Plug-In Outdoor Floodlight Cameras with 20ft Power Cord
Plug-In Mounted Outdoor Floodlight Cameras with 20ft Power Cord
When it comes to securing your outdoor spaces with powerful lighting and smart surveillance, plug-in mounted floodlight cameras offer an ideal solution. These devices combine bright, motion-activated floodlights with high-resolution cameras, providing both illumination and security without the need for complex hardwiring. If you have a convenient outdoor power outlet and want a straightforward installation with a long 20ft power cord, Wyze offers some of the best options on the market. Explore the top Wyze plug-in floodlight cameras designed to keep your home safe, well-lit, and under watchful eyes.
Wyze Cam Floodlight v2: The Ultimate Plug-In Floodlight Camera
Wyze Cam Floodlight v2 illuminating a driveway at night Bright, smart security lighting for your outdoor spaces The Wyze Cam Floodlight v2 is a standout choice for anyone seeking a plug-in mounted outdoor floodlight camera with a long power cord. It features a 20ft power cord option for easy plug-in installation, eliminating the need for an electrician or junction box.
Key Features:
  • 2800 Lumens Brightness: Two adjustable LED floodlights flood your yard with bright, motion-activated light, turning night into day.
  • 2K Video with Color Night Vision: Capture crystal-clear 2K resolution video with vibrant color even in low light, thanks to advanced night vision technology.
  • Wide 160° Field of View: See more of your property with a broad viewing angle that covers large areas and reduces blind spots.
  • AI-Powered Light Control: Intelligent lighting adjusts automatically with ambient light and motion detection for energy efficiency and security.
  • 24/7 Local Recording: Continuous recording to a microSD card (up to 256GB) means no subscription is required to save your footage.
  • Two-Way Talk & Loud Siren: Communicate with visitors or deter intruders with a 105dB siren and two-way audio through the Wyze app.
  • Dusk-to-Dawn Automation: Automatically turns on at sunset and off at sunrise for hassle-free operation.
  • IP65 Weather Resistance: Built to withstand rain, snow, and harsh outdoor conditions.
  • Smart Assistant Integration: Works seamlessly with Alexa, Google Assistant, and IFTTT for voice control and automation.
Installation & Power:
  • Designed for plug-in mounting with a 20ft power cord option, perfect for homes with accessible outdoor outlets.
  • DIY-friendly setup with no need for hardwiring or professional installation.
The Wyze Cam Floodlight v2 is perfect for homeowners and renters who want powerful lighting and security without complicated wiring.
Wyze Cam v4: Versatile Plug-In Camera with Spotlight
While not a floodlight camera by default, the Wyze Cam v4 is a plug-in outdoor camera that supports a 20ft extension cable and an outdoor power adapter (sold separately), making it a flexible option for plug-in setups.
Highlights:
  • 2.5K QHD Resolution: Ultra-clear video quality with enhanced color night vision.
  • Motion-Activated Spotlight: Built-in spotlight activates on motion to illuminate your property and deter intruders.
  • IP65 Weatherproof: Reliable performance in all weather conditions.
  • Wi-Fi 6 Support: Faster, more stable wireless connection.
  • Two-Way Talk & Siren: Communicate and sound alerts directly from your phone.
  • 24/7 Local Recording: Supports microSD cards up to 256GB for continuous recording.
  • Smart Home Compatible: Works with Alexa and Google Assistant.
Though it requires an outdoor power adapter and extension cable for plug-in use, Wyze Cam v4 offers excellent video quality and spotlight features for those who want a versatile camera with plug-in convenience.
Wyze Cam Floodlight Pro: High-Powered Security with Dual-Band Wi-Fi
For those seeking the most advanced floodlight camera with plug-in capability, the Wyze Cam Floodlight Pro is a premium option. While it is hardwired by default, it can be adapted for plug-in use with proper outdoor power outlets and extension cords.
Features:
  • 3,000 Lumens Brightness: Three dimmable LED panels provide intense illumination with 5000K color temperature.
  • 2.5K QHD Video: Crisp, detailed video with color night vision.
  • 180° Wide-Angle View: Covers a broad area with minimal blind spots.
  • AI-Powered Motion Detection: Detects people, vehicles, and pets with smart AI to trigger lights and alerts.
  • Dual-Band Wi-Fi (2.4 & 5 GHz): Ensures a strong, reliable connection.
  • 105dB Siren: Loud deterrent to keep intruders away.
  • IP65 Weather Resistance: Built for all weather conditions.
  • Smart Assistant Integration: Compatible with Alexa, Google Assistant, and IFTTT.
This model is ideal for users who want the brightest floodlight and most advanced AI detection in a plug-in style setup with a long power cord.
Why Choose a Plug-In Mounted Floodlight Camera?
Plug-in floodlight cameras with a 20ft power cord offer unmatched convenience and flexibility. They allow you to:
  • Avoid costly electrical work or rewiring.
  • Easily relocate or upgrade your security system.
  • Install quickly with minimal tools.
  • Use existing outdoor power outlets for continuous power.
Wyze’s lineup of plug-in floodlight cameras combines powerful lighting, high-resolution video, and smart features to keep your home safe and well-lit.
Summary of Plug-In Floodlight Cameras
ProductResolutionFloodlight BrightnessField of ViewPower SetupWeatherproofSpecial Features
Wyze Cam Floodlight v22K2800 Lumens160°Plug-in with 20ft cordIP65AI Light Control, Two-way Talk, Siren
Wyze Cam v42.5K QHDSpotlight (motion)115.9°Plug-in with adapter & extensionIP65Wi-Fi 6, Enhanced Color Night Vision
Wyze Cam Floodlight Pro2.5K QHD3000 Lumens180°Hardwired (adaptable)IP65AI Detection, Dual-Band Wi-Fi, Siren
Enhance Your Outdoor Security Today
Choosing the right plug-in mounted outdoor floodlight camera with a 20ft power cord means balancing brightness, video quality, and smart features. Wyze’s cameras provide excellent options for every need and budget, making your home safer and smarter with easy installation.
Wyze Cam Floodlight v2 lifestyle with two-way talk Communicate easily with two-way talk feature
FeatureWyze Cam Floodlight v2Wyze Cam v4Wyze Cam Floodlight Pro
Price$89.98$35.98 (single)$149.98
Color VariantsBlack, WhiteBlack, Grey, White, Clear (some sold out)Black, White
Video Resolution2K (2560x1440)2.5K QHD (2560x1440)2.5K QHD (2560x1440)
Field of View160° wide-angle115.9° (D) x 98.5° (H) x 53.1° (V)180° Diagonal, 170° Horizontal, 95° Vertical
Night VisionColor Night VisionEnhanced Color Night VisionColor Night Vision
Lighting2 floodlight heads, 2800 lumens, adjustable, motion-activatedMotion-activated spotlight3 dimmable light panels, 3000 lumens, 5000K
AudioTwo-way talk + 105dB sirenEnhanced two-way talk + 99dB sirenTwo-way talk + 105dB siren
Motion Detection270° PIR motion detectionMotion and sound detection, motion detection zonesAI computer vision with selectable object detection
Local Recording24/7 local recording to microSD (up to 256GB)24/7 local recording to microSD (up to 256GB)24/7 local recording to microSD (up to 256GB)
Wi-Fi Support2.4 GHz2.4 GHz & Wi-Fi 62.4 GHz & 5 GHz dual-band
Power SourceHardwiredWiredHardwired 110-120V AC
Weather ResistanceIP65IP65IP65
Smart Assistant IntegrationAlexa, Google AssistantAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Special FeaturesAmbient Light Mode, AI-Powered Light Control, dusk-to-dawn automationBluetooth setup, Wide Dynamic Range (WDR), Smoke & CO alerts, Auto-zoom with AIAI-powered selective lighting, 3 floodlight heads, wider field of view
DimensionsNot specified2in x 2in x 2 3/8in10.2 in x 9.1 in x 7.8 in
WeightNot specified0.49 lb (222 g)2.9 lbs (1.32 kg)
WarrantyNot specified1-Year1-Year
What are plug-in mounted outdoor floodlight cameras with a 20ft power cord?Plug-in mounted outdoor floodlight cameras with a 20ft power cord are security devices that combine powerful, motion-activated floodlights with high-resolution cameras. They are designed for easy installation using an outdoor power outlet, eliminating the need for hardwiring or professional installation. The 20ft power cord provides flexibility in placement, making them ideal for homeowners and renters seeking convenient and effective outdoor security.
Which Wyze floodlight cameras support plug-in installation with a 20ft power cord?The Wyze Cam Floodlight v2 is specifically designed for plug-in installation and comes with a 20ft power cord for easy setup. The Wyze Cam v4 can also be used as a plug-in camera with a 20ft extension cable and outdoor power adapter (sold separately). The Wyze Cam Floodlight Pro is hardwired by default but can be adapted for plug-in use with the appropriate outdoor power outlets and extension cords.
What are the key features of the Wyze Cam Floodlight v2?The Wyze Cam Floodlight v2 offers 2800 lumens of adjustable LED lighting, 2K video resolution with color night vision, a wide 160° field of view, AI-powered light control, 24/7 local recording to a microSD card, two-way talk, a 105dB siren, dusk-to-dawn automation, IP65 weather resistance, and compatibility with Alexa, Google Assistant, and IFTTT. It is designed for easy plug-in installation with a 20ft power cord.
How does the Wyze Cam v4 differ from the Wyze Cam Floodlight v2?The Wyze Cam v4 is a versatile plug-in outdoor camera that features 2.5K QHD resolution, a motion-activated spotlight, IP65 weatherproofing, Wi-Fi 6 support, two-way talk, a siren, and 24/7 local recording. Unlike the Floodlight v2, it does not have full floodlights by default but can be used with a 20ft extension cable and outdoor power adapter for plug-in convenience.
Can the Wyze Cam Floodlight Pro be used as a plug-in floodlight camera?The Wyze Cam Floodlight Pro is designed to be hardwired, but it can be adapted for plug-in use if you have a suitable outdoor power outlet and use an appropriate extension cord. It offers 3,000 lumens of brightness, 2.5K QHD video, a 180° wide-angle view, AI-powered motion detection, dual-band Wi-Fi, a 105dB siren, and IP65 weather resistance.
What are the benefits of choosing a plug-in mounted floodlight camera with a 20ft power cord?Plug-in mounted floodlight cameras with a 20ft power cord offer several benefits, including easy DIY installation without the need for electrical work, the ability to relocate or upgrade your security system easily, quick setup with minimal tools, and continuous power using existing outdoor outlets. They provide a flexible and cost-effective solution for enhancing outdoor security.
Are Wyze plug-in floodlight cameras weatherproof?Yes, Wyze plug-in floodlight cameras such as the Wyze Cam Floodlight v2, Wyze Cam v4, and Wyze Cam Floodlight Pro are all rated IP65 weather resistant. This means they are built to withstand rain, snow, and harsh outdoor conditions, ensuring reliable performance year-round.
Do Wyze plug-in floodlight cameras require a subscription for video recording?No, Wyze plug-in floodlight cameras support 24/7 local recording to a microSD card (up to 256GB), so you do not need a subscription to save your footage. However, cloud storage and additional features may be available with a Wyze subscription.
Are Wyze plug-in floodlight cameras compatible with smart home assistants?Yes, Wyze plug-in floodlight cameras are compatible with popular smart home assistants, including Amazon Alexa, Google Assistant, and IFTTT. This allows for voice control and integration with your smart home automation routines.
How do I install a Wyze plug-in floodlight camera with a 20ft power cord?To install a Wyze plug-in floodlight camera with a 20ft power cord, simply mount the camera in your desired outdoor location, plug the power cord into a nearby outdoor outlet, and follow the setup instructions in the Wyze app. No hardwiring or professional installation is required, making it a quick and easy DIY project.
What are the key features of the Wyze Cam Floodlight v2?Can you tell me more about the installation process for the Wyze Cam Floodlight v2?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Cam Floodlight v2?
