Energy Saving Smart Plugs with Scheduling & Remote Control
Energy Saving Smart Plugs with Scheduling and Remote Control Features
Looking to optimize your home’s energy use while enjoying the convenience of smart technology? Discover the best energy-saving smart plugs that offer scheduling and remote control features, perfect for automating your devices and reducing electricity bills. Whether you want to control indoor appliances or outdoor lighting, these smart plugs provide seamless app and voice control, energy monitoring, and robust scheduling options.
Wyze Plug Outdoor: Smart Control for Your Outdoor Devices
Power your outdoor spaces effortlessly with the
Wyze Plug Outdoor, designed to withstand the elements while giving you full control from your smartphone.
Key Features:
- Weather Resistant (IP64 Rated): Built to endure rain, dust, dirt, and snow, making it ideal for garden lights, holiday inflatables, and outdoor appliances.
- Dual Outlets with Independent Control: Manage two devices separately from one plug. Turn off your outdoor lights while keeping your pond pump running.
- Extended WiFi Range: Up to 300 feet in open space, so you can control outlets far from your home’s main WiFi router.
- Energy Monitoring: Track real-time and historical energy usage, set consumption alerts, and optimize your power use.
- High Power Output: Supports up to 15 AMP with overload protection, suitable for heavy-duty outdoor equipment like roof de-icers and pond pumps.
- Voice Assistant Compatible: Works with Alexa for hands-free control, perfect for turning devices on or off without stepping outside.
Take full control of your backyard or patio lighting and appliances with the Wyze Plug Outdoor — smart, durable, and energy-efficient.
Enjoy smart outdoor lighting and control with Wyze Plug Outdoor.
Wyze Plug: The Ultimate Indoor Smart Plug for Energy Savings
Transform your everyday devices into smart appliances with the
Wyze Plug, perfect for indoor use with powerful scheduling and remote control capabilities.
Why Choose Wyze Plug?
- Compact and Sleek Design: Fits easily into any outlet without blocking adjacent sockets.
- Scheduling & Automation: Set custom schedules to turn devices on/off automatically, helping you save energy by avoiding unnecessary power use.
- Remote Control via Wyze App: Control your devices from anywhere using your smartphone, whether you’re at home or away.
- Energy Monitoring: Keep track of your device’s power consumption to identify energy hogs and reduce waste.
- Voice Control: Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home integration.
- Safe and Certified: ETL certified with a 15A max output, operating safely within -4°F to 104°F indoors.
- Available in Multi-Packs: Choose from 2-pack or 4-pack options to cover multiple devices throughout your home.
Perfect for controlling lamps, fans, coffee makers, and more, the Wyze Plug makes your home smarter and more energy-efficient.
Schedule and control your indoor devices effortlessly with Wyze Plug.
Why Choose Smart Plugs with Scheduling and Remote Control?
Smart plugs with scheduling and remote control features are essential tools for modern energy management. They allow you to:
- Reduce Energy Waste: Automatically turn off devices when not in use.
- Enhance Convenience: Control appliances remotely or by voice commands.
- Improve Safety: Avoid leaving devices on accidentally.
- Customize Automation: Tailor schedules to your lifestyle and daily routines.
- Monitor Usage: Gain insights into your energy consumption patterns.
With Wyze smart plugs, you get all these benefits wrapped in affordable, easy-to-use devices that integrate smoothly into your smart home ecosystem.
Summary of Energy Saving Smart Plugs
Product | Outdoor/Indoor | Scheduling | Remote Control | Energy Monitoring | Voice Control | Weather Resistant |
Wyze Plug Outdoor | Outdoor | Yes | Yes | Yes | Alexa | IP64 |
Wyze Plug | Indoor | Yes | Yes | Yes | Alexa, Google, IFTTT | No |
Upgrade your home with smart plugs that save energy, simplify control, and bring convenience to your fingertips.
Product Highlights
Feature | Wyze Plug Outdoor | Wyze Plug |
Intended Use | Outdoor smart plug | Indoor smart plug |
Weather Resistance | IP64 (rain, dust, dirt, snow resistant) | Not weatherproof, for indoor use only |
Number of Outlets | 2 outlets with independent control | 1 outlet per plug |
WiFi Range | Up to 300 ft (open space) | Standard WiFi range |
Energy Monitoring | Yes, with usage alerts and history | No |
Voice Control | Yes, works with Alexa | Yes, works with Alexa and Google |
App Control | Yes | Yes |
Scheduling | Yes | Yes |
Overload Protection | 15 AMP output with overload protection | Not specified |
Price (1 Pack) | $15.99 (deal price) | $12.98 (1 pack, sold out) |
Price (2 Pack) | $34.98 | $24.98 (2 pack, sold out) |
Outdoor Use | Yes | No |
What are the benefits of using energy-saving smart plugs with scheduling and remote control?
Energy-saving smart plugs with scheduling and remote control help reduce electricity bills by automatically turning off devices when not in use, provide convenience through remote and voice control, improve safety by preventing devices from being left on, and allow you to monitor and optimize your energy consumption.What is the Wyze Plug Outdoor and what features does it offer?
The Wyze Plug Outdoor is a weather-resistant smart plug designed for outdoor use. It features dual outlets with independent control, extended WiFi range up to 300 feet, real-time and historical energy monitoring, high power output (up to 15 AMP), overload protection, and compatibility with Alexa for voice control.Is the Wyze Plug Outdoor suitable for all weather conditions?
Yes, the Wyze Plug Outdoor is IP64 rated, making it resistant to rain, dust, dirt, and snow. This makes it ideal for controlling garden lights, holiday inflatables, and other outdoor appliances in various weather conditions.Can I control multiple devices with the Wyze Plug Outdoor?
Yes, the Wyze Plug Outdoor has dual outlets that can be controlled independently, allowing you to manage two outdoor devices separately from a single plug.How does energy monitoring work on Wyze smart plugs?
Wyze smart plugs provide real-time and historical energy usage data through the Wyze app. You can track how much power your devices are using, set consumption alerts, and identify opportunities to save energy.What devices can I control with the Wyze Plug for indoor use?
The Wyze Plug is perfect for controlling indoor devices such as lamps, fans, coffee makers, and other small appliances. Its compact design ensures it fits easily into any outlet without blocking adjacent sockets.Does the Wyze Plug support voice control and smart home integration?
Yes, the Wyze Plug is compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless voice control and integration with your smart home ecosystem.Can I schedule devices to turn on or off automatically with Wyze smart plugs?
Yes, both Wyze Plug and Wyze Plug Outdoor offer robust scheduling features. You can set custom schedules to automate when your devices turn on or off, helping you save energy and tailor automation to your daily routines.How do I control Wyze smart plugs remotely?
You can control Wyze smart plugs remotely using the Wyze app on your smartphone. This allows you to turn devices on or off from anywhere, whether you are at home or away.Are Wyze smart plugs safe to use?
Yes, Wyze smart plugs are ETL certified and feature overload protection. The Wyze Plug is designed for indoor use within temperatures of -4°F to 104°F, while the Wyze Plug Outdoor is built to withstand outdoor conditions.What are the differences between Wyze Plug and Wyze Plug Outdoor?
Wyze Plug is designed for indoor use, supports scheduling, remote control, energy monitoring, and works with Alexa, Google Assistant, and IFTTT. Wyze Plug Outdoor is weather-resistant, suitable for outdoor use, features dual independent outlets, extended WiFi range, energy monitoring, and works with Alexa.Are Wyze smart plugs available in multi-packs?
Yes, the Wyze Plug for indoor use is available in 2-pack and 4-pack options, making it easy to control multiple devices throughout your home.
What are the key features of the Wyze Plug Outdoor?How does the energy monitoring feature work in the Wyze Plug?Are there any ongoing sales or discounts for the Wyze smart plugs?
