Wyze Outdoor Security: Solar-Powered Camera & Battery Solutions
Long Term Outdoor Security Solution with Wyze Camera and Solar Charging
For reliable, long-lasting outdoor security, combining Wyze’s advanced cameras with the Wyze Battery Cam Solar Panel offers an unbeatable solution. Whether you want continuous monitoring without frequent battery changes or a smart, weather-resistant setup, this combination ensures your property stays protected day and night.
Wyze Battery Cam Pro with Solar Panel: Wireless Freedom Meets Endless Power
Wyze Battery Cam Pro Highlights
- 2.5K HDR Video Resolution: Crystal-clear footage with vibrant detail.
- Wire-Free & No Hub Required: Easy installation anywhere without complicated wiring.
- Integrated Spotlight & Siren: Deter intruders with a bright spotlight and loud siren.
- Radar + PIR Motion Detection: Advanced sensing for accurate alerts.
- Removable, Rechargeable Battery Packs: 6200mAh capacity with up to 6 months battery life.
- Weatherproof IP65 Rating: Built to withstand rain, snow, and harsh outdoor conditions.
- Dual-Band Wi-Fi Support: Connects to both 2.4 GHz and 5 GHz networks.
- Two-Way Audio: Communicate through the built-in speaker and microphone.
- Local Storage: Supports up to 256 GB microSD cards for on-device recording.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
Wyze Battery Cam Solar Panel Features
- Extend Battery Life Indefinitely: Harness solar power to keep your Wyze Battery Cam Pro running longer without manual recharging.
- Weather Resistant IP65: Durable against rain, dust, and sun exposure.
- Easy 360° Mounting: Flexible installation anywhere outdoors.
- 13-Foot USB-C Power Cable: Conveniently position the solar panel for optimal sunlight.
- Compatibility: Works seamlessly with Wyze Cam Outdoor v1/v2 and Wyze Battery Cam Pro.
Attach the solar panel to your Wyze Battery Cam Pro and enjoy continuous, maintenance-free security powered by the sun.
Weather-resistant Wyze Cam Pan v3 in snowy outdoor environment
Why Choose Wyze Battery Cam Pro with Solar Panel?
- Long-Term Security Without Interruptions: The solar panel eliminates the hassle of frequent battery swaps or recharging.
- True Wireless Convenience: No need for power outlets or hubs, perfect for remote or hard-to-wire locations.
- Robust Outdoor Durability: Both camera and solar panel are IP65 rated, ensuring reliable operation in all weather.
- Smart Features for Enhanced Safety: Radar motion detection reduces false alarms, while the spotlight and siren actively deter threats.
- Easy Setup and Integration: Compatible with popular smart home ecosystems and controlled via the Wyze app.
Additional Wyze Outdoor Camera Options for Comprehensive Security
Wyze Cam v4 Outdoor Bundle
- 2.5K QHD Resolution: Ultra-clear video with enhanced color night vision.
- Motion-Activated Spotlight: Illuminates detected movement for better visibility.
- 24/7 Local Recording: Continuous recording with included 128GB microSD card.
- Wi-Fi 6 Support: Faster, more reliable wireless connection.
- Smart Assistant Compatibility: Works with Alexa and Google Assistant.
- Wired Power Source: Ideal for locations with easy access to power outlets.
Wyze Cam Pan v3
- 360° Pan and 180° Tilt: Covers wide areas with smooth motorized movement.
- 1080p HD Video: Clear day and night vision with 4 IR LEDs.
- IP65 Weather Resistant: Suitable for outdoor use with proper power adapter.
- Two-Way Audio & Built-In Siren: Communicate and deter intruders remotely.
- Multiple Mounting Options: Wall, ceiling, or magnetic mounts for flexible placement.
Conclusion: The Ultimate Outdoor Security Setup
For a
long-term outdoor security solution, the
Wyze Battery Cam Pro paired with the Wyze Battery Cam Solar Panel is the perfect wireless combo that offers extended battery life powered by the sun. This setup ensures your camera stays active and vigilant without the need for frequent maintenance.
For wired options or broader coverage, the
Wyze Cam v4 Outdoor Bundle and
Wyze Cam Pan v3 provide excellent alternatives with high-resolution video, smart features, and weather resistance.
Invest in Wyze’s smart outdoor security ecosystem to protect your home or business with confidence, convenience, and cutting-edge technology.
Product Tags Summary
Secure your driveway with Wyze’s smart outdoor lighting and camera system
Optimize your outdoor security with Wyze’s innovative cameras and solar charging solutions for peace of mind all year round.
Feature | Wyze Battery Cam Solar Panel | Wyze Battery Cam Pro |
Type | Accessory | Camera |
Video Resolution | N/A | 2.5K HDR (2560 x 1440) |
Power Source | Solar Panel (extends battery life) | Removable, Rechargeable Battery Packs (6200mAh) |
Battery Life | Extends battery life of compatible cameras | Up to 6 months on one charge |
Compatibility | Wyze Cam Outdoor v1/v2, Wyze Battery Cam Pro | Wireless, no hub required |
Weather Resistance | IP65 (weatherproof and dustproof) | IP65 Weatherproof |
Mounting | 360° Freestyle Mount, mountable anywhere | Multiple mounting options, including ceiling mount with Universal Mount |
Power Cable Length | 13-foot weatherproof power cable | N/A |
Wireless | No (provides power only) | Yes |
Motion Detection | N/A | Radar + PIR Motion Detection |
Integrated Spotlight & Siren | N/A | Yes (150 lumens LED spotlight, siren 100 dB) |
Local Storage | N/A | Supports microSD cards up to 256GB |
WiFi Support | N/A | 2.4 & 5 GHz WiFi |
Dimensions | 173 mm x 120 mm x 17 mm | 2.5 x 1.8 x 3.5 inches |
Weight | Not specified | 0.94 lbs (approx. 426 g) |
Price | $24.99 (Solar Panel) | From $89.98 (1 Pack) |
What makes the Wyze Battery Cam Pro with Solar Panel a reliable long-term outdoor security solution?
The Wyze Battery Cam Pro paired with the Wyze Battery Cam Solar Panel offers continuous, maintenance-free security by harnessing solar power. This setup eliminates the need for frequent battery changes, provides weatherproof durability (IP65 rating), and ensures your property is monitored day and night with advanced features like 2.5K HDR video, radar motion detection, and smart home integration.How does the Wyze Battery Cam Solar Panel extend the camera’s battery life?
The Wyze Battery Cam Solar Panel uses solar energy to keep your Wyze Battery Cam Pro charged, significantly extending its battery life and potentially eliminating the need for manual recharging. With proper sunlight exposure, your camera can operate continuously without interruption.Is the Wyze Battery Cam Pro truly wireless?
Yes, the Wyze Battery Cam Pro is completely wire-free and does not require a hub for operation. It connects directly to your Wi-Fi network (supports both 2.4 GHz and 5 GHz) and can be installed anywhere outdoors without the need for power outlets or complicated wiring.Are Wyze outdoor cameras weatherproof?
Yes, the Wyze Battery Cam Pro, Wyze Battery Cam Solar Panel, and Wyze Cam Pan v3 all have an IP65 weather resistance rating. This means they are built to withstand rain, snow, dust, and harsh outdoor conditions, making them ideal for year-round outdoor use.What smart features are included with the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro includes advanced features such as 2.5K HDR video resolution, radar and PIR motion detection for accurate alerts, an integrated spotlight and siren to deter intruders, two-way audio, local storage support up to 256GB microSD, and compatibility with Alexa, Google Assistant, and IFTTT.Can I use the Wyze Battery Cam Solar Panel with other Wyze cameras?
Yes, the Wyze Battery Cam Solar Panel is compatible with the Wyze Cam Outdoor v1/v2 and Wyze Battery Cam Pro, allowing you to extend the battery life of these models using solar power.What are the installation options for Wyze outdoor cameras and solar panels?
Wyze outdoor cameras and solar panels offer flexible installation options. The solar panel features a 360° adjustable mount and a 13-foot USB-C power cable for optimal sunlight positioning. Cameras like the Wyze Cam Pan v3 can be mounted on walls, ceilings, or with magnetic mounts for versatile placement.What are the differences between Wyze Battery Cam Pro, Wyze Cam v4 Outdoor Bundle, and Wyze Cam Pan v3?
The Wyze Battery Cam Pro is a wire-free, battery-powered camera with solar charging capability and advanced motion detection. The Wyze Cam v4 Outdoor Bundle offers 2.5K QHD resolution, color night vision, and 24/7 local recording with a wired power source. The Wyze Cam Pan v3 provides 360° pan and 180° tilt coverage, 1080p HD video, and is suitable for outdoor use with proper power adapters.Does the Wyze Battery Cam Pro support local video storage?
Yes, the Wyze Battery Cam Pro supports local storage with microSD cards up to 256GB, allowing you to record and store footage directly on the device for added security and convenience.Is the Wyze outdoor security system compatible with smart home devices?
Yes, Wyze outdoor cameras are compatible with popular smart home ecosystems, including Amazon Alexa, Google Assistant, and IFTTT, enabling seamless integration and voice control.
What are the installation requirements for the Wyze Battery Cam Solar Panel?Can the Wyze Battery Cam Pro be used without the solar panel?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Battery Cam?
