Dusk to Dawn Automation Kit for Wyze Outdoor Cam & Lighting
Dusk to Dawn Automation Kit for Outdoor Wyze Cam and Lighting
Enhance your outdoor security and lighting with a complete dusk to dawn automation kit designed specifically for Wyze Cam and lighting products. Whether you want to illuminate your driveway, backyard, or front porch automatically as daylight fades, these Wyze products offer seamless integration, smart automation, and robust weather resistance to keep your home safe and well-lit from dusk till dawn.
Wyze Cam Floodlight v2: Bright, Smart, and Automated Lighting
The Wyze Cam Floodlight v2 is a powerful outdoor security camera combined with ultra-bright lighting designed to dominate the dark with ease.
Key Features:
- 2800 Lumens of Brightness: Two dimmable LED light panels provide ample illumination with a crisp 5000K color temperature.
- 2K Video with Color Night Vision: Capture clear, colorful footage day and night with a 160° wide-angle lens.
- Dusk-to-Dawn Automation: Automatically turns on the floodlight as the sun sets and off at sunrise, saving energy and enhancing security.
- AI-Powered Light Control: Intelligent lighting that responds to motion and ambient light conditions.
- Weather Resistant: Rated IP65 for reliable outdoor use in rain, snow, or shine.
- Two-Way Audio & Siren: Built-in microphone and speaker allow communication, plus a 105dB siren for deterrence.
- Local Storage: Supports up to 256GB microSD card for continuous local recording.
- Smart Assistant Integration: Works with Alexa, Google Assistant, and IFTTT for voice control and automation.
This floodlight camera is perfect for anyone looking to automate outdoor lighting with smart security features that activate precisely when needed.
Alt text: Wyze Cam Floodlight v2 lighting a driveway at dusk with motion detection
Wyze Outdoor Power Adapter: Reliable Power for Outdoor Use
To ensure your Wyze Cam and lighting devices operate flawlessly outdoors, the Wyze Outdoor Power Adapter is essential.
Highlights:
- IP67 Weather Resistance: Designed to withstand rain, snow, and extreme weather conditions.
- Compatibility: Works with Wyze Cam v3, v4, OG series, Pan v3, and Battery Cam Pro (with appropriate adapters).
- Long Cable Lengths: Includes a 12.5 ft cable for flexible installation.
- Complete Kit: Comes with wire clips, screws, anchors, and a weatherproof L-shaped Micro USB adapter.
- Safe and Durable: Certified by FCC and UL for safety and reliability.
- 1-Year Warranty: Peace of mind with manufacturer support.
This adapter is a must-have accessory to power your outdoor Wyze cameras and lighting setups safely and continuously.
Wyze Cam Floodlight Pro: Next-Level Security and Lighting
For those seeking the ultimate dusk to dawn automation with enhanced video quality and AI features, the Wyze Cam Floodlight Pro is the premium choice.
Standout Features:
- 3000 Lumens Brightness: Three dimmable LED panels deliver powerful illumination with 5000K color temperature.
- 2.5K QHD Video: Ultra-clear 2560x1440 resolution with color night vision and a 180° wide field of view.
- AI Computer Vision: Detects specific objects like people and vehicles to trigger lights and alerts intelligently.
- Dual-Band WiFi: Supports both 2.4 GHz and 5 GHz for stable connectivity.
- Motion-Activated Lighting: Lights turn on only when needed, conserving energy while maximizing security.
- Siren and Two-Way Audio: 105dB siren and built-in mic/speaker for deterrence and communication.
- Weatherproof: IP65 rating ensures durability in harsh outdoor environments.
- Smart Home Compatible: Integrates with Alexa, Google Assistant, and IFTTT for voice and automation control.
This floodlight camera acts like a personal security guard, providing bright, smart lighting and detailed surveillance from dusk till dawn.
Alt text: Wyze Cam Floodlight Pro lighting a side door area at night with smart security features
Why Choose a Dusk to Dawn Automation Kit for Wyze Outdoor Cameras?
Automating your outdoor lighting with Wyze products means your home is always protected and well-lit without manual intervention. The dusk to dawn feature ensures lights activate only when needed, enhancing security and saving energy. Combined with Wyze’s advanced cameras and weatherproof accessories, you get a reliable, smart home security system that works seamlessly in any outdoor environment.
Summary of Recommended Products for Dusk to Dawn Automation
Product Name | Key Benefit | Price (USD) |
Wyze Cam Floodlight v2 | Bright 2800 lumens, 2K video, dusk-to-dawn automation | 89.98 |
Wyze Outdoor Power Adapter | Weatherproof power supply for outdoor cameras | 14.99 - 19.99 |
Wyze Cam Floodlight Pro | Premium 3000 lumens, 2.5K QHD, AI-powered lighting | 149.98 |
By combining these Wyze products, you can create a comprehensive dusk to dawn automation kit that ensures your outdoor areas are brightly lit and monitored with smart, reliable technology.
Feature | Wyze Cam Floodlight v2 | Wyze Outdoor Power Adapter | Wyze Cam Floodlight Pro |
Type | Camera | Accessory | Camera |
Price | $89.98 | $14.99 - $19.99 (varies by variant) | $149.98 |
Color Options | Black, White | N/A | Black, White |
Video Resolution | 2K HD (160° wide-angle) | N/A | 2.5K QHD (180° wide-angle) |
Lighting | 2 floodlight heads, 2800 lumens | N/A | 3 dimmable light panels, 3000 lumens total |
Night Vision | Color Night Vision | N/A | Color Night Vision |
Motion Detection | Advanced, 270° PIR motion detection | N/A | AI computer vision with selectable object detection |
Recording | 24/7 local recording (microSD up to 256GB) | N/A | Local recording (microSD up to 256GB) |
Two-way Talk + Siren | Yes, 105dB siren | N/A | Yes, 105dB siren |
Power Supply | Hardwired 110-120V AC or Plug-in Mount option | Outdoor power adapter for Wyze cameras (IP67) | Hardwired 110-120V AC |
Weather Resistance | IP65 | IP67 | IP65 |
Smart Assistant Integration | Alexa, Google Assistant | N/A | Alexa, Google Assistant, IFTTT |
Wi-Fi Compatibility | 2.4 GHz | N/A | 2.4 & 5 GHz dual-band |
Special Features | Ambient Light Mode, AI-Powered Light Control, Dusk-to-dawn automation | Weather-resistant power adapter for outdoor use | Onboard AI for motion-triggered lighting |
Dimensions | Not specified | Not specified | 10.2" x 9.1" x 7.8" (25.91 cm x 23.11 cm x 19.81 cm) |
Weight | Not specified | Not specified | 2.9 lbs (1.32 kg) |
Warranty | Not specified | Not specified | 1 Year |
What is a dusk to dawn automation kit for Wyze Cam and lighting?
A dusk to dawn automation kit for Wyze Cam and lighting is a set of smart devices designed to automatically illuminate your outdoor spaces, such as driveways, backyards, or porches, as daylight fades. These kits integrate Wyze cameras and lighting products to provide seamless, energy-efficient lighting and enhanced security from sunset to sunrise.How does the Wyze Cam Floodlight v2 enhance outdoor security?
The Wyze Cam Floodlight v2 combines a powerful outdoor security camera with ultra-bright, dimmable LED lighting. It features 2K video with color night vision, a 160° wide-angle lens, dusk-to-dawn automation, AI-powered light control, two-way audio, a 105dB siren, and weather resistance (IP65). This ensures your property is well-lit and monitored, deterring intruders and capturing clear footage day and night.What are the main features of the Wyze Cam Floodlight v2?
Key features of the Wyze Cam Floodlight v2 include 2800 lumens of brightness, 2K video with color night vision, dusk-to-dawn automation, AI-powered light control, IP65 weather resistance, two-way audio, a 105dB siren, local storage support up to 256GB microSD, and compatibility with Alexa, Google Assistant, and IFTTT.Is the Wyze Cam Floodlight v2 weatherproof?
Yes, the Wyze Cam Floodlight v2 is rated IP65, making it weather resistant and suitable for reliable outdoor use in rain, snow, or shine.What is the Wyze Outdoor Power Adapter and why is it important?
The Wyze Outdoor Power Adapter is a weatherproof power supply designed to ensure your Wyze Cam and lighting devices operate reliably outdoors. It features IP67 weather resistance, compatibility with multiple Wyze camera models, a 12.5 ft cable for flexible installation, and comes with all necessary mounting accessories. It is FCC and UL certified for safety and includes a 1-year warranty.Which Wyze cameras are compatible with the Wyze Outdoor Power Adapter?
The Wyze Outdoor Power Adapter is compatible with Wyze Cam v3, v4, OG series, Pan v3, and Battery Cam Pro (with the appropriate adapters).What makes the Wyze Cam Floodlight Pro a premium choice for outdoor security?
The Wyze Cam Floodlight Pro offers advanced features such as 3000 lumens of brightness, 2.5K QHD video resolution, color night vision, a 180° wide field of view, AI computer vision for detecting people and vehicles, dual-band WiFi (2.4 GHz and 5 GHz), motion-activated lighting, a 105dB siren, two-way audio, IP65 weatherproofing, and smart home integration with Alexa, Google Assistant, and IFTTT.How does dusk to dawn automation save energy with Wyze products?
Dusk to dawn automation ensures that your outdoor lights only turn on when needed—at sunset—and turn off at sunrise. This smart scheduling, combined with motion and ambient light sensors, helps conserve energy by preventing unnecessary lighting during daylight hours.Can Wyze outdoor lighting and cameras be controlled with smart home assistants?
Yes, Wyze outdoor lighting and cameras are compatible with popular smart home assistants such as Alexa, Google Assistant, and IFTTT, allowing for voice control and advanced automation.What are the benefits of automating outdoor lighting with Wyze products?
Automating outdoor lighting with Wyze products enhances home security, ensures your property is always well-lit, saves energy, and eliminates the need for manual operation. Wyze’s advanced cameras and weatherproof accessories provide a reliable, smart home security system that works seamlessly in any outdoor environment.What is included in the Wyze Outdoor Power Adapter kit?
The Wyze Outdoor Power Adapter kit includes a 12.5 ft cable, wire clips, screws, anchors, and a weatherproof L-shaped Micro USB adapter, providing everything needed for safe and flexible outdoor installation.Does the Wyze Cam Floodlight v2 support local video storage?
Yes, the Wyze Cam Floodlight v2 supports local video storage with a microSD card of up to 256GB capacity for continuous recording.What is the price range for Wyze dusk to dawn automation products?
The Wyze Cam Floodlight v2 is priced at $89.98, the Wyze Outdoor Power Adapter ranges from $14.99 to $19.99, and the Wyze Cam Floodlight Pro is available for $149.98.
What are the key features of the Wyze Cam Floodlight v2?How does the dusk-to-dawn automation work with the Wyze Cam Floodlight?Are there any ongoing promotions or discounts for Wyze products?
