Install Wyze Chime Controller with Wired Duo Doorbell Guide
How to Install Wyze Chime Controller with Wired Duo Doorbell Integration
Integrating your Wyze Chime Controller with a wired Wyze Duo Doorbell is a straightforward process that enhances your home security by enabling your existing mechanical chime to work seamlessly with your smart doorbell system. This guide will walk you through the installation steps, highlight the key features of the Wyze Video Doorbell v2 and the Front Porch Security Bundle, and provide essential tips for a smooth setup.
Wyze Video Doorbell v2: The Core of Your Wired Duo Doorbell Setup
Key Features and Specifications
  • 2K Video Resolution: Capture crystal-clear video at 2048 x 1536 pixels with a wide 166.8° diagonal field of view, ensuring you see every detail at your doorstep.
  • Local and Cloud Storage: Supports up to 256GB microSD card for local storage and cloud storage options with the Wyze Security Plan.
  • Two-Way Audio & Voice Deterrence: Communicate with visitors in real-time and deter unwanted guests with motion-activated voice alerts.
  • Robust Build: Polycarbonate body with resin lens, weather-resistant IP65 rating, and operating temperature range from -4°F to 122°F.
  • Easy Installation Kit: Comes with a Wyze Chime Controller, wall plate, wedge for angled mounting, wire caps, extension wires, screws, and a quick start guide.
  • Power Requirements: Works with 16V-24V AC power supply, minimum 10VA transformer recommended for optimal chime performance.
  • Smart Integrations: Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation.
Installation Highlights
  • Begin by setting up your Wyze Duo Cam Doorbell in the Wyze app.
  • Turn off power at your electrical panel before wiring.
  • Open your existing chime box, photograph the wiring, and follow the app’s wiring instructions to connect the Wyze Doorbell Chime Controller.
  • Use the included wire caps and extension wires to secure connections.
  • Mount the doorbell using the wall plate or wedge for the best viewing angle.
  • Restore power and test the doorbell and chime functionality.
  • Finalize setup in the Wyze app by selecting your built-in mechanical chime option.
Pro Tip: Even if your existing chime is broken or non-functional, installing the Wyze Doorbell Chime Controller is crucial to protect your doorbell from power surges and ensure proper power flow.
Front Porch Security Bundle: Complete Smart Home Integration
What’s Included?
  • Wyze Video Doorbell (1080p HD): Provides clear front porch video with two-way audio.
  • Wyze Chime: Offers multiple sound options including modern, classic, animal, automation, and intruder alarm sounds.
  • Wyze Lock: Control your door lock remotely, view lock history, and integrate with your doorbell notifications.
  • Additional Accessories: Wall plate, wedge, wire caps, extension wires, screws, and quick start guides for easy installation.
Features and Benefits
  • Remote Access: Unlock or lock your door from anywhere using the Wyze app.
  • Motion Detection & Alerts: Receive instant notifications for motion events and doorbell presses.
  • Voice Assistant Compatibility: Works with Alexa and Google Assistant for hands-free control.
  • Weather Resistance: Doorbell and chime designed to withstand outdoor conditions with IP65 rating.
  • Secure Data: End-to-end encryption and AES 128-bit encryption ensure your data privacy.
Installation Notes
  • The bundle requires an existing wired doorbell system with a 16V-24V AC power supply.
  • Follow the Wyze Video Doorbell v2 installation steps for wiring the chime controller.
  • The included Wyze Chime plugs into a standard US power outlet (100V-240V).
  • Use the Wyze app to configure and customize chime sounds and lock settings.
Step-by-Step Installation Guide for Wyze Chime Controller with Wired Duo Doorbell
1. Prepare Your Doorbell Setup:
  • Ensure your Wyze Duo Cam Doorbell is set up in the Wyze app.
  • Confirm your home’s doorbell wiring and power supply meet the 16V-24V AC, 10VA minimum requirement.
2. Power Off and Access Chime Box:
  • Turn off power at the electrical panel controlling your doorbell.
  • Press the doorbell button to verify power is off.
  • Open your mechanical chime box and take a clear photo of the wiring for reference.
3. Install the Wyze Doorbell Chime Controller:
  • Identify the number of wires in your chime box (2, 3, or 4+ wires).
  • Follow the Wyze app instructions to connect the chime controller wires to the correct terminals.
  • Use the provided wire caps to secure all wire connections safely.
4. Mount the Doorbell:
  • Attach the wall plate or wedge to your desired location.
  • Connect the doorbell wires to the extension wires or directly to the doorbell terminals.
  • Slide the doorbell onto the mounting plate until it clicks securely.
5. Restore Power and Test:
  • Turn the power back on at the electrical panel.
  • Press the doorbell button to ensure the chime rings and the doorbell powers on.
  • In the Wyze app, navigate to your doorbell settings and select “My built-in house chime” > “Mechanical” to complete the setup.
Safety Reminder: If you are unsure about handling electrical wiring or your chime wiring is complex, consult a licensed electrician.
Troubleshooting Tips
Chime Not Ringing After Installation:
  • Verify your transformer provides sufficient power; a 20-30VA transformer is recommended.
  • Check wiring connections for any loose or incorrect terminals.
  • Try alternate wiring configurations as suggested in the Wyze app.
Power Issues:
  • Ensure the Wyze Doorbell Chime Controller is installed even if your chime is broken to protect against power surges.
  • Confirm the doorbell flashes orange when powered on, indicating proper connection.
Enhance Your Home Security with Wyze
Installing the Wyze Chime Controller with your wired Duo Doorbell integration not only preserves your existing mechanical chime but also adds smart features like 2K video, two-way audio, and seamless app control. Whether you choose the Wyze Video Doorbell v2 alone or the comprehensive Front Porch Security Bundle, you’re investing in a reliable, easy-to-install, and feature-rich smart home security solution. Wyze Doorbell Installation Lifestyle Experience easy installation and smart home integration with Wyze. Front Porch Security Bundle in Use Complete front porch security with Wyze’s smart bundle.
Summary of Products Mentioned
By following this guide, you can confidently install your Wyze Chime Controller with your wired Duo Doorbell, ensuring your home stays secure and connected with the latest smart technology.
FeatureWyze Video Doorbell v2The Front Porch Security Bundle
Video Resolution2K (2048 x 1536)1080p HD
Video Doorbell IncludedYesYes (Wyze Video Doorbell and Chime)
Two-Way AudioYesYes
Local StoragemicroSD card slot for 24/7 local recordingNot specified
Cloud StorageOptional with Cam Plus subscriptionOptional with Cam Plus subscription
Motion-Activated Voice DeterrenceYes (requires Cam Plus or Cam Protect)Not specified
Pre-roll Motion Recording3-6 secondsNot specified
Weather ResistanceIP65IP65 (inferred from doorbell)
Works with Existing ChimeYes, includes chime controllerYes (Wyze Video Doorbell and Chime included)
Smart Home IntegrationAlexa, Google HomeAlexa, Google Home (via included devices)
Additional Devices IncludedDoorbell + Chime Controller (variant)Wyze Lock (varies by bundle), sometimes Wyze Cam V3
Price$44.98 (Doorbell + Chime Controller)From $123.99 to $173.97 depending on variant
PurposeWired video doorbell with advanced featuresComplete front porch security with doorbell, lock, and camera
Two-Way TalkYesYes
Video Quality2K video1080p HD
Lock ControlNoYes, remote lock/unlock with Wyze Lock
Number of Cameras1 (doorbell camera)1 or more (doorbell + optional Wyze Cam V3)
Return Policy30-day hassle-free returns30-day hassle-free returns (when in stock)
AvailabilityIn stockMostly sold out
How do I install the Wyze Chime Controller with a wired Wyze Duo Doorbell?To install the Wyze Chime Controller with your wired Wyze Duo Doorbell, first set up your doorbell in the Wyze app. Turn off power at your electrical panel, open your existing chime box, and take a photo of the wiring. Follow the Wyze app’s instructions to connect the chime controller using the provided wire caps and extension wires. Mount the doorbell using the wall plate or wedge, restore power, and test the system. Complete the setup in the Wyze app by selecting your built-in mechanical chime option.
What are the power requirements for the Wyze Video Doorbell v2 and Chime Controller?The Wyze Video Doorbell v2 and Chime Controller require a 16V-24V AC power supply with a minimum 10VA transformer for optimal performance. For best results, a 20-30VA transformer is recommended, especially if you experience chime issues.
Can I use the Wyze Chime Controller if my existing mechanical chime is broken?Yes, you should still install the Wyze Chime Controller even if your existing chime is broken or non-functional. The controller protects your doorbell from power surges and ensures proper power flow.
What features does the Wyze Video Doorbell v2 offer?The Wyze Video Doorbell v2 features 2K video resolution (2048 x 1536 pixels), a 166.8° diagonal field of view, local and cloud storage options, two-way audio, motion-activated voice deterrence, weather-resistant IP65 rating, and compatibility with Alexa, Google Assistant, and IFTTT.
What is included in the Wyze Front Porch Security Bundle?The Wyze Front Porch Security Bundle includes a Wyze Video Doorbell (1080p HD), Wyze Chime with multiple sound options, Wyze Lock for remote access and control, and installation accessories such as a wall plate, wedge, wire caps, extension wires, screws, and quick start guides.
How do I troubleshoot if my chime is not ringing after installation?If your chime is not ringing, verify that your transformer provides sufficient power (20-30VA recommended), check all wiring connections for security and correctness, and try alternate wiring configurations as suggested in the Wyze app.
Is the Wyze Video Doorbell v2 weather-resistant?Yes, the Wyze Video Doorbell v2 is weather-resistant with an IP65 rating, making it suitable for outdoor installation in a variety of weather conditions.
Can I control the Wyze Video Doorbell and Chime with voice assistants?Yes, the Wyze Video Doorbell v2 and Chime are compatible with Alexa and Google Assistant, allowing for hands-free control and smart home integration.
What storage options are available for Wyze Video Doorbell v2 recordings?The Wyze Video Doorbell v2 supports up to a 256GB microSD card for local storage and also offers cloud storage options through the Wyze Security Plan.
What should I do if I am unsure about handling electrical wiring during installation?If you are unsure about handling electrical wiring or if your chime wiring is complex, it is recommended to consult a licensed electrician to ensure a safe and proper installation.
What are the key features of the Wyze Video Doorbell v2?Can you explain the installation steps for the Wyze Chime Controller?What should I do if the chime is not ringing after installation?
