Wyze Wireless Security: Battery Cam Pro & Solar Panel Bundle
End-to-End Wireless Security Coverage with Wyze Cameras and Solar Accessories
For comprehensive, wire-free home or outdoor security, Wyze offers an integrated solution combining advanced wireless cameras with solar-powered accessories. Whether you want to monitor your front porch, backyard, or remote property, Wyze’s Battery Cam Pro and its solar panel accessory provide reliable, long-lasting surveillance without the hassle of wiring or frequent battery changes.
Wyze Battery Cam Pro: High-Definition Wireless Security
Stunning 2.5K HDR Video Quality
The Wyze Battery Cam Pro delivers crystal-clear 2.5K HDR video resolution (2560 x 1440), ensuring you capture every detail day or night. Its CMOS-Starlight sensor combined with an F1.6 lens and 134° diagonal field of view offers wide-angle coverage with sharp clarity.
Wire-Free and Weatherproof Design
Completely wire-free, this camera operates on removable, rechargeable 6200mAh battery packs that last up to 6 months on a single charge. Rated IP65 for weather resistance, it withstands rain, dust, and temperatures from -20°C to 50°C (-4°F to 122°F), making it perfect for outdoor use.
Advanced Motion Detection and Alerts
Equipped with radar and PIR motion sensors, the Battery Cam Pro detects movement accurately and triggers alerts. It also features an integrated spotlight and a 100 dB siren to deter intruders effectively.
Smart Home Integration
Compatible with Alexa, Google Assistant, and IFTTT, the camera fits seamlessly into your smart home ecosystem. Two-way audio with a built-in microphone and speaker allows you to communicate through the camera remotely.
Flexible Mounting and Connectivity
The camera supports both 2.4 GHz and 5 GHz WiFi bands for stable connections and includes a standard 1/4” - 20 mount for versatile installation options.
Wyze Battery Cam Solar Panel: Extend Your Camera’s Runtime
Harness Solar Power for Continuous Surveillance
The Wyze Battery Cam Solar Panel is designed to keep your Battery Cam Pro powered longer by harnessing sunlight. This 2.5W, 5VDC solar panel charges your camera’s battery continuously, reducing the need for manual recharging.
Weather-Resistant and Easy to Mount
With an IP65 waterproof rating, the solar panel is built to endure outdoor conditions. Its 360° adjustable mount allows you to position it optimally for maximum sun exposure anywhere around your home or property.
Long 13-Foot Power Cable
The included 13-foot micro USB cable provides flexible placement options, so you can mount the solar panel in the sunniest spot while keeping the camera exactly where you need it.
Compatibility
Works seamlessly with Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2 models, making it a versatile accessory for your wireless security setup.
Wyze Battery Cam Pro + Solar Panel Bundle: Ready-to-Go Wireless Security
For those seeking an all-in-one solution, the Wyze Battery Cam Pro + Solar Panel bundle offers the camera and solar accessory together at a great value. This combo ensures your camera stays powered for months with minimal maintenance, providing peace of mind with continuous, wire-free security coverage.
Additional Power Options: Wyze Removable Battery Pack
Convenient Battery Replacement
To keep your Wyze Battery Cam Pro running without interruption, the Wyze Removable Battery Pack offers a spare 6200mAh rechargeable battery. Easily swap batteries to maintain up to 6 months of operation per charge.
Fast and Simple Charging
Equipped with a USB-C charging port, the battery pack fully charges in approximately 9 hours, ensuring you’re always ready to go.
Why Choose Wyze for Wireless Security?
Wyze combines cutting-edge technology with user-friendly design to deliver wireless security cameras that are easy to install, weatherproof, and smart-home compatible. Adding solar accessories extends battery life, making your security system virtually maintenance-free.
Outdoor Security with Wyze Battery Cam Pro Alt text: Wyze Battery Cam Pro mounted outdoors monitoring a home entrance
Summary of Key Features
FeatureWyze Battery Cam ProWyze Battery Cam Solar PanelWyze Removable Battery Pack
Video Resolution2.5K HDR (2560 x 1440)N/AN/A
Battery Capacity6200mAh, up to 6 months runtimeSolar-powered 2.5W panel6200mAh rechargeable battery
Weather ResistanceIP65IP65N/A
Motion DetectionRadar + PIRN/AN/A
Connectivity2.4 & 5 GHz WiFiWired connection to cameraUSB-C charging port
Smart Home IntegrationAlexa, Google Assistant, IFTTTN/AN/A
Mounting1/4” - 20 standard mount360° adjustable mountN/A
With Wyze’s Battery Cam Pro and solar accessories, you can achieve reliable, end-to-end wireless security coverage that adapts to your lifestyle and environment—no wiring, no hassle, just smart protection powered by the sun.
FeatureWyze Battery Cam ProWyze Battery Cam Solar PanelWyze Battery Cam Pro + Solar PanelWyze Removable Battery Pack
TypeCameraAccessoryCamera + Accessory BundleAccessory
Price$89.98 (1 Pack)$24.99 (Solar Panel)$109.98$22.99
Video Resolution2.5K HDR (2560 x 1440)N/A2.5K HDR (2560 x 1440)N/A
WirelessYesN/AYesN/A
Power SourceRemovable, Rechargeable Battery PacksSolar Panel (extends battery life)Removable Battery + Solar PanelRechargeable Battery Pack (6200mAh)
Battery Capacity6200mAhN/A6200mAh (camera) + Solar Panel power6200mAh
Battery LifeUp to 6 MonthsExtends battery lifeExtended battery life via solar panelUp to 6 Months
Charging TimeApprox. 9 hoursN/AApprox. 9 hours (battery)Approx. 9 hours
Weather ResistanceIP65IP65IP65IP65 (operating temp -20°C to 50°C)
Motion DetectionRadar + PIRN/ARadar + PIRN/A
Integrated Spotlight & SirenYes (150 lumens spotlight, 100 dB siren)N/AYesN/A
Local StorageSupports microSD up to 256GBN/ASupports microSD up to 256GBN/A
WiFi Support2.4 & 5 GHzN/A2.4 & 5 GHzN/A
Mounting Methods1/4” - 20 standardMountable anywhere1/4” - 20 standardN/A
Dimensions2.5 x 1.8 x 3.5 inches173 mm x 120 mm x 17 mm2.5 x 1.8 x 3.5 inches + Solar Panel size2.9 x 1.6 x 0.9 inches
Weight0.94 lbsN/A0.94 lbs + Solar Panel weight3.9 oz (110g)
Bluetooth SetupBLE 5.1N/ABLE 5.1N/A
IntegrationsAlexa, Google Assistant, IFTTTN/AAlexa, Google Assistant, IFTTTN/A
Additional FeaturesColor Night Vision, Two-Way Audio, Local Recording360° Freestyle Mount, 13 ft Weatherproof CableAll Cam Pro features + Solar Panel benefitsUSB-C charging port, hot-swap battery
What is the Wyze Battery Cam Pro and how does it enhance home security?The Wyze Battery Cam Pro is a high-definition, wire-free security camera designed for both indoor and outdoor use. It features 2.5K HDR video resolution, advanced motion detection with radar and PIR sensors, and a weatherproof IP65 rating. Its rechargeable battery lasts up to 6 months, making it ideal for reliable, hassle-free home security.
How does the Wyze Battery Cam Pro’s solar panel accessory work?The Wyze Battery Cam Solar Panel is a 2.5W, 5VDC accessory that continuously charges your Wyze Battery Cam Pro using sunlight. With an IP65 waterproof rating and a 13-foot cable, it allows flexible placement for optimal sun exposure, reducing the need for manual battery recharging.
Is the Wyze Battery Cam Pro weatherproof and suitable for outdoor use?Yes, the Wyze Battery Cam Pro is rated IP65 for weather resistance, making it suitable for outdoor use in rain, dust, and temperatures ranging from -20°C to 50°C (-4°F to 122°F).
What smart home systems are compatible with Wyze Battery Cam Pro?The Wyze Battery Cam Pro integrates seamlessly with Alexa, Google Assistant, and IFTTT, allowing you to control and monitor your camera through your preferred smart home ecosystem.
How long does the Wyze Battery Cam Pro battery last and how can I extend its runtime?The Wyze Battery Cam Pro’s 6200mAh rechargeable battery can last up to 6 months on a single charge. Using the Wyze Battery Cam Solar Panel can extend the camera’s runtime by continuously charging the battery with solar power.
Can I use the Wyze Battery Cam Solar Panel with other Wyze cameras?Yes, the Wyze Battery Cam Solar Panel is compatible with the Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2 models, making it a versatile accessory for your wireless security setup.
What are the mounting options for the Wyze Battery Cam Pro and its solar panel?The Wyze Battery Cam Pro features a standard 1/4” - 20 mount for versatile installation, while the solar panel includes a 360° adjustable mount and a 13-foot cable for flexible placement in the sunniest location.
What is included in the Wyze Battery Cam Pro + Solar Panel bundle?The Wyze Battery Cam Pro + Solar Panel bundle includes both the camera and the solar panel accessory, providing an all-in-one, wire-free security solution that ensures continuous power and minimal maintenance.
How do I replace or recharge the Wyze Battery Cam Pro battery?You can use the Wyze Removable Battery Pack, a 6200mAh rechargeable battery, to easily swap out and maintain up to 6 months of operation per charge. The battery pack charges via USB-C and takes approximately 9 hours to fully recharge.
Why should I choose Wyze for wireless security solutions?Wyze offers advanced, user-friendly wireless security cameras that are easy to install, weatherproof, and compatible with major smart home platforms. With solar accessories and long-lasting batteries, Wyze provides a virtually maintenance-free security system for your home or property.
What are the key features of the Wyze Battery Cam Pro?How does the Wyze Battery Cam Solar Panel work with the camera?Do you have any deals, ongoing sales, discounts, or promotions?
