Affordable Lightweight Cordless Vacuum for Quick Daily Cleanups: Wyze Cordless Vacuum S
When it comes to quick daily cleanups, having a lightweight yet powerful cordless vacuum is essential. The
Wyze Cordless Vacuum S stands out as an affordable, efficient, and user-friendly option designed to make your cleaning routine effortless. Whether you need to tackle pet hair, dust, or crumbs, this vacuum offers impressive suction power and a long-lasting battery in a feather-light design.
Wyze Cordless Vacuum S: Powerful Cleaning in a Lightweight Design
Exceptional Suction Power for Every Mess
The Wyze Cordless Vacuum S delivers an outstanding suction performance with multiple power modes to suit your cleaning needs:
- Turbo Mode: 20,000 Pa suction power for deep cleaning stubborn dirt
- Medium Mode: 9,000 Pa for everyday messes
- ECO Mode: 6,000 Pa for gentle, energy-saving cleaning
With a rated power output of 300 W and 100 AW suction, this vacuum ensures no dirt is left behind, whether on carpets, hardwood floors, or upholstery.
Ultra-Lightweight and Ergonomic
Weighing only
2.8 lbs for the main unit and
4.9 lbs when fully assembled, the Wyze Cordless Vacuum S is as light as 2.8 pounds of feathers. This makes it incredibly easy to maneuver around furniture, stairs, and tight spaces without fatigue.
Long-Lasting Battery Life
Equipped with a 6-cell lithium-ion battery (2,000mAh*6), the vacuum offers:
- 40 minutes of runtime in ECO mode
- 23 minutes in Medium mode
- 10 minutes in Turbo mode
The battery is interchangeable, allowing you to swap in a fresh pack for extended cleaning sessions (battery pack sold separately).
Smart Features and Attachments
- LED screen for easy mode and battery monitoring
- Two powerful motors for enhanced suction
- 3-stage filtration system including a HEPA filter to trap fine dust and allergens
- 6 daylight-bright LED lights on the brush head to illuminate hidden dirt
- Comes with essential attachments: Crevice Tool, Floor Brush, Dust Cap, HEPA Filter, and Standard Tube for versatile cleaning.
Compact Dimensions and Stylish Look
- Main unit size: 12.4 x 4.5 x 8.7 inches
- Assembled length: 41.1 inches
- Color: Steel grey with Wyze green accents, blending modern style with functionality.
"Finally! A vacuum that is free and independent and no longer reliant on its parents for financial and emotional support." — Wyze
Lightweight cordless vacuum perfect for pet owners and quick cleanups
Essential Accessories to Enhance Your Wyze Cordless Vacuum S Experience
Wyze Cordless Vacuum S - Battery Pack
Need extra juice for longer cleaning sessions? The official
Wyze Cordless Vacuum S Battery Pack is designed specifically for this model, ensuring compatibility and reliable performance. Priced affordably, it’s a smart investment for uninterrupted cleaning.
Wyze Cordless Vacuum S - Charger
Keep your vacuum powered up with the
replacement charger designed for the Wyze Cordless Vacuum S. Compact and efficient, it supports AC charging with a 4-6 hour full charge time.
This accessory bends so you don’t have to, making it easier to reach under furniture and tight spots. Compatible only with Wyze Cordless Vacuum models, it adds flexibility to your cleaning routine.
Wyze Cordless Vacuum - HEPA Filter
Maintain optimal air quality by regularly replacing your vacuum’s HEPA filter. Available in convenient 2-packs, these filters trap allergens and fine dust, perfect for allergy sufferers.
Wyze Cordless Vacuum - Mini Motorized Brush Head
Ideal for cleaning car seats, sofas, and other upholstery, this mini brush head attachment is designed exclusively for the Wyze Cordless Vacuum. Its compact size and motorized action make it perfect for detailed cleaning.
Effortless cleaning on hardwood floors with Wyze Cordless Vacuum S
Why Choose Wyze Cordless Vacuum S for Daily Quick Cleanups?
- Affordable price point under $140, offering excellent value for a high-performance cordless vacuum
- Lightweight and ergonomic design reduces strain during use
- Powerful suction modes to handle everything from light dust to heavy debris
- Long battery life with quick recharge times
- Smart features and multiple attachments for versatile cleaning needs
- Compact and stylish to fit seamlessly into your home environment
If you want a cordless vacuum that combines power, portability, and affordability for your daily cleaning tasks, the Wyze Cordless Vacuum S is an unbeatable choice.
What makes the Wyze Cordless Vacuum S ideal for quick daily cleanups?
The Wyze Cordless Vacuum S is lightweight, weighing only 2.8 lbs for the main unit, and offers powerful suction with multiple modes. Its ergonomic design and easy maneuverability make it perfect for quick daily cleanups of dust, pet hair, and crumbs.How powerful is the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S delivers up to 20,000 Pa of suction power in Turbo mode, 9,000 Pa in Medium mode, and 6,000 Pa in ECO mode. With a 300 W rated power output and 100 AW suction, it effectively cleans carpets, hardwood floors, and upholstery.How long does the battery last on the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S offers up to 40 minutes of runtime in ECO mode, 23 minutes in Medium mode, and 10 minutes in Turbo mode. The battery is interchangeable, allowing you to swap in a fresh pack for extended cleaning sessions.What attachments and accessories are included with the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S comes with essential attachments such as a Crevice Tool, Floor Brush, Dust Cap, HEPA Filter, and Standard Tube. Additional accessories like a battery pack, charger, foldable vacuum tube, HEPA filter 2-pack, and mini motorized brush head are also available.Does the Wyze Cordless Vacuum S have a HEPA filter?
Yes, the Wyze Cordless Vacuum S features a 3-stage filtration system that includes a HEPA filter, which helps trap fine dust and allergens, making it ideal for allergy sufferers.Is the Wyze Cordless Vacuum S suitable for pet owners?
Absolutely. The Wyze Cordless Vacuum S is designed to handle pet hair efficiently with its powerful suction and specialized attachments, making it a great choice for pet owners.How long does it take to fully charge the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S can be fully charged in 4-6 hours using the official replacement charger.What are the dimensions and weight of the Wyze Cordless Vacuum S?
The main unit measures 12.4 x 4.5 x 8.7 inches and weighs 2.8 lbs. When fully assembled, it is 41.1 inches long and weighs 4.9 lbs.Is the Wyze Cordless Vacuum S affordable?
Yes, the Wyze Cordless Vacuum S is priced under $140, offering excellent value for a high-performance cordless vacuum.What smart features does the Wyze Cordless Vacuum S offer?
The Wyze Cordless Vacuum S includes an LED screen for easy mode and battery monitoring, two powerful motors, and six LED lights on the brush head to illuminate hidden dirt.Can I use the Wyze Cordless Vacuum S on different floor types?
Yes, the Wyze Cordless Vacuum S is designed to clean various surfaces, including carpets, hardwood floors, and upholstery, thanks to its multiple suction modes and versatile attachments.Are replacement parts and accessories available for the Wyze Cordless Vacuum S?
Yes, you can purchase official replacement parts and accessories such as battery packs, chargers, foldable vacuum tubes, HEPA filters, and mini motorized brush heads specifically designed for the Wyze Cordless Vacuum S.
