Add Extra Chimes for Full Floor Coverage with Wyze Doorbell
Enhance Your Wyze Doorbell Coverage with Extra Chimes
If you're looking to expand your Wyze doorbell's audio coverage across multiple floors or rooms, adding an extra chime is the perfect solution. Wyze offers versatile accessories designed to seamlessly integrate with your Wyze Video Doorbell v2, ensuring you never miss a visitor no matter where you are in your home.
Wyze Universal Wi-Fi Chime: Wireless Convenience for Any Wyze Doorbell
Key Features
- Wireless Setup: No complicated wiring needed; simply plug in the Wyze Universal Wi-Fi Chime to any standard power outlet.
- Wide Compatibility: Works with all Wyze Cams and doorbells, including the Wyze Video Doorbell v2.
- Multiple Tones: Choose from 17 different chime tones to suit your preference.
- Smart Automations: Program the chime to sound not only when the doorbell rings but also when your Wyze cameras detect motion or people.
- Multi-Device Connection: Connect multiple chimes throughout your home for comprehensive coverage.
Specifications
- Dimensions: 81 x 53 x 38 mm
- Speaker Size: 40mm
- Wi-Fi: IEEE802.11 b/g/n 2.4 GHz
- Power Input: 10-24V AC, 10VA 60Hz
- Operating Temperature: -4°F to 122°F (-20°C to 50°C)
- Bluetooth: BLE 5.0
- Certifications: FCC, IC, UL, CP65
The Wyze Universal Wi-Fi Chime is ideal for homeowners who want a fuss-free, wireless way to hear their doorbell from anywhere inside the house, especially in multi-level homes.
Wyze Chime Controller: Perfect Companion for Wyze Video Doorbell v2
Why Choose the Wyze Chime Controller?
- Designed for Wired Doorbells: This standalone chime controller unit is specifically compatible with the Wyze Video Doorbell v2 and Duo Cam Doorbell.
- Mechanical Chime Compatibility: Works with nearly every mechanical chime, allowing you to integrate your existing chime hardware.
- Easy Installation: Simple wiring process makes setup quick and hassle-free.
- Compact Design: Small footprint (47mm x 32mm x 15mm) fits discreetly behind your chime.
Technical Details
- Power: AC16V/AC24V, ≥10VA
- Wire Length: 13cm
- Operating Temperature: -20°C to 50°C
- Storage Temperature: -40°C to 80°C
For those with existing mechanical chimes or wired setups, the Wyze Chime Controller is the perfect accessory to extend your doorbell’s audible reach without replacing your current hardware.
Wyze Video Doorbell v2: The Core of Your Smart Doorbell System
Advanced Video and Audio Features
- 2K HD Video: Crystal-clear 2048 x 1536 resolution with a wide 166.8° diagonal field of view.
- Night Vision: Equipped with 6 infrared LEDs for clear nighttime monitoring.
- Two-Way Audio: Built-in microphone and speaker with noise and echo cancellation.
- Local and Cloud Storage: Supports microSD cards up to 256GB and optional cloud storage with Wyze Security Plan.
- Weather Resistant: IP65 rating ensures durability in all weather conditions.
Compatibility and Integration
- Works seamlessly with the Wyze Chime Controller and Universal Wi-Fi Chime.
- Supports voice assistants like Alexa, Google Assistant, and IFTTT.
- Easy installation with included accessories such as wall plates, wedges, and wire caps.
The Wyze Video Doorbell v2 is the foundation of your smart home entry system, providing high-quality video and audio while supporting multiple chime options for enhanced coverage.
Why Add Extra Chimes for Your Wyze Doorbell?
Expanding your doorbell’s audible range with additional chimes ensures you never miss a visitor or delivery, no matter where you are in your home. Whether you prefer wireless convenience or integrating with existing mechanical chimes, Wyze offers flexible solutions tailored to your setup.
Summary of Recommended Products for Extra Chime Coverage
Product Name | Compatibility | Price (USD) | Key Benefit |
Wyze Universal Wi-Fi Chime | All Wyze Cams & Doorbells | $19.98 | Wireless, multi-tone chime |
Wyze Chime Controller | Wyze Video Doorbell v2 & Duo | $17.99 | Mechanical chime integration |
Wyze Video Doorbell v2 | Wired Doorbell with Chime Ctrl | $44.98 | High-res video + chime support |
Experience seamless home security and convenience with Wyze doorbell and chimes.
By choosing the right Wyze chime accessory, you can customize your home’s doorbell system to fit your lifestyle and home layout perfectly. Whether you want wireless flexibility or wired integration, Wyze has you covered for complete floor-to-floor coverage.
Feature | Wyze Universal Wi-Fi Chime | Wyze Chime Controller | Wyze Video Doorbell v2 |
Type | Accessory | Accessory | Camera |
Compatibility | Works with all Wyze cameras and doorbells | Only compatible with Wyze Video Doorbell v2 and Duo Cam Doorbell | Standalone product |
Installation | Plug-in, no wiring required | Requires wiring, works with existing mechanical chimes | Wired installation (16V-24V AC) |
Power | Plug-in | Wired (AC 16-24 V) | Wired (16V-24V AC, ≥10VA) |
Alerts | Chimes on doorbell press or person detection | Works with in-house mechanical chime | Two-way audio, real-time alerts, motion detection |
Video Resolution | N/A | N/A | 2K (2048 x 1536) |
Field of View | N/A | N/A | 135° horizontal, 103° vertical |
Storage | N/A | N/A | Local microSD up to 256GB, cloud with subscription |
Smart Automations | Yes, can chime on person detection | No | Yes |
Mounting Options | Anywhere, plug-in | Screw mounting | Screw mounting |
Price (USD) | $19.98 | $17.99 (currently out of stock) | $44.98 (Doorbell + Chime Controller bundle) |
How can I expand the audio coverage of my Wyze Video Doorbell v2?
You can expand your Wyze Video Doorbell v2’s audio coverage by adding extra chimes, such as the Wyze Universal Wi-Fi Chime or the Wyze Chime Controller. These accessories allow you to hear your doorbell from multiple rooms or floors, ensuring you never miss a visitor.What is the Wyze Universal Wi-Fi Chime and how does it work?
The Wyze Universal Wi-Fi Chime is a wireless accessory that plugs into any standard power outlet and works with all Wyze Cams and doorbells, including the Wyze Video Doorbell v2. It offers 17 different chime tones, supports smart automations, and allows you to connect multiple chimes throughout your home for comprehensive coverage.Is the Wyze Universal Wi-Fi Chime compatible with all Wyze doorbells?
Yes, the Wyze Universal Wi-Fi Chime is compatible with all Wyze Cams and doorbells, including the Wyze Video Doorbell v2. It provides wireless convenience and can be easily set up in any room.Can I use multiple Wyze Universal Wi-Fi Chimes in my home?
Yes, you can connect multiple Wyze Universal Wi-Fi Chimes throughout your home to ensure you hear your doorbell from any room or floor.What are the key features of the Wyze Universal Wi-Fi Chime?
Key features of the Wyze Universal Wi-Fi Chime include wireless setup, compatibility with all Wyze Cams and doorbells, 17 selectable chime tones, smart automations for motion or person detection, and the ability to connect multiple chimes for full-home coverage.What is the Wyze Chime Controller and who should use it?
The Wyze Chime Controller is a standalone unit designed for wired doorbells, specifically the Wyze Video Doorbell v2 and Duo Cam Doorbell. It allows you to integrate your existing mechanical chime hardware, making it ideal for homeowners who want to extend their doorbell’s audible reach without replacing their current chime.Is the Wyze Chime Controller compatible with mechanical chimes?
Yes, the Wyze Chime Controller is compatible with nearly every mechanical chime, allowing you to use your existing chime hardware with the Wyze Video Doorbell v2.What are the installation requirements for the Wyze Chime Controller?
The Wyze Chime Controller requires a simple wiring process and is powered by AC16V/AC24V, ≥10VA. Its compact design allows it to fit discreetly behind your existing chime.What are the main features of the Wyze Video Doorbell v2?
The Wyze Video Doorbell v2 features 2K HD video resolution, a wide 166.8° field of view, night vision with 6 infrared LEDs, two-way audio with noise and echo cancellation, support for local and cloud storage, and weather resistance with an IP65 rating.Does the Wyze Video Doorbell v2 support voice assistants?
Yes, the Wyze Video Doorbell v2 supports popular voice assistants such as Alexa, Google Assistant, and IFTTT for seamless smart home integration.Why should I add extra chimes to my Wyze doorbell system?
Adding extra chimes to your Wyze doorbell system ensures you never miss a visitor or delivery, no matter where you are in your home. Wyze offers both wireless and wired chime solutions to fit different home layouts and preferences.What are the prices and key benefits of Wyze chime accessories?
The Wyze Universal Wi-Fi Chime is priced at $19.98 and offers wireless, multi-tone chime options. The Wyze Chime Controller costs $17.99 and enables integration with mechanical chimes. The Wyze Video Doorbell v2 is available for $44.98 and provides high-resolution video with chime support.Can I use both the Wyze Universal Wi-Fi Chime and the Wyze Chime Controller with the Wyze Video Doorbell v2?
Yes, the Wyze Video Doorbell v2 is compatible with both the Wyze Universal Wi-Fi Chime and the Wyze Chime Controller, allowing you to customize your doorbell system for wireless or wired chime coverage.
Can you tell me more about the Wyze Universal Wi-Fi Chime and its features?How does the Wyze Chime Controller work with the Wyze Video Doorbell v2?Do you have any ongoing sales or discounts for Wyze accessories?
