Affordable Smart Plugs with Scheduling for Home Automation
Looking to upgrade your home with affordable smart plugs that offer convenient scheduling features? Smart plugs are an essential part of any home automation setup, allowing you to control your devices remotely, save energy, and create automated routines effortlessly. Below, we highlight the best Wyze smart plugs designed to fit your budget while delivering powerful scheduling and smart home integration.
Wyze Plug: Compact Indoor Smart Plug with Scheduling
Key Features
  • Price & Packs: Available in 2-pack ($24.98) and 4-pack ($39.98) options, making it budget-friendly for multiple rooms.
  • Connectivity: Connects via 2.4GHz WiFi for reliable control.
  • Compatibility: Works seamlessly with Android 5.0+ and iOS 9.0+ devices.
  • Smart Integrations: Supports Alexa, Google Assistant, and IFTTT for voice commands and automation.
  • Scheduling: Easily set schedules and timers through the Wyze app to automate your devices.
  • Power Specs: 15A max output, suitable for most household appliances.
  • Indoor Use: Designed for indoor environments with operating temperatures from -4°F to 104°F.
  • Warranty: Comes with a 1-year warranty for peace of mind.
Why Choose Wyze Plug?
This smart plug is perfect for anyone starting their home automation journey. Its compact design fits into any outlet without blocking adjacent sockets. With scheduling, you can automate lights, fans, coffee makers, and more to turn on/off at your preferred times, saving energy and enhancing convenience. Wyze Plug in Home Setting Control your home devices effortlessly with Wyze Plug scheduling
Wyze Plug Outdoor: Weather-Resistant Smart Plug for Outdoor Automation
Key Features
  • Durability: Rated IP64 for weather resistance, perfect for outdoor use rain or shine.
  • Dual Outlets: Features 2 outlets to power multiple devices simultaneously.
  • Scheduling & Monitoring: Set schedules and monitor energy usage via the Wyze app.
  • Connectivity: Uses 2.4GHz WiFi and Bluetooth V4.2 for stable connections up to 300 feet.
  • Compatibility: Supports Android 5.0+ and iOS 9.0+.
  • Voice Control: Compatible with Alexa for hands-free operation.
  • Power Specs: 15A max output with overload protection.
  • Operating Range: Works in temperatures from -4°F to 120°F.
  • Warranty: 1-year warranty included.
Ideal Uses
Perfect for automating outdoor lighting, holiday decorations, garden fountains, or backyard party setups. The Wyze Plug Outdoor brings smart control to your exterior spaces, making your outdoor living smarter and more energy-efficient. Outdoor Smart Plug Lifestyle Enhance your outdoor space with smart scheduling and control
Why Smart Plugs with Scheduling Are Essential for Home Automation
"Smart plugs with scheduling capabilities transform your home by automating everyday tasks, reducing energy waste, and providing remote control from anywhere."
Scheduling allows you to program your devices to turn on or off at specific times, which is perfect for:
  • Automating lights to simulate occupancy when you're away.
  • Managing appliances like coffee makers or heaters to start before you wake up.
  • Reducing electricity bills by ensuring devices aren’t left on unnecessarily.
Both the Wyze Plug and Wyze Plug Outdoor offer intuitive app control and voice assistant compatibility, making them versatile choices for any smart home setup.
Summary of Affordable Smart Plugs for Scheduling
ProductIndoor/OutdoorSchedulingVoice ControlPrice RangeWarranty
Wyze PlugIndoorYesAlexa, Google Assistant, IFTTT$24.98 - $39.981 Year
Wyze Plug OutdoorOutdoorYesAlexa$15.99 - $34.981 Year
Start automating your home today with these affordable, reliable smart plugs that bring convenience and energy savings right to your fingertips.
FeatureWyze Plug OutdoorWyze Plug
ColorBlackWhite
Size Variants1 Pack, 2 Pack2 Pack, 4 Pack
Price Range$15.99 - $34.98$24.98 - $39.98
Weight7.2 oz5.3 oz
Dimensions4.0" x 2.8" x 1.4"2.7" x 2.0" x 1.5"
Weather ResistanceIP64 (Indoor & Outdoor use)Indoor use only
Operating Temperature-4°F to 120°F-4°F to 104°F
Input Voltage120V~, 60Hz100-120 VAC, 60Hz
Output15A Max with Overload Protection15A Max
Connectivity2.4GHz WiFi, Bluetooth V4.22.4GHz WiFi
CompatibilityAndroid 5.0+, iOS 9.0+Android 5.0+, iOS 9.0+
CertificationsFCC, IC, ETLETL
Warranty1 Year1 Year
Max Motor Load1/2 HPNot specified
Outlets21
Energy MonitoringYesNo
Voice Assistant SupportAlexaAlexa, Google Assistant, IFTTT
Included in BoxNot specifiedWyze Plug x 2, Quick Start Guide x 1
What are the benefits of using Wyze smart plugs with scheduling for home automation?Wyze smart plugs with scheduling allow you to automate your devices, save energy, and control appliances remotely. Scheduling features help you program devices to turn on or off at specific times, which can simulate occupancy, manage appliances efficiently, and reduce electricity bills.
What is the price range for Wyze smart plugs?Wyze Plug (indoor) is available in a 2-pack for $24.98 and a 4-pack for $39.98. Wyze Plug Outdoor ranges from $15.99 to $34.98, making both options affordable for home automation.
Are Wyze smart plugs compatible with voice assistants?Yes, Wyze Plug supports Alexa, Google Assistant, and IFTTT for voice commands and automation. Wyze Plug Outdoor is compatible with Alexa for hands-free control.
Can I use Wyze smart plugs to automate outdoor devices?Yes, the Wyze Plug Outdoor is designed for outdoor use with an IP64 weather resistance rating. It features dual outlets and can automate outdoor lighting, holiday decorations, garden fountains, and more.
How do I set schedules on Wyze smart plugs?You can easily set schedules and timers for your Wyze smart plugs using the Wyze app. This allows you to automate when your devices turn on or off according to your preferences.
What devices are Wyze smart plugs compatible with?Wyze smart plugs work with most household appliances up to 15A max output. They are compatible with Android 5.0+ and iOS 9.0+ devices.
Are Wyze smart plugs easy to install and use?Yes, Wyze smart plugs are designed for easy installation. Simply plug them into an outlet, connect to your 2.4GHz WiFi, and set up through the Wyze app. Their compact design ensures they don’t block adjacent sockets.
Do Wyze smart plugs come with a warranty?Yes, both Wyze Plug and Wyze Plug Outdoor come with a 1-year warranty for added peace of mind.
Can I monitor energy usage with Wyze smart plugs?Yes, the Wyze Plug Outdoor allows you to monitor energy usage through the Wyze app, helping you track and manage your power consumption.
What is the operating temperature range for Wyze smart plugs?Wyze Plug (indoor) operates from -4°F to 104°F, while Wyze Plug Outdoor works from -4°F to 120°F, making them suitable for various environments.
Can you tell me more about the Wyze Plug's compatibility with smart home systems?What are the specific features of the Wyze Plug Outdoor compared to the indoor version?Are there any ongoing promotions or discounts for the Wyze smart plugs?
