Wyze Cordless Vacuum S: The Ultimate Cordless Vacuum for Full House Cleaning
When it comes to cordless vacuums with long battery life and powerful suction, the
Wyze Cordless Vacuum S stands out as a top choice for full house cleaning. Designed to combine lightweight convenience with robust performance, this vacuum is perfect for tackling every corner of your home efficiently.
Experience the freedom of cordless cleaning with up to 40 minutes of runtime on a single charge, powerful suction modes, and smart features that make cleaning effortless.
Key Features and Specifications of Wyze Cordless Vacuum S
Powerful Suction for Deep Cleaning
The Wyze Cordless Vacuum S delivers an impressive suction power that adapts to your cleaning needs:
- Turbo Mode: 20,000 Pa suction power for stubborn dirt and pet hair
- Medium Mode: 9,000 Pa for everyday cleaning
- ECO Mode: 6,000 Pa for extended runtime and light cleaning
- Air Watts: 100 AW for efficient debris pickup
This multi-level suction capability ensures your floors, carpets, and upholstery are spotless with minimal effort.
Long-Lasting Battery Life
Equipped with a
6-cell lithium-ion battery (2,000mAh*6), the vacuum offers:
- 40 minutes of runtime in ECO mode
- 23 minutes in Medium mode
- 10 minutes in Turbo mode
- Quick recharge time of 4-6 hours to full battery
The battery is interchangeable, allowing you to swap in a fresh pack (sold separately) for uninterrupted cleaning sessions.
Lightweight and Ergonomic Design
Weighing only
2.8 lbs (main unit) and
4.9 lbs (assembled), the Wyze Cordless Vacuum S is as light as feathers, making it easy to maneuver around furniture and carry between rooms without fatigue.
Advanced Cleaning Technology
- Dual motors for enhanced suction and efficiency
- 3-stage filtration system including a HEPA filter to trap fine dust and allergens
- 6 daylight-bright LED lights on the brush head illuminate hidden dirt in dark corners and under furniture
- Comes with multiple attachments: Crevice Tool, Floor Brush, Dust Cap, HEPA Filter, and Standard Tube for versatile cleaning
Dimensions and Build
- Main unit: 12.4 x 4.5 x 8.7 inches
- Assembled unit height: 41.1 inches
- Stylish steel grey finish with Wyze green accents
Enhance Your Cleaning Experience with Wyze Accessories
To maximize the performance and convenience of your Wyze Cordless Vacuum S, consider these compatible accessories:
Wyze Cordless Vacuum S - Battery Pack
- Extend your cleaning time with an extra battery pack designed specifically for the Wyze Cordless Vacuum S.
- Price: $59.99
- Perfect for large homes or multiple cleaning sessions without waiting for recharge.
Wyze Cordless Vacuum S - Charger
- Replacement charger ensures your vacuum is always ready to go.
- Compact and compatible with the original unit.
- Price: $4.99
- Flexible tube attachment that bends to reach tricky spots without straining your wrist.
- Ideal for cleaning under furniture or tight spaces.
- Price: $15.99 (discounted from $29.99)
Wyze Cordless Vacuum - HEPA Filter (2 Pack)
- Replace filters regularly to maintain optimal suction and air quality.
- Designed exclusively for Wyze Cordless Vacuum.
- Price: $15.99
Wyze Cordless Vacuum - Mini Motorized Brush Head
- Specialized brush for cleaning car seats, sofas, and upholstery.
- Compact size (6 x 5.5 x 5 inches) for detailed cleaning.
- Price: $29.99
Why Choose Wyze Cordless Vacuum S for Your Home?
- Cordless freedom with long battery life lets you clean your entire house without interruptions.
- Powerful suction modes handle everything from light dust to heavy pet hair.
- Lightweight design reduces fatigue and makes cleaning accessible for everyone.
- Smart features like LED lights and a 3-stage filtration system improve cleaning quality and indoor air.
- Affordable price with high-end features, plus a range of accessories to customize your cleaning setup.
Effortless cleaning around pets and furniture with Wyze Cordless Vacuum S
Lightweight and powerful cordless vacuum for full house cleaning
Perfect for hardwood floors and all surfaces with bright LED brush head
Conclusion
The
Wyze Cordless Vacuum S is an excellent choice for anyone seeking a cordless vacuum with long battery life, powerful suction, and versatile cleaning capabilities. Whether you have pets, hardwood floors, or carpets, this vacuum adapts to your needs and makes full house cleaning a breeze.
Upgrade your cleaning routine today with Wyze Cordless Vacuum S and its range of handy accessories designed to keep your home spotless and fresh.
What are the main features of the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S features powerful multi-level suction (up to 20,000 Pa in Turbo mode), a long-lasting interchangeable battery with up to 40 minutes of runtime, lightweight and ergonomic design, dual motors, a 3-stage HEPA filtration system, LED lights on the brush head, and multiple cleaning attachments for versatile use.How long does the battery last on the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S offers up to 40 minutes of runtime in ECO mode, 23 minutes in Medium mode, and 10 minutes in Turbo mode. The battery is interchangeable, allowing you to swap in a fresh pack (sold separately) for extended cleaning sessions.How powerful is the suction on the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S delivers up to 20,000 Pa of suction power in Turbo mode, 9,000 Pa in Medium mode, and 6,000 Pa in ECO mode, with 100 Air Watts for efficient debris pickup. This ensures deep cleaning on carpets, floors, and upholstery.Is the Wyze Cordless Vacuum S suitable for pet hair and allergens?
Yes, the Wyze Cordless Vacuum S is ideal for pet owners. Its powerful suction and dual motors effectively remove pet hair, while the 3-stage HEPA filtration system traps fine dust and allergens, improving indoor air quality.What attachments and accessories are available for the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S comes with a Crevice Tool, Floor Brush, Dust Cap, HEPA Filter, and Standard Tube. Additional accessories include an extra battery pack, replacement charger, foldable vacuum tube, HEPA filter 2-pack, and a mini motorized brush head for upholstery and car cleaning.How much does the Wyze Cordless Vacuum S weigh?
The main unit of the Wyze Cordless Vacuum S weighs only 2.8 lbs, and the fully assembled vacuum weighs 4.9 lbs, making it lightweight and easy to maneuver around your home.How long does it take to recharge the Wyze Cordless Vacuum S battery?
The Wyze Cordless Vacuum S battery takes approximately 4-6 hours to fully recharge.Can I extend the cleaning time of my Wyze Cordless Vacuum S?
Yes, you can extend your cleaning time by purchasing an additional interchangeable battery pack, which allows you to swap batteries and continue cleaning without waiting for a recharge.Does the Wyze Cordless Vacuum S work on all floor types?
Yes, the Wyze Cordless Vacuum S is designed for use on hardwood floors, carpets, and other surfaces. Its powerful suction and versatile attachments make it suitable for a variety of cleaning tasks throughout your home.What is the size and design of the Wyze Cordless Vacuum S?
The main unit measures 12.4 x 4.5 x 8.7 inches, and the assembled unit stands 41.1 inches tall. It features a stylish steel grey finish with Wyze green accents, combining modern aesthetics with ergonomic design.
