20ft Wyze Cam USB Extension: Long-Range Power for Pool Security
Long Range Power Solutions for Wyze Cam Overlooking Backyard Pool
When it comes to securing your backyard pool area, having reliable, long-range power and connectivity for your Wyze Cam is essential. Whether you want crystal-clear video surveillance or flexible installation options, Wyze offers a range of products designed to extend your camera’s reach and power capabilities. This guide highlights the best Wyze accessories and cameras to ensure your backyard pool is monitored effectively, day and night.
Wyze Cam USB Extension Cable - 20ft: Extend Your Camera’s Reach
Say Goodbye to Short Cables
The Wyze Cam USB Extension Cable - 20ft is the perfect accessory for anyone needing extra length to position their Wyze Cam exactly where it’s needed. This 20-foot cable allows you to place your camera overlooking your backyard pool without worrying about proximity to power outlets.
  • Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, Pan v2/v3, and OG models.
  • Length: 20 feet of flexible USB extension for versatile placement.
  • Ease of Use: Simply plug in to extend your existing USB power cable without any complicated setup.
This cable is ideal for outdoor setups where power outlets are limited or inconveniently located, giving you the freedom to monitor your pool area from the best vantage point.
Wyze Cam v4 Outdoor Bundle: Ultimate Security with Long-Range Power
Crystal-Clear 2.5K QHD Resolution & Enhanced Night Vision
The Wyze Cam v4 Outdoor Bundle is designed for outdoor environments like your backyard pool, offering unmatched clarity and security features:
  • 2.5K Quad HD Video: Capture every detail with stunning resolution.
  • Enhanced Color Night Vision: See vibrant colors even in low light, perfect for nighttime pool monitoring.
  • Motion-Activated Spotlight: Automatically lights up the area when motion is detected.
  • Wi-Fi 6 Support: Ensures a stronger, more reliable connection at greater distances, ideal for long-range setups.
  • 24/7 Local Recording: Continuous monitoring with a microSD card (included in the bundle).
  • Smart Home Integration: Compatible with Alexa and Google Assistant for voice control and automation.
Outdoor-Ready Power Solutions
The bundle includes a Wyze Outdoor Power Adapter, ensuring your camera stays powered continuously in all weather conditions. This adapter is designed to withstand rain, snow, and heat, making it perfect for poolside installation.
“Wyze Cam v4 is the clearest and most reliable outdoor camera, combining long-range Wi-Fi 6 connectivity with robust power options for uninterrupted backyard security.”
Backyard pool with Wyze Cam monitoring
Wyze Cam v4: Flexible Power and Installation Options
Compact and Powerful Indoor/Outdoor Camera
The Wyze Cam v4 offers many of the same advanced features as the outdoor bundle but with flexible mounting and power options:
  • 2.5K QHD Video with Wide Dynamic Range: Clear images in all lighting conditions.
  • Color Night Vision & IR LEDs: See in the dark with enhanced detail.
  • Multiple Mounting Options: Stand, wall, ceiling, or magnetic mounts for versatile placement.
  • Weather Resistance: Rated IP65 for outdoor use.
  • Power: Comes with a 6-foot micro USB cable; can be paired with the 20ft USB extension cable
FeatureWyze Cam USB Extension Cable - 20ftWyze Cam v4 Outdoor BundlePan v3 + Lamp Socket v2 Bundle
Product TypeAccessory (USB Extension Cable)Camera BundleBundle (Camera Accessory)
Compatible DevicesWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoWyze Cam v4Wyze Cam v3, v3 Pro, v4, OG, Pan v3
Cable Length20 ftN/AN/A
Price$7.99$69.99$53.96
Included Items1 x 20ft USB Extension CableWyze Cam v4, Wyze Outdoor Power Adapter, Wyze MicroSD Card 128GBLamp Socket v2
Camera ResolutionN/A2.5K QHDN/A
Night VisionN/AEnhanced Color Night VisionN/A
Local RecordingN/A24/7 local recordingN/A
Wi-Fi SupportN/AWi-Fi 6N/A
Motion DetectionN/AYesN/A
Sound DetectionN/AYesN/A
Motion Detection ZonesN/AYesN/A
Smoke & CO AlertsN/AYesN/A
Weather ResistanceN/AIP65Not weatherproof, suitable for damp locations
Power SourceUSB PoweredWired120V~, 60Hz (Lamp Socket)
Spotlight & SirenN/AMotion-activated spotlight, sirenMotion-activated lights
Mounting OptionsN/AStand, Wall mount, Ceiling mount, Magnetic wall mountN/A
ConnectivityUSB2.4 GHz Wi-Fi, Wi-Fi 6, Bluetooth802.11 b/g/n 2.4GHz Wi-Fi, Bluetooth
DimensionsN/A2in x 2in x 2 3/8in56.5mm x 56.5mm x 65mm
WeightN/A0.49 lb (222 g)80 g
Warranty30-day hassle-free returns1 Year1 Year
Special FeaturesExtends USB cable length for Wyze CamsOutdoor compatible, spotlight, siren, enhanced audioPowers Wyze Cams via lamp socket, dusk to dawn scheduling
What is the best way to power a Wyze Cam for monitoring my backyard pool?The best way to power a Wyze Cam for backyard pool monitoring is by using the Wyze Cam USB Extension Cable - 20ft. This cable allows you to extend your camera’s reach to areas far from power outlets, ensuring reliable power and flexible placement for optimal surveillance.
Which Wyze Cam models are compatible with the 20ft USB Extension Cable?The Wyze Cam USB Extension Cable - 20ft is compatible with Wyze Cam v2, v3, v4, Pan v2/v3, and OG models, making it a versatile solution for extending power to your camera.
How does the Wyze Cam v4 Outdoor Bundle enhance poolside security?The Wyze Cam v4 Outdoor Bundle enhances poolside security with 2.5K Quad HD video, enhanced color night vision, a motion-activated spotlight, Wi-Fi 6 support for long-range connectivity, 24/7 local recording, and a weather-resistant outdoor power adapter for continuous operation in all weather conditions.
Can the Wyze Cam v4 be used outdoors to monitor my pool?Yes, the Wyze Cam v4 is rated IP65 for weather resistance, making it suitable for outdoor use. It offers flexible mounting options and can be powered with the included 6-foot cable or the optional 20ft USB extension cable for greater installation flexibility.
Does the Wyze Cam v4 support night vision for pool monitoring at night?Yes, the Wyze Cam v4 features enhanced color night vision and IR LEDs, allowing you to monitor your pool area with clear, detailed images even in low-light or nighttime conditions.
What are the benefits of Wi-Fi 6 support in the Wyze Cam v4 Outdoor Bundle?Wi-Fi 6 support in the Wyze Cam v4 Outdoor Bundle provides a stronger, more reliable wireless connection at greater distances, making it ideal for long-range setups such as monitoring a backyard pool from afar.
Is the Wyze Outdoor Power Adapter weatherproof for poolside installation?Yes, the Wyze Outdoor Power Adapter included in the Wyze Cam v4 Outdoor Bundle is designed to withstand rain, snow, and heat, ensuring your camera remains powered and operational in all weather conditions.
Can I integrate Wyze Cam with smart home systems for pool security?Yes, Wyze Cam v4 and the Outdoor Bundle are compatible with Alexa and Google Assistant, allowing you to control and automate your pool security camera using voice commands and smart home routines.
