Discover the Wyze Cordless Vacuum S with LED Headlights for Superior Cleaning Visibility
When it comes to cordless vacuums that combine power, convenience, and smart features, the
Wyze Cordless Vacuum S stands out as a top choice. Designed for effortless cleaning with enhanced visibility, this vacuum is perfect for tackling dust and debris in every corner of your home—even in dimly lit spaces.
Why Choose Wyze Cordless Vacuum S?
Powerful Suction for Deep Cleaning
The Wyze Cordless Vacuum S delivers an impressive
20,000 Pa suction power in Turbo Mode, ensuring even the most stubborn dirt is lifted from carpets, hardwood floors, and upholstery. It offers multiple suction modes to suit your cleaning needs:
- Turbo Mode: 20,000 Pa (10 minutes runtime)
- Medium Mode: 9,000 Pa (23 minutes runtime)
- ECO Mode: 6,000 Pa (40 minutes runtime)
This versatility means you can clean efficiently without worrying about battery life or power loss.
Lightweight and Ergonomic Design
Weighing just
2.8 lbs for the main unit and
4.9 lbs when fully assembled, the Wyze Cordless Vacuum S is as light as feathers, making it easy to maneuver around furniture, stairs, and tight spaces without fatigue.
Long-Lasting Interchangeable Battery
Equipped with a
6-cell lithium-ion battery (2,000mAh*6), this vacuum offers up to
40 minutes of runtime in ECO mode. The battery is interchangeable, so you can extend your cleaning sessions by swapping in a fully charged pack.
Enhanced Visibility with LED Headlights
One of the standout features is the
6 daylight-bright LED lights embedded in the brush head. These LEDs illuminate dark corners, under furniture, and other hard-to-see areas, ensuring no dust bunnies escape your attention.
"Finally! A vacuum that is free and independent and no longer reliant on its parents for financial and emotional support." – Wyze
Enjoy pet-friendly cleaning with the Wyze Cordless Vacuum S, perfect for sofas and floors alike.
Advanced Features for a Smarter Clean
Dual Motors for Maximum Efficiency
The vacuum is powered by
two motors, providing consistent suction and performance across all surfaces.
3-Stage Filtration System
Keep your home air cleaner with the
3-stage filtration system, including a HEPA filter that traps fine dust and allergens.
User-Friendly LED Screen
Stay informed with the built-in
LED screen that displays battery life, suction mode, and maintenance alerts.
Comprehensive Attachments Included
The Wyze Cordless Vacuum S comes with a variety of tools to tackle different cleaning tasks:
- Crevice Tool for tight spaces
- Floor Brush for hard floors and carpets
- Dust Cap
- HEPA Filter and Filter Housing
- Standard Tube for extended reach
Accessories to Enhance Your Wyze Cordless Vacuum S Experience
Extend the functionality and convenience of your vacuum with these official Wyze accessories designed specifically for the Cordless Vacuum S:
Wyze Cordless Vacuum S - Battery Pack
Need extra cleaning time? The
replacement battery pack ensures you never run out of juice during your cleaning sessions. Compatible only with the Wyze Cordless Vacuum S, it offers hassle-free 30-day returns.
Price: $59.99
Wyze Cordless Vacuum S - Charger
Keep your vacuum powered up with the official
replacement charger designed for the Wyze Cordless Vacuum S.
Price: $4.99
This
foldable tube accessory bends to reach awkward angles and tight spots, reducing strain on your arms and back. Compatible with Wyze Cordless Vacuum models.
Price: $15.99 (discounted from $29.99)
Wyze Cordless Vacuum - HEPA Filter (2 Pack)
Maintain optimal filtration by replacing your HEPA filters regularly with this
2-pack filter set designed exclusively for Wyze Cordless Vacuum.
Price: $15.99
Wyze Cordless Vacuum - Mini Motorized Brush Head
Perfect for cleaning
car seats, sofas, and upholstery, this mini brush head attachment is compact and powerful.
Price: $29.99
Effortlessly clean hardwood floors with the Wyze Cordless Vacuum S and its versatile attachments.
Specifications at a Glance
Feature | Specification |
Suction Power | 100 AW / 20,000 Pa (Turbo Mode) |
Weight | 2.8 lbs (main unit), 4.9 lbs (assembled) |
Battery | 6-cell lithium-ion, 2,000mAh*6 |
Runtime | Up to 40 minutes (ECO Mode) |
Charging Time | 4-6 hours |
Dust Cup Volume | 0.7 L |
Noise Level | 65 dBA (Turbo Mode) |
Dimensions | 12.4 x 4.5 x 8.7 inches (main unit) |
Color | Steel grey with Wyze green accents |
Operating Temperature | -4ºF to 169ºF (-20ºC to 75ºC) |
Conclusion
The
Wyze Cordless Vacuum S is a powerful, lightweight, and smart cleaning solution that excels in visibility thanks to its integrated LED headlights. Whether you’re cleaning pet hair, dust, or debris on various surfaces, this vacuum offers the suction power, battery life, and accessories to make your cleaning routine easier and more effective.
Upgrade your home cleaning experience with the Wyze Cordless Vacuum S and its range of compatible accessories designed to keep your space spotless and allergen-free.
What is the suction power of the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S delivers up to 20,000 Pa of suction power in Turbo Mode, making it highly effective for deep cleaning carpets, hardwood floors, and upholstery. It also offers Medium Mode (9,000 Pa) and ECO Mode (6,000 Pa) to suit different cleaning needs.How long does the battery last on the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S provides up to 40 minutes of runtime in ECO Mode, 23 minutes in Medium Mode, and 10 minutes in Turbo Mode. The battery is interchangeable, allowing you to extend cleaning sessions by swapping in a fully charged pack.Does the Wyze Cordless Vacuum S have LED headlights?
Yes, the Wyze Cordless Vacuum S features 6 daylight-bright LED headlights embedded in the brush head, providing superior visibility for cleaning in dark corners, under furniture, and other hard-to-see areas.Is the Wyze Cordless Vacuum S lightweight and easy to use?
Absolutely. The main unit weighs just 2.8 lbs, and the fully assembled vacuum weighs 4.9 lbs, making it easy to maneuver around furniture, stairs, and tight spaces without causing fatigue.What filtration system does the Wyze Cordless Vacuum S use?
The Wyze Cordless Vacuum S is equipped with a 3-stage filtration system, including a HEPA filter that effectively traps fine dust and allergens, helping to keep your home’s air cleaner.What attachments and accessories are included with the Wyze Cordless Vacuum S?
The vacuum comes with a crevice tool, floor brush, dust cap, HEPA filter and filter housing, and a standard tube for extended reach. Additional accessories like a replacement battery pack, charger, foldable vacuum tube, HEPA filter 2-pack, and mini motorized brush head are also available for purchase.How do I extend the cleaning time of my Wyze Cordless Vacuum S?
You can extend your cleaning time by purchasing an additional interchangeable battery pack, which allows you to swap batteries and continue cleaning without waiting for a recharge.What surfaces can the Wyze Cordless Vacuum S clean?
The Wyze Cordless Vacuum S is designed to clean a variety of surfaces, including carpets, hardwood floors, upholstery, and even car seats, thanks to its powerful suction and versatile attachments.How do I maintain the filtration system in the Wyze Cordless Vacuum S?
To maintain optimal filtration, regularly replace the HEPA filter with the official Wyze Cordless Vacuum HEPA Filter 2-pack, which is designed specifically for this vacuum model.What is the dust cup capacity of the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S features a 0.7-liter dust cup, allowing you to clean larger areas before needing to empty the container.How long does it take to fully charge the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S takes approximately 4 to 6 hours to fully charge using the official replacement charger.Is the Wyze Cordless Vacuum S suitable for pet owners?
Yes, the Wyze Cordless Vacuum S is ideal for pet owners, as it effectively removes pet hair from sofas, floors, and upholstery with its strong suction and specialized attachments.What are the dimensions and color of the Wyze Cordless Vacuum S?
The main unit measures 12.4 x 4.5 x 8.7 inches and comes in a stylish steel grey color with Wyze green accents.What is the noise level of the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S operates at a noise level of 65 dBA in Turbo Mode, making it relatively quiet for a high-powered vacuum.What is the operating temperature range for the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S can operate in temperatures ranging from -4ºF to 169ºF (-20ºC to 75ºC), ensuring reliable performance in various environments.
