Extend Wyze Cam Reach in Detached Garages with 20ft USB Cable
Extend Your Wyze Cam Reach with the 20ft USB Extension Cable
If you have a Wyze Cam installed in a detached garage or any location where the power outlet is far from the camera, the Wyze Cam USB Extension Cable - 20ft is the perfect accessory to extend your camera’s reach without hassle. This cable is compatible with a wide range of Wyze cameras including Wyze Cam v2, v3, v4, Wyze Cam Pan v2/v3, and the original Wyze Cam models.
Key Features of the Wyze Cam USB Extension Cable - 20ft
  • Length: 20 feet of flexible USB extension cable to reach distant power sources.
  • Compatibility: Works seamlessly with Wyze Cam v2/v3/v4, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
  • Easy Setup: Simply plug the extension cable between your camera and power adapter to gain extra length.
  • Affordable: Priced at just $7.99, it’s a cost-effective solution to power your camera in hard-to-reach places.
This cable is ideal for detached garages, workshops, or any outdoor structure where running power cables is challenging. It ensures your Wyze Cam stays powered and connected without compromising on placement flexibility.
Wyze Battery Cam Pro – Wireless Freedom for Detached Locations
For those who want to avoid cables altogether, the Wyze Battery Cam Pro offers a wire-free security camera solution perfect for detached garages or remote areas.
Why Choose Wyze Battery Cam Pro?
  • Wire-Free Operation: No need for power outlets or hubs; runs on removable, rechargeable battery packs.
  • 2.5K HDR Video: Crystal-clear video quality with enhanced color and detail.
  • Integrated Spotlight & Siren: Motion-activated 150-lumen spotlight and siren for added security.
  • Radar + PIR Motion Detection: Dual sensors for precise and early motion alerts.
  • Weatherproof: Rated IP65, it withstands rain, dust, and extreme temperatures.
  • Wi-Fi Support: Connects to both 2.4 GHz and 5 GHz networks for reliable streaming.
  • Expandable Power: Compatible with Wyze Solar Panel for continuous charging outdoors.
This camera is perfect if you want to install a security camera in a detached garage without worrying about power cables or complicated wiring.
Wired Options: Wyze Cam OG and Wyze Cam OG Telephoto
If you prefer wired cameras with reliable power and faster live streaming, the Wyze Cam OG and Wyze Cam OG Telephoto are excellent choices for detached garages.
Wyze Cam OG Highlights
  • 1080p Full HD Video: Clear and smooth video streaming.
  • 120° Field of View: Wide coverage for indoor or outdoor use.
  • Built-in Spotlight & Siren: 40 lumens spotlight and 90-decibel siren for security alerts.
  • Weather Resistant: IP65 rating for outdoor durability.
  • Fast Notifications: 3X faster alerts and improved 2-way audio.
  • Local Storage: Supports up to 256GB microSD card for continuous recording.
Wyze Cam OG Telephoto Highlights
  • 3X Telephoto Lens: Zoom in on distant objects with a narrower 27° field of view.
  • 1080p Video Resolution: Crisp video quality with night vision.
  • Same Rugged Build: IP65 weather resistance and built-in spotlight.
  • Versatile Mounting: Wall, ceiling, or stand mount options.
Both wired cameras come with a 6-foot power cable, so pairing them with the 20ft USB extension cable can help you reach power sources in detached garages or other outbuildings.
Wyze Cam v4 – Advanced Features with Flexible Mounting
The Wyze Cam v4 is a versatile indoor/outdoor camera that offers advanced features and multiple mounting options, making it suitable for detached garages with power access.
Wyze Cam v4 Features
  • 2.5K QHD Video: High-resolution video with wide dynamic range.
  • Color Night Vision: See vivid colors even in low light.
  • Built-in Spotlight & Siren: 72 lumens spotlight and loud siren for deterrence.
  • Multiple Mounting Options: Stand, wall, ceiling, or magnetic mounts.
  • Weatherproof: IP65 rating for outdoor use.
  • Fast Live Streaming: 50% faster than previous Wyze models.
  • Local and Cloud Storage: Supports microSD cards up to 512GB and cloud plans.
Using the 20ft USB extension cable with Wyze Cam v4 allows you to place the camera exactly where you need it in your detached garage without worrying about short cables.
Whether you want to extend the power cable length for your existing Wyze Cam or prefer a wireless battery-powered camera, Wyze offers flexible solutions to secure your detached garage effectively.
Wyze Cam installed outdoors near a garage Secure your detached garage with extended cable reach. Wireless Wyze Battery Cam Pro mounted on an outdoor wall Wire-free security with Wyze Battery Cam Pro. Wyze Cam OG Telephoto mounted on a garage exterior Zoom in on distant activity with Wyze Cam OG Telephoto.
Summary of Products for Extra Reach and Garage Security
Product NameTypeKey BenefitPrice
Wyze Cam USB Extension Cable - 20ftAccessoryExtends USB power cable length$7.99
Wyze Battery Cam ProWireless CamWire-free, rechargeable, weatherproof$89.98+
Wyze Cam OGWired Cam1080p, spotlight, siren, weatherproof$29.98+
Wyze Cam OG TelephotoWired CamTelephoto lens, zoom, weatherproof$25.98+
Wyze Cam v4Wired Cam2.5K QHD, color night vision, versatile mounts$100.00
Use the Wyze Cam USB Extension Cable - 20ft to power your wired Wyze cameras in detached garages or hard-to-reach places. For wireless freedom, the Wyze Battery Cam Pro is an excellent choice with no wiring needed.
Enhance your detached garage security today with Wyze’s reliable cameras and accessories designed for flexible installation and superior performance.
FeatureWyze Cam USB Extension Cable - 20ftWyze Battery Cam ProWyze Cam OGWyze Cam v4Wyze Cam OG Telephoto
TypeAccessoryCameraCameraCameraCamera
Price$7.99$89.98 (1 Pack)$29.98 (1 Pack)$100.00$25.98 (1 Pack)
Video ResolutionN/A2.5K HDR1920 x 1080 (1080p)2.5K QHD (2560x1440)1920 x 1080 (1080p)
Field of ViewN/ANot specified120°DFOV 115.8°, HFOV 98.5°, VFOV 53.1°Telephoto: DFOV 27°, HFOV 23.6°, VFOV 13.6°
Night VisionN/AYes (Color Night Vision)4 IR LEDs (850nm)4 IR LEDs (850 nm) + 2 white spotlight LEDs (72 lumens)4 IR LEDs (850nm)
AudioN/ABuilt-in Microphone & SpeakerBuilt-in Speaker & Microphone; Noise & Echo Cancellation99dB waterproof speaker, noise & echo cancellationBuilt-in Speaker & Microphone; Noise & Echo Cancellation
Power SourceUSB Extension CableWire-Free, Rechargeable BatteryWired (5V/1A adapter)Wired (5V/1A adapter)Wired (5V/1A adapter)
Weather ResistanceN/AIP65IP65IP65IP65
ConnectivityUSB2.4 & 5 GHz WiFi802.11 b/g/n, 2.4 GHz Wi-Fi2.4 GHz Wi-Fi, Wi-Fi 6802.11 b/g/n, 2.4 GHz Wi-Fi
Local StorageN/AMicroSD card supportSupports up to 256 GB microSD in exFAT formatmicroSD card up to 512 GBSupports up to 256 GB microSD in exFAT format
DimensionsN/ANot specified1.89 in x 1.89 in x 1.89 in (48 mm x 48 mm x 48 mm)2 in x 2 in x 2 3/8 in1.89 in x 1.89 in x 1.89 in (48 mm x 48 mm x 48 mm)
WeightN/ANot specified4.1 oz (116 g)0.49 lb (222 g)4.1 oz (116 g)
Special FeaturesExtends USB cable length to 20ftWire-free, integrated spotlight & siren, radar + PIR motion detection, removable battery packs, solar panel compatibleBuilt-in spotlight, 3X faster notifications, improved 2-way audioEnhanced color night vision, motion-activated spotlight, Wi-Fi 6, Alexa & Google Assistant compatible3x telephoto lens, improved 2-way audio, built-in spotlight
Mounting OptionsN/AVarious (not specified)Stand, wall mount, ceiling mountStand, wall mount, ceiling mount, magnetic mountStand, wall mount (M4 screw), ceiling mount (M4 screw)
WarrantyN/ANot specified1 Year1 Year1 Year
What is the Wyze Cam USB Extension Cable - 20ft used for?The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze camera’s power connection, making it easy to install your camera in detached garages, workshops, or any location far from a power outlet.
Which Wyze cameras are compatible with the 20ft USB Extension Cable?The 20ft USB Extension Cable is compatible with Wyze Cam v2, v3, v4, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, Wyze Cam OG Telephoto, and the original Wyze Cam models.
How do I set up the Wyze Cam USB Extension Cable?Simply plug the 20ft USB extension cable between your Wyze camera and its power adapter to instantly extend the cable length and reach distant power sources.
Can I use the Wyze Cam USB Extension Cable outdoors?Yes, the Wyze Cam USB Extension Cable is ideal for outdoor use, especially for powering cameras in detached garages, outbuildings, or other hard-to-reach places.
What is the price of the Wyze Cam USB Extension Cable - 20ft?The Wyze Cam USB Extension Cable - 20ft is affordably priced at $7.99.
What is the best Wyze camera for a detached garage without power outlets?The Wyze Battery Cam Pro is the best option for detached garages without power outlets. It operates wire-free on rechargeable batteries, offers 2.5K HDR video, and is weatherproof for outdoor use.
Does the Wyze Battery Cam Pro require a hub or power cable?No, the Wyze Battery Cam Pro does not require a hub or power cable. It runs on removable, rechargeable battery packs for true wireless installation.
Is the Wyze Battery Cam Pro weatherproof?Yes, the Wyze Battery Cam Pro is rated IP65, making it weatherproof and suitable for outdoor use in rain, dust, and extreme temperatures.
Can I use a solar panel with the Wyze Battery Cam Pro?Yes, the Wyze Battery Cam Pro is compatible with the Wyze Solar Panel, allowing for continuous charging outdoors.
What are the benefits of using Wyze Cam OG or Wyze Cam OG Telephoto in a detached garage?Wyze Cam OG and Wyze Cam OG Telephoto offer reliable wired power, fast live streaming, weather resistance (IP65), built-in spotlight and siren, and support for local storage, making them excellent choices for detached garages.
How long is the power cable included with Wyze Cam OG and Wyze Cam OG Telephoto?Both Wyze Cam OG and Wyze Cam OG Telephoto come with a 6-foot power cable, which can be extended using the 20ft USB extension cable for greater installation flexibility.
What are the key features of the Wyze Cam v4 for garage security?Wyze Cam v4 features 2.5K QHD video, color night vision, a built-in 72-lumen spotlight and siren, multiple mounting options, IP65 weatherproof rating, fast live streaming, and support for both local and cloud storage.
Can I use the Wyze Cam v4 with the 20ft USB extension cable?Yes, the Wyze Cam v4 is compatible with the 20ft USB extension cable, allowing you to place the camera exactly where you need it in your detached garage.
Which Wyze camera should I choose for wireless security in a detached garage?For wireless security in a detached garage, the Wyze Battery Cam Pro is the recommended choice due to its wire-free operation, rechargeable batteries, and weatherproof design.
What storage options are available for Wyze cameras?Wyze cameras support local storage via microSD cards (up to 256GB or 512GB depending on the model) and offer cloud storage plans for video recordings.
Can you tell me more about the compatibility of the Wyze Cam USB Extension Cable with different Wyze camera models?What are the benefits of using the Wyze Battery Cam Pro in a detached garage?Are there any ongoing promotions or discounts available for Wyze products?
