Wyze USB Cable: Power and Compatibility for Wyze Devices
Wyze USB Cable and Compatible Wyze Devices
When searching for a Wyze USB cable, it’s essential to understand which Wyze products utilize USB cables for power and connectivity. Wyze offers a range of smart home cameras and accessories that rely on USB cables, especially micro USB or USB Type-A connections, to ensure reliable power delivery and seamless operation. Below, we highlight the key Wyze products compatible with USB cables, focusing on their specs and how the USB cable plays a vital role in their performance.
Wyze Cam OG: The Next-Gen Wired Camera
Key Features
  • Power & Connectivity: Uses a 6 ft (1.8 m) USB power cable with 5V/1A adapter input, perfect for stable wired power.
  • Video Quality: Full HD 1080p (1920 x 1080) resolution with 120° field of view.
  • Enhanced Night Vision: 4 IR LEDs (850 nm) for clear night monitoring.
  • Built-in Spotlight: 40 lumens spotlight for added security and visibility.
  • Audio: Upgraded two-way audio with noise and echo cancellation.
  • Durability: Weather-resistant IP65 rating, suitable for indoor and outdoor use.
  • Storage: Supports up to 256 GB microSD card for local storage.
  • Smart Features: 3X faster notifications and 50% faster live streaming than previous models.
The Wyze Cam OG is a wired camera that depends on a USB cable for power, making the quality and length of the USB cable crucial for optimal placement and uninterrupted operation. Wyze Cam OG in outdoor setting Wyze Cam OG providing reliable outdoor security with USB power
Wyze Cam v4 Home Security Bundle: Wired Power with Advanced Features
Highlights
  • Resolution: Crystal-clear 2.5K QHD (2560 x 1440) video quality.
  • Color Night Vision: Enhanced color night vision with motion-activated spotlight.
  • USB Cable Included: Comes with a 6-foot flat micro USB to USB-A cable for power.
  • Connectivity: Supports Wi-Fi 6 for faster and more reliable streaming.
  • Storage: Local 24/7 recording with microSD card support up to 128GB.
  • Mounting Options: Versatile mounting including wall, ceiling, and magnetic mounts.
  • Weatherproof: IP65 rating for outdoor durability.
  • Smart Home Integration: Compatible with Alexa and Google Assistant.
The Wyze Cam v4 bundle is ideal for users who want wired security cameras powered via USB cables, ensuring continuous power without battery concerns.
Wyze Lamp Socket: Power Your Wyze Cameras Without a Plug
Overview
  • Purpose: Powers Wyze Cam v3 and v4 without needing a traditional plug.
  • USB Port: Includes 1 Type-A USB port outputting 5V/1A, perfect for powering cameras via USB cable.
  • Cable Length: Comes with a 30-inch (75 cm) USB cable for flexible installation.
  • Features: Motion-activated lights, dusk-to-dawn scheduling, and linkability with other Wyze devices.
  • Compatibility: Works with Android 7.0+ and iOS 12.0+ devices.
  • Installation: Fits standard E26 lamp sockets.
  • Indoor Use: Suitable for damp locations but not fully weatherproof.
This accessory is perfect for users looking to power their Wyze cameras via USB cable in locations without easy access to power outlets. Wyze Lamp Socket in home setting Wyze Lamp Socket powering smart devices with USB cable convenience
Why the Wyze USB Cable Matters
Wyze USB cables are more than just power cords—they are the lifeline for your wired Wyze cameras and accessories. A high-quality USB cable ensures:
  • Stable Power Delivery: Prevents interruptions in video streaming and device operation.
  • Flexible Placement: Longer cables allow you to position cameras optimally for security.
  • Compatibility: Proper USB cables match the power requirements (5V/1A) of Wyze devices.
  • Durability: Quality cables withstand daily wear and environmental factors when used indoors or outdoors.
When choosing a Wyze USB cable, consider the length and build quality to match your specific Wyze device and installation needs.
Summary of Wyze USB Cable Compatible Products
Product NameUSB Cable UseKey Specs
Wyze Cam OGWired power via 6 ft USB cable1080p, IP65, built-in spotlight
Wyze Cam v4 Home Security BundleWired power with 6 ft micro USB cable2.5K QHD, color night vision, Wi-Fi 6
Wyze Lamp SocketPowers cameras via USB port30-inch USB cable, motion-activated lights
Investing in the right Wyze USB cable ensures your Wyze cameras and accessories perform at their best, providing reliable security and smart home convenience.
Related Lifestyle Images
Wyze Cam OG outdoor security Secure your home day and night with Wyze Cam OG Wyze Lamp Socket in home Smart home lighting powered by Wyze Lamp Socket
Optimize your Wyze smart home setup today by choosing the right USB cable for your Wyze devices!
FeatureWyze Cam OGWyze Cam v4 Home Security BundleWyze Lamp Socket
TypeCameraCamera BundleCamera Accessory
Price$29.98 (1 Pack)$169.99 (4 Cameras + 4 MicroSD Cards)$16.98 (Lamp Socket), $49.98 (Socket + Cam v4)
Video Resolution1080p (1920 x 1080)2.5K QHDN/A
Field of View120° (approx. 121.4° DFOV)Not specifiedN/A
Night VisionColor Night VisionEnhanced Color Night VisionN/A
SpotlightBuilt-in 40-lumen spotlightMotion-activated spotlightMotion-activated lights
AudioImproved 2-way audio with noise & echo cancellationImproved 2-way audioN/A
Notifications3x faster motion notificationsMotion and sound detection with alertsN/A
Weather ResistanceIP65 (Indoor/Outdoor)Wired, requires Outdoor Power Adapter for outdoor useNot weatherproof, suitable for damp locations
PowerWired (Micro USB)Wired (Micro USB)Powers Wyze Cam v3/v4 without plug
Local Storage SupportmicroSD up to 256GBmicroSD card required for local recordingN/A
Connectivity802.11 b/g/n 2.4 GHz Wi-FiWi-Fi 6 support (requires Wi-Fi 6 router)802.11 b/g/n 2.4 GHz Wi-Fi, Bluetooth
Compatibility (Phone)Android 9.0+, iOS 15.0+Android 7.0+, iOS 12.0+Android 7.0+, iOS 12.0+
IntegrationsAlexa, Google Assistant, IFTTTAlexa, Google AssistantN/A
Dimensions1.89 in x 1.89 in x 1.89 in (48mm cube)Not specified56.5mm x 56.5mm x 65mm
Weight4.1 oz (116 g)Not specified80 g
Warranty1 YearNot specifiedNot specified
Additional FeaturesBuilt-in spotlight & mini-siren, 3x faster notifications, upgraded two-way audio24/7 local recording, motion-activated spotlight, enhanced color night visionDusk to dawn scheduling, linkability
Use CaseIndoor/outdoor security cameraHome security with 4 cameras and storagePowers Wyze Cam v3/v4, smart exterior lighting
Which Wyze devices are compatible with USB cables?Wyze devices that are compatible with USB cables include the Wyze Cam OG, Wyze Cam v4 Home Security Bundle, and the Wyze Lamp Socket. These products use USB cables for power and connectivity, ensuring reliable operation and flexible installation.
What type of USB cable does the Wyze Cam OG use?The Wyze Cam OG uses a 6-foot (1.8 meter) USB power cable with a 5V/1A adapter input. This cable is essential for providing stable wired power to the camera, both indoors and outdoors.
Does the Wyze Cam v4 Home Security Bundle include a USB cable?Yes, the Wyze Cam v4 Home Security Bundle comes with a 6-foot flat micro USB to USB-A cable for power. This ensures continuous wired power for uninterrupted security monitoring.
How does the Wyze Lamp Socket power Wyze cameras?The Wyze Lamp Socket features a Type-A USB port that outputs 5V/1A, allowing you to power Wyze Cam v3 and v4 cameras using a USB cable. It includes a 30-inch (75 cm) USB cable for flexible installation in locations without traditional power outlets.
Why is the quality of the Wyze USB cable important?A high-quality Wyze USB cable ensures stable power delivery, prevents interruptions in video streaming, and allows for flexible camera placement. Durable cables are also better suited for both indoor and outdoor use, matching the power requirements of Wyze devices.
What are the power requirements for Wyze devices using USB cables?Most Wyze devices that use USB cables require a 5V/1A power input. Using a compatible USB cable and adapter is crucial for optimal device performance and reliability.
Can I use any USB cable with my Wyze camera?It is recommended to use a high-quality USB cable that matches the required specifications (5V/1A) for your Wyze camera. Using the included or certified cables ensures stable power and reliable operation.
Are Wyze USB cables suitable for outdoor use?Wyze USB cables included with devices like the Wyze Cam OG and Wyze Cam v4 are designed to withstand daily wear and environmental factors, making them suitable for both indoor and outdoor installations when paired with weather-resistant cameras.
What is the length of the USB cable included with Wyze cameras?The Wyze Cam OG and Wyze Cam v4 Home Security Bundle both include a 6-foot (1.8 meter) USB cable, while the Wyze Lamp Socket comes with a 30-inch (75 cm) USB cable for flexible placement.
How do I choose the right Wyze USB cable for my setup?When choosing a Wyze USB cable, consider the length needed for your installation, the build quality for durability, and compatibility with your specific Wyze device’s power requirements (5V/1A).
What are the key features of the Wyze Cam OG?How does the Wyze Lamp Socket work with Wyze cameras?Do you have any deals, ongoing sales, discounts, or promotions?
