide a safe, easy, and cost-effective way to install your outdoor security lighting without the need for complicated electrical work. Their plug-in design, weather resistance, and compatibility with multiple Wyze floodlight models make them the ideal choice for any home security setup.
Summary of Floodlight Mount Options
Product | Mount Type | Compatible Models | Key Features | Price (USD) |
Wyze Cam Floodlight Plug-In Mount | Plug-in mount | Floodlight v1, v2, Pro | 20 ft cord, outdoor safe, easy install | 19.98 |
Wyze Cam Floodlight Pro + Plug-In Mount | Bundle (camera + mount) | Floodlight Pro | 2.5K QHD, 3000 lumens, plug-in mount | 169.96 |
Wyze Cam Floodlight v2 + Plug-In Mount | Bundle (camera + mount) | Floodlight v2 | 2K HD, 2800 lumens, plug-in mount | 109.96 |
Floodlight Security Bundle | Dual floodlight bundle | Floodlight Pro + Floodlight v2 | Dual cameras, 24/7 recording, IP65 | 209.96 |
Wyze Cam Floodlight v2 (Standalone) | Wall/Ceiling mount | Floodlight v2 | 2K HD, 2800 lumens, dimmable lights | 89.98 |
Enhance your home security with Wyze floodlight mounts and floodlight cameras that combine powerful lighting, smart features, and easy installation. Choose the solution that fits your needs and enjoy peace of mind with bright, reliable outdoor security lighting.
What is the Wyze Cam Floodlight Plug-In Mount and how does it simplify installation?
The Wyze Cam Floodlight Plug-In Mount is a plug-and-play accessory designed for all Wyze Cam Floodlight models, including v1, v2, and Floodlight Pro. It eliminates the need for complex junction box installations, allowing for quick and easy setup with a 20 ft power cord and complete mounting kit. This mount is outdoor safe and available in black or white to match your home exterior.Which Wyze floodlight cameras are compatible with the plug-in mount?
The Wyze Cam Floodlight Plug-In Mount is compatible with Wyze Cam Floodlight v1, v2, and Floodlight Pro models, providing a versatile and easy installation solution for all these devices.What are the benefits of choosing a Wyze floodlight camera bundle with a plug-in mount?
Wyze floodlight camera bundles with plug-in mounts, such as the Floodlight Pro + Plug-In Mount and Floodlight v2 + Plug-In Mount, offer advanced security features like high-resolution video, wide field of view, bright LED lighting, and smart home integrations. The included plug-in mount ensures hassle-free installation without the need for a junction box.Is the Wyze Cam Floodlight Plug-In Mount weather resistant?
Yes, the Wyze Cam Floodlight Plug-In Mount is rated for outdoor use with an operating temperature range from -22°F to 122°F and features IP65 water resistance, ensuring durability in various weather conditions.What is included in the Wyze Cam Floodlight Plug-In Mount kit?
The Wyze Cam Floodlight Plug-In Mount kit includes a 20 ft (6m) power cord, silicone ring, mounting screws, foam tape, and a quick start guide for easy and secure installation.What features does the Wyze Cam Floodlight Pro + Plug-In Mount bundle offer?
The Wyze Cam Floodlight Pro + Plug-In Mount bundle features 2.5K QHD video resolution, a 180° ultra-wide field of view, 3000 lumens of bright light, color night vision, smart home compatibility (Alexa, Google Assistant, IFTTT), and a weather-resistant plug-in mount for easy installation.How does the Wyze Cam Floodlight v2 + Plug-In Mount bundle enhance home security?
The Wyze Cam Floodlight v2 + Plug-In Mount bundle provides 2K HD video, 160° wide-angle coverage, 2800-lumen LED lights, advanced motion detection, a 105dB siren, and a plug-in mount with a 20 ft cable for flexible, no-junction-box installation.What is included in the Floodlight Security Bundle from Wyze?
The Floodlight Security Bundle includes both the Floodlight Pro (2.5K QHD, 3000 lumens) and Floodlight v2 (2K HD, 2800 lumens) cameras, offering dual coverage, 24/7 recording with microSD support, IP65 water resistance, dimmable lighting, and smart home compatibility.Can I purchase the Wyze Cam Floodlight v2 as a standalone product for custom mounting?
Yes, the Wyze Cam Floodlight v2 is available as a standalone product, supporting both wall and ceiling mounting. It features 2800 lumens of dimmable light, 2K video with color night vision, a 105dB siren, two-way audio, and IP65 weather resistance.Why should I choose Wyze floodlight mounts for my outdoor security lighting?
Wyze floodlight mounts offer a safe, easy, and cost-effective installation solution for outdoor security lighting. Their plug-in design eliminates the need for complicated electrical work, and they are compatible with multiple Wyze floodlight models, making them ideal for any home security setup.What are the main differences between Wyze floodlight mount options?
Wyze offers several floodlight mount options: the Plug-In Mount for easy installation with a 20 ft cord, bundles that include both the camera and mount for Floodlight Pro and v2, a dual floodlight security bundle for maximum coverage, and a standalone v2 model for custom mounting. Each option is designed for specific security needs and installation preferences.
