Top Outdoor Floodlight Cameras with AI Motion Detection for Home
Best Outdoor Floodlight Cameras with Motion Detection and AI for Home Security
When it comes to securing your home, having a reliable outdoor floodlight camera equipped with advanced motion detection and AI capabilities is essential. These smart devices not only illuminate your property with powerful lights but also intelligently detect and respond to movement, providing you with peace of mind day and night. Below, we explore the top Wyze outdoor floodlight cameras that combine cutting-edge AI, motion detection, and bright lighting to keep your home safe.
Wyze Cam Floodlight Pro: The Ultimate AI-Powered Security Guard
Advanced AI Motion Detection and Video Quality
The Wyze Cam Floodlight Pro stands out with its evolutionary onboard AI computer vision that smartly detects motion from specific objects such as people and vehicles. This means the floodlight only activates when it truly matters, reducing false alarms and unnecessary lighting.
  • Video Resolution: Stunning 2.5K QHD (2560x1440) with color night vision ensures crystal-clear footage.
  • Field of View: Ultra-wide 180° diagonal lens covers your entire yard with a 170° horizontal and 95° vertical view.
  • Frame Rate: Smooth video at 20 FPS during the day and 15 FPS at night.
Powerful Lighting and Durable Design
  • Brightness: Three dimmable LED panels deliver a total of 3,000 lumens at a crisp 5000K color temperature, lighting up your outdoor space brilliantly.
  • Weather Resistance: Rated IP65, it withstands harsh weather from -4°F to 140°F (-20°C to 60°C).
  • Mounting: Flexible wall or ceiling installation options.
  • Connectivity: Dual-band WiFi (2.4 & 5 GHz) for stable streaming and control.
  • Audio: Built-in 105dB siren and two-way audio for deterrence and communication.
Wyze Cam Floodlight Pro acts like a personal home security guard, combining bright lighting with smart AI detection to protect your property efficiently.
Wyze Cam Floodlight Pro in action with bright lighting Bright, AI-driven floodlight security for your home
Wyze Cam Floodlight v2: Bright, Smart, and Affordable
Impressive Illumination and AI-Powered Features
The Wyze Cam Floodlight v2 offers a powerful 2800 lumens of brightness with two dimmable LED panels, providing excellent lighting coverage for your outdoor areas.
  • Video Quality: 2K resolution (2304 x 1296) with color night vision for clear images even in low light.
  • Field of View: Wide 160° diagonal view to monitor large areas.
  • AI Light Control: Automatically adjusts lighting based on detected motion and ambient light.
  • Motion Detection: Smart alerts with AI-powered light control to reduce false triggers.
Robust and Weatherproof
  • Weather Resistance: IP65 rating ensures reliable performance in rain, snow, or heat.
  • Audio: Two-way talk with built-in speaker and microphone plus a loud 105dB siren.
  • Storage: Supports up to 256GB microSD card for local recording.
  • Integration: Works seamlessly with Alexa, Google Assistant, and IFTTT for smart home automation.
The Wyze Cam Floodlight v2 is perfect for those seeking a balance of bright lighting, smart AI features, and affordability.
Wyze Cam Floodlight v2 illuminating a driveway at dusk Smart floodlight camera lighting your driveway
Wyze Cam v4: Compact, Versatile Outdoor Security with Spotlight
High-Resolution Video and Motion-Activated Spotlight
Though not a traditional floodlight camera, the Wyze Cam v4 is a compact outdoor camera with a built-in motion-activated spotlight, making it a versatile choice for home security.
  • Video Resolution: Crisp 2.5K QHD (2560x1440) with enhanced color night vision.
  • Field of View: 115.8° diagonal, 98.5° horizontal, and 53.1° vertical for focused coverage.
  • Spotlight: Motion-activated spotlight enhances visibility and deters intruders.
  • Connectivity: Supports Wi-Fi 6 for faster, more reliable connections.
Smart Features and Durability
  • Audio: Two-way talk with a 99dB waterproof speaker and built-in siren.
  • Storage: Local microSD support up to 512GB and optional cloud storage.
  • Weatherproof: IP65 rating for all-season outdoor use.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
Wyze Cam v4 is ideal for users who want a compact, easy-to-install outdoor camera with spotlight and AI motion detection.
Wyze Cam v4 mounted outdoors with spotlight Compact outdoor camera with spotlight and AI detection
Why Choose Wyze Outdoor Floodlight Cameras?
Wyze offers a range of outdoor floodlight cameras that combine powerful illumination, AI-driven motion detection, and smart home compatibility. Whether you want the ultimate coverage and brightness of the Floodlight Pro, the affordable and bright Floodlight v2, or the compact versatility of the Cam v4 with spotlight, Wyze has a solution tailored to your home security needs.
With IP65 weather resistance, dual-band WiFi, and integrations with Alexa and Google Assistant, these cameras provide reliable, intelligent security that adapts to your lifestyle.
Summary of Top Outdoor Floodlight Cameras
ProductVideo ResolutionBrightness (Lumens)Field of ViewAI Motion DetectionWeatherproofPrice (USD)
Wyze Cam Floodlight Pro2.5K QHD3000180° diagonalYesIP65149.98
Wyze Cam Floodlight v22K2800160° diagonalYesIP6589.98
Wyze Cam v42.5K QHDSpotlight (72 lumens)115.8° diagonalYesIP65107.94
Protect your home with the best outdoor floodlight cameras featuring AI motion detection and smart lighting. Choose Wyze for innovative, reliable, and affordable home security solutions.
FeatureWyze Cam Floodlight ProWyze Cam v4Wyze Cam Floodlight v2
Price$149.98$35.98 - $107.94 (varies by pack)$89.98
Video Resolution2.5K QHD (2560x1440)2.5K QHD (2560x1440)2K (2304x1296)
Field of View180° Ultra-Wide115.8° (DFOV), 98.5° (HFOV), 53.1° (VFOV)160° Diagonal
Night VisionColor Night VisionEnhanced Color Night VisionColor Night Vision
LED Floodlight Brightness3000 lumens, adjustable and dimmableMotion-activated spotlight2800 lumens, 2 dimmable LED panels
Motion DetectionAI computer vision (people, vehicles)AI-based motion detection with zonesAI-Powered Light Control
AudioBuilt-in speaker and microphone; 2-way talkEnhanced 2-way talk, 99 dB speaker, sirenBuilt-in speaker and microphone; 2-way talk
Siren105 dB99 dB105 dB
Wi-Fi Support2.4 & 5 GHz Wi-FiWi-Fi 6 (2.4 GHz & 5 GHz)2.4 GHz (802.11 b/g/n)
Local StoragemicroSD up to 256 GBmicroSD up to 512 GBmicroSD up to 256 GB
Cloud StorageOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscription
Weather ResistanceIP65IP65IP65
Power SupplyHardwired (110-120V AC)Wired (requires outdoor power adapter for outdoor use)Hardwired (110-120V AC)
InstallationDIY, wall/ceiling mount, plug-in mount optionMagnetic mount, wall, ceiling, standWall or ceiling mount
Special FeaturesAmbient Light Mode, Motion-Activated Voice Deterrence, 3 articulating light panels, Dusk to Dawn AutomationAuto-zoom with AI, Smoke & CO alerts, Wide Dynamic Range (WDR), Bluetooth setupAmbient Light Mode, Dusk to Dawn Automation
Operating Temperature-4°F to 140°F (-20°C to 60°C)-4°F to 122°F (-20°C to 50°C)-4°F to 140°F (-20°C to 60°C)
DimensionsNot specified2in x 2in x 2 3/8in9.5in x 7.7in x 7.0in
WeightNot specified0.49 lb (222 g)2.76 lbs (1.25 kg)
What are the best Wyze outdoor floodlight cameras for home security?The top Wyze outdoor floodlight cameras for home security are the Wyze Cam Floodlight Pro, Wyze Cam Floodlight v2, and Wyze Cam v4. Each model offers advanced AI motion detection, weatherproof design, and smart home integration to keep your property safe.
How does AI motion detection work on Wyze outdoor floodlight cameras?Wyze outdoor floodlight cameras use onboard AI computer vision to intelligently detect motion from specific objects like people and vehicles. This reduces false alarms and ensures the floodlight only activates when necessary, providing more accurate security alerts.
What is the video quality of Wyze Cam Floodlight Pro?The Wyze Cam Floodlight Pro features stunning 2.5K QHD (2560x1440) video resolution with color night vision, delivering crystal-clear footage both day and night.
How bright are Wyze outdoor floodlight cameras?The Wyze Cam Floodlight Pro delivers 3,000 lumens of brightness with three dimmable LED panels, while the Wyze Cam Floodlight v2 offers 2,800 lumens with two panels. The Wyze Cam v4 features a motion-activated spotlight with 72 lumens for focused illumination.
Are Wyze outdoor floodlight cameras weatherproof?Yes, all featured Wyze outdoor floodlight cameras have an IP65 weather resistance rating, ensuring reliable performance in rain, snow, or extreme temperatures.
Can Wyze floodlight cameras be integrated with smart home systems?Yes, Wyze floodlight cameras are compatible with Alexa, Google Assistant, and IFTTT, allowing seamless integration with your smart home devices for enhanced automation and control.
What storage options are available for Wyze outdoor floodlight cameras?Wyze outdoor floodlight cameras support local storage via microSD cards (up to 256GB for Floodlight v2 and up to 512GB for Cam v4) and offer optional cloud storage for video recordings.
What is the difference between Wyze Cam Floodlight Pro and Wyze Cam Floodlight v2?The Wyze Cam Floodlight Pro offers higher video resolution (2.5K QHD), brighter lighting (3,000 lumens), a wider 180° field of view, and dual-band WiFi. The Floodlight v2 provides 2K resolution, 2,800 lumens, a 160° field of view, and is more affordable.
Does the Wyze Cam v4 have a floodlight?The Wyze Cam v4 is not a traditional floodlight camera but features a built-in motion-activated spotlight (72 lumens) that enhances visibility and deters intruders, making it a versatile option for outdoor security.
What is the field of view for Wyze outdoor floodlight cameras?The Wyze Cam Floodlight Pro has an ultra-wide 180° diagonal field of view, the Floodlight v2 offers a 160° diagonal view, and the Cam v4 provides a 115.8° diagonal field of view for focused coverage.
Do Wyze outdoor floodlight cameras have two-way audio?Yes, all featured Wyze outdoor floodlight cameras include two-way audio, allowing you to communicate with visitors or deter intruders directly from your mobile device.
What is the price range for Wyze outdoor floodlight cameras?The Wyze Cam Floodlight Pro is priced at $149.98, the Wyze Cam Floodlight v2 at $89.98, and the Wyze Cam v4 at $107.94, offering options for different budgets and security needs.
What are the key features of the Wyze Cam Floodlight Pro?How does the AI motion detection work in the Wyze outdoor floodlight cameras?Are there any ongoing promotions or discounts for Wyze products?
