Dual Band WiFi Floodlight Cameras with Ambient Mode and Onboard AI Detection
When it comes to securing your home with smart lighting and advanced AI detection, Wyze offers top-tier floodlight cameras that combine powerful illumination, crystal-clear video, and intelligent features. Whether you want a reliable 2K camera with ambient lighting or a pro-level 2.5K QHD camera with dual-band WiFi, Wyze has you covered.
Explore the best dual band WiFi floodlight cameras featuring Ambient Mode and onboard AI detection to keep your property safe and well-lit.
Wyze Cam Floodlight Pro: The Ultimate Dual-Band AI Floodlight Camera
Experience powerful security lighting with Wyze Cam Floodlight Pro on your deck at evening.
Key Features
- Dual-Band WiFi Support (2.4 & 5 GHz): Enjoy faster, more reliable connectivity with dual-band WiFi, ensuring your floodlight camera stays connected even in crowded networks.
- 2.5K QHD Video Resolution: Capture ultra-clear video with Quad HD clarity, providing detailed images day and night with vibrant color night vision.
- 180° Ultra-Wide Field of View: Cover your entire yard or property with the widest viewing angle in the floodlight camera category, minimizing blind spots.
- Onboard AI Computer Vision: Advanced AI detects motion intelligently, triggering lights and alerts only for selected objects like people and vehicles, reducing false alarms.
- Adjustable 3,000 Lumen LED Lights: Three independently articulating floodlight panels deliver bright, customizable illumination to deter intruders effectively.
- Ambient Light Mode: Provides a constant low-level ambient light that brightens automatically when motion is detected, enhancing security without harsh lighting.
- Motion-Activated Voice Deterrence & 105dB Siren: Scare off unwanted visitors with voice prompts and a loud siren triggered by AI-detected motion.
- Weatherproof IP65 Rating: Built to withstand harsh weather conditions, from rain to snow, ensuring year-round protection.
- Easy DIY Installation: Replace your existing floodlight in under 20 minutes with simple instructions and optional plug-in mount for hassle-free setup.
Why Choose Wyze Cam Floodlight Pro?
This model is perfect for homeowners who want the best in video quality, AI-powered detection, and flexible WiFi connectivity. The dual-band WiFi ensures smooth streaming and quick alerts, while the powerful 3000 lumen lights keep your property brightly lit and secure.
Wyze Cam Floodlight v2: Smart 2K Floodlight Camera with Ambient Mode
Keep your driveway safe and illuminated with Wyze Cam Floodlight v2’s motion detection and ambient lighting.
Standout Features
- 2K HD Video with Color Night Vision: See every detail clearly, even in low light, with vibrant color night vision and 160° wide-angle coverage.
- 2800 Lumen Adjustable LEDs: Two bright floodlight heads illuminate your property, turning night into day to deter intruders.
- Ambient Light Mode: Provides a gentle, constant low-level light that brightens automatically when motion is detected, perfect for subtle security lighting.
- AI-Powered Light Control: Smart AI adjusts lighting based on detected motion and environmental conditions.
- 24/7 Local Recording: Continuous recording to a microSD card (up to 256GB) without subscription fees.
- Two-Way Talk & Loud 105dB Siren: Communicate with visitors or scare off unwanted guests directly through the app.
- 270° PIR Motion Detection: Wide motion detection area eliminates blind spots and triggers lights faster.
- Dusk-to-Dawn Automation: Automatically turns lights on at sunset and off at sunrise.
- IP65 Weather Resistance: Durable and reliable in all weather conditions.
- Seamless Smart Assistant Integration: Works with Alexa, Google Assistant, and IFTTT for voice control and automation.
- Easy Setup with Access Point WiFi: No need to scan QR codes on ladders; setup is simple and safe.
Ideal For
Homeowners looking for a high-quality 2K floodlight camera with ambient lighting and AI detection at an affordable price. The Wyze Cam Floodlight v2 balances performance and value with smart features and robust security.
Wyze Cam Floodlight Plug-In Mount: Simplify Your Installation
Features & Benefits
- Plug-and-Play Convenience: Avoid the complexity and cost of installing a junction box by using this easy plug-in mount.
- Compatible with Wyze Floodlight Models: Works seamlessly with Wyze Cam Floodlight v1, v2, and Floodlight Pro.
- 20 ft Power Cord: Provides flexible placement options for your floodlight camera.
- Outdoor Safe & Weather Resistant: Rated for outdoor use with a wide operating temperature range (-22°F to 122°F).
- Complete Mounting Kit Included: Comes with mounting screws, silicone ring, foam tape, and quick start guide for hassle-free installation.
This accessory is perfect for renters or anyone who prefers a simple, non-invasive power solution for their floodlight camera.
Wyze Cam Floodlight Pro + Plug-In Mount Bundle
Get the best of both worlds with this convenient bundle that includes the Wyze Cam Floodlight Pro and the Plug-In Mount in one package. Enjoy the advanced features of the Pro camera with the ease of plug-in installation, saving time and money on setup.
Why Choose Wyze Dual Band WiFi Floodlight Cameras?
"Wyze floodlight cameras combine powerful illumination, intelligent AI detection, and flexible connectivity to provide comprehensive home security solutions that are easy to install and use."
- Advanced AI Detection: Onboard AI vision detects people, vehicles, and packages, reducing false alerts.
- Ambient Mode Lighting: Provides constant low-level light that brightens on motion, enhancing security without harsh glare.
- Dual-Band WiFi (Pro Model): Ensures faster, more reliable connections on both 2.4 GHz and 5 GHz networks.
- Robust Weather Resistance: IP65 rating means your floodlight camera withstands rain, snow, and extreme temperatures.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for voice commands and automation.
- Flexible Installation Options: Choose between hardwired or plug-in mount setups to fit your home’s needs.
Conclusion
For those searching for a
dual band WiFi floodlight camera with ambient mode and onboard AI detection, Wyze offers two standout models:
- Wyze Cam Floodlight Pro for premium 2.5K QHD video, dual-band WiFi, and advanced AI-powered lighting.
- Wyze Cam Floodlight v2 for excellent 2K video, ambient lighting, and smart AI features at a great value.
Pair either with the
Wyze Cam Floodlight Plug-In Mount for easy, no-junction-box installation. Protect your home with smart, bright, and intelligent floodlight cameras designed to keep you safe day and night.
What is a dual band WiFi floodlight camera?
A dual band WiFi floodlight camera is a security camera that supports both 2.4 GHz and 5 GHz WiFi networks, providing faster and more reliable connectivity. This ensures smooth video streaming and quick alerts, even in crowded network environments.What are the key features of the Wyze Cam Floodlight Pro?
The Wyze Cam Floodlight Pro offers dual-band WiFi support (2.4 & 5 GHz), 2.5K QHD video resolution, a 180° ultra-wide field of view, onboard AI computer vision for intelligent motion detection, adjustable 3,000 lumen LED lights, Ambient Light Mode, motion-activated voice deterrence and 105dB siren, IP65 weatherproof rating, and easy DIY installation.How does Ambient Light Mode work on Wyze floodlight cameras?
Ambient Light Mode provides a constant low-level light that automatically brightens when motion is detected. This feature enhances security by offering subtle illumination without harsh glare, making your property safer and more welcoming.What is onboard AI detection in Wyze floodlight cameras?
Onboard AI detection uses advanced computer vision to intelligently detect motion and identify specific objects such as people, vehicles, and packages. This reduces false alarms and ensures that lights and alerts are triggered only for relevant events.What is the difference between Wyze Cam Floodlight Pro and Wyze Cam Floodlight v2?
Wyze Cam Floodlight Pro features 2.5K QHD video, dual-band WiFi, a 180° field of view, and advanced AI detection, making it ideal for those seeking premium performance. Wyze Cam Floodlight v2 offers 2K HD video, 160° wide-angle coverage, AI-powered light control, and is a more affordable option with robust features.Can Wyze floodlight cameras record video locally without a subscription?
Yes, Wyze Cam Floodlight v2 supports 24/7 local recording to a microSD card (up to 256GB) without any subscription fees, allowing you to store and access your footage directly.Are Wyze floodlight cameras weatherproof?
Yes, both Wyze Cam Floodlight Pro and Wyze Cam Floodlight v2 have an IP65 weather resistance rating, making them durable and reliable in rain, snow, and extreme temperatures.How easy is it to install a Wyze floodlight camera?
Wyze floodlight cameras are designed for easy DIY installation. You can replace your existing floodlight in under 20 minutes, and with the optional Plug-In Mount, you can avoid complex wiring and install the camera using a standard power outlet.What is the Wyze Cam Floodlight Plug-In Mount and who is it for?
The Wyze Cam Floodlight Plug-In Mount is an accessory that allows you to power your floodlight camera using a standard outlet, eliminating the need for a junction box. It is ideal for renters or anyone seeking a simple, non-invasive installation solution.Do Wyze floodlight cameras work with smart home assistants?
Yes, Wyze floodlight cameras are compatible with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.What security features do Wyze floodlight cameras offer?
Wyze floodlight cameras offer advanced AI detection, motion-activated voice deterrence, a loud 105dB siren, two-way talk, and customizable lighting to deter intruders and keep your property secure.Can I use the Wyze Cam Floodlight Plug-In Mount with all Wyze floodlight models?
Yes, the Plug-In Mount is compatible with Wyze Cam Floodlight v1, v2, and Floodlight Pro models, providing flexible installation options for different needs.
