Off Grid Home Surveillance Solution with Wyze Cameras and Solar Panel
Creating a reliable off-grid home surveillance system is easier than ever with Wyze’s innovative battery-powered cameras combined with the Wyze Battery Cam Solar Panel. This setup ensures continuous monitoring without the hassle of frequent battery changes or wiring, perfect for remote homes, cabins, or any location without easy access to power.
Wyze Battery Cam Pro: The Core of Your Off-Grid Security
High-Resolution Video & Smart Detection
The Wyze Battery Cam Pro delivers stunning 2.5K HDR video resolution, providing crystal-clear footage day and night. Equipped with a CMOS-Starlight sensor and dual IR and white LEDs, it offers excellent night vision capabilities to keep your property secure around the clock.
Wireless & Weatherproof Design
Designed for true wireless freedom, this camera operates on removable, rechargeable 6200mAh battery packs that can last up to 6 months on a single charge. Its IP65 weatherproof rating means it withstands rain, snow, and dust, making it ideal for outdoor use in various climates.
Advanced Features for Enhanced Security
- Integrated spotlight and 100 dB siren to deter intruders
- Radar + PIR motion detection for precise alerts
- Two-way audio with built-in microphone and speaker
- Dual-band WiFi (2.4 & 5 GHz) for stable connectivity
- Compatible with Alexa, Google Assistant, and IFTTT for smart home integration
Compact & Easy Installation
With a matte finish and compact size (2.5 x 1.8 x 3.5 inches), the Wyze Battery Cam Pro mounts easily anywhere using the included wall mount, making it a versatile choice for any off-grid surveillance setup.
Wyze Battery Cam Solar Panel: Power Your Camera with the Sun
Extend Battery Life with Solar Power
The Wyze Battery Cam Solar Panel is designed to keep your Wyze Battery Cam Pro running longer by harnessing solar energy. This accessory is perfect for off-grid locations where power outlets are unavailable.
Durable and Weather Resistant
Built with an IP65 waterproof rating, the solar panel withstands harsh weather conditions, including rain and dust. Its white frame with black solar cells blends seamlessly into outdoor environments.
Flexible Mounting and Long Cable
The solar panel features a 360° adjustable mount, allowing you to position it for optimal sun exposure. It comes with a 13-foot USB-C power cable, providing flexibility in placement relative to your camera.
What’s Included
- Solar panel with integrated mount
- Micro USB and USB-C adapter cables
- Screws and wall anchors for secure installation
- Quick start guide for easy setup
Compatibility
Works seamlessly with Wyze Cam Outdoor v1/v2 and Wyze Battery Cam Pro, making it the perfect companion to your off-grid surveillance system.
Why Choose Wyze for Off-Grid Surveillance?
“Record for longer. Attach a solar panel to your Wyze Battery Cam Pro to extend the battery life. Designed to be weather resistant and mountable anywhere.”
Wyze’s combination of high-quality battery cameras and solar-powered accessories offers a smart, sustainable solution for off-grid home security. Whether you’re monitoring a remote cabin, RV, or backyard, this system provides peace of mind with minimal maintenance.
Alt text: Wyze Battery Cam Pro mounted on a remote cabin wall under sunlight
Summary of Key Specs
| Feature | Wyze Battery Cam Pro | Wyze Battery Cam Solar Panel |
| Video Resolution | 2.5K HDR (2560 x 1440) | N/A |
| Battery Life | Up to 6 months | Extends battery life via solar power |
| Weather Resistance | IP65 | IP65 |
| Motion Detection | Radar + PIR | N/A |
| Night Vision | IR LEDs + White LEDs | N/A |
| Connectivity | 2.4 & 5 GHz WiFi | USB-C power cable |
| Mounting | Wall mount included | 360° adjustable mount |
| Dimensions | 2.5 x 1.8 x 3.5 inches | 173 x 120 x 17 mm |
Harness the power of the sun and the advanced technology of Wyze cameras to build a dependable off-grid home surveillance system that keeps your property safe and monitored without the need for constant battery changes or wired power.
What is the best off-grid home surveillance solution with Wyze cameras?
The best off-grid home surveillance solution from Wyze combines the Wyze Battery Cam Pro with the Wyze Battery Cam Solar Panel. This setup provides continuous, reliable security monitoring for remote homes, cabins, or any location without easy access to power.How does the Wyze Battery Cam Pro work for off-grid security?
The Wyze Battery Cam Pro is a wireless, battery-powered security camera designed for off-grid use. It features a 2.5K HDR video resolution, night vision, radar and PIR motion detection, two-way audio, and a weatherproof IP65 rating. Its rechargeable battery can last up to 6 months on a single charge, making it ideal for locations without wired power.Can I power my Wyze Battery Cam Pro with solar energy?
Yes, you can power your Wyze Battery Cam Pro with the Wyze Battery Cam Solar Panel. The solar panel harnesses sunlight to extend the camera’s battery life, making it perfect for off-grid surveillance where power outlets are unavailable.Is the Wyze Battery Cam Pro weatherproof?
Yes, the Wyze Battery Cam Pro has an IP65 weatherproof rating, which means it is resistant to rain, snow, and dust. This makes it suitable for outdoor use in various climates.What features does the Wyze Battery Cam Pro offer for home security?
The Wyze Battery Cam Pro offers 2.5K HDR video, night vision with IR and white LEDs, radar and PIR motion detection, an integrated spotlight, a 100 dB siren, two-way audio, dual-band WiFi (2.4 & 5 GHz), and compatibility with Alexa, Google Assistant, and IFTTT.How long does the Wyze Battery Cam Pro battery last?
The Wyze Battery Cam Pro uses removable, rechargeable 6200mAh battery packs that can last up to 6 months on a single charge, depending on usage and environmental conditions.What is included with the Wyze Battery Cam Solar Panel?
The Wyze Battery Cam Solar Panel package includes the solar panel with an integrated 360° adjustable mount, micro USB and USB-C adapter cables, screws and wall anchors for installation, and a quick start guide.Is the Wyze Battery Cam Solar Panel weather resistant?
Yes, the Wyze Battery Cam Solar Panel is built with an IP65 waterproof rating, making it durable and resistant to rain, dust, and harsh outdoor conditions.Which Wyze cameras are compatible with the Wyze Battery Cam Solar Panel?
The Wyze Battery Cam Solar Panel is compatible with the Wyze Cam Outdoor v1/v2 and the Wyze Battery Cam Pro.How easy is it to install the Wyze Battery Cam Pro and Solar Panel?
Both the Wyze Battery Cam Pro and the Wyze Battery Cam Solar Panel are designed for easy installation. The camera comes with a wall mount, and the solar panel features a 360° adjustable mount and a 13-foot USB-C power cable for flexible placement.Why choose Wyze for off-grid home surveillance?
Wyze offers a smart, sustainable solution for off-grid home security with high-quality battery-powered cameras and solar-powered accessories. Their products provide reliable monitoring, minimal maintenance, and easy integration with smart home systems, making them ideal for remote locations.
