Extend Wyze Cam Power 20ft for Driveway Window Monitoring
Stretching Wyze Cam Power to an Outer Window Facing the Driveway
If you're looking to extend the power supply of your Wyze Cam to an outer window facing your driveway, the Wyze Cam v4 combined with the right accessories offers a seamless and reliable solution. Whether you want to monitor your driveway with crystal-clear video or ensure your camera stays powered without hassle, Wyze has you covered with versatile options including USB extension cables and smart power adapters.
Wyze Cam v4: The Ultimate Outdoor Security Camera
Superior Video Quality and Night Vision
The Wyze Cam v4 delivers stunning 2.5K Quad High Definition video, providing crystal-clear images and videos of your driveway and surroundings. Its enhanced Color Night Vision technology allows you to see vibrant colors even in low-light conditions, making nighttime monitoring more effective than ever.
Weather-Resistant and Durable
Rated IP65 for weather resistance, the Wyze Cam v4 is built to withstand rain, snow, and dust, making it perfect for outdoor placement near your driveway or outer window. This means you can confidently mount it outside without worrying about the elements.
Easy Setup and Smart Features
  • Bluetooth® setup eliminates the need for QR codes.
  • Screw-free magnetic mount allows quick installation on metal surfaces or with the included mounting plate.
  • Supports Wi-Fi 6 for a stronger, more reliable connection even at greater distances.
  • Motion and sound detection with customizable detection zones.
  • Smoke and CO alarm alerts for added safety.
Powering Your Wyze Cam v4 Outdoors
To power your Wyze Cam v4 at an outer window or driveway-facing location, consider using a USB extension cable up to 20 feet long. This allows you to stretch the power source from an indoor outlet to your desired outdoor mounting spot without compromising power stability.
Wyze Cam v4 Outdoor Bundle: Ready for Extended Outdoor Use
What’s Included
  • Wyze Cam v4 with all the advanced features mentioned above.
  • Wyze Outdoor Power Adapter designed specifically for outdoor use, ensuring safe and continuous power supply.
  • 128GB Wyze MicroSD Card for 24/7 local recording without subscription fees.
Why Choose the Outdoor Bundle?
This bundle is ideal if you want a hassle-free setup for your driveway camera. The outdoor power adapter is weatherproof and built to handle outdoor conditions, making it perfect for powering your Wyze Cam v4 through a window or mounted outside.
Enhanced Security Features
  • Motion-activated spotlight to deter intruders.
  • 99 dB siren for added security.
  • Integration with Alexa and Google Assistant for voice control and smart home compatibility.
Stretching your power with a 20ft USB extension cable combined with the outdoor power adapter ensures your Wyze Cam v4 stays powered reliably, even when mounted far from indoor outlets.
Wyze Cam v4 monitoring driveway Alt text: Wyze Cam v4 mounted on an outer window overlooking a driveway
Cam v4 + Lamp Socket v2 Bundle: Power Without an Outlet
Innovative Power Solution
If running a USB extension cable is inconvenient, the Cam v4 + Lamp Socket v2 Bundle offers a smart alternative. This bundle allows you to power your Wyze Cam v4 through a standard lamp socket, eliminating the need for a nearby power outlet.
Features of the Lamp Socket v2
  • Compatible with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3.
  • Motion-activated lighting with dusk-to-dawn scheduling.
  • Easy installation with E26 socket compatibility.
  • Suitable for damp locations (not fully weatherproof).
Ideal Use Case
Mount your Wyze Cam v4 near an outdoor light fixture or porch lamp socket facing your driveway. This setup provides continuous power and smart lighting control, enhancing both security and convenience.
Summary: Best Options for Extending Wyze Cam Power Outdoors
ProductKey BenefitsPower Extension Solution
Wyze Cam v42.5K QHD, Color Night Vision, IP65 ratedUse with 20ft USB extension cable
Wyze Cam v4 Outdoor BundleIncludes outdoor power adapter and microSD cardOutdoor power adapter for weatherproof power
Cam v4 + Lamp Socket v2 BundlePowers camera via lamp socket, motion-activated lightNo outlet needed, uses lamp socket power
By combining the Wyze Cam v4 with a 20ft USB extension cable and either the Outdoor Power Adapter or Lamp Socket v2, you can easily position your camera at an outer window facing your driveway with reliable power and enhanced security features.
FeatureWyze Cam v4Wyze Cam v4 Outdoor BundleCam v4 + Lamp Socket v2 Bundle
Price$100.00 (special American worker support version) / $35.98 - $107.94 (regular versions)$69.99$49.96
Included ItemsWyze Cam v4 onlyWyze Cam v4, Wyze Outdoor Power Adapter, 128GB MicroSD CardWyze Cam v4, Lamp Socket v2
Resolution2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD (2560x1440) (camera only)
Night VisionEnhanced Color Night VisionEnhanced Color Night VisionEnhanced Color Night Vision (camera only)
SpotlightMotion-activated spotlightMotion-activated spotlightNo spotlight (lamp socket powers camera)
SirenYes (99 dB)YesNo
AudioEnhanced Two-Way TalkEnhanced Two-Way TalkTwo-Way Talk (camera only)
Weather ResistanceIP65IP65Lamp Socket: Not weatherproof, suitable for damp locations
PowerWired, requires power adapterWired, includes Outdoor Power AdapterPowered via Lamp Socket (E26 socket, 120V~, 60Hz)
Local StoragemicroSD card support up to 512GBmicroSD card included (128GB)microSD card required (not included)
Wi-Fi Support2.4 GHz Wi-Fi, Wi-Fi 62.4 GHz Wi-Fi, Wi-Fi 62.4 GHz Wi-Fi, Bluetooth (camera only)
Smart Assistant IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT (camera only)
Mounting OptionsStand, Wall, Ceiling, Magnetic mountSame as Wyze Cam v4Lamp Socket mounts in standard E26 socket
Additional FeaturesSmoke & CO Alerts, Motion Detection Zones, AI Auto-ZoomSame as Wyze Cam v4Motion-Activated Lights, Dusk to Dawn Scheduling (lamp socket)
Dimensions (Camera)2in x 2in x 2 3/8in (222g)Same as Wyze Cam v4Lamp Socket: 56.5mm x 56.5mm x 65mm (80g)
Warranty1 Year1 Year1 Year
NotesRequires microSD card and power adapter (sold separately) for outdoor useOutdoor Power Adapter and 128GB microSD includedIncandescent bulbs not supported; use CFL or LED under 20W
How can I power my Wyze Cam v4 at an outer window facing my driveway?You can power your Wyze Cam v4 at an outer window by using a USB extension cable up to 20 feet long, allowing you to connect the camera to an indoor outlet while mounting it outside. For added weather resistance and reliability, consider using the Wyze Outdoor Power Adapter, which is designed specifically for outdoor use.
Is the Wyze Cam v4 suitable for outdoor use?Yes, the Wyze Cam v4 is rated IP65 for weather resistance, making it durable and suitable for outdoor placement. It can withstand rain, snow, and dust, so you can confidently mount it near your driveway or on an outer window.
What are the video quality and night vision features of the Wyze Cam v4?The Wyze Cam v4 offers 2.5K Quad High Definition video for crystal-clear images and videos. It also features enhanced Color Night Vision technology, allowing you to see vibrant colors even in low-light conditions, making it ideal for nighttime driveway monitoring.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes the Wyze Cam v4, a weatherproof Wyze Outdoor Power Adapter for safe and continuous outdoor power, and a 128GB Wyze MicroSD Card for 24/7 local recording without subscription fees.
How does the Cam v4 + Lamp Socket v2 Bundle work for outdoor power?The Cam v4 + Lamp Socket v2 Bundle allows you to power your Wyze Cam v4 through a standard E26 lamp socket, eliminating the need for a nearby power outlet. The Lamp Socket v2 also provides motion-activated lighting and dusk-to-dawn scheduling, making it a convenient solution for mounting your camera near outdoor light fixtures.
Can I use the Lamp Socket v2 outdoors?The Lamp Socket v2 is suitable for damp locations but is not fully weatherproof. It is ideal for use in covered outdoor areas, such as porch lamp sockets, to power your Wyze Cam v4 while providing smart lighting control.
What smart features does the Wyze Cam v4 offer for driveway security?The Wyze Cam v4 includes motion and sound detection with customizable detection zones, smoke and CO alarm alerts, a motion-activated spotlight, a 99 dB siren, and integration with Alexa and Google Assistant for voice control and smart home compatibility.
How far can I extend the power supply for my Wyze Cam v4?You can extend the power supply for your Wyze Cam v4 up to 20 feet using a USB extension cable. For outdoor installations, pairing the extension cable with the Wyze Outdoor Power Adapter ensures reliable and weatherproof power delivery.
Do I need a subscription for 24/7 recording with Wyze Cam v4?No, you do not need a subscription for 24/7 recording. The Wyze Cam v4 Outdoor Bundle includes a 128GB Wyze MicroSD Card, allowing you to record and store footage locally without any ongoing fees.
What are the best options for extending Wyze Cam power outdoors?The best options for extending Wyze Cam power outdoors include using a 20ft USB extension cable with the Wyze Outdoor Power Adapter for weatherproof power, or the Cam v4 + Lamp Socket v2 Bundle to power your camera via a standard lamp socket without needing an outlet.
What are the key features of the Wyze Cam v4 that make it suitable for outdoor use?Can you explain how the Bluetooth setup for the Wyze Cam v4 works?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Cam v4?
