Wyze Cordless Vacuum S: The Ultimate Multi-Function Vacuum for Hardwood Floors and Rugs
When it comes to keeping your hardwood floors and rugs spotless, the
Wyze Cordless Vacuum S stands out as a powerful, lightweight, and versatile cleaning solution. Designed for modern homes, this cordless vacuum combines strong suction, smart features, and user-friendly design to tackle dirt, dust, and pet hair with ease.
Experience the freedom of cordless cleaning with 20,000 Pa suction power and a feather-light weight of just 2.8 pounds for the main unit. Whether you’re vacuuming delicate hardwood or plush rugs, the Wyze Cordless Vacuum S adapts to your needs.
Effortless cleaning on hardwood floors and rugs with Wyze Cordless Vacuum S
Powerful Suction and Long-Lasting Battery
The Wyze Cordless Vacuum S offers multiple suction modes to optimize cleaning performance:
- Turbo Mode: 20,000 Pa suction for deep cleaning stubborn dirt (10 minutes runtime)
- Medium Mode: 9,000 Pa suction for everyday cleaning (23 minutes runtime)
- ECO Mode: 6,000 Pa suction for extended cleaning sessions (up to 40 minutes runtime)
Equipped with a 6-cell lithium-ion battery (2,000mAh*6), this vacuum provides up to 40 minutes of cordless cleaning on a single charge. The battery is interchangeable, allowing you to swap in a spare pack for uninterrupted cleaning sessions.
Lightweight and Ergonomic Design
Weighing only 2.8 lbs for the main unit and 4.9 lbs when fully assembled, the Wyze Cordless Vacuum S is incredibly easy to maneuver around furniture and tight spaces. Its compact dimensions (12.4 x 4.5 x 8.7 inches main unit) and steel grey finish with Wyze green accents make it both stylish and practical.
Advanced Features for Superior Cleaning
- Dual Motors: Two powerful motors ensure consistent suction across all surfaces.
- 3-Stage Filtration System: Captures fine dust and allergens, ideal for homes with pets or allergy sufferers.
- 6 Daylight-Bright LED Lights: Integrated into the brush head to illuminate hidden dust under furniture and in dark corners.
- LED Screen: Displays battery life and suction mode for easy monitoring.
Versatile Attachments for Every Cleaning Task
The Wyze Cordless Vacuum S comes with a comprehensive set of attachments to clean every nook and cranny:
- Crevice Tool for tight spaces
- Floor Brush optimized for hardwood and rugs
- Dust Cap and HEPA Filter for improved air quality
- Standard Tube for extended reach
For enhanced flexibility, consider the
Wyze Cordless Vacuum - Foldable Vacuum Tube accessory, which bends to reach awkward angles without straining your wrist.
Pet-friendly cleaning made easy with Wyze Cordless Vacuum S
Essential Accessories to Maximize Your Wyze Vacuum Experience
Wyze Cordless Vacuum S - Battery Pack
Need extra cleaning time? The official
Wyze Cordless Vacuum S Battery Pack is designed specifically for this model, allowing you to double your runtime and clean larger areas without interruption.
- Price: $59.99
- Compatibility: Wyze Cordless Vacuum S
- Hassle-free 30-day returns
This accessory bends so you don’t have to, making it easier to clean under furniture and in hard-to-reach spots.
- Price: $15.99 (discounted from $29.99)
Additional Replacement Parts and Accessories
- HEPA Filter (2 Pack): Replace regularly to maintain optimal filtration and air quality.
- Mini Motorized Brush Head: Perfect for cleaning car seats, sofas, and upholstery.
- Replacement Charger: Keep a spare charger handy for convenience.
Why Choose Wyze Cordless Vacuum S for Hardwood Floors and Rugs?
The Wyze Cordless Vacuum S is engineered to deliver powerful suction, lightweight handling, and smart features that make cleaning hardwood floors and rugs effortless. Its multi-function design, combined with a suite of accessories, ensures you have the right tool for every cleaning challenge.
Whether you’re tackling pet hair on rugs or dust on hardwood, this vacuum’s versatility and performance make it a top choice for maintaining a clean, healthy home environment.
Summary of Key Specs
Feature | Specification |
Suction Power | Up to 20,000 Pa (Turbo Mode) |
Weight | 2.8 lbs (main unit), 4.9 lbs (assembled) |
Battery | 6-cell lithium-ion, 2,000mAh*6 |
Runtime | 40 min (ECO), 23 min (Medium), 10 min (Turbo) |
Dust Cup Volume | 0.7 L |
Noise Level | 65 dBA (Turbo Mode) |
Filtration | 3-stage HEPA |
LED Lights | 6 daylight-bright LEDs on brush head |
Dimensions (Main Unit) | 12.4 x 4.5 x 8.7 inches |
What makes the Wyze Cordless Vacuum S ideal for hardwood floors and rugs?
The Wyze Cordless Vacuum S is designed with powerful suction, multiple cleaning modes, and a floor brush optimized for both hardwood floors and rugs. Its lightweight and ergonomic design makes it easy to maneuver, while advanced features like dual motors and a 3-stage HEPA filtration system ensure thorough cleaning and improved air quality.How powerful is the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S offers up to 20,000 Pa of suction power in Turbo Mode, making it highly effective at deep cleaning stubborn dirt, dust, and pet hair from various surfaces.What is the battery life of the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S provides up to 40 minutes of runtime in ECO Mode, 23 minutes in Medium Mode, and 10 minutes in Turbo Mode. The battery is interchangeable, allowing you to swap in a spare for extended cleaning sessions.Is the Wyze Cordless Vacuum S lightweight and easy to use?
Yes, the main unit weighs only 2.8 lbs and the fully assembled vacuum weighs 4.9 lbs, making it easy to carry and maneuver around furniture and tight spaces.What attachments and accessories are included with the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S comes with a crevice tool, floor brush, dust cap, HEPA filter, and standard tube. Additional accessories like a foldable vacuum tube, mini motorized brush head, replacement battery pack, and extra HEPA filters are also available.How does the 3-stage HEPA filtration system work?
The 3-stage HEPA filtration system captures fine dust, allergens, and pet dander, making the Wyze Cordless Vacuum S ideal for homes with pets or allergy sufferers. Regular replacement of the HEPA filter ensures optimal performance and air quality.Can I extend the cleaning time of my Wyze Cordless Vacuum S?
Yes, you can purchase an additional Wyze Cordless Vacuum S Battery Pack to double your cleaning time and clean larger areas without interruption.What are the key features of the Wyze Cordless Vacuum S?
Key features include up to 20,000 Pa suction power, lightweight design, 3-stage HEPA filtration, dual motors, 6 daylight-bright LED lights on the brush head, an LED screen for battery and mode display, and a comprehensive set of attachments.Is the Wyze Cordless Vacuum S suitable for pet owners?
Yes, the Wyze Cordless Vacuum S is pet-friendly, with strong suction and a HEPA filtration system that effectively captures pet hair and allergens. The mini motorized brush head accessory is perfect for cleaning pet hair from upholstery and car seats.What are the dimensions and noise level of the Wyze Cordless Vacuum S?
The main unit measures 12.4 x 4.5 x 8.7 inches and the vacuum operates at a noise level of 65 dBA in Turbo Mode, making it compact and relatively quiet for home use.How do the LED lights on the Wyze Cordless Vacuum S help with cleaning?
The Wyze Cordless Vacuum S features 6 daylight-bright LED lights on the brush head, which illuminate hidden dust and debris under furniture and in dark corners, ensuring a thorough clean.Where can I buy replacement parts and accessories for the Wyze Cordless Vacuum S?
Replacement parts and accessories, such as HEPA filters, battery packs, foldable vacuum tubes, mini motorized brush heads, and chargers, are available for purchase on the official Wyze website.
