Dual Band Outdoor Security Floodlight Cameras with 2.4 GHz Wi-Fi
When it comes to securing your outdoor spaces, having a reliable floodlight camera that supports dual-band Wi-Fi (2.4 GHz and 5 GHz) is essential for faster, more stable connections and enhanced coverage. Wyze offers a range of cutting-edge outdoor security floodlight cameras designed to illuminate your property while providing crystal-clear video surveillance and smart features. Below, we explore the top Wyze floodlight cameras that meet your need for dual-band outdoor security cameras with 2.4 GHz Wi-Fi support.
Wyze Cam Floodlight Pro: The Ultimate Dual-Band Security Solution
Experience powerful security lighting and crystal-clear video with Wyze Cam Floodlight Pro.
Key Features:
- Dual-Band Wi-Fi Support: Connect seamlessly to both 2.4 GHz and 5 GHz networks for faster, more reliable streaming and notifications.
- Ultra-Wide 180° Field of View: Covers your entire yard with minimal blind spots, ensuring comprehensive surveillance.
- 2.5K QHD Video Resolution: Capture stunningly detailed video footage day and night with enhanced color night vision.
- 3,000 Lumens Adjustable LED Lights: Bright, customizable floodlights with three independently articulating panels to tailor your lighting coverage.
- AI-Powered Motion Detection: Onboard AI computer vision detects people, vehicles, and other objects you select, triggering lights and alerts only when necessary.
- Motion-Activated Voice Deterrence & 105 dB Siren: Scare off unwanted visitors with voice prompts and a loud siren.
- Dusk-to-Dawn Automation & IP65 Weather Resistance: Automatically adjusts lighting based on ambient light and withstands harsh weather conditions.
- 24/7 Local Recording: Supports up to 256GB microSD card for continuous recording without subscription.
- Easy DIY Installation: Replace your existing floodlight in under 20 minutes with no electrician needed.
- Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT for voice control and automation.
Wyze Cam Floodlight Pro is the perfect choice if you want a high-powered, intelligent floodlight camera with dual-band Wi-Fi for superior connectivity and security.
Wyze Cam Floodlight v2: Bright, Smart, and Reliable
Keep your home safe with Wyze Cam Floodlight v2’s powerful LEDs and wide-angle view.
Highlights:
- 2.4 GHz Wi-Fi Connectivity: Reliable connection optimized for outdoor environments.
- 2K HD Video with Color Night Vision: See clear, vibrant video even in low light.
- 160° Wide-Angle Lens: Double the visibility compared to previous models, covering large areas.
- 2800 Lumens Motion-Activated LED Lights: Bright floodlights that turn on instantly when motion is detected.
- Ambient Light Mode: Provides a constant low-level light that brightens upon motion detection, deterring intruders.
- AI-Powered Light Control & Motion Detection: Smarter lighting that adapts to your environment.
- Two-Way Talk & 105 dB Siren: Communicate with visitors or scare off trespassers remotely.
- Dusk-to-Dawn Automation & IP65 Weatherproofing: Hassle-free operation and durability in all weather.
- 24/7 Local Recording: Supports microSD cards up to 256GB for continuous video storage.
- Easy Setup & Smart Assistant Compatibility: Works with Alexa and Google Home, plus easy Wi-Fi setup without QR codes.
Wyze Cam Floodlight v2 is an excellent option for those seeking a powerful, budget-friendly floodlight camera with essential smart features and 2.4 GHz Wi-Fi support.
Wyze Cam Floodlight v2 + Plug-In Mount: Flexible Power Solution
For users who prefer not to hardwire their floodlight cameras, the
Wyze Cam Floodlight v2 + Plug-In Mount bundle offers a convenient alternative.
Benefits:
- Plug-In Mount Included: Easily install your floodlight camera using a standard outdoor power outlet—no junction box or electrician required.
- All Features of Wyze Cam Floodlight v2: Enjoy 2K HD video, 2800 lumens LEDs, AI motion detection, two-way talk, and more.
- 20-Foot Power Cable with Cable Management: Provides flexibility in placement and neat installation.
- Available in Black or White: Matches your home’s exterior style.
This bundle is perfect for renters or anyone looking for a simple, no-fuss installation without sacrificing performance.
Why Choose Wyze for Your Outdoor Security?
"Wyze floodlight cameras combine powerful illumination, advanced AI detection, and smart home compatibility to provide comprehensive outdoor security with easy installation and reliable dual-band Wi-Fi connectivity."
Wyze’s outdoor floodlight cameras are designed to keep your home safe with features like:
- Dual-Band Wi-Fi (2.4 & 5 GHz): Ensures stable, fast connections even in crowded wireless environments.
- High-Resolution Video: From 2K to 2.5K QHD, capturing every detail.
- Smart AI Detection: Reduces false alarms by recognizing people, vehicles, and packages.
- Weatherproof Durability: IP65 rating means your camera withstands rain, snow, and heat.
- Voice Control & Automation: Integrate with Alexa, Google Assistant, and IFTTT for hands-free control.
- Flexible Installation Options: Hardwired or plug-in mounts to suit your setup.
Summary of Dual Band Outdoor Floodlight Cameras
Product | Video Resolution | Field of View | Lighting (Lumens) | Wi-Fi Bands | Special Features | Price Range |
Wyze Cam Floodlight Pro | 2.5K QHD | 180° | 3000 | 2.4 & 5 GHz | AI vision, voice deterrence, 3 adjustable lights | $149.98 |
Wyze Cam Floodlight v2 | 2K HD | 160° | 2800 | 2.4 GHz | Ambient light mode, two-way talk, siren | $89.98 |
Wyze Cam Floodlight v2 + Plug-In Mount | 2K HD | 160° | 2800 | 2.4 GHz | Plug-in mount for easy installation | $109.96 |
Enhance Your Home Security Today
Choosing the right dual-band outdoor security floodlight camera with 2.4 GHz Wi-Fi support means better connectivity, brighter illumination, and smarter detection. Wyze’s lineup offers options for every budget and installation preference, ensuring your home stays safe and well-lit around the clock.
What are the benefits of dual-band Wi-Fi in Wyze outdoor floodlight cameras?
Dual-band Wi-Fi support (2.4 GHz and 5 GHz) in Wyze outdoor floodlight cameras ensures faster, more stable connections and enhanced coverage. This means smoother video streaming, quicker notifications, and reliable performance even in crowded wireless environments.Which Wyze floodlight camera supports both 2.4 GHz and 5 GHz Wi-Fi bands?
The Wyze Cam Floodlight Pro supports both 2.4 GHz and 5 GHz Wi-Fi bands, providing superior connectivity and flexibility for your home security setup.What is the video resolution of Wyze Cam Floodlight Pro?
Wyze Cam Floodlight Pro features a 2.5K QHD video resolution, delivering crystal-clear footage with enhanced color night vision for detailed surveillance day and night.Does Wyze Cam Floodlight v2 support dual-band Wi-Fi?
Wyze Cam Floodlight v2 supports 2.4 GHz Wi-Fi connectivity, which is optimized for reliable outdoor performance, but it does not support 5 GHz Wi-Fi.What are the main differences between Wyze Cam Floodlight Pro and Wyze Cam Floodlight v2?
Wyze Cam Floodlight Pro offers dual-band Wi-Fi (2.4 & 5 GHz), a 2.5K QHD resolution, a 180° field of view, 3,000 lumens adjustable LED lights, and advanced AI-powered features. Wyze Cam Floodlight v2 provides 2.4 GHz Wi-Fi, 2K HD resolution, a 160° wide-angle lens, 2,800 lumens LEDs, and essential smart features at a more budget-friendly price.Can I install Wyze floodlight cameras without hardwiring?
Yes, the Wyze Cam Floodlight v2 + Plug-In Mount bundle allows you to install your floodlight camera using a standard outdoor power outlet, eliminating the need for hardwiring or a junction box. This is ideal for renters or those seeking a simple installation.Are Wyze outdoor floodlight cameras weatherproof?
Yes, all Wyze outdoor floodlight cameras are IP65 weather-resistant, ensuring reliable operation in rain, snow, and extreme temperatures.Do Wyze floodlight cameras support local video recording?
Yes, Wyze floodlight cameras support 24/7 local recording with microSD cards up to 256GB, allowing continuous video storage without a subscription.What smart home platforms are Wyze floodlight cameras compatible with?
Wyze floodlight cameras work with Alexa, Google Assistant, and IFTTT, enabling voice control and smart home automation.How bright are the Wyze floodlight cameras?
Wyze Cam Floodlight Pro features 3,000 lumens of adjustable LED lighting, while Wyze Cam Floodlight v2 and the v2 + Plug-In Mount offer 2,800 lumens, providing powerful illumination for your outdoor spaces.What AI-powered features do Wyze floodlight cameras offer?
Wyze floodlight cameras use onboard AI computer vision to detect people, vehicles, and other objects, reducing false alarms and triggering lights and alerts only when necessary. Some models also offer motion-activated voice deterrence and sirens.How easy is it to install Wyze outdoor floodlight cameras?
Wyze floodlight cameras are designed for easy DIY installation. The hardwired models can replace your existing floodlight in under 20 minutes, while the plug-in mount option allows for tool-free setup using a standard outdoor outlet.
