Wyze Cordless Vacuum S: Best for Large Multi-Floor Homes
Wyze Cordless Vacuum S: The Ultimate Cleaning Solution for Large Homes with Multiple Floor Types
When it comes to maintaining a spotless home with diverse flooring, the Wyze Cordless Vacuum S stands out as a top-tier choice. Designed for large homes, this cordless vacuum combines powerful suction, lightweight design, and smart features to tackle everything from hardwood floors to carpets with ease.
Experience the freedom of cordless cleaning with the Wyze Cordless Vacuum S — engineered to deliver 20,000 Pa of suction power and up to 40 minutes of runtime on a single charge.
Wyze Cordless Vacuum S in action with pet-friendly home Alt text: Lifestyle image of Wyze Cordless Vacuum S cleaning a pet-friendly living room with sofa and corgi
Powerful Suction for Every Floor Type
The Wyze Cordless Vacuum S is equipped with dual motors that provide exceptional suction power tailored to your cleaning needs:
  • Turbo Mode: 20,000 Pa for deep cleaning carpets and stubborn debris
  • Medium Mode: 9,000 Pa for everyday cleaning on mixed surfaces
  • ECO Mode: 6,000 Pa for gentle cleaning and extended battery life
This range of suction settings ensures optimal performance whether you're vacuuming hardwood, tile, or plush rugs.
Lightweight and Ergonomic Design
Weighing just 2.8 pounds for the main unit and 4.9 pounds when fully assembled, the Wyze Cordless Vacuum S is incredibly easy to maneuver around furniture and up stairs. Its compact size (12.4 x 4.5 x 8.7 inches main unit) and ergonomic handle reduce fatigue during extended cleaning sessions, making it perfect for large homes.
Long-Lasting Battery Life with Quick Recharge
Equipped with a 6-cell lithium-ion battery (2,000mAh*6), this vacuum offers:
  • Up to 40 minutes of runtime in ECO mode
  • 23 minutes in Medium mode
  • 10 minutes in Turbo mode
Charging takes just 4-6 hours via AC charging, so your vacuum is ready when you need it most. For even longer cleaning sessions, consider the Wyze Cordless Vacuum S - Battery Pack accessory to double your runtime.
Essential Accessories to Enhance Your Cleaning Experience
Maximize the versatility and convenience of your Wyze Cordless Vacuum S with these compatible accessories designed specifically for this model:
  • Extend your cleaning time with an additional battery pack
  • Perfect for large homes requiring multiple cleaning cycles
  • Hassle-free 30-day return policy
Wyze Cordless Vacuum S - Charger
  • Replacement charger to keep your vacuum powered up
  • Compact and compatible with the Wyze Cordless Vacuum S
  • Flexible tube that bends to reach under furniture and tight spaces
  • Reduces strain by allowing you to clean awkward areas effortlessly
Wyze Cordless Vacuum - HEPA Filter (2 Pack)
  • Maintain optimal air quality with regular filter replacements
  • High-efficiency particulate air (HEPA) filtration captures fine dust and allergens
Wyze Cordless Vacuum - Mini Motorized Brush Head
  • Ideal for cleaning car seats, sofas, and upholstery
  • Compact size (6 x 5.5 x 5 inches) for detailed cleaning
Wyze Cordless Vacuum S lifestyle cleaning hardwood floors Alt text: Lifestyle image of Wyze Cordless Vacuum S cleaning hardwood floors in a modern home
Why Choose Wyze Cordless Vacuum S for Your Large Home?
  • Multi-floor adaptability: From hardwood to carpet, the vacuum adjusts suction power for efficient cleaning
  • Lightweight and portable: Easy to carry and use throughout your home without fatigue
  • Smart features: LED screen displays suction mode and battery life for intuitive operation
  • Bright LED brush head: Six daylight-bright LEDs illuminate dark corners and under furniture
  • Large dust cup: 0.7 L capacity reduces the frequency of emptying during big cleaning jobs
  • Quiet operation: Noise level capped at 65 dBA in Turbo mode, keeping your home peaceful
The Wyze Cordless Vacuum S is the perfect blend of power, convenience, and smart design — ideal for homeowners who demand a thorough clean without the hassle of cords or heavy equipment.
Summary of Wyze Cordless Vacuum S Specs
FeatureSpecification
Suction Power20,000 Pa (Turbo), 9,000 Pa (Medium), 6,000 Pa (ECO)
Weight2.8 lbs (main unit), 4.9 lbs (assembled)
Battery6-cell lithium-ion, 2,000mAh*6
Runtime40 min (ECO), 23 min (Medium), 10 min (Turbo)
Charging Time4-6 hours
Dust Cup Volume0.7 L
Noise Level65 dBA (Turbo)
Dimensions (Main Unit)12.4 x 4.5 x 8.7 inches
Operating Temperature-4ºF to 169ºF (-20ºC to 75ºC)
FeaturesLED screen, 2 motors, 3-stage filtration, 6 LED lights in brush head
Invest in the Wyze Cordless Vacuum S today to enjoy effortless, powerful cleaning tailored for large homes with multiple floor types. Its combination of advanced technology, lightweight design, and smart accessories makes it a must-have for any modern household.
ProductTypePrice (USD)Key FeaturesCompatibilityWeight / DimensionsNotes
Wyze Cordless Vacuum SConnected Home139.9920,000 Pa suction, 2 motors, 40-min interchangeable lithium-ion battery, 2.8 lbs, 3-speed LED display, 3-stage HEPA filtration, 6 LED lights on brush headN/A2.8 lbsEasy to empty, washable dust cup & filters, built-in filter brush
Wyze Cordless Vacuum S - Battery PackAccessories59.99Extra battery pack for extended useWyze Cordless Vacuum SN/ALow stock (36 left)
Wyze Cordless Vacuum S - ChargerReplacement4.99Replacement chargerWyze Cordless Vacuum SN/A30-day hassle-free returns
Wyze Cordless Vacuum - Foldable Vacuum TubeAccessories15.99Foldable tube for easier cleaningWyze Cordless VacuumN/APrice compared at 29.99 USD
Wyze Cordless Vacuum - HEPA Filter (2 Pack)Accessories15.99Replaceable HEPA filters, removes 95% of particles <0.3 µmWyze Cordless VacuumN/ASold as 2 pack
Wyze Cordless Vacuum - Mini Motorized Brush HeadAccessories29.99Motorized brush head for car seats and sofasWyze Cordless Vacuum6 x 5.5 x 5 inchesFor detailed cleaning on upholstery
What types of floors can the Wyze Cordless Vacuum S clean?The Wyze Cordless Vacuum S is designed for multi-floor adaptability, making it ideal for cleaning hardwood, tile, carpets, and rugs. Its adjustable suction modes ensure optimal performance on all floor types.
How powerful is the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S features dual motors and offers up to 20,000 Pa of suction power in Turbo mode, 9,000 Pa in Medium mode, and 6,000 Pa in ECO mode, allowing for deep cleaning of carpets and effective removal of stubborn debris.
How long does the battery last on the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S provides up to 40 minutes of runtime in ECO mode, 23 minutes in Medium mode, and 10 minutes in Turbo mode. The battery recharges fully in 4-6 hours.
Is the Wyze Cordless Vacuum S lightweight and easy to use?Yes, the Wyze Cordless Vacuum S weighs just 2.8 pounds for the main unit and 4.9 pounds when fully assembled. Its ergonomic handle and compact design make it easy to maneuver around furniture and up stairs, reducing fatigue during extended cleaning sessions.
What accessories are available for the Wyze Cordless Vacuum S?Available accessories include the Wyze Cordless Vacuum S Battery Pack for extended runtime, a replacement charger, a foldable vacuum tube for cleaning under furniture, HEPA filters for improved air quality, and a mini motorized brush head for cleaning upholstery and car seats.
Does the Wyze Cordless Vacuum S have HEPA filtration?Yes, the Wyze Cordless Vacuum S uses a high-efficiency particulate air (HEPA) filter to capture fine dust and allergens, helping to maintain optimal air quality in your home.
How large is the dust cup on the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S features a 0.7-liter dust cup, which reduces the frequency of emptying during large cleaning jobs.
Is the Wyze Cordless Vacuum S suitable for large homes?Absolutely. The Wyze Cordless Vacuum S is specifically designed for large homes, offering powerful suction, long battery life, and a range of accessories to handle multiple cleaning cycles and diverse floor types.
How noisy is the Wyze Cordless Vacuum S during operation?The Wyze Cordless Vacuum S operates quietly, with a maximum noise level of 65 dBA in Turbo mode, ensuring a peaceful cleaning experience.
What smart features does the Wyze Cordless Vacuum S offer?The vacuum includes an LED screen that displays suction mode and battery life, as well as a brush head with six daylight-bright LEDs to illuminate dark corners and under furniture for thorough cleaning.
How do I extend the runtime of my Wyze Cordless Vacuum S?You can extend the runtime by purchasing the Wyze Cordless Vacuum S Battery Pack accessory, which allows for quick battery swaps and longer cleaning sessions—ideal for large homes.
What are the dimensions of the Wyze Cordless Vacuum S?The main unit of the Wyze Cordless Vacuum S measures 12.4 x 4.5 x 8.7 inches, making it compact and easy to store.
How long does it take to charge the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S takes approximately 4-6 hours to fully recharge using the included AC charger.
What are the different suction modes available on the Wyze Cordless Vacuum S?How long does it take to fully charge the Wyze Cordless Vacuum S?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Cordless Vacuum S?
