Smart Plugs That Remember Power State for Switched Outlets
Smart Plugs That Remember Previous Power State for Switched Outlets
When it comes to smart plugs that intelligently manage your switched outlets by remembering their previous power state, Wyze offers reliable and feature-rich options designed to simplify your home automation experience. Whether you need indoor or outdoor solutions, these smart plugs provide seamless control, energy monitoring, and voice assistant compatibility to keep your devices running exactly how you want.
Wyze Plug Outdoor: Rugged Smart Plug for All Seasons
Key Features
- Weather-Resistant Design: Rated IP64, the Wyze Plug Outdoor is built to withstand rain, snow, and extreme temperatures from -4°F to 120°F, making it perfect for garden lights, holiday inflatables, and outdoor appliances.
- Dual Outlets: Control two devices independently with 15A max output per outlet and built-in overload protection.
- App Control & Scheduling: Easily set schedules, monitor energy usage, and control your outdoor devices remotely via the Wyze app.
- Voice Assistant Integration: Compatible with Alexa for hands-free control.
- Connectivity: Operates on 2.4GHz WiFi with Bluetooth V4.2 for reliable connection up to 300 feet.
Why Choose Wyze Plug Outdoor?
This smart plug remembers the last power state of your connected devices, so after a power outage or manual switch, your devices return to their previous on/off status automatically. This feature is essential for switched outlets where you want consistent behavior without manual resets.
Enjoy smart control of your outdoor devices with Wyze Plug Outdoor.
Wyze Plug: Compact Indoor Smart Plug with Memory
Key Features
- Simple Indoor Use: Designed for indoor environments with operating temperatures from -4°F to 104°F.
- Compact Size: Measuring 2.7" x 2.0" x 1.5", it fits easily into any outlet without blocking adjacent sockets.
- Smart Scheduling & Remote Control: Use the Wyze app to schedule devices, turn them on/off remotely, and monitor energy consumption.
- Voice Control: Works with Alexa, Google Assistant, and IFTTT for versatile smart home integration.
- Memory Function: Remembers the last power state after power interruptions, ensuring your switched outlets behave as expected without manual intervention.
Ideal For
This plug is perfect for lamps, fans, coffee makers, and other indoor appliances connected to switched outlets where you want the device to resume its previous state automatically.
Control your home devices effortlessly with Wyze Plug.
Why Smart Plugs with Power State Memory Matter
Smart plugs that remember their previous power state provide peace of mind and convenience. After a power outage or manual switch, your devices automatically return to their last on/off status, eliminating the need to reset or manually turn them back on. This is especially useful for switched outlets where the physical switch controls power flow but you want smart control to persist.
Both the
Wyze Plug Outdoor and
Wyze Plug incorporate this intelligent feature, making them stand out in the smart plug market for switched outlet applications.
Summary of Smart Plug Specs
Feature | Wyze Plug Outdoor | Wyze Plug (Indoor) |
Power Outlets | 2 | 1 |
Max Output | 15A per outlet | 15A |
Weather Resistance | IP64 (Outdoor Rated) | Indoor Use Only |
Operating Temperature | -4°F to 120°F | -4°F to 104°F |
Connectivity | 2.4GHz WiFi + Bluetooth V4.2 | 2.4GHz WiFi |
Voice Assistant Support | Alexa | Alexa, Google Assistant, IFTTT |
Power State Memory | Yes | Yes |
Energy Monitoring | Yes | Yes |
Dimensions | 4.0" x 2.8" x 1.4" | 2.7" x 2.0" x 1.5" |
Enhance Your Smart Home with Wyze Smart Plugs
Integrate these smart plugs into your home automation system to enjoy effortless control, energy savings, and the convenience of devices that remember their last state. Whether you need a durable outdoor plug or a compact indoor solution, Wyze smart plugs deliver reliable performance and smart features tailored for switched outlets.
Feature | Wyze Plug Outdoor | Wyze Plug |
Type | Outdoor Smart Plug | Indoor Smart Plug |
Weather Resistance | IP64 (Rain, dust, dirt, snow resistant) | Not weatherproof, suitable for damp locations only |
Number of Outlets | 2 outlets with independent control | 1 outlet per plug |
WiFi Range | Up to 300 ft (open space) | Standard WiFi range (not specified) |
Energy Monitoring | Yes, with usage alerts and historical data | No |
Voice Control | Yes, works with Alexa | Yes, works with Alexa and Google Assistant |
Scheduling | Yes | Yes |
App Control | Yes | Yes |
Output Rating | 15 AMP with overload protection | Not specified |
Use Case | Outdoor devices like garden lights, inflatables, pond pumps, roof de-icers | Indoor devices like lamps, fans |
Price (1 Pack) | $15.99 | $12.98 (1 Pack, sold out) |
Price (2 Pack) | $34.98 | $24.98 (2 Pack) |
Hub Required | No | No |
Additional Features | Two outlets in one device, weather resistant | Vacation Mode (random on/off for security) |
Do Wyze smart plugs remember their previous power state after a power outage?
Yes, both Wyze Plug Outdoor and Wyze Plug (Indoor) are designed to remember the last power state of your connected devices. After a power outage or manual switch, your devices will automatically return to their previous on/off status, ensuring consistent operation without manual resets.What are the main features of the Wyze Plug Outdoor smart plug?
The Wyze Plug Outdoor features a weather-resistant IP64 design, dual independently controlled outlets with 15A max output each, built-in overload protection, energy monitoring, app-based scheduling and control, Alexa voice assistant compatibility, and reliable connectivity via 2.4GHz WiFi and Bluetooth V4.2.Is the Wyze Plug Outdoor suitable for all weather conditions?
Yes, the Wyze Plug Outdoor is rated IP64 for weather resistance and operates in temperatures from -4°F to 120°F, making it ideal for use in rain, snow, and extreme outdoor conditions.Can I control Wyze smart plugs with voice assistants?
Yes, Wyze Plug Outdoor works with Alexa, while Wyze Plug (Indoor) is compatible with Alexa, Google Assistant, and IFTTT, allowing for hands-free voice control and smart home integration.Does the Wyze Plug (Indoor) block adjacent outlets?
No, the Wyze Plug (Indoor) is compact, measuring 2.7" x 2.0" x 1.5", so it fits easily into any outlet without blocking adjacent sockets.Can I monitor energy usage with Wyze smart plugs?
Yes, both Wyze Plug Outdoor and Wyze Plug (Indoor) offer energy monitoring features through the Wyze app, allowing you to track and manage your energy consumption.What devices are ideal for use with Wyze smart plugs?
Wyze smart plugs are perfect for controlling lamps, fans, coffee makers, garden lights, holiday inflatables, and other indoor or outdoor appliances, especially when connected to switched outlets where you want the device to resume its previous state automatically.What is the difference between Wyze Plug Outdoor and Wyze Plug (Indoor)?
Wyze Plug Outdoor is designed for outdoor use with weather resistance, dual outlets, and Alexa compatibility, while Wyze Plug (Indoor) is compact for indoor use, supports Alexa, Google Assistant, and IFTTT, and has a single outlet. Both offer power state memory and energy monitoring.How do I control and schedule devices with Wyze smart plugs?
You can use the Wyze app to remotely control your devices, set schedules, and monitor energy usage for both Wyze Plug Outdoor and Wyze Plug (Indoor), providing convenient and automated smart home management.Why is power state memory important for smart plugs used with switched outlets?
Power state memory ensures that after a power outage or manual switch, your devices automatically return to their last on/off status. This eliminates the need to reset or manually turn devices back on, providing convenience and peace of mind, especially for switched outlets.
Can you tell me more about the features of the Wyze Plug Outdoor?How does the memory function work in the Wyze Plug?Do you have any ongoing sales or discounts for smart plugs?
