Easy Plug-In Mount Solutions for Wyze Floodlight with 20 Foot Cord
If you're looking for a hassle-free, plug-and-play mounting solution for your Wyze Floodlight, especially one that includes a convenient 20-foot cord, Wyze offers the perfect products to simplify your outdoor lighting setup. Say goodbye to complicated junction box installations and expensive electrician fees. With Wyze’s plug-in mounts and compatible floodlights, you can easily power and position your floodlight exactly where you need it.
Wyze Cam Floodlight Plug-In Mount: Simple, Flexible, and Ready to Use
Effortless Installation Without Junction Boxes
The
Wyze Cam Floodlight Plug-In Mount is designed to eliminate the complexity of traditional floodlight wiring. No need to hire electricians or cut into your home’s exterior walls. This mount lets you plug your Wyze Floodlight directly into any outdoor-rated outlet, making installation quick and straightforward.
Long 20-Foot Outdoor-Rated Cable
The mount comes with a durable 20-foot cable, giving you the freedom to place your floodlight exactly where it’s most effective. Whether it’s your porch, backyard, or driveway, the extended cord length ensures you won’t be limited by outlet locations.
Clean Cable Management
Included with the mount is a velcro strap to neatly manage the cable, keeping your installation tidy and professional-looking.
Compatible with All Wyze Cam Floodlights
This mount works seamlessly with all Wyze Cam Floodlight models, including:
- Wyze Cam Floodlight v1
- Wyze Cam Floodlight v2
- Wyze Cam Floodlight Pro
“If you can plug in a cable, then you can enjoy the security of a Wyze Floodlight.”
Easy outdoor installation with Wyze Cam Floodlight Plug-In Mount
Wyze Cam Floodlight v2 + Plug-In Mount: Advanced Lighting with Plug-and-Play Convenience
Brilliant 2K HD Video and Vibrant Night Vision
The
Wyze Cam Floodlight v2 + Plug-In Mount bundle offers a powerful security solution with 2K HD video quality and vibrant color night vision. Its 160° wide-angle view ensures broad coverage of your outdoor space.
2800-Lumen LEDs and 105dB Siren
Illuminate your property with bright 2800-lumen LEDs and deter intruders with a loud 105dB siren, all controlled easily through the Wyze app.
Flexible Power with 20-Foot Cable
The included plug-in mount features the same 20-foot outdoor-rated cable, allowing flexible placement without the need for complex wiring.
Easy Installation, No Junction Box Needed
Just plug it in and mount it on your wall or ceiling. The included velcro strap helps keep the cable neat and secure.
Wyze Cam Floodlight Pro + Plug-In Mount: Premium Security and Lighting Bundle
Ultra-Wide 180° Field of View with 2.5K QHD Resolution
For those wanting the best in outdoor security, the
Wyze Cam Floodlight Pro + Plug-In Mount bundle delivers stunning 2.5K QHD video with an ultra-wide 180° field of view, capturing every detail.
Powerful 3000-Lumen Lighting and Weather Resistance
With three floodlight heads producing 3000 lumens, this floodlight brightens large areas effectively. It’s rated IP65 for water and dust resistance, built to withstand harsh outdoor conditions.
Convenient 20-Foot Power Cord
The plug-in mount includes a 20-foot SJTW-rated cable with 18 AWG wire, providing safe and flexible power options without the need for a junction box.
Voice and App Control Integration
Control your floodlight hands-free with Alexa, Google Assistant, or the Wyze app, making outdoor lighting management effortless.
Premium outdoor security and lighting with Wyze Cam Floodlight Pro
Wyze Plug Outdoor: Power Your Floodlight and More with Smart Outdoor Control
Weather-Resistant Smart Plug with 2 Outlets
The
Wyze Plug Outdoor is perfect for powering your Wyze Floodlight or other outdoor devices. It features two independently controlled outlets, so you can manage multiple devices from the Wyze app.
Long-Range WiFi and Energy Monitoring
With up to 300 feet WiFi range in open space, you can place the plug almost anywhere outdoors. Monitor energy usage and set schedules to optimize power consumption.
Durable IP64 Weather Resistance
Built to withstand rain, dust, dirt, and snow, this plug is made for all-season outdoor use.
Voice Control Compatibility
Use Alexa or Google Assistant to turn your outdoor lights on or off without stepping outside.
Smart outdoor power control with Wyze Plug Outdoor
Why Choose Wyze Plug-In Mounts and Floodlights?
“Say goodbye to the complexity and cost of installing a junction box. Go with an easy, plug-n-play floodlight solution instead.”
- No electrician needed: Save time and money with simple plug-in installation.
- Flexible placement: 20-foot cords give you freedom to position floodlights optimally.
- Smart control: Manage lighting remotely via app or voice commands.
- Weatherproof design: Built to last in outdoor environments.
- Energy efficient: Monitor and control power usage easily.
Summary of Relevant Products
Product | Key Features | Price Range |
Wyze Cam Floodlight Plug-In Mount | 20 ft cable, no junction box, easy install | $19.98 |
Wyze Cam Floodlight v2 + Plug-In Mount | 2K HD, 2800 lumens, 20 ft cable | $109.96 |
Wyze Cam Floodlight Pro + Plug-In Mount | 2.5K QHD, 3000 lumens, 20 ft cable, IP65 | $169.96 |
Wyze Plug Outdoor | Dual outlets, weather-resistant, energy monitoring | $15.99 - $34.98 |
Conclusion
For an easy plug-in mount solution for your Wyze Floodlight with a 20-foot cord, Wyze’s plug-in mounts paired with their floodlight models provide the perfect combination of convenience, power, and smart home integration. Whether you want a basic setup or premium security lighting, these products make outdoor lighting installation and control effortless.
### Product Tags and Highlights
What is the Wyze Cam Floodlight Plug-In Mount and how does it simplify installation?
The Wyze Cam Floodlight Plug-In Mount is a hassle-free mounting solution that allows you to install your Wyze Floodlight without the need for a junction box or electrician. Simply plug the 20-foot outdoor-rated cable into any outdoor outlet for quick and easy installation.Which Wyze Cam Floodlight models are compatible with the Plug-In Mount?
The Wyze Cam Floodlight Plug-In Mount is compatible with all Wyze Cam Floodlight models, including Wyze Cam Floodlight v1, v2, and Pro.How long is the power cord included with Wyze plug-in floodlight mounts?
All Wyze plug-in floodlight mounts come with a durable, outdoor-rated 20-foot power cord, giving you flexibility to position your floodlight where you need it most.Do I need an electrician or a junction box to install Wyze Floodlights with the plug-in mount?
No, you do not need an electrician or a junction box. The plug-in mount allows for a simple, DIY installation by plugging directly into an outdoor-rated outlet.What are the key features of the Wyze Cam Floodlight v2 + Plug-In Mount bundle?
The Wyze Cam Floodlight v2 + Plug-In Mount bundle features 2K HD video, vibrant color night vision, a 160° wide-angle view, 2800-lumen LEDs, a 105dB siren, and a 20-foot outdoor-rated cable for flexible placement.What makes the Wyze Cam Floodlight Pro + Plug-In Mount a premium security solution?
The Wyze Cam Floodlight Pro + Plug-In Mount offers 2.5K QHD resolution, an ultra-wide 180° field of view, three 3000-lumen floodlight heads, IP65 weather resistance, a 20-foot SJTW-rated cable, and smart control via Alexa, Google Assistant, or the Wyze app.How does the Wyze Plug Outdoor enhance outdoor power control?
The Wyze Plug Outdoor provides two independently controlled, weather-resistant outlets, long-range WiFi up to 300 feet, energy monitoring, scheduling, and voice control compatibility with Alexa and Google Assistant.Are Wyze plug-in mounts and floodlights weatherproof?
Yes, Wyze plug-in mounts and floodlights are designed for outdoor use and feature weather-resistant ratings such as IP65, ensuring durability in rain, dust, dirt, and snow.Can I control Wyze Floodlights and plugs remotely?
Yes, you can control Wyze Floodlights and Wyze Plug Outdoor remotely using the Wyze app or through voice commands with Alexa or Google Assistant.What are the benefits of using a 20-foot cord with Wyze Floodlight plug-in mounts?
The 20-foot cord provides flexible placement options, allowing you to install your floodlight in the optimal location regardless of where your outdoor outlets are situated.Is cable management included with Wyze plug-in mounts?
Yes, each Wyze plug-in mount includes a velcro strap for neat and professional cable management.What is the price range for Wyze plug-in mounts and floodlight bundles?
Wyze plug-in mounts start at $19.98, while floodlight bundles range from $109.96 for the Wyze Cam Floodlight v2 + Plug-In Mount to $169.96 for the Wyze Cam Floodlight Pro + Plug-In Mount. The Wyze Plug Outdoor is priced between $15.99 and $34.98.
