Motion Activated Weatherproof Floodlight Cameras with Color Night Vision
Motion Activated Indoor Outdoor Weatherproof Dimmable Floodlight Cameras with Full HD Color Night Vision
When it comes to securing your home or business, having a reliable floodlight camera that works both indoors and outdoors is essential. The perfect floodlight camera combines motion activation, weatherproof durability, dimmable lighting, and full HD color night vision to keep your property safe day and night. Below, explore the top Wyze floodlight cameras and security cams that meet these needs with advanced features and smart home compatibility.
Wyze Cam Floodlight v2: Bright, Smart, and Reliable Security Lighting
Powerful Illumination and Crisp 2K Video Quality
The Wyze Cam Floodlight v2 dominates darkness with two adjustable 2800-lumen LED floodlights that are motion-activated and dimmable. Its 2K resolution camera delivers crystal-clear video with a wide 160° field of view, ensuring you capture every detail in vibrant color—even at night with its advanced Color Night Vision.
Intelligent Features for Smarter Security
  • AI-Powered Light Control: Automatically adjusts brightness based on ambient light and motion detection.
  • 270° PIR Motion Detection: Covers a broad area to eliminate blind spots and trigger lights instantly.
  • Two-Way Talk & 105dB Siren: Communicate with visitors or deter intruders with a loud siren.
  • 24/7 Local Recording: Continuous recording to a microSD card (up to 256GB) without subscription fees.
  • Dusk-to-Dawn Automation: Floodlight turns on and off automatically based on daylight.
  • IP65 Weatherproof: Built to withstand rain, snow, and extreme temperatures.
Seamless Smart Home Integration
Works effortlessly with Alexa, Google Assistant, and IFTTT for voice control and automation. The Wyze app offers easy setup without QR codes, customizable detection zones, and instant alerts. Wyze Cam Floodlight v2 illuminating driveway at night Motion-activated floodlight camera securing a driveway at night
Wyze Cam v4: Versatile Indoor/Outdoor Camera with Spotlight and Enhanced Night Vision
Stunning 2.5K QHD Resolution with Enhanced Color Night Vision
Wyze Cam v4 offers unmatched clarity with 2.5K Quad HD video and an upgraded image processor that delivers wide dynamic range (WDR) for vibrant colors and sharp details, even in low light. Its enhanced color night vision outperforms traditional infrared, revealing more detail in darkness.
Motion-Activated Spotlight and Siren for Added Security
Equipped with a built-in spotlight that activates on motion, the Wyze Cam v4 lights your path and deters unwanted visitors. The 99dB siren adds an extra layer of protection.
Weatherproof and Easy to Mount
Rated IP65 for weather resistance, this camera is perfect for both indoor and outdoor use. Its screw-free magnetic mount allows quick installation without tools.
Advanced Connectivity and Smart Features
  • Supports Wi-Fi 6 for stronger, more reliable connections.
  • Compatible with Alexa, Google Assistant, and IFTTT.
  • 24/7 local recording with microSD card support up to 256GB.
  • Smoke and CO alarm alerts for enhanced home safety.
Wyze Cam Floodlight Pro: The Ultimate Wide-Angle Floodlight Camera
Ultra-Wide 180° Field of View with 2.5K QHD Video
The Floodlight Pro covers your entire yard with a massive 180° diagonal field of view and delivers stunning 2.5K QHD video with color night vision. Its three dimmable LED panels produce 3000 lumens of bright, natural light at 5000K color temperature.
AI-Powered Object Detection and Smart Lighting
Using advanced onboard AI, the Floodlight Pro detects people, vehicles, and other objects you select, turning on lights only when necessary to reduce false alarms and save energy.
Robust Build and Connectivity
  • Dual-band Wi-Fi (2.4 & 5 GHz) ensures stable connections.
  • IP65 water resistance for all-weather durability.
  • Loud 105dB siren for effective deterrence.
  • Hardwired 110-120V AC power supply for continuous operation.
Smart Home Compatibility
Integrates with Alexa, Google Assistant, and IFTTT for voice commands and automation. Woman with dog near Wyze Cam Floodlight Pro Wyze Cam Floodlight Pro providing bright security lighting outdoors
Convenient Plug-In Mount Options for Floodlight Cameras
For those who prefer a simpler installation without electrical work, Wyze offers plug-in mount bundles for both the Floodlight v2 and Floodlight Pro models. These kits include a 20-foot power cord and a plug-in mount, allowing you to easily install your floodlight camera using an existing outdoor outlet—no junction box or electrician needed.
Benefits of Plug-In Mount Bundles
  • Flexible power solution for renters or DIY enthusiasts.
  • Easy cable management with included Velcro strap.
  • Same advanced features and weatherproof ratings as hardwired models.
Wyze Bulb Cam: Compact 2-in-1 Security Camera and Smart LED Bulb
Discreet Security with 2K HD Video and Color Night Vision
Wyze Bulb Cam fits into any standard E26 socket, combining a smart LED bulb with a 2K security camera. It offers a wide 160° field of view and color night vision to keep an eye on your home without bulky equipment.
Motion-Activated Lighting and Alerts
The bulb cam’s light activates on motion, illuminating dark areas while sending instant alerts to your phone. It supports local video storage up to 256GB microSD cards and includes two-way audio and a 95dB siren.
Weatherproof and Easy to Install
Rated IP65 for outdoor use, it’s perfect for porches, garages, or any fixture where you want discreet security lighting. Wyze Bulb Cam installed in outdoor light fixture Wyze Bulb Cam installed in an outdoor light fixture for seamless security
Why Choose Wyze Floodlight Cameras with Color Night Vision?
"Wyze floodlight cameras combine powerful illumination, advanced AI detection, and vibrant full HD color night vision to provide comprehensive security for your home or business. Whether you want a hardwired solution or a plug-in option, Wyze offers versatile, weatherproof cameras that integrate seamlessly with your smart home ecosystem."
With options ranging from the budget-friendly Wyze Cam v4 to the feature-packed Floodlight Pro, you can find the perfect floodlight camera tailored to your security needs. Enjoy peace of mind with motion-activated lighting, crisp video quality, and smart alerts that keep you connected no matter where you are.
Summary of Featured Products
Product NameResolutionField of ViewLumensNight Vision TypeWeatherproofPower TypeSpecial Features
Wyze Cam Floodlight v22K160°2800Color Night VisionIP65Hardwired / Plug-InAI Light Control, 270° PIR, 105dB Siren
Wyze Cam v42.5K QHD115.9°SpotlightEnhanced Color Night VisionIP65HardwiredWi-Fi 6, Magnetic Mount, 99dB Siren
Wyze Cam Floodlight Pro2.5K QHD180°3000Color Night VisionIP65Hardwired / Plug-InAI Object Detection, Dual-Band Wi-Fi
Wyze Bulb Cam2K160°800Color Night VisionIP65Standard Bulb Socket2-in-1 Bulb & Camera, Motion-Activated
Secure your home with the best motion-activated, weatherproof, dimmable floodlight cameras featuring full HD color night vision from Wyze. Choose the model that fits your needs and enjoy smarter, safer living.
FeatureWyze Cam Floodlight v2Wyze Cam v4Wyze Cam Floodlight ProWyze Cam Floodlight v2 + Plug-In MountWyze Bulb Cam
Price$89.98$35.98 (1 Pack)$149.98$109.96$49.98
Video Resolution2K (1920x1080 approx.)2.5K QHD (2560x1440)2.5K QHD (2560x1440)2K2K (2304x1296)
Field of View160° wide-angle115.9° (D) x 98.5° (H) x 53.1° (V)180° diagonal160° wide-angle160° (diagonal 166°)
Night VisionColor Night VisionEnhanced Color Night VisionColor Night VisionVibrant Color Night VisionColor Night Vision
Lighting2 x 2800 lumen LEDsMotion-activated spotlight3 x 3000 lumen dimmable LEDs2 x 2800 lumen LEDsUp to 800 lumens
Motion Detection270° PIR motion detectionMotion and sound detectionAI computer vision with object selectivityAdvanced motion detectionMotion detection
Two-Way TalkYesYesYesYesYes
Siren Volume105 dB99 dB105 dB105 dB95 dB
Local Recording24/7 local recording (microSD up to 256GB)24/7 local recording (microSD up to 256GB)Up to 256GB microSD card24/7 local recording (microSD up to 256GB)Local storage support up to 256GB
Power SupplyHardwiredWired (USB power adapter included)Hardwired 110-120V ACHardwired + Plug-In Mount (20ft cable)120V AC (standard E26 socket)
Weather ResistanceIP65IP65IP65IP65IP65
Wi-Fi Support2.4 GHz2.4 GHz & Wi-Fi 62.4 & 5 GHz dual-band2.4 GHz2.4 GHz
Smart Assistant IntegrationAlexa, Google AssistantAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google AssistantAlexa, Google Assistant
AI Features (with Cam Plus)Person, Package, Vehicle DetectionPerson, Package, Vehicle DetectionPerson, Package, Vehicle DetectionPerson, Package, Vehicle DetectionMotion Warning
InstallationHardwired, DIY install option with plug-in mountWired, magnetic mount, screw-freeHardwiredPlug-In Mount included for flexible powerFits standard light socket
DimensionsNot specified2in x 2in x 2 3/8in10.2 x 9.1 x 7.8 inSame as Floodlight v2Not specified
WeightNot specified0.49 lb (222 g)2.9 lbs (1.32 kg)Same as Floodlight v2Not specified
Additional FeaturesAmbient Light Mode, Dusk-to-Dawn Automation, AI-Powered Light ControlSmoke & CO Alerts, Auto-Zoom with AI, Bluetooth setup3 dimmable light panels, dual-band WiFi, Edge AI detectionsIncludes 20ft cable with velcro strap for cable management2-in-1 camera and smart LED bulb, digital zoom, supports up to 5 accessory bulbs
What are the key features of Wyze Cam Floodlight v2?Wyze Cam Floodlight v2 offers powerful 2800-lumen adjustable LED floodlights, 2K video resolution, a wide 160° field of view, advanced color night vision, AI-powered light control, 270° PIR motion detection, two-way talk, a 105dB siren, 24/7 local recording, dusk-to-dawn automation, and IP65 weatherproof durability. It also integrates with Alexa, Google Assistant, and IFTTT for smart home automation.
Is the Wyze Cam Floodlight v2 weatherproof for outdoor use?Yes, the Wyze Cam Floodlight v2 is rated IP65 weatherproof, making it suitable for both indoor and outdoor use. It is designed to withstand rain, snow, and extreme temperatures.
Does Wyze Cam Floodlight v2 support local video recording?Yes, Wyze Cam Floodlight v2 supports 24/7 local video recording to a microSD card (up to 256GB), allowing you to store footage without subscription fees.
What smart home platforms are Wyze floodlight cameras compatible with?Wyze floodlight cameras are compatible with Alexa, Google Assistant, and IFTTT, enabling voice control and smart home automation.
What is the difference between Wyze Cam Floodlight v2 and Wyze Cam Floodlight Pro?Wyze Cam Floodlight v2 features 2K resolution, 160° field of view, and 2800 lumens, while Wyze Cam Floodlight Pro offers 2.5K QHD resolution, a wider 180° field of view, and 3000 lumens. The Floodlight Pro also includes three dimmable LED panels, dual-band Wi-Fi, and advanced AI-powered object detection.
Can I install Wyze floodlight cameras without hardwiring?Yes, Wyze offers plug-in mount bundles for both the Floodlight v2 and Floodlight Pro models. These kits include a 20-foot power cord and plug-in mount, allowing for easy installation using an existing outdoor outlet—no electrician or junction box required.
What are the benefits of the plug-in mount option for Wyze floodlight cameras?The plug-in mount option provides a flexible power solution, especially for renters or DIY enthusiasts. It allows for easy installation and cable management, while retaining all the advanced features and weatherproof ratings of the hardwired models.
What makes Wyze Cam v4 suitable for both indoor and outdoor security?Wyze Cam v4 is IP65 weatherproof, supports Wi-Fi 6 for reliable connectivity, and features a screw-free magnetic mount for easy installation. It offers 2.5K QHD video, enhanced color night vision, a motion-activated spotlight, a 99dB siren, and 24/7 local recording, making it versatile for both indoor and outdoor use.
How does Wyze Bulb Cam combine lighting and security?Wyze Bulb Cam is a 2-in-1 device that fits into any standard E26 socket, functioning as both a smart LED bulb and a 2K security camera. It features a 160° field of view, color night vision, motion-activated lighting, instant alerts, two-way audio, a 95dB siren, and IP65 weatherproofing for outdoor use.
Do Wyze floodlight cameras offer color night vision?Yes, all featured Wyze floodlight cameras—including the Floodlight v2, Floodlight Pro, Cam v4, and Bulb Cam—offer full HD color night vision, providing vibrant and detailed video even in low-light conditions.
What is the maximum microSD card size supported by Wyze security cameras?Wyze security cameras support microSD cards up to 256GB for continuous local video recording.
How do Wyze floodlight cameras help deter intruders?Wyze floodlight cameras use motion-activated, bright LED lighting, loud sirens (up to 105dB), two-way talk, and instant alerts to your phone to deter intruders and enhance property security.
Are Wyze floodlight cameras easy to install?Yes, Wyze floodlight cameras are designed for easy installation. The plug-in mount bundles require no electrical work, while the Wyze Cam v4 features a screw-free magnetic mount. The Wyze Bulb Cam installs like a standard light bulb.
What is AI-powered object detection in Wyze Cam Floodlight Pro?AI-powered object detection in Wyze Cam Floodlight Pro uses advanced onboard AI to identify people, vehicles, and other objects you select. This ensures the floodlight only activates when necessary, reducing false alarms and saving energy.
Can Wyze cameras send instant alerts to my phone?Yes, Wyze cameras send instant motion and event alerts to your phone via the Wyze app, keeping you informed of any activity around your property.
What are the key features of the Wyze Cam Floodlight v2?How does the AI-powered light control work in the Wyze Cam Floodlight v2?Are there any ongoing promotions or discounts for Wyze products?
