Wyze Outdoor Floodlights: App Control & Local Recording Security
Outdoor Floodlights with Wyze App Control and Local Recording
Enhance your home security with advanced outdoor floodlights that offer seamless Wyze app control and reliable local recording. Whether you want to illuminate your driveway, monitor your yard, or deter unwanted visitors, Wyze provides smart floodlight cameras designed to meet your needs with cutting-edge features, easy installation, and robust performance.
Wyze Cam Floodlight v2: Brilliant Illumination Meets Smart Security
Key Features
  • 2800 Lumens Brightness: Two powerful LED floodlights light up your outdoor spaces with vivid clarity.
  • 2K HD Video with Color Night Vision: Capture crystal-clear footage day and night with a 160° wide-angle lens.
  • 24/7 Local Recording: Continuous recording to a microSD card (up to 256GB) ensures you never miss a moment without any subscription fees.
  • AI-Powered Light Control & Ambient Light Mode: Lights adjust automatically based on motion and ambient conditions, providing constant low-level lighting that brightens when needed.
  • Two-Way Talk & 105dB Siren: Communicate with visitors or scare off intruders directly through the Wyze app.
  • Dusk-to-Dawn Automation & IP65 Weather Resistance: Automatically turns on/off with sunset and sunrise, built to withstand harsh weather.
  • Easy DIY Installation: Compatible with a floodlight plug-in mount for simple setup without an electrician.
Why Choose Wyze Cam Floodlight v2?
This model offers a perfect balance of brightness, smart features, and affordability. Its wide 160° field of view and 2K resolution provide excellent coverage and detail, making it ideal for front porches, backyards, and driveways. Wyze Cam Floodlight v2 in action illuminating a driveway at night Bright and smart outdoor security lighting
Wyze Cam Floodlight Pro: The Ultimate Smart Floodlight Camera
Advanced Specifications
  • 3000 Lumens with 3 Adjustable LED Panels: Ultra-bright and customizable lighting coverage to banish darkness from every corner.
  • 2.5K QHD Video & 180° Ultra-Wide Field of View: See your entire yard with stunning Quad HD clarity and minimal blind spots.
  • Onboard AI Computer Vision: Motion-activated lights and alerts triggered only by selected objects like people and vehicles, reducing false alarms.
  • Dual-Band Wi-Fi (2.4 & 5 GHz): Faster, more reliable connectivity for seamless app control.
  • Motion-Activated Voice Deterrence & 105dB Siren: Automated voice warnings combined with a loud siren to deter intruders effectively.
  • Ambient Light Mode & Dusk-to-Dawn Automation: Provides constant ambient lighting and smart on/off scheduling.
  • 24/7 Local Recording: Supports microSD cards up to 256GB for continuous video storage without monthly fees.
  • IP65 Weatherproof & Easy DIY Installation: Built tough for all weather conditions and simple to install by replacing existing floodlights.
Ideal For
Those who want the highest resolution, widest coverage, and smartest AI-powered detection in a floodlight camera. Perfect for larger properties or anyone needing premium security lighting. Wyze Cam Floodlight Pro installed on a side door with a woman and dog nearby Smart security with voice deterrence and bright lighting
Floodlight Security Bundle: Best of Both Worlds
Bundle Highlights
  • Combines Wyze Cam Floodlight Pro and Wyze Cam Floodlight v2 for comprehensive coverage.
  • Total lumen output exceeds 5800 lumens, ensuring no dark spots around your property.
  • Both cameras support 2K+ resolution, color night vision, and 24/7 local recording.
  • Includes motion-activated voice deterrence, ambient light mode, and IP65 weather resistance.
  • Save with a bundled price while getting two powerful floodlight cameras.
This bundle is perfect for homeowners who want to secure multiple outdoor areas with the latest Wyze technology and enjoy local recording without subscription fees.
Convenient Power Options: Wyze Cam Floodlight Plug-In Mounts
Features
  • Plug-n-Play Installation: Avoid the hassle and cost of installing a junction box.
  • Compatible with Wyze Cam Floodlight v1, v2, and Floodlight Pro.
  • Comes with a 20-foot power cord and cable management accessories.
  • Rated for outdoor use and built to withstand temperatures from -22°F to 122°F.
  • UL certified for safety and reliability.
Bundled Options
  • Available as standalone mounts or combined with Wyze Cam Floodlight v2 or Floodlight Pro in convenient bundles.
  • Ideal for renters or anyone with an accessible outdoor power outlet.
Why Choose Wyze Outdoor Floodlights?
"Wyze floodlights combine powerful illumination, smart AI detection, and local recording capabilities with easy app control, making them the perfect choice for modern home security."
  • Seamless Wyze App Integration: Control your floodlights, view live video, receive motion alerts, and communicate through two-way audio—all from your smartphone.
  • Local Recording Without Subscription: Save video footage directly to a microSD card, giving you full control without monthly fees.
  • Smart Home Compatibility: Works with Alexa, Google Assistant, and IFTTT for voice commands and automation.
  • Weatherproof and Durable: IP65 rating ensures reliable performance in rain, snow, or heat.
  • Flexible Installation: Hardwired or plug-in mount options to fit your setup.
Summary Table of Wyze Outdoor Floodlights
FeatureWyze Cam Floodlight v2Wyze Cam Floodlight ProFloodlight Security Bundle
Video Resolution2K (2304 x 1296)2.5K QHD (2560 x 1440)Includes both v2 & Pro
Field of View160°180°Combined wide coverage
LED Brightness (Lumens)280030005800+ total lumens
Local Recording24/7 via microSD (up to 256GB)24/7 via microSD (up to 256GB)24/7 via microSD
AI Motion DetectionYes (with Cam Plus)Advanced onboard AIYes
Two-Way Talk & SirenYesYesYes
Weather ResistanceIP65IP65IP65
Power OptionsHardwired or Plug-In MountHardwired or Plug-In MountBundle includes both cameras
App ControlWyze AppWyze AppWyze App
Conclusion
For outdoor floodlights with Wyze app control and local recording, Wyze Cam Floodlight v2 and Wyze Cam Floodlight Pro stand out as top choices. Whether you want a single floodlight with excellent features or a comprehensive security bundle, Wyze offers smart, bright, and reliable solutions that keep your home safe and well-lit. The plug-in mount options make installation hassle-free, perfect for any home setup. Illuminate your property, monitor activity in stunning detail, and enjoy peace of mind with Wyze’s innovative floodlight cameras.
FeatureWyze Cam Floodlight v2Wyze Cam Floodlight ProFloodlight Security BundleWyze Cam Floodlight Pro + Plug-In MountWyze Cam Floodlight v2 + Plug-In Mount
Price (USD)$89.98$149.98$209.96$169.96$109.96
Camera Resolution2K (2304 x 1296)2.5K QHD (2560 x 1440)Floodlight Pro: 2.5K QHD
Floodlight v2: 2K
2.5K QHD (2560 x 1440)2K (2304 x 1296)
Field of View (FOV)160°180° (Diagonal), 170° (Horizontal)Floodlight Pro: 180°
Floodlight v2: 160°
180° Ultra-Wide160°
LED Brightness (Lumens)28003000Floodlight Pro: 3000
Floodlight v2: 2800
30002800
Night VisionColor Night VisionColor Night VisionIncludedYesYes
Motion DetectionPIR 270° + AI-Powered Light ControlAI Computer Vision Motion DetectionIncludedAI Computer Vision Motion DetectionAdvanced Motion Detection
Two-Way TalkYesYesIncludedYesYes
Siren105 dB105 dBIncluded105 dB105 dB
Ambient Light ModeYesYesIncludedYesYes
Dusk-to-Dawn AutomationYesYesIncludedYesYes
Weather ResistanceIP65IP65IP65IP65IP65
Local Recording24/7 with microSD (up to 256GB)24/7 with microSD (up to 256GB)Included24/7 with microSD (up to 256GB)24/7 with microSD (up to 256GB)
Wi-Fi Compatibility2.4 GHzDual-band 2.4 & 5 GHz2.4 GHz (Floodlight v2), Dual-band (Pro)Dual-band 2.4 & 5 GHz2.4 GHz
Smart Assistant IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTIncludedAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Power SupplyHardwired 110-120V ACHardwired 110-120V ACHardwired 110-120V ACHardwired 110-120V ACHardwired 110-120V AC
Plug-In Mount IncludedNoNoNoYesYes
Plug-In Mount PriceN/AN/AN/AIncludedIncluded
InstallationDIY, no junction box neededDIY, no junction box neededDIY, no junction box neededDIY, plug-n-play with mountDIY, plug-n-play with mount
Operating Temperature-4°F to 140°F (-20°C to 60°C)-4°F to 140°F (-20°C to 60°C)-4°F to 140°F (-20°C to 60°C)-4°F to 140°F (-20°C to 60°C)-4°F to 140°F (-20°C to 60°C)
Warranty1 Year1 Year1 Year1 Year1 Year
What are the main features of Wyze Cam Floodlight v2?Wyze Cam Floodlight v2 offers 2800 lumens of brightness, 2K HD video with color night vision, 160° wide-angle lens, 24/7 local recording to a microSD card (up to 256GB), AI-powered light control, ambient light mode, two-way talk, a 105dB siren, dusk-to-dawn automation, IP65 weather resistance, and easy DIY installation with plug-in mount compatibility.
How does Wyze Cam Floodlight Pro differ from Floodlight v2?Wyze Cam Floodlight Pro features 3000 lumens with three adjustable LED panels, 2.5K QHD video, a 180° ultra-wide field of view, advanced onboard AI computer vision for smart motion detection, dual-band Wi-Fi (2.4 & 5 GHz), motion-activated voice deterrence, a 105dB siren, ambient light mode, dusk-to-dawn automation, 24/7 local recording, IP65 weatherproofing, and easy DIY installation. It is ideal for larger properties needing premium security lighting.
Can Wyze outdoor floodlights record video locally without a subscription?Yes, both Wyze Cam Floodlight v2 and Floodlight Pro support 24/7 local video recording to a microSD card (up to 256GB) without requiring any monthly subscription fees.
What is included in the Wyze Floodlight Security Bundle?The Wyze Floodlight Security Bundle includes both the Wyze Cam Floodlight Pro and Wyze Cam Floodlight v2, providing over 5800 lumens of total brightness, 2K+ resolution, color night vision, 24/7 local recording, motion-activated voice deterrence, ambient light mode, IP65 weather resistance, and bundled savings for comprehensive outdoor security coverage.
Are Wyze outdoor floodlights weatherproof?Yes, all Wyze outdoor floodlights, including the v2 and Pro models, are IP65 rated for weather resistance, ensuring reliable performance in rain, snow, or heat.
How can I install Wyze Cam Floodlights without hardwiring?Wyze offers plug-in mount options for their floodlights, allowing for easy DIY installation without the need for a junction box or electrician. The plug-in mount comes with a 20-foot power cord and is compatible with Wyze Cam Floodlight v1, v2, and Pro.
Do Wyze outdoor floodlights work with smart home systems?Yes, Wyze outdoor floodlights are compatible with Alexa, Google Assistant, and IFTTT, allowing for voice commands and smart home automation.
What app features are available with Wyze outdoor floodlights?With the Wyze app, you can control your floodlights, view live video, receive motion alerts, communicate through two-way audio, activate the siren, and adjust lighting settings directly from your smartphone.
What is the maximum storage capacity for local recording on Wyze floodlights?Both Wyze Cam Floodlight v2 and Floodlight Pro support microSD cards up to 256GB for continuous 24/7 local video recording.
What power options are available for Wyze outdoor floodlights?Wyze outdoor floodlights can be installed using either a hardwired connection or a plug-in mount, providing flexibility for different home setups.
What is ambient light mode on Wyze floodlights?Ambient light mode provides constant low-level lighting that automatically brightens when motion is detected, enhancing security and visibility while saving energy.
How does AI-powered detection work on Wyze Cam Floodlight Pro?Wyze Cam Floodlight Pro uses onboard AI computer vision to detect and trigger alerts or lighting only for selected objects, such as people and vehicles, reducing false alarms from animals or other movements.
What are the differences between the Wyze Cam Floodlight v2 and the Wyze Cam Floodlight Pro?Can you explain the installation process for the Wyze Cam Floodlight?Are there any ongoing promotions or discounts for the Wyze floodlights?
