Wyze Cordless Vacuum S: Adjustable Suction for All Surfaces
Discover the Wyze Cordless Vacuum S: Adjustable Suction for Every Surface
When it comes to keeping your home spotless, the Wyze Cordless Vacuum S stands out as a powerful, lightweight, and versatile cleaning companion. Designed for modern living, this cordless vacuum offers adjustable suction settings tailored to different surfaces, making it perfect for hardwood floors, carpets, upholstery, and even pet hair.
Experience the freedom of cordless cleaning with industrial-level suction power and smart features that adapt to your cleaning needs.
Powerful Suction with Dual Motors
The Wyze Cordless Vacuum S is engineered with two high-performance motors—one in the main body and another in the brush head. This dual-motor system delivers an impressive 20,000 Pa of suction power on turbo mode, ensuring deep cleaning on all surfaces.
  • Three adjustable suction speeds:
  • Eco: 6,000 Pa for delicate surfaces
  • Medium: 9,000 Pa for everyday cleaning
  • Turbo: 20,000 Pa for heavy-duty messes
  • Brushless digital motors reduce friction, extend durability, and maintain peak power.
This means whether you're vacuuming hardwood floors, thick carpets, or pet hair on sofas, you can select the perfect suction level for efficient cleaning without wasting battery life. Wyze Cordless Vacuum S lifestyle cleaning with dog on sofa Lightweight and pet-friendly cleaning for every corner of your home
Lightweight Design & Long-Lasting Battery
Weighing just 2.8 pounds—lighter than a fluffy corgi puppy—the Wyze Cordless Vacuum S is easy to maneuver around furniture and up stairs without fatigue.
  • Interchangeable lithium-ion battery provides up to 40 minutes of fade-free cleaning on a single charge.
  • Battery can be swapped out quickly to extend cleaning sessions without waiting for recharge.
For those who want even more runtime, the Wyze Cordless Vacuum S - Battery Pack accessory offers an additional battery to keep you cleaning longer without interruption.
Smart Features for a Thorough Clean
The Wyze Cordless Vacuum S is designed to help you see and clean hidden dust and debris:
  • 6 daylight-bright LED lights on the brush head illuminate dark spaces under furniture and corners.
  • 3-stage filtration system:
1. Cyclone separates large debris 2. Metal screen filters dirt and hair 3. HEPA filter captures 95% of particles as small as 0.3 microns, improving air quality. Maintenance is simple with a washable dust cup and filters that are easy to remove and rinse. The built-in filter brush helps keep the HEPA filter clean for maximum efficiency. Wyze Cordless Vacuum S cleaning hardwood floor Illuminate and clean every surface with precision
Essential Accessories to Enhance Your Wyze Vacuum Experience
Extend your cleaning sessions with an extra battery pack designed specifically for the Wyze Cordless Vacuum S. Swap batteries seamlessly to keep your vacuum running without downtime.
Wyze Cordless Vacuum S - Charger
Keep your vacuum powered up with a replacement charger compatible with the Wyze Cordless Vacuum S, ensuring you’re always ready to clean.
This handy accessory bends to reach tricky spots, reducing strain and making it easier to clean under furniture or in tight spaces.
Wyze Cordless Vacuum - HEPA Filter
Maintain peak filtration performance by replacing your HEPA filters regularly. Available in convenient 2-packs, these filters keep your vacuum capturing fine dust and allergens effectively.
Wyze Cordless Vacuum - Mini Motorized Brush Head
Perfect for cleaning car seats, sofas, and other upholstery, this mini brush head accessory tackles pet hair and dirt in small, hard-to-reach areas.
Why Choose Wyze Cordless Vacuum S?
  • Adjustable suction power for all floor types and surfaces
  • Lightweight and ergonomic for effortless cleaning
  • Long-lasting, interchangeable battery for extended use
  • Advanced filtration system for cleaner air
  • Bright LED lights to reveal hidden dust
  • Wide range of accessories to customize your cleaning needs
The Wyze Cordless Vacuum S is the smart choice for anyone seeking a powerful, flexible, and easy-to-use cordless vacuum that adapts to every cleaning challenge.
Make your home cleaning smarter and more efficient with the Wyze Cordless Vacuum S and its range of accessories designed to keep your space spotless and allergen-free.
ProductTypePrice (USD)Key FeaturesCompatibilityWeight / Dimensions
Wyze Cordless Vacuum SConnected Home139.9920,000 Pa suction, 40-min battery, 2 motors, 2.8 lbs, 3-speed settings, 6 LED lights, HEPA filterN/A2.8 lbs
Wyze Cordless Vacuum S - Battery PackAccessories59.99Extra interchangeable battery for extended useWyze Cordless Vacuum SN/A
Wyze Cordless Vacuum S - ChargerReplacement Part4.99Replacement chargerWyze Cordless Vacuum SN/A
Wyze Cordless Vacuum - Foldable Vacuum TubeAccessories15.99Flexible tube attachment for easier cleaningWyze Cordless VacuumN/A
Wyze Cordless Vacuum - HEPA FilterAccessories15.992-pack replacement HEPA filtersWyze Cordless VacuumN/A
Wyze Cordless Vacuum - Mini Motorized Brush HeadAccessories29.99Motorized brush for car seats and sofasWyze Cordless Vacuum6 x 5.5 x 5 inches
What surfaces can the Wyze Cordless Vacuum S clean?The Wyze Cordless Vacuum S is designed for versatile cleaning on hardwood floors, carpets, upholstery, and even pet hair. Its adjustable suction settings make it suitable for a wide range of surfaces throughout your home.
How powerful is the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S features dual high-performance motors that deliver up to 20,000 Pa of suction power on turbo mode, ensuring deep and thorough cleaning on all surfaces.
What are the suction modes available on the Wyze Cordless Vacuum S?The vacuum offers three adjustable suction speeds: Eco (6,000 Pa) for delicate surfaces, Medium (9,000 Pa) for everyday cleaning, and Turbo (20,000 Pa) for heavy-duty messes.
How long does the battery last on the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S provides up to 40 minutes of fade-free cleaning on a single charge. The battery is interchangeable, allowing you to swap in a spare for extended cleaning sessions.
Is the Wyze Cordless Vacuum S lightweight and easy to use?Yes, the Wyze Cordless Vacuum S weighs just 2.8 pounds, making it lightweight and easy to maneuver around furniture, up stairs, and into tight spaces.
What filtration system does the Wyze Cordless Vacuum S use?The vacuum features a 3-stage filtration system: a cyclone for large debris, a metal screen for dirt and hair, and a HEPA filter that captures 95% of particles as small as 0.3 microns, improving air quality.
Are the filters and dust cup on the Wyze Cordless Vacuum S washable?Yes, both the dust cup and filters are washable and easy to remove, making maintenance simple and cost-effective.
Does the Wyze Cordless Vacuum S have LED lights?Yes, the vacuum is equipped with 6 daylight-bright LED lights on the brush head to illuminate dark spaces under furniture and in corners, helping you spot hidden dust and debris.
What accessories are available for the Wyze Cordless Vacuum S?Available accessories include an extra battery pack, replacement charger, foldable vacuum tube for hard-to-reach areas, HEPA filter 2-packs, and a mini motorized brush head for cleaning upholstery and car seats.
How do I extend the cleaning time of my Wyze Cordless Vacuum S?You can extend your cleaning sessions by purchasing the Wyze Cordless Vacuum S - Battery Pack, which allows you to swap batteries quickly and continue cleaning without waiting for a recharge.
Why should I choose the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S offers adjustable suction power, lightweight design, long-lasting interchangeable battery, advanced HEPA filtration, bright LED lights, and a wide range of accessories, making it a smart and flexible choice for efficient home cleaning.
What are the different suction speeds available on the Wyze Cordless Vacuum S?How long does the battery last on a single charge for the Wyze Cordless Vacuum S?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Cordless Vacuum S?
