Wyze Cam 20ft USB Extension Cable: Relocate Your Camera for Better Wi-Fi & Flexible Placement
Extend Your Wyze Cam Reach: The Ultimate 20ft USB Extension Cable Solution
Are you struggling with poor Wi-Fi reception for your Wyze Cam due to limited cable length? Relocating your camera to a better spot is now easier than ever with the Wyze Cam USB Extension Cable - 20ft. Discover how this essential accessory, paired with the latest Wyze Cams, can transform your home security setup.
Why Choose a 20ft USB Extension Cable for Your Wyze Cam?
Short cables can limit your camera placement, often forcing you to settle for suboptimal Wi-Fi spots. The Wyze Cam USB Extension Cable - 20ft gives you the freedom to position your camera exactly where you need it—indoors or outdoors—without worrying about power access.
"Say goodbye to short cables and enjoy the freedom of a 20ft cable."
Key Features:
  • Length: 20ft (6m) for maximum flexibility
  • Compatibility: Works with Wyze Cam v2/v3/v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto
  • Weatherproof: IP67 rating for reliable outdoor use
  • Durability: Built with AWG 18# wire for safe, efficient charging
  • Easy Installation: Plug-and-play design with USB Type A Male to Female connectors
Wyze Cam in a cozy outdoor lifestyle setting, showing flexible placement with a long cable
Compatible Wyze Cameras: Unlock New Placement Possibilities
The 20ft USB Extension Cable is designed to work seamlessly with a range of Wyze Cams, allowing you to relocate your camera to the perfect Wi-Fi spot.
Wyze Cam v4: Next-Gen Clarity and Flexibility
  • Resolution: 2.5K QHD (2560x1440) for ultra-clear video
  • Weather Resistance: IP65 for indoor/outdoor use
  • Night Vision: Color night vision with 4 IR LEDs and 2 white spotlights
  • Smart Features: Motion-activated spotlight, built-in siren, and simultaneous two-way talk
  • Connectivity: Supports 2.4 GHz Wi-Fi and Wi-Fi 6
Wyze Cam OG & OG Telephoto: Versatile Security, Indoors and Out
  • Wyze Cam OG: 120° field of view, built-in 40-lumen spotlight, 90dB siren, and 1080p HD video
  • Wyze Cam OG Telephoto: 3x telephoto lens for detailed monitoring, 1080p HD, and color night vision
  • Both: IP65 weather resistance, upgraded two-way audio, and support for up to 256GB microSD cards
Wyze Cam OG Telephoto and OG in a home security lifestyle context
Weatherproof and Reliable for Any Environment
Whether you’re mounting your Wyze Cam in the living room, on the porch, or in the backyard, the 20ft USB Extension Cable is built to withstand the elements.
  • IP67 Weather Rating: Protects against dust and water, ensuring safe outdoor use
  • Operating Temperature: -30°C to 50°C (-22°F to 122°F)
  • Robust Construction: Designed for long-term durability in any setting
"Extend your reach with ease 🛠️ Designed to work with specific Wyze Cameras."
Installation Tips for Optimal Wi-Fi and Security
  • Choose the Best Wi-Fi Spot: Use the extra length to move your camera closer to your router or access point for a stronger, more reliable connection.
  • Outdoor Placement: Take advantage of the cable’s weatherproof design to monitor driveways, patios, or entryways.
  • Secure Routing: Run the cable along walls or under eaves to keep it tidy and protected.
Wyze Cam v4 in a high-resolution, night vision lifestyle scenario
Frequently Asked Questions
Q: Does the 20ft USB Extension Cable come with a power adapter? A: No, it does not. Use any Wyze-branded 5V/2A power adapter for best results. Q: Is this cable compatible with Wyze Cam Outdoor or Wyze Doorbell? A: No, it is not compatible with Wyze Cam Outdoor or Wyze Doorbell products. Q: Can I use this cable for data transfer? A: No, this extension cable is for charging only and does not support data transmission.
Conclusion: Relocate Your Wyze Cam with Confidence
Upgrade your Wyze Cam setup with the 20ft USB Extension Cable and enjoy the freedom to place your camera wherever you need it most. Whether you’re improving Wi-Fi connectivity or expanding your surveillance coverage, this essential accessory ensures your Wyze Cam is always in the right spot.
Featured Products:
  • Wyze Cam USB Extension Cable - 20ft
  • Wyze Cam v4
  • Wyze Cam OG
Take control of your home security and never settle for poor Wi-Fi spots again!
FeatureWyze Cam USB Extension Cable - 20ftWyze Cam OG TelephotoWyze Cam OGWyze Cam v4
Product TypeAccessory (USB Extension Cable)Security CameraSecurity CameraSecurity Camera
Price$7.99$29.98 (1 pack)$21.58 (1 pack)$35.98 (1 pack)
Cable Length / Power20ft / 5V 2A6ft USB cable / 5V 1A6ft USB cable / 5V 1A6ft USB cable / 5V 1A
CompatibilityWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG, OG TelephotoStandalone or with OGStandalone or with OG Telephoto-
Video ResolutionN/A1080p Full HD (1920 x 1080)1080p Full HD (1920 x 1080)2.5K QHD (2560 x 1440)
Field of ViewN/A27° (DFOV)120°115.8° (DFOV)
Night VisionN/AColor Night VisionColor Night VisionEnhanced Color Night Vision
Weather ResistanceIP67IP65IP65IP65
Indoor/Outdoor UseYesYesYesYes
Special FeaturesCharge only, no data, weatherproof3x Telephoto lens, 3x faster notifications, 2-way audio, Picture-in-Picture, 90dB sirenBuilt-in spotlight (40 lumens), 3x faster notifications, 2-way audio, Picture-in-Picture, 90dB sirenMotion-activated spotlight (72 lumens), built-in siren, Wi-Fi 6, 8x digital zoom, simultaneous 2-way talk
Local StorageN/AmicroSD up to 256GBmicroSD up to 256GBmicroSD up to 512GB
Cloud StorageN/AWith Cam Plus subscriptionWith Cam Plus subscriptionWith subscription plan
Smart IntegrationsN/AAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Operating Temperature-30°C to 50°C (-22°F to 122°F)-4°F to 131°F (-20°C to 55°C)-4°F to 131°F (-20°C to 55°C)-4°F to 122°F (-20°C to 50°C)
Dimensions (Camera)N/A1.89" x 1.89" x 1.89"1.89" x 1.89" x 1.89"2" x 2" x 2 3/8"
Warranty30-day returns1-Year1-Year1-Year
What Wyze cameras are compatible with the 20ft USB Extension Cable?The 20ft USB Extension Cable is compatible with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2, v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto. It is not compatible with Wyze Cam Outdoor or Wyze Doorbell products.
Is the Wyze Cam 20ft USB Extension Cable weatherproof for outdoor use?Yes, the Wyze Cam 20ft USB Extension Cable is IP67 rated, making it weatherproof and suitable for both indoor and outdoor use. It is designed to withstand dust, water, and extreme temperatures from -30°C to 50°C (-22°F to 122°F).
Does the 20ft USB Extension Cable come with a power adapter?No, the 20ft USB Extension Cable does not include a power adapter. For best performance, use any Wyze-branded 5V/2A power adapter.
Can I use the Wyze Cam 20ft USB Extension Cable for data transfer?No, the Wyze Cam 20ft USB Extension Cable is designed for charging and power only. It does not support data transmission.
How does the 20ft USB Extension Cable improve Wyze Cam placement and Wi-Fi connectivity?The 20ft length allows you to position your Wyze Cam closer to your Wi-Fi router or in optimal locations for better signal strength, both indoors and outdoors, without worrying about power outlet proximity.
What are the key features of the Wyze Cam 20ft USB Extension Cable?Key features include a 20ft (6m) length for flexible placement, IP67 weatherproof rating, AWG 18# wire for safe and efficient charging, and a plug-and-play USB Type A Male to Female design for easy installation.
Is the Wyze Cam 20ft USB Extension Cable easy to install?Yes, the extension cable features a plug-and-play design with USB Type A Male to Female connectors, making installation quick and simple.
Can I use the 20ft USB Extension Cable with Wyze Cam Outdoor or Wyze Doorbell?No, the 20ft USB Extension Cable is not compatible with Wyze Cam Outdoor or Wyze Doorbell products.
What installation tips help optimize Wyze Cam performance with the extension cable?For optimal performance, use the extra cable length to place your camera closer to your Wi-Fi router, securely route the cable along walls or under eaves, and take advantage of the weatherproof design for outdoor monitoring.
What are the key features of the Wyze Cam USB Extension Cable - 20ft?Is the 20ft USB Extension Cable compatible with all Wyze Cam models?Do you have any ongoing sales or discounts for the Wyze Cam USB Extension Cable?
